POV-Ray : Newsgroups : povray.off-topic : Electronics activity Server Time
1 Nov 2026 19:46:33 EST (-0500)
  Electronics activity (Message 1 to 50 of 65)
Goto Latest 50 Messages Next 15 Messages >>>
Subject: Electronics activity
Date: 23 May 2010 06:41:13
Message: <4bf90649$1@news.povray.org>
Hoookay, well yesterday I had running silicon. And this time, it did
what I was expecting it to do! ;-)
I took a trip to Maplin and somehow spent £25 - which is impressive,
given that a 74HC00 is a mere £0.79 (for example).
Ironically, the biggest problem was actually *wires*. I bought a box of
nicely cut wires, and that was £10 on its own. (In fairness, it comes in
a nice compartmental box and there's quite a lot of wire in it, each
length in a different colour, with the ends neatly bent to a
right-angle.) Unfortunately, the wire is so utterly stiff and unbendable
that I had a lot of trouble using it.
The other expensive item was LEDs. If you want those "high intensity"
ones, they're like £1.50 *each*. o_O Like, WTF? Anyway, some of the
"normal" ones are more like £0.29 each. But they only have two or three
of them in stock. (Again, WTF?) So if you want to buy more than 3 LEDs,
basically what you have to do is buy a "lucky bag", which just contains
a random assortment of ~30 LEDs for about £6.
So £10 wires + £6 LEDs = nearly the whole of what I spent already. The
breadboard was £3 or something, so that's £19. And then the actual IC
and a battery holder, both of which were mere pence as you'd expect. So
I walked out having spent £20.
And then I walked back into the shop and bought some batteries. Because,
you know, I'm not going to get far without that. £5 for half a dozen
batteries is pretty much a normal price really.
I have now taken the box of wires back. I was able to buy a 10 m reel of
thin, flexible wire for a piffling £2, which is much more like it.
However, it's multi-strand (presumably why it's flexible), so now I have
to go find my soldering iron and some solder so I can tin the ends...
http://blog.orphi.me.uk/
Subject: Re: Electronics activity
Date: 23 May 2010 06:51:55
Message: <4bf908cb@news.povray.org>
The next thing you should build is a dual voltage power supply.
Best Regards,
Date: 23 May 2010 06:58:27
Message: <4bf90a53@news.povray.org>
Am 23.05.2010 12:41, schrieb Orchid XP v8:
No, actually it's not - once you get used to this effect :-P
Pre-cut wires? Gee, you must have too much money to spend ;-) (or
suffering from an utter lack of time... duh, thinking about it, it
somehow makes sense after all... >_<)
Date: 23 May 2010 07:10:34
Message: <4bf90d2a@news.povray.org>
Yeah, it's like that time I was on Amazon, and I saw a textbook for,
like, £4, so I bought it. And then I bought another one. And in short
order, I somehow spent £80. o_O Which seems silly, given that £4 is a
small amount, while £80 is a frickin' HUGE amount. Then again, it's only
actually 20 books...
Or, more recently, when I was buying CDs for a mere £2 each, and still
somehow spent £100. The point being, even a small price, when multiplied
by a suitably big number, becomes a *big* total. ;-)
Well, I don't know where my soldering iron, solder or wire cutters are.
And I know from experience that trying to strip wires is approximately
impossible, and trying to tin the ends is very tricky. And I thought £10
for a nice set of wires with a box to keep them in wasn't bad.
...and then I discovered that the wires can't be bent, so I went and got
my money back. :-P
I'm actually surprised that 10 m of wire is £2 and not £0.2, to be
honest. (Or I could get 100 m for £6. But I actually wanted several
colours...)
Date: 23 May 2010 07:12:35
Message: <4bf90da3$1@news.povray.org>
Uh, why?
1. If I actually wanted one, I could *buy* one for a very modest price.
(And that way, it would actually work properly.)
2. I don't know how many amp-hours an AA battery is, but with each IC
using several micro-watts of power, I don't envisage running them flat
any time soon.
Date: 23 May 2010 09:19:13
Message: <4bf92b51@news.povray.org>
> Uh, why?
Why not? It is educational, useful, fun and profesional. You will often
use one supply (5V for TTL Vcc) and another for a signal or maybe a
relay supply.
> any time soon.
But you will sometime and there is always the chance of you not noticing
the battery voltage dropping and your circuts not working properly.
But then I only worked in electronics for 25 years so what do I know ;-)
Best Regards,
Date: 23 May 2010 09:44:59
Message: <4bf9315b$1@news.povray.org>
Using propper snips gently compress the insulation,about a 1/4 to 3/8 of
an inch (6 to 10 mm) rotate the snips 90 degrees left then right.
Release the wire and grip it again where you first gripped it with the
snips and pull. Alternatively using a sharp knife, score the insulation
to the wire all round the wire and pull the insulation off with your
fingernails or teeth.
To tin stranded wire twist the strands so that none are sticking out.
Have either a loop of multicore solder sitting on your bench with a
couple of inches sticking up or your spool of solder with some solder
sticking up. Tin the iron with solder so that there is a drip on the
iron and tin a little bit of the wire. Take the wire to the top of the
solder and with the iron, gently melt the solder whilst drawing the wire
through the melted solder.
It is harder to write it than to do it. :-)
Best Regards,
Date: 23 May 2010 10:24:01
Message: <4bf93a81$1@news.povray.org>
>> Uh, why?
> Why not?
Because when it doesn't work, I will probably end up killing myself, for
starters... A power supply is far too complicated for me to get right.
>> any time soon.
Oh, I'm sure they'll do that anyway. ;-)
Heh, where to buy capacitors cheap, I imagine. ;-)
Date: 23 May 2010 10:29:03
Message: <4bf93baf$1@news.povray.org>
With the thickness of wire I'm using, 6 mm would be several times the
total diammeter of the wire. ;-)
Oddly, this is significantly harder than you'd think...
The 30-year-old solder I found seems to be quite "bubbly", which makes
it difficult to do this. It also doesn't seem to want to melt very
evenly, resulting on lots of blobs, or only one side of the wire tinned.
Now I remember why I wanted to buy wire ready-cut. ;-)
Still, I have just spent about an hour sitting on my driveway with a
workmate, several bunches of wire and a soldering iron. People probably
think I'm weird now... Everybody's out mowing the lawn, riding bicycles,
having a BBQ or sunbathing, and some sad tosser over at number 11 is
sitting with a bunch of wires and tools.
Date: 23 May 2010 10:40:13
Message: <4bf93e4d@news.povray.org>
Buy? ROTFL
Best Regards,
Date: 23 May 2010 10:42:10
Message: <4bf93ec2$1@news.povray.org>
> Buy? ROTFL
Let me guess... REAL engineers MAKE capacitors out of foil and wrapping
paper? :-P
Date: 23 May 2010 10:50:01
Message: <4bf94099@news.povray.org>
So, you can always trim it.
You might be better using solid core wire if it is that thin.
These sort of things are learned by experience and listening to the old
men round the camp fire
I know, strip and tin one end first then strip the other end. That stops
the strands getting mangled.
Tin the end first then when the strands can't separate do the length.
Use a dry iron to stroke the blobs off.
BTW modern solder has better flux.
LOL
Good job they can't see you with PovRay ;-)
Best Regards,
Date: 23 May 2010 10:50:48
Message: <4bf940c8$1@news.povray.org>
>> Buy? ROTFL
> paper? :-P
LOL, They get them from work ;-)
Best Regards,
Date: 23 May 2010 11:10:03
Message: <4bf9454b$1@news.povray.org>
>> paper? :-P
There are people who get paid money to do stuff involving capacitors? o_O
Date: 23 May 2010 11:19:51
Message: <4bf94797$1@news.povray.org>
>>> paper? :-P
:-D
Best Regards,
Date: 23 May 2010 11:42:52
Message: <4bf94cfc$1@news.povray.org>
ve,
Indeed, one of my own big insights was "Wow, I can use the computer for
another project, if I write *software*!"  ;-)
> Pre-cut wires?
And I would think if you're getting pre-cut breadboard wires, you *want*
them to be stiff.
    Ada - the programming language trying to avoid
    you literally shooting yourself in the foot.
Date: 24 May 2010 04:44:12
Message: <4bfa3c5c$1@news.povray.org>
>> Pre-cut wires?
> them to be stiff.
I have now cut some flexible wire, and it works quite well. (In
particular, it can go around corners...)
Date: 24 May 2010 04:45:24
Message: <4bfa3ca4$1@news.povray.org>
Hmm, this isn't going to work at all, is it?
Download 'logic1.png' (7 KB)
Preview of image 'logic1.png'
Date: 24 May 2010 04:49:24
Message: <4bfa3d94$1@news.povray.org>
PS. MS Word is utterly *horrible* at drawing circuit diagrams... (But I
guess you probably knew that already.)
Date: 24 May 2010 09:24:38
Message: <4bfa7e16$1@news.povray.org>
On 5/23/2010 9:24 AM, Orchid XP v8 wrote:
>> Why not?
A power supply is a rather simple device: A transformer that steps down
the 240VAC to (for example) 12VAC, a bridge rectifier to convert the AC
source into DC then a couple regulators to get (perhaps) 5 and 12 volts.
Personally, though I'm a bit skittish about using wall power, I use an
AC adapter w/12 volts (though the one powering my headphone amp is 24v
regulated, so the op-amp gets +/- 12v much more than is ever needed for
boosting heaphones, but gives the op amp plenty of headroom to source
current for the low impedance phones I have)
... One of these days I'll upgrade it to an op-amp w/ a mosfet output
stage so I can get as much current as I can, even though this is plenty
loud ;)
~Mike
Date: 24 May 2010 09:26:00
Message: <4bfa7e68$1@news.povray.org>
For a minute there I thought you were going to say you picked them off
of discarded electronics.
~Mike
Date: 24 May 2010 09:30:54
Message: <4bfa7f8e$1@news.povray.org>
>>> Why not?
...or I could use one assembled by professionals who actually know what
they're doing. ;-)
I don't mind destroying a few 29p LEDs by accident, but I'd really
rather not die a virgin...
Date: 24 May 2010 09:35:23
Message: <4bfa809b$1@news.povray.org>
This is why you buy solid wire and not stranded! Though I have learned
that stranded is the best choice for hooking up external peripherals to
your circuit, when used in a project.
For extra fun, do something like this:
http://www.flickr.com/photos/87959461@N00/4469974973/
http://www.flickr.com/photos/87959461@N00/4470754768/
I learned a pretty important lesson with this project:
Put the jumpers on the component side, and use stranded wire for the
external parts (jacks, pot, power and LED) the solid wire made install
into the enclosure a royal pain.
A breakout board for a 14-segment display. (The title is incorrect):
http://www.flickr.com/photos/87959461@N00/4487754588/
> colours...)
Copper isn't cheap....
~Mike
Date: 24 May 2010 09:38:48
Message: <4bfa8168$1@news.povray.org>
Trouble is, you just can't *bend* the stuff! It's like trying so connect
components together with a coat hanger...
(Although, I bought 4 chunks of wire, and one of them actually *is*
single-core wire. While it's rather rigid, it's not quite as bad as the
other stuff.)
>> colours...)
And 10 m of wire weighs, what, about 10 grams?
Oddly, both the single-strand and multi-strand cables appear to contain
some kind of white metal, not copper.
Date: 24 May 2010 09:57:15
Message: <4bfa85bb$1@news.povray.org>
> they're doing. ;-)
pff.. I did that, was highly dissatisfied with the result, and the thing
ran on batteries, which was inconvenient. So, I built one to my own
requirements. :D
~Mike
Date: 24 May 2010 09:58:38
Message: <4bfa860e$1@news.povray.org>
tin-plated copper.
~Mike
Date: 24 May 2010 10:13:41
Message: <4bfa8995$1@news.povray.org>
Lordy, no. Nothing but the best for the maintenance department. :-)
Best Regards,
Date: 24 May 2010 11:29:40
Message: <4bfa9b64$1@news.povray.org>
You're not supposed to run breadboard wires around corners. You're supposed
to plug it into a hole and run a connected wire at an angle if you need angles.
Date: 24 May 2010 11:31:46
Message: <4bfa9be2$1@news.povray.org>
> supposed to plug it into a hole and run a connected wire at an angle if
> you need angles.
I don't follow.
Date: 24 May 2010 17:59:36
Message: <4bfaf6c8$1@news.povray.org>
Invisible wrote:
> I don't follow.
http://www.robotroom.com/Pumpkin/LEDPulsingBreadboard.jpg
See how the black cable goes from C1 to C2?
Or how the purple cable goes "around the corner"?
Date: 25 May 2010 03:55:05
Message: <4bfb8259$1@news.povray.org>
I see...
Makes it kinda hard to rest the ends of the wires on both battery
terminals simultaneously when they're utterly rigid though. Similarly,
if you've got one wire that's 4 holes wide and another that's 6 holes
wide, you have to systematically design your circuits to not need any
connections 5 holes wide. Routing becomes formally equivilent to solving
the Zero Sum problem. (!) Not to mention the fact that those tiny 1-hole
wide wire loops are excruciatingly hard to manipulate.
By contrast, if you have some flexible wire, you can make a loop of any
size you desire, and it's very easy to work with.
Date: 25 May 2010 04:09:48
Message: <4bfb85cc@news.povray.org>
Would it work if each switch had a seperate resistor? Or does that not
fix it?
Date: 25 May 2010 06:26:58
Message: <4bfba5f2$1@news.povray.org>
Depends what you mean by "work".  Seems like the two input pins on the IC
are actually tied together (to the top side of the resistor), so it's just
going to work like a NOT gate.
Did you also do the calculations to check that it's ok to use a single 360
Ohm resistor with those two LEDs for every combination of output states?
> Would it work if each switch had a seperate resistor? Or does that not fix
> it?
Dude, really, you are going to fall over yourself over and over again if you
refuse to learn at least some basic analogue circuit electronics.  You must
have realised by now that even to implement the simplest logic circuits you
absolutely must have some basic level of understanding.
Also try to draw your circuit schematics the same way as others do (you will
pick this up automatically whilst you learn about them, eg ICs like this are
usually drawn vertically, not horizontally).  Others will be more likely to
help you if they don't have to spend time deciphering which wires are
connected to what.
Date: 25 May 2010 06:31:29
Message: <4bfba701@news.povray.org>
> nicely cut wires, and that was £10 on its own. (In fairness, it comes in a
> nice compartmental box and there's quite a lot of wire in it, each length
> in a different colour, with the ends neatly bent to a right-angle.)
> Unfortunately, the wire is so utterly stiff and unbendable that I had a
It is meant to be like that, so you can plug it straight into the
breadboard.  If you really need to bend it then get a pair of needle nose
pliers and make a neat bend.  Those pliers are also very useful for plugging
in and removing the very shortest wires.
That's what battery holders are for.
Date: 25 May 2010 06:46:18
Message: <4bfbaa7a$1@news.povray.org>
> you refuse to learn at least some basic analogue circuit electronics.
> You must have realised by now that even to implement the simplest logic
> circuits you absolutely must have some basic level of understanding.
So what you're saying is that there is basically no way I will ever get
this to work, and I should just give up now?
Date: 25 May 2010 07:04:33
Message: <4bfbaec1$1@news.povray.org>
No, you can probably get this circuit to work by experimenting yourself,
asking here and googling.  Some people might even be nice enough to give
some detailed explanations, and you might learn some stuff.  You might even
be able to get a slightly more complex circuit to work ok.
But in the end you're doing things backwards, learn the basics *first*, it
will make your life so much easier, and you won't get stuck at every point
when things don't work as expected.  You will be able to answer your own
questions if you have the knowledge of how basic electronic circuits work.
For example the next thing will be relays to control things that need higher
power or voltage, you're going to connect one of your outputs to a relay
coil and then wonder why it's not working, and then complain that the relay
is destroying all your ICs :-)
Date: 25 May 2010 07:15:46
Message: <4bfbb162$1@news.povray.org>
> it will make your life so much easier, and you won't get stuck at every
> point when things don't work as expected.  You will be able to answer
> your own questions if you have the knowledge of how basic electronic
> circuits work.
Funny, I thought I *already* had a basic knowledge of how circuits work...
I guess what's throwing me is this new "logic low = negative" thing. I'm
used to thinking of logic low as "nothing connected here". If you were
making a bunch of logic out of switches with either connect or don't
connect a wire to the positive rail, everything would be quite a bit
simpler. (E.g., connecting the output of two gates together couldn't
possibly create a short-circuit condition, since each output is
connected to the same battery terminal or to nothing at all.)
I guess I'm still trying to get my head around all the consequences of
that. For one thing, it looks like every single [external] input and
output is going to end up needing a resistor on it. Yay. :-/
> higher power or voltage, you're going to connect one of your outputs to
> a relay coil and then wonder why it's not working, and then complain
> that the relay is destroying all your ICs :-)
Uh, no, even I'm not crazy enough to want to do that. :-P
1. I'm turning LEDs on and off. What the hell do I need relays for?
2. Relays are comparatively expensive.
3. Relays presumably use about 100x the current that an IC can supply.
4. PROFIT!
5. Relays move vastly slower than even the slowest electronic logic
gate. Why bother?
Date: 25 May 2010 07:33:41
Message: <4bfbb595$1@news.povray.org>
The circuit diagram you posted here makes it look like you don't.
OOC why are you used to thinking that?
> If you were making a bunch of logic out of switches with either connect or
> don't connect a wire to the positive rail, everything would be quite a bit
> possibly create a short-circuit condition, since each output is connected
This doesn't work, because as soon as you connect a "not connected" output
to something, it becomes "connected" and will have a specific voltage.  The
severely limits how many things you can connect to a single output.
It was just an example, you might one day want to control a motor, a
brighter lamp or a heater or something.
Hehe no, I've got a tiny surface mount IC here that is driving 6W of LEDs
directly.
> 4. PROFIT!
Huh, what are you planning to sell? No more free advice :-)
Date: 25 May 2010 08:08:40
Message: <4bfbbdc8$1@news.povray.org>
>> work...
Well, I noticed it wasn't going to work *before* I assembled it, right? ;-)
>> I'm used to thinking of logic low as "nothing connected here".
I guess it's the way most books refer to circuits as "on" or "off".
Usually if something is "on" it means it's connected to a power source,
and if it's "off" then it isn't connected. That's how, e.g., a light
switch works. It doesn't connect the output to the other pole when you
turn it off, it just doesn't connect it to *anything*.
Of course, strictly speaking, logic high and logic low can be
_anything_. So long as it's documented what they are and all the
circuitry is expecting the same thing, it'll work. But still, most
people casually refer to "on" and "off".
Fair enough. But my immediate plans only run to wiring up lots and lots
of logic gates, and observing their output.
> LEDs directly.
Sure. But I'll bet it isn't a general-purpose logic gate. It'll be some
special driver IC or something.
>> 4. PROFIT!
OOC, what's your hourly rate?
Date: 25 May 2010 08:09:14
Message: <4bfbbdea$1@news.povray.org>
> LEDs directly.
It's more about the relay's coil being an inductor. Once the IC
switches, it will send a high voltage pulse back through the IC, frying
it nicely. There are ways to get around that, but I'll leave that as an
exercise to the reader to figure that out.
Hint: The circuit simulator has an example of this. :)
~Mike
Date: 25 May 2010 08:18:50
Message: <4bfbc02a@news.povray.org>
This was exactly the point I was trying to make, that wiring up a relay
would "seem" to work (assuming your IC could source enough current) but then
in reality it's going to blow the IC :-D
Date: 25 May 2010 08:19:38
Message: <4bfbc05a$1@news.povray.org>
More importantly, if the *whole* circuit is relays, there's nothing to
fry. ;-)
(Other than your electricity bill, anyway...)
Date: 25 May 2010 08:24:31
Message: <4bfbc17f@news.povray.org>
Of course, same as your hex buffer you mentioned.  But you still can't
connect a relay directly to it without risking damage to the IC (as Mike
explained).
How much you got?
Date: 25 May 2010 08:37:03
Message: <4bfbc46f$1@news.povray.org>
>> some special driver IC or something.
> explained).
And I still wouldn't try it in the first place. ;-)
> How much you got?
I think we can take it as read that it's peanuts compared to what you
usually make. ;-)
Date: 25 May 2010 08:53:10
Message: <4bfbc836$1@news.povray.org>
>> How much you got?
> usually make. ;-)
So?  Depends how fun it is.  If you wanted me to test drive Ferraris then
you needn't pay me very much :-)
Date: 25 May 2010 09:23:38
Message: <4bfbcf5a$1@news.povray.org>
As Scott said, if you knew more about electronics then you would know
that a back emf diode is an integral part of these circuits and relays
used in process control come with the diodes fitted.
Best Regards,
Date: 25 May 2010 11:55:06
Message: <4bfbf2da@news.povray.org>
Invisible wrote:
> those tiny 1-hole
Needle-nose pliers.
And I don't think you're supposed to use that wire for the battery.
Date: 25 May 2010 12:28:28
Message: <4bfbfaac$1@news.povray.org>
> I see...
Seriously, go down to the local electronics supply store and buy a
packet of 9-volt battery clips. It makes life much easier!
~Mike
Date: 25 May 2010 12:37:24
Message: <4bfbfcc4@news.povray.org>
Strange... Here's how my mind worked when I encountered the floating
gate = high issue, and not truly realizing logic zero really needs to be
tied to ground:
First I checked the data sheet, and found the information that a
floating input would be interpreted as high. Then I stared at my dip
switch and lamented the fact that it wasn't a SPDT switch. The I
searched the electronics websites for SPDT dip switches, and came up
frustratingly empty. Then started thinking to myself, "How can I make
this work if I only have a SPDT switch" after staring at the circuit I
thought to myself, well, if I connect it to ground with a suitable
resistor, then that should allow the chip to see ground without dumping
tons of current through the switch when its in the on position.
I tried it, and with some trepidation flipped the tiny switch to the on
position and ... it worked just as it was supposed to!
Then I go an research after the fact, playing with the circuit
simulator, and prodding various things in it to find out that yes,
indeed, it does do what I thought it would do. and it makes sense. With
no current from the positive rail, the gate's input can source to
ground. While a voltage is on the positive rail, the gate sinks some of
the current. Exactly what I needed.
A bit more research later and I discovered if I had read a tutorial on
working with logic gates, I would have known about this solution, and
it's called a pull-down or pull-up resistor, depending on which rail it
hooks to.
~Mike
Date: 25 May 2010 12:52:57
Message: <4bfc0069@news.povray.org>
Mike Raiford wrote:
> f I had read a tutorial on working with logic gates,
Heck, if you've ever used a SCSI device you know *that* much. :-)
