POV-Ray : Newsgroups : povray.off-topic : Too much time on their hands ... Server Time
1 Nov 2026 19:44:19 EST (-0500)
  Too much time on their hands ... (Message 1 to 10 of 10)
Subject: Too much time on their hands ...
Date: 26 May 2010 16:56:27
Message: <4bfd8afb$1@news.povray.org>
Someone with far too much time on their hands:
http://goldfish.ikaruga.co.uk/logic.html
Enter mechanical computing. :)
~Mike
Subject: Re: Too much time on their hands ...
Date: 27 May 2010 03:01:32
Message: <4bfe18cc$1@news.povray.org>
Imagine how hard you'd have to push if you connected together a handful of
these blocks!
Date: 27 May 2010 04:55:30
Message: <4bfe3382$1@news.povray.org>
There's nothing wrong with that. Some of the iconic first computers were
mechanical. ;-) (And I don't just mean Babbage's Analytical Engine; go
look up the Zuse Z1 computer.)
> of these blocks!
Well, that's just it. The entire assembly is passive, whereas normally
logic gates have their output power derived from a source independent to
the input. (Especially buffers - that's essentially their entire point!)
It's not particularly easy to see how you'd do this with reciprocating
mechanical signals; if you were using continuous rotational motion, it
would be clearer that amplification is possible. (Although it's still
not obvious what the best way to achieve it is...)
Date: 27 May 2010 05:06:57
Message: <4bfe3631$1@news.povray.org>
>> of these blocks!
> would be clearer that amplification is possible. (Although it's still not
You'd have an big drive shaft going down the middle powered by a huge motor
rotating at a constant speed.  Whenever a logic gate needs to output a logic
1, it would just connect its output shaft to the big shaft.  Would make for
interesting circuit layouts :-)
With linear motion you could have a big "activate" rod that you push with a
big force to "run" the circuit.  You set up your inputs by either connecting
them to this rod or not, and each logic gate could be arranged to either
connect or disconnect its output to the core activate rod (they could spring
back to "0" if not connected).  I haven't thought this through yet if it
would actually work or not with more complex circuits!
Date: 27 May 2010 05:26:35
Message: <4bfe3acb$1@news.povray.org>
> motor rotating at a constant speed.  Whenever a logic gate needs to
> output a logic 1, it would just connect its output shaft to the big
> shaft.  Would make for interesting circuit layouts :-)
The difficulty is comming up with a mechanism which will connect one
shaft to another if a third shalf is rotating, and disconnect them when
it stops rotating.
> with a big force to "run" the circuit.  You set up your inputs by either
> connecting them to this rod or not, and each logic gate could be
> arranged to either connect or disconnect its output to the core activate
> rod (they could spring back to "0" if not connected).  I haven't thought
> this through yet if it would actually work or not with more complex
> circuits!
I'm not sure that would work. A rod that's just staying still doesn't
impart power.
I think whatever system you choose, whether it's rotating axials or
water pressure or flowing electrons, the fundamental device that you
seem to need is a thing to connect or disconnect two halves of a signal
pathway based on an input. (And I think it might be neccessary to
configure it to react to different senses of the input.) If you can
manufacture that, it seems like you can make all the other fundamental
logic gates.
  pathway --#-- pathway
         control
You can now make a buffer:
   (+) --#-- Output
       Input
For an inverter, just invert the sense of the input.
An AND gate is no difficulty:
   (+) --#----#-- Output
        In1  In2
Similarly for an OR gate:
   (+) -+--#--#-- Output
        | In1 |
          In2
If that construction doesn't work, take an AND gate and invert all the
signal pathways. Either way, with buffers, inverters and AND/OR gates,
you should be able to construct anything.
Date: 27 May 2010 05:37:36
Message: <4bfe3d60$1@news.povray.org>
> The difficulty is comming up with a mechanism which will connect one shaft
> to another if a third shalf is rotating, and disconnect them when it stops
> rotating.
Just get a clutch (like the one in a car) that is controlled by a third
shaft rather than your foot.  The third shaft could just have some masses
attached to it that move outwards when the shaft is rotating, like a
centrifugal speed governor.
> impart power.
Sorry I didn't explain very well, my idea was that the gates would only
update their state when you pushed the rod.  It would be like a kind of
master clock for every gate.  You could then have something driving the rod
back and to, and the gates would all update on each forward push of the rod.
Date: 27 May 2010 06:02:21
Message: <4bfe432d$1@news.povray.org>
>> when it stops rotating.
Does Lego have a part like that? ;-)
> rod back and to, and the gates would all update on each forward push of
> the rod.
...so instead of continuous rotational drive, you have continuous
reciprocating drive, basically?
Date: 27 May 2010 06:20:53
Message: <4bfe4785@news.povray.org>
http://www.brickengineer.com/pages/2007/11/27/smooth-lego-clutch/
Yes basically, otherwise as you stated you can't transfer any power.
Date: 27 May 2010 06:30:33
Message: <4bfe49c9@news.povray.org>
>>> third shaft rather than your foot.
OK, so there's your clutch. Now, how to convert the rotational motion of
an axial into the sliding motion to operate this clutch?
Right, OK. That could work...
Date: 27 May 2010 06:49:26
Message: <4bfe4e36$1@news.povray.org>
http://en.wikipedia.org/wiki/Centrifugal_governor
Shouldn't be too hard to rig something up that works this way out of lego,
and use the linear motion to control the position of the clutch.
