POV-Ray : Newsgroups : povray.off-topic : Fan without blades: should we ROTFL or weep? Server Time
17 Oct 2026 23:01:12 EDT (-0400)
  Fan without blades: should we ROTFL or weep? (Message 1 to 43 of 43)
Subject: Fan without blades: should we ROTFL or weep?
Date: 4 Jun 2010 06:14:07
Message: <4c08d1ef@news.povray.org>
I just did read an add for a "bladeless fan", a so called air-multiplier
made by Dyson.
When I read the add I clicked on to find out more. Dyson would surely not
lie to us - so I was really interested in how they build a wonder like this.
Any electric fan, easy to clean, no blades? How is it done? Electromagnetic
fields? I simply had to see...
Now take a look at this thing and tell me - should I ROTFL or start to weep
for the poor fools who buy this?
http://www.dyson.com/technology/airmultiplier.asp
Besides: do US laws allow for blatant lies in ads? Bladeless - my ass! And
easy to clean? I doubt you can clean the real fan-parts at all.
Subject: Re: Fan without blades: should we ROTFL or weep?
Date: 4 Jun 2010 06:25:46
Message: <4c08d4aa$1@news.povray.org>
What makes you think it's a lie?
http://en.wikipedia.org/wiki/Air_Multiplier#Dyson_Air_Multiplier
It doesn't have blades; it uses an impeller. And although I can't recall
the name for it now, I've seen a device similar to this that passively
accelerates airflow.
They had a rocket motor blow into a bag, and it did inflate, but quite
slowly. Then they added this compression ring, and when the rocket motor
starts blowing, the ring causes air from the surroundings to be sucked
in as well, causing the bag to fill much more rapidly.
Date: 4 Jun 2010 06:55:00
Message: <web.4c08da60fc7ba21234d207310@news.povray.org>
> made by Dyson.
Put my hand through one in the store.
Date: 4 Jun 2010 08:10:10
Message: <4c08ed22@news.povray.org>
I don't have much doubt that the shape of the ring actually amplifies
airflow. And airflow is probably not as chopped up.
However, I think that there is small functional difference between a
fan-blade and what is used in the impeller. It all boils down to rotating
structures pusing air molecules forward. I expected something >new<.
And I really doubt that cleaning the impeller is easier than cleaning a fan.
Date: 4 Jun 2010 08:17:52
Message: <4c08eef0$1@news.povray.org>
Sure - but the impeller (hidden in the base) is still based on rotating
mechanical objects. Or am I wrong here? Did I miss something? If so - my
apologies.
I see small difference (in priciple) between it and a fan. Nothing really
new, apart from the ring-geometry used to amplify airflow.
And I really doubt that the impeller is more easy to clean than a
conventional fan. What if enough dust is sucked inside the impeller? >Can<
you even clean it?
Date: 4 Jun 2010 08:26:18
Message: <4c08f0ea@news.povray.org>
A fan pushes air forwards by using flat blades to fan it. An impeller
pushes air *outwards* by centrifugal force. That's an entirely different
mode of action. (Although of course impellers aren't exactly new either.)
What _is_ new is that by using clever air currents, you can make the
draft much bigger with less effort. And I guess it looks kinda neato.
 From what little I've seen, fans tend to get dusty when they're not in
use, because they're exposed to the air. An impeller, by definition, is
internal. When it's not running, there's very little air to get it dusty.
Still, at the end of the day, if you don't like it, don't buy one. :-)
Date: 4 Jun 2010 09:32:32
Message: <4c090070$1@news.povray.org>
>> rotating structures pusing air molecules forward. I expected something
>> >new<.
>> a fan.
The reverse sides of the fan blades get dusty too, even when the fan is
in use.
http://isometricland.com
Date: 4 Jun 2010 11:15:00
Message: <web.4c0917b8fc7ba212a00085090@news.povray.org>
Don't know about how you'd clean the fan I saw, if anything it's a greater
mildew risk for the mechanics trapped inside.
But the device was bladeless in the sense that I couldn't imagine a 3 year old
hurting himself with it unless they bit on the power cord.
Date: 4 Jun 2010 12:00:44
Message: <4c09232c$1@news.povray.org>
http://en.wikipedia.org/wiki/File:Pump_Impellers-1.jpg
Looks like blades to me.  I'm not really sure what the difference between
"blades" and "impeller" is, tho.
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Date: 4 Jun 2010 12:05:39
Message: <4c092453$1@news.povray.org>
There is nothing new, only modifications and improvements upon existing
things and concepts.
Tim Cook
http://empyrean.freesitespace.net
Date: 4 Jun 2010 14:12:36
Message: <4c094214$1@news.povray.org>
"gregjohn" <pte### [at] yahoocom> schrieb im Newsbeitrag
news:web.4c0917b8fc7ba212a00085090@news.povray.org...
> old
Granted. ;-)
Date: 4 Jun 2010 14:14:46
Message: <4c094296$1@news.povray.org>
To my untutored eye it is the same, shaped a bit differently, maybe.
Date: 4 Jun 2010 14:30:40
Message: <4c094650$1@news.povray.org>
It is the reverse mode of action.
My computer's power-source has what I would call a fan. In fact, everybody I
knows calls it this. Yet it impells air into the unit. So should it be named
impeller?
> What _is_ new is that by using clever air currents, you can make the draft
Yes. That's what caugt my eye. It does look good, and at first glance one
wonders how it is done. Hence my disappointment when I found out. ;-)
Look into your computer. If it is older than a year, examine the fans. Now,
that is what I call dirty. The little impeller sucks in air. It will get as
dirty, won't it?
Have you looked at the price? $329.99 - this is surely innovative. ;-)
http://www.dyson.com/store/fans.asp
Date: 4 Jun 2010 23:09:11
Message: <4c09bfd7@news.povray.org>
> made by Dyson.
There are a couple of points that make it quite nice.
The air flow is created by a really neat impeller and high power
electric motor.  I believe it was adapted from the Dyson 'airblade' hand
dryer.  If you have not seen and used one of those you are in for a
surprise!  Wow that thing is good.
In regard to dust being accumulated in the impeller, consider that it is
a lot smaller than the blades of a conventional fan but generates a lot
higher speed airflow.  Dust simply doesn't have a chance to build up on
the working part.  How concerned are you about dust building up on the
impeller of a turbo-charger in a car engine?
Then you might appreciate that the air that goes through the impeller is
filtered.  This is used to entrain a larger air mass that doesn't pass
through the impeller.  So whatever the final volume of air that is
moved, less goes through the critical part of the Dyson than passes
through the blades of a conventional fan - by more than an order of
magnitude.
Dyson after all does know a bit about air flow and dust.
I guess that dust and fluff would build up on the leading edge of the
annulus.  This would however be much easier to clean than on a
conventional fan.  Just wipe it.  My current desk fan has a wire cage
around the blade.  That collects dust and you have to remove the front
part and take the blade out to properly clean it.
The other 'air multiplier' benefits are the quiet operation and steady
airflow.
If they weren't so expensive I'd get one.  Still will if I see one on
sale.  I do have a Dyson vacuum cleaner and it is so much better than
any other type I have used.  A great alternative concept to how the
whole thing should be done, brilliant design, brilliantly engineered
with quality materials.  Absolutely the best and not one fault with it
that I can see.
Date: 5 Jun 2010 01:40:01
Message: <web.4c09e320fc7ba2124a677e7a0@news.povray.org>
this is it!  I name it the "WTF thread of the day" of yesterday.
And it is a fan and will get dirty, except you quite likely won't be able to
clean it except by getting it to maintenance.  Lesson to be learned here:
underneath all shiny and neato things there's always a lot of dirt. :P
Date: 5 Jun 2010 03:44:55
Message: <4c0a0077@news.povray.org>
I take that 'WTF' as disagreeing with me.
Your only point that seems specific is that fans get dirty and you imply
that this will be a problem that can only be fixed by maintenance?
Correct me if that isn't what you were saying.
So lets see.  I have a Dyson vacuum cleaner.  It is used pretty much
once a week to clean a 4 bedroom house with carpets everywhere except
the wet floor areas.  I've had it for about 6.5 years.
By its nature there is a large amount of dusty and dirty air being
passed through the device.  Number of trips to maintenance thus far is
zero.  Apparent loss of functionality due to the inevitable (you say)
buildup of dirt is zero.
We bought it on the recommendation of commercial carpet cleaners who use
uprated models of the same thing.  I specifically asked about
reliability and they said they had never had a problem and never had to
do any maintenance on them.  That was based on heavy duty use and many
units in the same company.
A traditional fan has large slow moving blades that all of the air that
they move passes through.  Around that they have a wire cage covering
both the in and out sides.  They are pretty good at collecting dust and
fluff.  Very poor at shedding it.  In fact the dust that they collect
seems to help collect more.
You shouldn't generalise from there to all fans in all devices.
Especially when they are substantially different and designed by people
who specialise in the field.
Now I can't say that the Dyson fan is equally as good as the model of
Dyson vacuum cleaner that we have.  Seems like there isn't the same sort
of problem to justify such an expensive solution.  I haven't tried one
to see if it is indeed quieter or better in any way.
Date: 5 Jun 2010 03:58:38
Message: <4c0a03ae$1@news.povray.org>
> impeller?
A fan works by having blades with a uniform cross-section, but angled to
accelerate air parallel to the plane of rotation. If you spin the blades
one way, it blows forwards. If you spin them the other way, it blows
backwards.
An impeller uses centrifugal forces to blow air *outwards* (i.e., away
from the center of rotation - usually meaning that air is sucked into
the impeller through a port near the center and exits the impeller from
the edges). If you spin the impeller the other way, the air still flows
in the same direction.
I can understand that. ;-)
True. Then again, the entire inside of my PC is carpeted in dust; why
not the fans? I guess somebody more qualified than me can explain why
fans get dusty...
Ouch! o_O
OK, definitely don't buy one...
http://blog.orphi.me.uk/
Date: 5 Jun 2010 04:07:54
Message: <4c0a05da$1@news.povray.org>
We have a Dyson Airblade at work. It is THE most useless thing I've ever
encountered!
When I was a child, it never ceased to amaze me that hand driers
actually work. I mean, sure, it blows hot air on your hands. The
principle makes sense. But surely you're going to have to wait a hell of
a long time before your hands become *dry*, right?
But no, without fail it always manages to dry your hands in seconds. I
mean, *really* dry!
...and then we come to the Dyson Airblade. Now I don't know if this
particular one is just faulty (wouldn't surprise me; everything else in
this building is!), but it is *hopeless*. The air it blows at you is
utterly freezing on your wet hands. It blows so hard that you can
actually see it flobbling your flesh around. And it's deafeningly loud.
I'm not even kidding. I took a sound meter in there and measured the
sound level. The reading came back as 98 dB (A-weighted) or 93 dB
(C-weighted). Apparently that's in the range that's supposed to cause
temporary hearing damage.
And, quite apart from making your hands extremely cold and mashing your
skin around quite unconforably, IT DOESN'T DRY YOUR HANDS! Which, given
that this is the entire purpose for which the device exists, qualifies
it as an unmitigated failure IMHO.
What they definitely know how to do is design products that look
"innovative" and "sciency". Fair play; I couldn't do that.
Date: 5 Jun 2010 05:20:58
Message: <4c0a16fa@news.povray.org>
> encountered!
Strange how our experience can be so different.  I was surprised how
fast it was and would say it was the best I've used.  No wait to heat
up.  No failure to register that my hands were in position.  Done in
about 10 seconds.  Didn't notice that it was loud although it may well
have been.
Yes they do that.  He should be designing spacecraft for SF book covers
and movies.  Still I find (based on the vac) that it is very well made
and works extremely well.
I understand that some of the original patents protecting the Dyson
vacuum cleaner have expired.  Now there are lots of cheap knock offs on
the market that emulate the 'bagless' aspect.  The couple I've seen up
close looked cheap and frail plus lacked a lot of the nice secondary
features.
Date: 5 Jun 2010 05:24:57
Message: <4c0a17e9$1@news.povray.org>
> encountered!
My experience is the opposite. Traditional hot air hand driers “time
out” long before my hands are dried and even multiple goes leave my
hands still wet. On the other hand <groan> the air blades are warm and
efficient. They are noisy, I’ll give you that.
Best Regards,
Date: 5 Jun 2010 06:14:11
Message: <4c0a2373@news.povray.org>
Indeed.
> I was surprised how
I was surprised too. Usually even cheap hand driers work surprisingly
well. I guess there's just not much to get wrong.
Oh yeah, I forgot about that part... This air blade is sometimes quite
awkward about that. Usually it works, but somethings it point-blank
fails to register that your hands are there (to the point that you have
to just leave with wet hands). And sometimes it stops before you've
removed your hands, and nothing you do will make it start again.
As for the sound... sound meters don't lie. 93 dB isn't quiet. (Gives me
tinnitus every time!)
Date: 5 Jun 2010 13:28:05
Message: <4c0a8925@news.povray.org>
I think it's just yours. Or you're doing it wrong, either way.
Date: 5 Jun 2010 16:11:07
Message: <4c0aaf5b@news.povray.org>
I've found them to be pretty effective - they installed those things in
the restrooms at the local CostCo.  I'd never seen one before, but it got
the job done (at least well enough). :-)
Jim
Date: 5 Jun 2010 16:30:00
Message: <web.4c0ab320fc7ba212add30b9c0@news.povray.org>
nope, sorry.  About the whole thread.  Only replied to your by sheer lazyness.
:P
Isn't a vacuum cleaner designed to be cleaned and have the dirt properly
"captured" and packaged?  I don't think that's the point of this device, which
is to just get the blades out of sight (and, possibly, cleaning maintenance)...
Date: 5 Jun 2010 20:25:23
Message: <4c0aeaf3$1@news.povray.org>
> :P
Sorry if I was snarky.  There are 3 or 4 products / brands that I've
found to be close to perfect.  When some Internet know-it-all (not you)
starts mouthing off about one with no more basis than what he or she
'thinks' based on 15 seconds looking at a web site and maybe reading the
opinion of other equally un-informed people - well you've got to take a
stand at some point :)
Yes.  But two points - First, as far as I can see the Dyson vacs are
designed and engineered such that you don't have to clean the internal
components.  The whole air path through the system which must include
the fan / impeller seems not to allow any build-up.  There is a final
stage 'HEPA' filter that they recommend rinsing out and drying once a
year (I recall).  Again the design is such that it snaps out and back in
as easily as you can imagine it could be done.  However so little dust
gets to that stage that it does not seem to need any attention.  The
'turbo head' does get long strands of hair wrapped around it over time.
  Easily cleaned and I can't see how that can be avoided.
Second, to the extent that dust could be a problem in their fan, I'm
willing to venture that the Dyson people have given just as much
attention to the problem.  That is their strong suit.
Date: 5 Jun 2010 22:58:38
Message: <4c0b0ede$1@news.povray.org>
> features.
Jump to new topic: Dyson's patents may have run out, but I haven't seen
any bagged or bag-less vac that beats the old Rainbows. Similar concept,
impel the air into a cyclone; only the rainbows used a cyclone of water.
Back to topic: I saw one of the Dyson fans at a big store, I was
impressed by the design. It does hit "Oh, shiny" quite well. But I will
still wait for the cheap knock-offs, I can't afford $300 for
mass-produced art.
Date: 6 Jun 2010 06:59:43
Message: <4c0b7f9f$1@news.povray.org>
I have seen but not used water based vacs.  More tagged as 'carpet
cleaning'.  You could hire them from shops at one point.  Maybe they
were the 'Rainbow' mode that you mentioned?
> mass-produced art.
Same here.  Doesn't seem like a big enough problem to warrant the
expense (assuming that they are indeed better).  I've never bought
things for cool factor alone.
Plus I would almost never buy V1 of something radically new.  Even the
original Dyson vac looks relatively primitive and lacks a lot of the
refinements of the newer generations.
Date: 6 Jun 2010 08:41:32
Message: <4c0b977c$1@news.povray.org>
>> mass-produced art.
Cool factor? Fan? I see what you did there. ;-)
Date: 6 Jun 2010 09:14:06
Message: <4c0b9f1e@news.povray.org>
>>> mass-produced art.
Ok.  I admit I did buy a fridge for its cool factor alone.
Date: 6 Jun 2010 09:55:33
Message: <4c0ba8d5$1@news.povray.org>
Oh. So it wasn't just because you needed the storage space for all the
bodies? ;-)
Date: 6 Jun 2010 10:30:13
Message: <4c0bb0f5@news.povray.org>
> bodies? ;-)
That is what gazebos are for.
Date: 6 Jun 2010 10:52:54
Message: <4c0bb646@news.povray.org>
> fans get dusty...
The fans and heatsink tend to be the dirtiest parts of my computer. They
always get clogged with dirt first.
Date: 6 Jun 2010 11:26:14
Message: <4c0bbe16$1@news.povray.org>
>> fans get dusty...
The heatsink I can understand. It's a small, confined space that
constantly has dust being blown into it. Not quite so sure why the fan
clogs up.
Date: 6 Jun 2010 13:29:46
Message: <4c0bdb0a$1@news.povray.org>
The ones I have seen at shops, or more specifically adverts for cleaning
shops, are ones that push water onto the carpet and then pull it back
off again. Used with water, they are called carpet shampooers around
here. The vac I used worked like a normal vacuum, but instead of a bag
or bin it just funneled the air into a container of water. Absolutely
disgusting to watch water turn from clear to filled with the stuff one
house could hold on the floor in a week. Worked better than HEPA
filters, though.
>> mass-produced art.
Oh, I would and have. Just not pop-art.
Also a good reason. However, I can not see many directions to take the
fan concept. Higher speeds, maybe, or floor stands.
Now, if they made a humidifier version, and added blue LEDs inside the
turbine to make the mist glow, then I might get one.
Date: 6 Jun 2010 19:34:10
Message: <4c0c3072@news.povray.org>
Examples please.
Sounds like a DIY project.
I was thinking about trying it with a polystyrene ball.  Point the fan
upwards.  Throw the ball up into the ring.  The air flow carries it
through.  Then would it be trapped in the stream above the ring by the
Bernoulli effect ?
Date: 6 Jun 2010 22:39:30
Message: <4c0c5be2$1@news.povray.org>
> Bernoulli effect ?
Yes. Dyson made a video where they routed balloons thru many dozen of these
things in a big loop.
Date: 7 Jun 2010 00:32:10
Message: <4c0c764a$1@news.povray.org>
> Bernoulli effect ?
I imagine it would, much like a toy I had when I was a kid.
Jim
Date: 7 Jun 2010 02:28:08
Message: <4c0c9178$1@news.povray.org>
On 7/06/2010 12:39 PM, Darren New wrote:
> Paul Fuller wrote:
>> Then would it be trapped in the stream above the ring by the Bernoulli
>> effect ?
> these things in a big loop.
Here it is - http://www.youtube.com/watch?v=4WNcjkZ6d0w
Date: 7 Jun 2010 14:05:24
Message: <4c0d34e4$1@news.povray.org>
> Examples please.
I suppose the definition of 'cool' would be the trick. To me, hand made
jewelery is cool, even if it is just driveway gravel wrapped in plastic
electrical wire. Cheap old cameras are cool, more so if I can make them
work again. Bow-ties are cool. Non-functional? The doll that happened to
match my desk so well that she has sat on it for years without being
noticed often. Some old networking hubs that will look nice in the 19U
racks that serve as storage cabinets. An old brick car phone.
All cheap, but all purchased because of that 'oh, cool, I don't need
that but I want it' factor.
If you were scoping to see what was worth stealing, not a whole lot. ;-)
Right, for the cheap knock offs. That way, when the liquid fries one of
the motors, I am only out a few dollars.
Date: 7 Jun 2010 14:43:06
Message: <4c0d3dba$1@news.povray.org>
>> >  Examples please.
> work again. Bow-ties are cool...
Good job I did not reply in High Dudgeon. ;-)
I thought you wrote “Just not op-art”.
Best Regards,
Date: 7 Jun 2010 20:25:20
Message: <4c0d8df0@news.povray.org>
Drat.  Not worth the airfare.
A tank of propane may have some possibilities with one of these although
they probably are not powerful enough.
Once upon a time I worked as a sysprog for a bank.  There was an
incident when water condensation built up in the air conditioning units
on Level 3.  The outlet pipe had become blocked and water spilled over
the collection pan, found a crack in the slab, trickled into a light
fitting and collected until it broke the fitting and dumped out.
Estimated to be about 10 litres of water.
Then the real drama began.  Level 2 was the main computer room.  The
light fitting was the one sitting above the disk system housing amongst
other things the volumes for the mainframe running the production online
system.  Water + Electronics = Failure.
Much mayhem ensued.
The link is that one of the IBM engineers had the idea to get some
industrial gas heaters in to help dry things out.  These were large
blowers with gas burning in the air stream.  Crank up the speed and
amount of gas and they were quite impressive.  Somewhere less than a
rocket motor but still a *lot* better than a hand electric hair dryer.
Quite an interesting day.  I had a spare system image on another disk
unit on the other side of the computer room.  We got the system back up
in the evening and got through batch in time for the next day.  The
affected unit was rebuilt.  It needed some new controller boards but the
physical drives were fine.  No data lost.
Good blokes those IBM engineers.
Not so good is the idea of putting the air con plant directly above the
computer room.
Date: 7 Jun 2010 21:18:49
Message: <4c0d9a79$1@news.povray.org>
>>> >  Examples please.
In the land of checkered planes and mirrored spheres, how could I not
like op-art?
Should have said pop-art and minimalism. I still wonder how a black
square on a white canvas was influential so long after the invention of
both black ink and white canvas. But that is an off-topic art rant.
Date: 8 Jun 2010 16:04:55
Message: <4c0ea267@news.povray.org>
> like op-art?
That’s what confused me. But it gives me an idea so Bridget Riley eat
your heart out.
Some minimalism is OK (IMO) but I think it can be over done. (Is that an
oxymoron?)
Best Regards,
Download '4spheresandaplane.jpg' (104 KB)
Preview of image '4spheresandaplane.jpg'
