POV-Ray : Newsgroups : povray.off-topic : Fan without blades: should we ROTFL or weep? Server Time
20 Mar 2026 23:41:46 EDT (-0400)
  Fan without blades: should we ROTFL or weep? (Message 1 to 10 of 43)
Subject: Fan without blades: should we ROTFL or weep?
Date: 4 Jun 2010 06:14:07
Message: <4c08d1ef@news.povray.org>
I just did read an add for a "bladeless fan", a so called air-multiplier
made by Dyson.
When I read the add I clicked on to find out more. Dyson would surely not
lie to us - so I was really interested in how they build a wonder like this.
Any electric fan, easy to clean, no blades? How is it done? Electromagnetic
fields? I simply had to see...
Now take a look at this thing and tell me - should I ROTFL or start to weep
for the poor fools who buy this?
http://www.dyson.com/technology/airmultiplier.asp
Besides: do US laws allow for blatant lies in ads? Bladeless - my ass! And
easy to clean? I doubt you can clean the real fan-parts at all.
Subject: Re: Fan without blades: should we ROTFL or weep?
Date: 4 Jun 2010 06:25:46
Message: <4c08d4aa$1@news.povray.org>
What makes you think it's a lie?
http://en.wikipedia.org/wiki/Air_Multiplier#Dyson_Air_Multiplier
It doesn't have blades; it uses an impeller. And although I can't recall
the name for it now, I've seen a device similar to this that passively
accelerates airflow.
They had a rocket motor blow into a bag, and it did inflate, but quite
slowly. Then they added this compression ring, and when the rocket motor
starts blowing, the ring causes air from the surroundings to be sucked
in as well, causing the bag to fill much more rapidly.
Date: 4 Jun 2010 06:55:00
Message: <web.4c08da60fc7ba21234d207310@news.povray.org>
> made by Dyson.
Put my hand through one in the store.
Date: 4 Jun 2010 08:10:10
Message: <4c08ed22@news.povray.org>
I don't have much doubt that the shape of the ring actually amplifies
airflow. And airflow is probably not as chopped up.
However, I think that there is small functional difference between a
fan-blade and what is used in the impeller. It all boils down to rotating
structures pusing air molecules forward. I expected something >new<.
And I really doubt that cleaning the impeller is easier than cleaning a fan.
Date: 4 Jun 2010 08:17:52
Message: <4c08eef0$1@news.povray.org>
Sure - but the impeller (hidden in the base) is still based on rotating
mechanical objects. Or am I wrong here? Did I miss something? If so - my
apologies.
I see small difference (in priciple) between it and a fan. Nothing really
new, apart from the ring-geometry used to amplify airflow.
And I really doubt that the impeller is more easy to clean than a
conventional fan. What if enough dust is sucked inside the impeller? >Can<
you even clean it?
Date: 4 Jun 2010 08:26:18
Message: <4c08f0ea@news.povray.org>
A fan pushes air forwards by using flat blades to fan it. An impeller
pushes air *outwards* by centrifugal force. That's an entirely different
mode of action. (Although of course impellers aren't exactly new either.)
What _is_ new is that by using clever air currents, you can make the
draft much bigger with less effort. And I guess it looks kinda neato.
 From what little I've seen, fans tend to get dusty when they're not in
use, because they're exposed to the air. An impeller, by definition, is
internal. When it's not running, there's very little air to get it dusty.
Still, at the end of the day, if you don't like it, don't buy one. :-)
Date: 4 Jun 2010 09:32:32
Message: <4c090070$1@news.povray.org>
>> rotating structures pusing air molecules forward. I expected something
>> >new<.
>> a fan.
The reverse sides of the fan blades get dusty too, even when the fan is
in use.
http://isometricland.com
Date: 4 Jun 2010 11:15:00
Message: <web.4c0917b8fc7ba212a00085090@news.povray.org>
Don't know about how you'd clean the fan I saw, if anything it's a greater
mildew risk for the mechanics trapped inside.
But the device was bladeless in the sense that I couldn't imagine a 3 year old
hurting himself with it unless they bit on the power cord.
Date: 4 Jun 2010 12:00:44
Message: <4c09232c$1@news.povray.org>
http://en.wikipedia.org/wiki/File:Pump_Impellers-1.jpg
Looks like blades to me.  I'm not really sure what the difference between
"blades" and "impeller" is, tho.
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Date: 4 Jun 2010 12:05:39
Message: <4c092453$1@news.povray.org>
There is nothing new, only modifications and improvements upon existing
things and concepts.
Tim Cook
http://empyrean.freesitespace.net
