POV-Ray : Newsgroups : povray.off-topic : Logic Simulator.... For whomever wants to look at it. Server Time
1 Nov 2026 18:53:14 EST (-0500)
  Logic Simulator.... For whomever wants to look at it. (Message 1 to 50 of 53)
Goto Latest 50 Messages Next 3 Messages >>>
Subject: Logic Simulator.... For whomever wants to look at it.
Date: 28 May 2010 12:01:01
Message: <4bffe8bd@news.povray.org>
New thread at Andrew's request:
Download Location:
http://sourceforge.net/projects/logicsim/files/
Be sure to read the notes. Requires .NET Framework 3.5
I'll reply to this thread for updates.
This is wiring only, with minimal select and drag features.
Subject: Re: Logic Simulator.... For whomever wants to look at it.
Date: 28 May 2010 18:34:54
Message: <4c00450e@news.povray.org>
> Download Location:
*Downloads source code and Mono*
*Tries compiling*
SimulatorControl.cs(745,34): error CS0103: The name `Properties' does not
exist in the current context
SimulatorControl.cs(757,38): error CS0103: The name `Properties' does not
Tracer.cs(26,38): error CS1502: The best overloaded method match for
`LogicSim.Tracer.Tracer(string, System.Diagnostics.TraceLevel)' has some
invalid arguments
Tracer.cs(14,19): (Location of the symbol related to previous error)
Tracer.cs(26,38): error CS1503: Argument `#2' cannot convert
`System.Diagnostics.SourceLevels' expression to type
`System.Diagnostics.TraceLevel'
Hmm... I think I'll go for the binary :)
*Downloads .exe*
Well, at least it starts.
*Clicks on a wire*
** (LogicSim.exe:15845): WARNING **: GdipSetPenCustomEndCap isn't
implemented
System.NotImplementedException: The requested feature is not implemented
[GDI+ status: NotImplemented]
  at System.Drawing.GDIPlus.CheckStatus (Status status) [0x00000]
  at System.Drawing.Graphics.DrawImage (System.Drawing.Image image,
Rectangle destRect, Int32 srcX, Int32 srcY, Int32 srcWidth, Int32 srcHeight,
GraphicsUnit srcUnit, System.Drawing.Imaging.ImageAttributes imageAttr)
[0x00000]
  at (wrapper remoting-invoke-with-check) System.Drawing.Graphics:DrawImage
(System.Drawing.Image,System.Drawing.Rectangle,int,int,int,int,System.Drawing.GraphicsUnit,System.Drawing.Imaging.ImageAttributes)
Okay, maybe not :)
Date: 29 May 2010 00:15:22
Message: <4c0094da$1@news.povray.org>
On 5/28/2010 5:34 PM, Nicolas Alvarez wrote:
>> Download Location:
> *Tries compiling*
> invalid arguments
Oh...
That one looks like an issue with release builds:
There's a conditional there, and the code when DEBUG is not defined is
wrong. I haven't run a release build yet.
> *Downloads .exe*
> *Clicks on a wire*
> implemented
> [0x00000]
> Okay, maybe not :)
What is your execution environment? If you're trying to run it under
mono, I'm pretty sure it won't work. I haven't had any chance to port it
to mono, and it looks like it's missing a few things.
Date: 29 May 2010 20:58:01
Message: <4c01b819@news.povray.org>
>> *Downloads .exe*
>> *Clicks on a wire*
>> implemented
>> srcHeight, GraphicsUnit srcUnit, System.Drawing.Imaging.ImageAttributes
>> imageAttr)
>> [0x00000]
>> Okay, maybe not :)
I'm on Debian Linux, 64-bit; with Mono 2.4.4.
Date: 30 May 2010 00:06:10
Message: <4c01e432@news.povray.org>
Do you know if Mono will run projects with Linq?
I'd like to be able to port this to mono when it's done. I use some Linq
features on the collections (mostly just a couple of the extension
methods (such as Select and Where) as a convenience)
It looks like a few of the GDI+ things I may have to look out for, I
might recode a few portions of the code that's relying on custom end
caps, since that seems to be a problem.
Date: 30 May 2010 01:21:55
Message: <4c01f5f3@news.povray.org>
I wrote 200 lines of C# in my life, and it didn't involve Linq or graphics.
Just an HTTP request and some XML parsing :)
I barely know what Linq *is* :)
Date: 2 Jun 2010 12:04:53
Message: <4c068125$1@news.povray.org>
> Download Location:
I've updated the files online. Now contains a toolbar, menu bar,
selection and dragging works, and the properties list populates with
some basic information (And a small amount of stray data that needs to
be hidden from the property list)
Release note contains more information on hotkeys and such.
~Mike
Date: 2 Jun 2010 12:11:42
Message: <4c0682be$1@news.povray.org>
You might wanna start putting version numbers on this stuff, so people
can tell what version they have / what's on SF.
Just a friendly suggestion. ;-)
http://blog.orphi.me.uk/
Date: 2 Jun 2010 17:08:30
Message: <4c06c84e$1@news.povray.org>
Sure, but not right now. It's not even a usable application at this
point. It's basically a release to test and get feedback.
Maybe I'll start giving it version strings like "ui-test-0.0.02-06-2010"
Seems a bit silly, though.
~Mike
Date: 3 Jun 2010 07:47:40
Message: <4c07965c$1@news.povray.org>
I usually just assign a unique number to each one I release. Like, the
first one is Test01.exe, the next one is Test02.exe, and so on. Just a
small thing.
Date: 3 Jun 2010 07:52:21
Message: <4c079775@news.povray.org>
I especially like how labels are hidden by default. Select something add
a label, watch it not appear, and then realise you have to also set it
to visible. ;-)
Still, you've got a mile further than me, so who am I to criticise?
What the...? Oh, wait, you're American. That explains it.
Date: 3 Jun 2010 10:04:53
Message: <4c07b685$1@news.povray.org>
> to visible. ;-)
Yeah, Inputs/Outputs will likely start with the label on by default.
Wires and such will probably have the label hidden by default.
Pah. I need the perspective of someone who is not writing the program. :)
Explains what?
~Mike
Date: 3 Jun 2010 10:05:44
Message: <4c07b6b8$1@news.povray.org>
> small thing.
Ah. I might do that... or something similar.
~Mike
Date: 3 Jun 2010 10:14:00
Message: <4c07b8a8$1@news.povray.org>
>> to visible. ;-)
Fair enough.
> Explains what?
There aren't 23 months in the year. ;-)
Date: 3 Jun 2010 10:49:15
Message: <4c07c0eb$1@news.povray.org>
Oh, right... You guys do the dates "backwards" ;)
Though I have to admit d-m-y makes more logical sense.
~Mike
Date: 3 Jun 2010 11:53:45
Message: <4c07d009@news.povray.org>
My wrist watch does this, and altho I handle military time with no problem,
this still throws me every time I look at the month and see a day on my watch.
    Ada - the programming language trying to avoid
    you literally shooting yourself in the foot.
Date: 3 Jun 2010 14:23:26
Message: <4c07f31e$1@news.povray.org>
D/M/Y makes sense. Y/M/D makes sense. M/D/Y is just perverse! :-P
Date: 3 Jun 2010 14:59:50
Message: <4c07fba6$1@news.povray.org>
What's wrong with "June 2, 2010"?  That's where M/D/Y comes from.
(Though I will admit that I usually write dates as 2-June-2010 or similar
because of the ambiguity of NN/XX/YY formats - and I deal with an
international audience pretty constantly).
Jim
Date: 3 Jun 2010 15:04:58
Message: <4c07fcda$1@news.povray.org>
I spent that entire day feeling like my throat was on fire?
Oh, wait - that's possibly not what you meant...
Date: 3 Jun 2010 15:13:54
Message: <4c07fef2$1@news.povray.org>
Wait, what?  How?
Ah, yes, that's true. ;-)
Jim
Date: 3 Jun 2010 15:31:42
Message: <4c08031e@news.povray.org>
> Wait, what?  How?
I have a cold.
I am going to be SO PISSED if I miss the Summer Dance on Saturday
because of this...!
Date: 3 Jun 2010 15:38:04
Message: <4c08049c$1@news.povray.org>
>> Wait, what?  How?
> I have a cold.
:-(  It's that time of year.
> because of this...!
Get well!
Jim
Date: 3 Jun 2010 16:05:29
Message: <4c080b09$1@news.povray.org>
>> I have a cold.
Midsummer?
>> because of this...!
> Get well!
Yeah, here's to hoping. I've been drinking ascorbic acid all day. (Which
takes like crap, by the way...)
Date: 3 Jun 2010 17:04:21
Message: <4c0818d5$1@news.povray.org>
On Thu, 03 Jun 2010 21:05:28 +0100, Orchid XP v8 wrote:
>>> I have a cold.
> Midsummer?
Yeah, it's that time of year, too.  Also the time of year for colds.
I've had sinus issues the past few weeks (result of allergies here) that
have also made me feel like crap.
>>> because of this...!
>> Get well!
Yuck if you're drinking it straight - what about orange juice?  That
tastes better than the raw stuff and is full of it.
Jim
Date: 3 Jun 2010 17:07:41
Message: <4c08199d$1@news.povray.org>
Actually I'm drinking a mixture of dextrose and ascorbic acid. Put it in
my tea instead of sucrose. Tastes damned weird!
Also, I've been drinking a lot of blackcurrent, which apparently
contains significantly more of it than orange juice. (Then again, I'm
drinking blackcurrent squash, not juice, so...)
Date: 3 Jun 2010 17:09:12
Message: <4c0819f8$1@news.povray.org>
>>> (Which takes like crap, by the way...)
I'll repeat:  yuck. ;-)
I didn't even know such a thing existed. :-)
(Blackcurrent squash, that is)
Jim
Date: 3 Jun 2010 18:19:31
Message: <4c082a73$1@news.povray.org>
> I didn't even know such a thing existed.:-)
Gosh! Some countries are WEIRD. ;-)
Here, some girlies drink Lager and Black(current juice). We give our
kids Ribena to make them strong and healthy.
Best Regards,
Date: 3 Jun 2010 21:10:27
Message: <4c085283$1@news.povray.org>
>>> >  I'm drinking blackcurrent squash, not juice, so...)
Like the UK?  Or are you thinking about the French? ;-)
LOL
Date: 4 Jun 2010 03:00:09
Message: <4c08a479$1@news.povray.org>
Exposure to oxygen, metals, light, or heat destroys ascorbic acid,
Putting it in hot tea is therefore a non-event.
(Putting it in iced tea is another story... but who drink iced tea anyway ?)
Cold water is all you need if it must be disolved.
A: Because it messes up the order in which people normally read text.<br/>
Q: Why is it such a bad thing?<br/>
A: Top-posting.<br/>
Q: What is the most annoying thing on usenet and in e-mail?
Date: 4 Jun 2010 03:13:05
Message: <4c08a781@news.povray.org>
I wouldn’t ever say that about the French who are the epitome of good
taste when it comes to food and drink.
I have a fondness for Ricard Pastis
> LOL
For once I wasn’t being funny o_O
Best Regards,
Date: 4 Jun 2010 10:32:18
Message: <4c090e72$1@news.povray.org>
> taste when it comes to food and drink. I have a fondness for Ricard
> Pastis
:-)  Personally, I prefer Italian, but my stepson is in Paris right now,
and I know he'd agree with you.
>> LOL
That happens? ;-)
Jim
Date: 4 Jun 2010 13:08:14
Message: <4c0932fe$1@news.povray.org>
I was wondering about that, actually. I guess I assumed that since it
still tastes of orange skins there must still be some in there...
BTW, did you know that apparently most organisms can synthesize ascorbic
acid? Humans actually have the entire synthesis pathway intact, except
for one faulty enzyme right at the end. But because what humans
naturally eat contains ascorbic acid anyway, it wasn't a
life-threatening mutation...
Date: 4 Jun 2010 14:51:40
Message: <4c094b3c$1@news.povray.org>
>> Pastis
 From my reading “Italian” food is America’s preferred style of eating
out. Personally I think it is over rated. My favourite “foreign” food is
Chinese.
Best Regards,
Date: 4 Jun 2010 17:01:53
Message: <4c0969c1$1@news.povray.org>
> Chinese.
That doesn't surprise me, though the difference between real Italian and
"Americanised Italian" is quite striking.
Like the difference between authentic Chinese food and what normally
passes as Chinese in both our countries (I've had Chinese in London,
actually).  I have a friend whose mother visited (back when we were in
high school) and she prepared "the real thing" - no Kung Pao Chicken
there. ;-)
My real preference tends towards Indian (including "Indian" that
originated in Scotland as I understand it - the curry dish), but we tend
now not to go out for that, we make it at home. :-)
Jim
Date: 4 Jun 2010 17:32:56
Message: <4c097108@news.povray.org>
>> Chinese.
Something I (will) remain ignorant of ;-)
> actually).
Where in London? The place I generally eat is in Soho’s Wong Kei. There
are a lot of “High Street” restaurants in Soho too :-(
> there. ;-)
Lucky you :-)
I’m not sure I follow you on this one. In Scotland as far as I remember
it’s 10 pints of beer and a vindaloo. The only British Indian dish I can
think of is Chicken Tikka Masala. Actually after Googling it I see that
Glasgow claims it as its own. And Birmingham claims the Balti.
Best Regards,
Date: 4 Jun 2010 18:20:07
Message: <4c097c17$1@news.povray.org>
>> and "Americanised Italian" is quite striking.
Well, if you come over here, I can take you to a Japanese place that's
pretty authentic (according to my Japanese sister-in-law <g>).
>> actually).
It was in Soho, back in 2002, let me see if I can find it....
It looks like it would have to have been on Lisle Street, because I
remember it wasn't far from Leister Square station, though we rode in and
met the rest of our group at Westminster and walked from there.
But I also remember that the entrance was on the left-hand side of the
front of the restaurant, and there was a stairway that led upstairs (we
sat on the second floor).  It *might* have been Fung Shing, The interior
shots on their website remind me of what I remember, if that's any
indication.
But I also vaguely recall that the exterior was red and there were a fair
number of awnings over the street, including in front of the entrance.
Unfortunately, for that day of the trip, I only have photos of the
British Museum and Paddington Station - the dinner was an experience we
didn't photograph (the food was good, but the experience was memorable
for all the wrong reasons).
>> I have a friend whose mother visited (back when we were in high school)
>> and she prepared "the real thing" - no Kung Pao Chicken there. ;-)
> Lucky you :-)
Unfortunately, while the flavours were really good, some of the textures
didn't agree with me.  But certainly very different from what most
Americans think of as "Chinese" food.
>> tend now not to go out for that, we make it at home. :-)
The Tikka is part of it, certainly.  :-)  I've read in some Indian
cookbooks that what many westerners think of as "Indian" food is really
British in nature, partially because some of the spice mixes aren't
native to India.
That said, though, one of our favourite restaurants to visit in Salt Lake
City does authentic Indian food - had a friend who grew up in India visit
with us, and he said it reminded him of his grandmother's cooking (in a
good way).  So at least one place here got it right (quite possibly
because the family that owns it is from India and most of the staff are
immigrants from India).  Next time I'm in there, I'll have to ask Avtar
what part of India his family is from.  They're always happy to see us,
but we've not gone as much recently because we do make our own.
Jim
Date: 5 Jun 2010 09:45:24
Message: <4c0a54f4$1@news.povray.org>
> pretty authentic (according to my Japanese sister-in-law<g>).
That’s worth remembering.
> indication.
I’ve not eaten there. So many restaurants so little time. :-(
Red is a popular colour. :-)
Paddington Station is worth a photograph or two. :-)
  - the dinner was an experience we didn't photograph
Restraint well shown. ;)
Have you tried congee or chow ho fun? The textures of both are not what
westerners are used to.
The story goes that someone wanted Chicken Tikka, which is a dry dish,
but he wanted it moist? So the chef added Heinz tomato soup and viola!
Chicken Tikka Masala was born.
> native to India.
That is probably true. The posh Brits brought back curry in the days of
the Raj. When it became popular it was modified to reduce the heat of
the spices and to use whatever native herbs that could be used.
That is what I am going to do this afternoon, pig curry.
Best Regards,
Date: 5 Jun 2010 16:23:32
Message: <4c0ab244@news.povray.org>
Except, of course, I meant *when* not *if*. ;-)
>> and met the rest of our group at Westminster and walked from there.
>> interior shots on their website remind me of what I remember, if that's
>> any indication.
Especially in Soho.  I'm going to want to try the one you go to if the
chance presents itself - whether it was Fung Shing or not, we just picked
it by looking at the menu outside, and it's always better to have a
recommendation.
>> fair number of awnings over the street, including in front of the
>> entrance.
It sure is.
Yep, and that's what we got.  I grew up reading Paddington Bear stories,
and we've got a collection that we still read from time to time. :-)
You have no idea how much restraint.  There was, at one point, an actual
danger of one of the members of our party having someone shove chopsticks
up her nose.  I'll give it this:  it was certainly memorable. ;-)
But the details of that story are better told in person over a few pints.
>> textures didn't agree with me.  But certainly very different from what
>> most Americans think of as "Chinese" food.
I may have; that's been longer ago than the trip to Soho, and I have no
recollection of what specifically we had.
All this talk about food is making me hungry. :-)
LOL, even if it's not the actual story, it's funny. :-)
>> native to India.
It's certainly a plausible story. :-)
>> Lake City does authentic Indian food - had a friend who grew up in
>> India visit with us, and he said it reminded him of his grandmother's
>> cooking (in a good way).  So at least one place here got it right
>> (quite possibly because the family that owns it is from India and most
>> of the staff are immigrants from India).  Next time I'm in there, I'll
>> have to ask Avtar what part of India his family is from.  They're
>> always happy to see us, but we've not gone as much recently because we
>> do make our own.
Ooooh, don't think I've had that before (pork obviously isn't often used,
but you know that <G>).  One year for Thanksgiving we did a turkey curry,
and that was quite good.  I prefer prawn, chicken, and lamb (in that
order) myself.
Jim
Date: 5 Jun 2010 17:02:52
Message: <4c0abb7c$1@news.povray.org>
I'm a bit scared of SLC
> recommendation.
Hmm! It is a bit of a cult place. I can’t remember the number of times
I’ve taken people there to see a look of horror on their faces.
I remember one time when two tourists wanted a table to themselves and
said that they would pay the difference. The waiter screamed “Rich men
don’t eat at the Wong Kei. Get out!”
In the old days there was often a floor show from the waiters who were
renowned for their rudeness. But the food is very good and very cheap.
<Dr John, what’s your opinion?>
The Bear now eats Marmite.
O_O
A deal :-D
Congee is rice porridge and ho fun is flat rice noodles.
Well if it was Glasgow then the chances were he was drunk and …
>>> native to India.
I’ve eaten in Indian restaurants in OZ, Jamaica and Nigeria. The
Nigerian Indian food blew my head off but the chef was from Southern
India where hotter spices are used than in the north. Most British
Indians are from the North of India or Pakistan or Bangladesh.
> but you know that<G>).
I used 1 Kg of diced pork and it is delicious. Unfortunately I only have
Thai fragrant rice. But it does :-)
> order) myself.
Potato and cauliflower curries are very good too (Bombay potatoes, aloo
saag and aloo gobi).
Best Regards,
Date: 5 Jun 2010 22:51:50
Message: <4c0b0d46@news.povray.org>
Nah, don't be - it's the liberal part of the state. :-)
>> picked it by looking at the menu outside, and it's always better to
>> have a recommendation.
> I’ve taken people there to see a look of horror on their faces. I
> don’t eat at the Wong Kei. Get out!” In the old days there was often a
> floor show from the waiters who were renowned for their rudeness. But
> the food is very good and very cheap. <Dr John, what’s your opinion?>
LOL, sounds like our kind of place, though we do like personable wait
staff, but if the food's good and it's not a place tourists tend to
frequent, all the better. :-)
>> stories, and we've got a collection that we still read from time to
>> time. :-)
Indeed, but there's no accounting for taste. :-)
>> actual danger of one of the members of our party having someone shove
>> chopsticks up her nose.  I'll give it this:  it was certainly
>> memorable. ;-)
> O_O
Yeah, that's the usual reaction to the story. :)
>> pints.
> A deal :-D
You got it.  Now to find the cash for the trip. :-)
We may have done the second, but I don't think we did the first.
Indeed, I remember parts of my trip to Glasgow.  Good thing we took
photos. ;-)
That sounds consistent with what I've heard as well.
>> used, but you know that<G>).
One does with what one has sometimes.  We buy 20 lb bags of basmati here,
never really seem to run low.  But I could see it mixing well with pork.
>> One year for Thanksgiving we did a turkey curry, and that was quite
>> good.  I prefer prawn, chicken, and lamb (in that order) myself.
I'm not a big fan of cauliflower, but I do like potatoes in my curry.
Jim
Date: 6 Jun 2010 04:59:00
Message: <4c0b6354@news.povray.org>
I'll take your word on that.
One out of three isn’t good. o_O
The staff are renowned for their rudeness and briskness. The restaurant
must be in all the tourist books as it is hoaching with tourists in the
season. But this adds to the fun and the queues. You either hate the
place or love it.
I love it because it is the type of Chinese food I like and often the
service is quick. So I can nip in for a meal and be out in about half an
hour, if I am on my own. Look at the Wiki entry.
http://en.wikipedia.org/wiki/Wong_Kei
The New World in Gerrard Place is maybe a bit more up market. If you
like dim sum they do “yum cha” until 6 pm. With the dim sum being served
from trolleys and the greeters wearing cheongsam. The food is good and
the price for central London is reasonable.
>>> time. :-)
Indeed ;-)
>> A deal :-D
Try to come off season, it is cheeper but wet and cold :-)
> photos. ;-)
You got out alive? What a good native guide you had. ;-)
Fusion :-)
It is a surprise when you do. I buy my rice in 10 Kg bags as well.
Nor am I generally but it absorbs the flavour wonderfully. Try adding
some florets about 15 minutes before the end of the cooking. Overcooking
is OK too.
Best Regards,
Date: 6 Jun 2010 14:20:23
Message: <4c0be6e7@news.povray.org>
No need, it's pretty well documented - democrats hold (and have for
years) positions as the mayor for SLC and for the county, lots of local
"green" initiatives (including vehicles that run on alternative fuels for
the city), and so on. :-)
My read of what you wrote was that tourists tend not to go there because
of the service (or rather, they get thrown out if they make a stink that
makes them sound like tourists).
> place or love it.
OK, I misread, then. :-)
> http://en.wikipedia.org/wiki/Wong_Kei The New World in Gerrard Place is
> maybe a bit more up market. If you like dim sum they do “yum cha” until
> 6 pm. With the dim sum being served from trolleys and the greeters
> wearing cheongsam. The food is good and the price for central London is
> reasonable.
That sounds very good. :-)
>>> A deal :-D
The last two times have been off-season, and we really enjoyed it.  But
if we're relocating, we also need to spend a little time there during the
season as well. :)
>> photos. ;-)
But of course; though I don't know if our friends we went with count as
natives to Glasgow; certainly to the UK, but not Glasgow. :-)
> Fusion :-)
Yeah.  I can't remember which show it was now, but on a cooking show
someone had to create a new Indian-style dish, and he wasn't sure what
kind of meat to use; he remembered something about beef, but didn't know
about pork, so he selected that.  Even still, I think he came out ahead.
It sure is - that's definitely the way to buy it.  It keeps very well as
long as it's a cool, dry place.
> is OK too.
I'll keep that in mind. :)
Jim
Date: 6 Jun 2010 15:21:46
Message: <4c0bf54a@news.povray.org>
+1 point
< lots of local
> the city),
-1 point (I worked for oil companies for almost 20 years) :-P
The number of overseas tourists last year was 14.1 million and the total
overnight-stay visitors was 27 million. Not all of them visited the Wong
Kei (Mr Wong’s shop) ;-)
I imagine a lot don’t go more than once. Although, I recommended it to a
Chinese Australian who came on holiday and he ate there 10 times in a
week. The price might have had something to do with it. ;-)
>> place or love it.
I may have miss-writ.
>> reasonable.
It is if you can eat Hong Kong style food. For instance in the scramble
egg rice the egg is barely cooked.
>> Try to come off season, it is cheaper but wet and cold :-)
> season as well. :)
No, then it is full of tourists and hot. Off season is best. :-)
>> Fusion :-)
Some people think it is an unclean meat. They don’t know what they are
missing.
>> is OK too.
Actually par boiling them first is best.
Best Regards,
Date: 7 Jun 2010 00:37:04
Message: <4c0c7770@news.povray.org>
> +1 point
> < lots of local
>> for the city),
Surely not BP, no?  If so, you might be buying the first round. ;-)
But in terms of 'liberal' point of view, green energy is a pretty good
sign, don't you think?
LOL
I imagine it's also popular with student visitors. :-)
<Stephen Colbert>I accept your apology, sir</Stephen Colbert>
Might work for me, or it could end up being a texture thing.
>> the season as well. :)
Well, "hot" to you is different than "hot" to me.  It's 82F here right
now, and we're supposed to hit 90F by mid-week.
I guess spring is over. <sigh>
>>> Fusion :-)
>> know about pork, so he selected that.  Even still, I think he came out
>> ahead.
> missing.
Well, it tends to be thought of as such for religious reasons, so it
either becomes "throw away my religion and religious traditions" or eat
it.  Generally; I know a guy who is ostensibly Jewish who likes the
occasional bacon sandwich (made with the real thing, not turkey bacon).
>>> Overcooking is OK too.
Hmm, I could see that working.
Jim
Date: 7 Jun 2010 04:27:10
Message: <4c0cad5e$1@news.povray.org>
On 07/06/2010 5:37 AM, Jim Henderson wrote:
>> <  lots of local
>>> for the city),
No, I worked for Conoco for 12 years and for 4 years I contracted for
other operators.
Yes, :-D
I transferred my orniness to this thread. ;-)
Yes, the average age is quite low if you don’t count the singletons.
Lost on me as we don't get Stephen Colbert here.
Slimy is a description, it goes for “ho fun” too.
I thought that as I was writing it.
> I guess spring is over.<sigh>
Spring has sprung,
the grass has ris’,
I wonder where the birdie is?
There he is up in the sky,
He dropped some whitewash in my eye!
I‘m alright, I won't cry,
I'm just glad that cows can't fly!
>> missing.
Yeah, bacon butties are the Devil's invention.
Best Regards,
Date: 7 Jun 2010 10:28:21
Message: <4c0d0205@news.povray.org>
>>> <  lots of local
>>>> for the city),
> other operators.
I see - well, then, I guess the first round's mine. ;-)
> Yes, :-D
So I noticed. ;-)
It's a common tactic in his interviews (he is a satirical commentator on
current events, and the last 7 minutes of the show includes an interview
where he usually tries to wind up the guest).
>>> scramble egg rice the egg is barely cooked.
Yeah, "slimy" often kicks the gag reflex here.  But not always.
So what do you consider "hot"?  That'll give me an idea. :)
> the grass has ris’,
LOL
>>> missing.
LOL. Bacon, though, is mana. ;-)
Jim
Date: 7 Jun 2010 13:49:33
Message: <4c0d312d$1@news.povray.org>
>>>> <   lots of local
>>>>> for the city),
>> other operators.
But I was on BP's Thistle platform for a trip.
What a mess it was. <Grrr>
>> Yes, :-D
> So I noticed. ;-)
Easy Peasy :-)
I’ve seen clips of his show but you noticed that I didn’t fall into your
trap :-P
So I accept you apology in advance.
It does for most Westerners :-)
75 F is hot for most of us Brits but since I've worked in the subtropics
anything over 90 F is too hot for my comfort. I did find 104 F was
tolerable if I moved slowly and kept out of the sun. And I onced worked
for half an hour at a time at 210 F when I was offshore.
You mean that the Israelites were eating bacon during their travels in
the desert?
You could knock be down with a feather.
Best Regards,
Date: 7 Jun 2010 14:47:12
Message: <4c0d3eb0$1@news.povray.org>
>>> other operators.
Hmmm, might have to reconsider that first round, then. ;-)
I was watching something this weekend that talked about the number of
safety incidents for various oil companies over the past 3-4 years.  Most
of them were in the < 10 category.  BP?  More than *700*.
Ouch.
> trap :-P
LOL, well played, sir. ;-)
Interesting, I didn't know that.  I thought it was "just" me (not as in
"I'm the only one" but "I'm one of a small number").
75 F is very comfortable for me.  In fact, that's what it is outside here
right now.  Warmer than that depends on the humidity and available
drinking water.  I did some work in Arizona in 106 F (server room setup
but the building wasn't finished yet and the AC wasn't installed, much
less the windows), and it was OK, but took a lot of drink with me
(Gatorade, as I recall).
But I've seen > 100 F in 80%+ humidity and that's just miserable.
> the desert?
LOL.
<tap>
Jim
Date: 7 Jun 2010 15:26:13
Message: <4c0d47d5@news.povray.org>
As long as you buy the lst one ;_)
>> What a mess it was.<Grrr>
> of them were in the<  10 category.  BP?  More than *700*.
> Ouch.
I'm glad it's called BP instead if British Petroleum, now.
>> trap :-P
<Bows>
IMHO :-)
Yes you need to drink. Which raises another gripe of mine. People
carrying water bottles in temperate climates as if they are in the tropics.
> But I've seen>  100 F in 80%+ humidity and that's just miserable.
One job I had (on BP's Thistle) was to keep an eye on the production
instrumentation, when the telemetry had broken. It was about 40 C (104
F) and the humidity was very high. We must have drunk a gallon of water
an hour.
> LOL.
> <tap>
:-D
Best Regards,
Date: 7 Jun 2010 15:27:13
Message: <4c0d4811$1@news.povray.org>
Last one, I meant.
Best Regards,
