POV-Ray : Newsgroups : povray.off-topic : Unit tests Server Time
17 Oct 2026 23:01:32 EDT (-0400)
  Unit tests (Message 1 to 21 of 21)
Subject: Unit tests
Date: 3 Jun 2010 12:10:23
Message: <4c07d3ef$1@news.povray.org>
Thinking on it a bit, it sounds like unit testing is just a way to add
Eiffel-style programming-by-contract to your code without any actual
language support for it.
    Ada - the programming language trying to avoid
    you literally shooting yourself in the foot.
Subject: Re: Unit tests
Date: 3 Jun 2010 14:41:22
Message: <4c07f752@news.povray.org>
I thought the term was "design by contract"?
Well whatever. Contracts seem like a nice idea; you make it clear who's
supposed to check for error conditions - whether it's supposed to be the
caller or the callee. And you can enforce it by enabling checks at
runtime. Having said that, I don't recall using it much myself in my own
code.
On top of that, any kind of testing is going to be easier if a
function's output depends only on its current inputs...
http://blog.orphi.me.uk/
Date: 3 Jun 2010 14:47:19
Message: <4c07f8b7$1@news.povray.org>
Yeah. Brain-O.
> code.
Yep. Every time you use "assert" to check your inputs, you're doing that.
Except with minimal language assistance.
Unit testing just takes those asserts outside the function.
Yep. The problem with "unit testing" per se is that it only tests a unit. It
doesn't test anything except the invariants of the unit you're testing.
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Date: 3 Jun 2010 14:54:47
Message: <4c07fa77@news.povray.org>
> that. Except with minimal language assistance.
Eiffel has preconditions *and* postconditions, which most people don't
seem to bother checking with assert() calls.
Whilst Haskell does have an assert() function, it seems to be more
popular to use QuickCheck.
QuickCheck does automated randomised testing. Give QC a property that's
supposed to hold for any inputs, and it generates inputs at random and
checks whether the property holds.
The big snag, of course, if that if your code fails only under very
specific, rare circumstances, randomised testing might not hit the bug.
(This is why books on testing talk about testing limits, flow control
paths, etc.)
Also, asserts or design by contract will catch the source of a crash in
a live running program. (Assuming that enabling the tests doesn't slow
the program to the speed of a glacier...)
> unit. It doesn't test anything except the invariants of the unit you're
> testing.
I thought the idea was that you then combine several units into a larger
unit, and test that (and so on, recursively). Then again, maybe that's
what they mean by "integration testing"...
Date: 3 Jun 2010 15:30:42
Message: <4c0802e2@news.povray.org>
  A little thought experiment: How would you write a comprehensive
postcondition to a function that sorts a list/array of elements?
(Assume there is no reliable third-party sorting function available.)
Date: 3 Jun 2010 15:33:00
Message: <4c08036c$1@news.povray.org>
Sorting a container is at best O(n log n), but determining whether one
is already sorted is only O(n). :-)
Date: 3 Jun 2010 15:38:02
Message: <4c08049a$1@news.povray.org>
Here's a better one: You write a compiler. How the **** do you determine
whether it actually works properly? (!)
Date: 3 Jun 2010 15:47:53
Message: <4c0806e9@news.povray.org>
  Hmm, that's not what I asked.
Date: 3 Jun 2010 16:07:00
Message: <4c080b64$1@news.povray.org>
Yes. The postconditions are checked with unit tests. And people try to check
invariants that way too. And unit tests generally don't try to check loop
invariants.
Again, you're checking invariants, which I find is usually not that useful.
Yes, that's integration testing.  Then there's "functional testing", where
you test the program does what the customer actually wants. Then there's
system testing, where you make sure the program does what the customer
actually wants even when interacting with other code (basically).
Date: 3 Jun 2010 16:08:13
Message: <4c080bad@news.povray.org>
Trivial.
Forall(i < length-1) assert(j[i]<=j[i+1]);
Basically, the definition of sorting. Of course, you need to be able to put
qualifiers in your assertions.
Date: 3 Jun 2010 16:21:00
Message: <4c080eac$1@news.povray.org>
Of course, the *other* thing that's popular is constructing software in
such a way that it cannot malfunction in the first place. (E.g., if
negative numbers aren't allowed, use unsigned integers. Now you don't
have to check whether the input is negative, because it can never *be*
negative.) Obviously, there are limits to how well this approach works...
Date: 3 Jun 2010 18:03:54
Message: <4c0826ca$1@news.povray.org>
> Trivial.
> put qualifiers in your assertions.}
A sorting function that, given any input, returns [1,2,3,4,5], will pass
that test.
Try again.
Date: 3 Jun 2010 20:01:25
Message: <4c084255$1@news.povray.org>
>> Trivial.
> that test.
Heck, for that matter anything returning a zero-length array would pass. OK,
to be *comprehensive*, you would have to add that the result is a
permutation of the original. You could do this by counting how many times
each original value occurs in the list and making sure it occurs in the
result the same number of times.
Date: 4 Jun 2010 02:07:24
Message: <4c08981c$1@news.povray.org>
> testing.
	I wouldn't call it a "problem".
Guitar for sale. Very cheap. No strings attached.
Date: 4 Jun 2010 04:07:48
Message: <4c08b454@news.povray.org>
> OK, to be *comprehensive*, you would have to add that the result is a
> times each original value occurs in the list and making sure it occurs
> in the result the same number of times.
Let's hope Warp doesn't ask us to test for a *stable* sort...
Date: 4 Jun 2010 11:32:37
Message: <4c091c95@news.povray.org>
>> testing.
Well, a limitation.  I do very little programming where the invariants of
the class are particularly difficult to ensure.  That would be
"datastructures" and "file systems", which I use system/language libraries for.
Date: 4 Jun 2010 11:33:43
Message: <4c091cd7$1@news.povray.org>
>>> testing.
> of the class are particularly difficult to ensure.  That would be
> libraries for.
Or, to rephrase, sure, a SQL server can have gazillions of unit tests that
make sense. But I don't write SQL servers. That's been done. :-)
Date: 4 Jun 2010 12:13:10
Message: <4c092616@news.povray.org>
> >> Trivial.
> > that test.
  That was one warning example at school aboit how easy it is to write
pre- and postconditions which actually are not comprehensive enough.
The sorting example is superb to demonstrate that, because many people,
like you, think that it's enough to go through the array after the sorting
is done and check that every value is larger or equal to the previous value.
The counter-example to this is, of course, to make the "sorting" fill the
array with the same value (eg. the first one), and it would pass the test.
  At the same time it poses an interesting thought problem: *How* would you
write a post-condition that truly checks that the resulting array has the
same values as the original, but sorted? And a bit more difficult: What
would be the asymptotically fastest possible way of doing the check?
Date: 4 Jun 2010 12:41:12
Message: <4c092ca8$1@news.povray.org>
Yes, it's a good point. :-)
Obviously had it not been an offhand post to p.o-t I would have put more
thought into it. I thought you were asking more about the technology of how
it was done, and I was saying "obviously you need universal qualifiers like
this..." rather than trying to actually be comprehensive.
Sure. As I said, you can loop thru the original array, counting the number
of times old[i] appears in old, then for each of those loop thru new[j]
counting the number of times old[i]==new[j].  So it's at worst O(N^2).
It's not hard to specify, which is what I thought you were getting at. Hard
to do efficiently, but that's what people do in debug builds.
For example, MS has a rule that you're not allowed to publish performance
reviews of their beta software. At one point, they gave a beta of Excel to a
journalist, and they tried it out, and published that it was terribly slow.
Well, it was a debug build, and every time you did an update, it would
calculate everything with the optimized path, then it would iteratively
calculate every single cell over and over until it stabilized (or they
looped more than the number of cells), and then compared the two. Of course
it was slow.
Once you're confident your sort works, you don't have to test you haven't
introduced new values in production. :-)
Date: 4 Jun 2010 15:16:34
Message: <4c095112$1@news.povray.org>
>>> testing.
> libraries for.
	I think you took me too seriously. I meant that it does precisely what
it claims to. It's not meant for all kinds of tests. Just one kind.
	I suppose limited is more appropriate, but it still sounds too
negative.<G> It's like saying mutt is limited because it doesn't send
mails and needs the sendmail command. It just was never meant for
sending mail.
Date: 4 Jun 2010 15:48:13
Message: <4c09587d$1@news.povray.org>
I understand. I consider it a "problem" when a test tests something that
doesn't really tell you things are working.  Especially the way it's hyped
as making your code easy to refactor and blah blah blah.
> sending mail.
Given that you have to put a fair amount of work into unit tests, and that
what unit tests ensure isn't especially interesting in most cases, I'd say
yes, "limited" ought to sound negative.
Automated testing is great.  Automated testing of a single class when that
class does something profound all by itself is useful. Most of *my* classes
are designed for interacting with other classes, tho, rather than for
maintaining particular invariants.  Places where the classes are designed to
maintain invariants are places where I'm usually using a library anyway.
