POV-Ray : Newsgroups : povray.off-topic : Electronics research Server Time
1 Nov 2026 19:46:11 EST (-0500)
  Electronics research (Message 1 to 50 of 104)
Goto Latest 50 Messages Next 50 Messages >>>
Subject: Electronics research
Date: 19 May 2010 07:07:32
Message: <4bf3c674$1@news.povray.org>
Ah yes. That's the fun thing about doing digital electronics. You can't
just *buy* a 7400. No, you have to decide whether you want a 74LS00 or a
74HC00 or a 74HCT00 or...
Reading the datasheets is like walking into another world. (Especially
since the datasheets are usually poorly-scanned grainy PDFs that don't
match the part number you actually asked about!)
However, I just found the following pages:
http://www.kpsec.freeuk.com/components/ic.htm#logic
http://www.kpsec.freeuk.com/components/74series.htm
http://www.kpsec.freeuk.com/components/cmos.htm
Suddenly everything seems so much clearer. For example...
"74LS series: Inputs 'float' high to logic 1 if unconnected."
Oh crap. Well that would explain a thing or two! >_<
(I foolishly assumed that being unconnected would register as 0V - i.e.,
logic 0. Damn, this is going to make interactive testing *so* much harder!)
Also, it's nice to have some indication of the power requirements,
switching frequencies, and what the hell all the letter codes mean!
Subject: Re: Electronics research
Date: 19 May 2010 07:34:00
Message: <4bf3cca8@news.povray.org>
You should never be leaving any inputs as floating anyway, that's just
asking for trouble (for example if you use a different IC series later).
Best to always tie your inputs to whatever you want them to be.
Date: 19 May 2010 07:58:58
Message: <4bf3d282$1@news.povray.org>
Sure. But I'm sitting with the IC between my fingers, poking the pins
with the end of a wire. Not so easy to tie it all down just for a quick
test.
So it seems that every input pin is supposed to be connected to one rail
or the other. (Or an output, which I guess is going to be the most
common case...)
The page also claims that you can configure an output pin to drive an
LED so that it lights when the pin goes *low*... Man, electronics is weird!
Date: 19 May 2010 08:31:54
Message: <4bf3da3a$1@news.povray.org>
> The page also claims that you can configure an output pin to drive an LED
Why is that weird?  The LED doesn't care which leg is connected to the logic
output pin, it's just a voltage.  You could even connect the LED between two
output pins*, then it would only turn on when one was high and the other was
low.
* Using a series resistor if required...
Date: 19 May 2010 08:51:21
Message: <4bf3dec9$1@news.povray.org>
>> weird!
> logic output pin, it's just a voltage.  You could even connect the LED
> between two output pins*, then it would only turn on when one was high
> and the other was low.
I always thought of it as logic high meaning "connected to the +V rail"
and logic low meaning "not connected to anything". From the looks of
things, it seems that actually logic low means "connected to the -V
rail". So it's like a bipolar setup...
Yes, that's the other fun thing. Depending on which type of gates you're
using, they supply about 20 mA. But some of the LEDs I'm looking it draw
40 mA...
Date: 19 May 2010 08:54:02
Message: <4bf3df6a$1@news.povray.org>
Mmm, 74HC00, 79p. That's quite cheap...
Wait. If I need, say, 10 of them, that's £7.90. Suddenly that doesn't
sound quite so cheap any more. o_O
Remind me, *why* am I embarking on this crazy project? ;-)
Oh, hey Mike, cheapest relay I can find is £1.91. Have a nice day. >:-D
Date: 19 May 2010 09:14:11
Message: <4bf3e423$1@news.povray.org>
Am 19.05.2010 13:07, schrieb Invisible:
Texas Instruments has a nice collection of 74xx data sheets in a single
proper PDF file at <http://focus.ti.com/lit/ug/scyd013b/scyd013b.pdf>
("Digital Logic Pocket Data Book"), apparently covering all their
current products (as of 2007) in the 74xx line, from single-gate 5-pin
thingies like the 74x1G00 (single NAND gate) to 100-pin monsters like
the 74x32543 (36-bit registered bus transceivers with 3-state outputs).
Date: 19 May 2010 09:21:19
Message: <4bf3e5cf$1@news.povray.org>
Am 19.05.2010 14:51, schrieb Invisible:
> 40 mA...
That's why normally you'd use an additional transistor to drive the LED
(if you have multiple LEDs to drive you may want to use a transistor
array in an IC package).
Date: 19 May 2010 09:29:36
Message: <4bf3e7c0@news.povray.org>
Logic "high" and "low" are just names given to a certain agreed range of
voltages.  The difference between "not connected to anything" (floating) and
"logic low" is very important when working with data busses.  If you have
several devices all with their outputs connected to a data bus, then only
one device at a time must be driving the data lines to logic low/high, the
rest must set their outputs to floating.
> From the looks of things, it seems that actually logic low means
> "connected to the -V rail". So it's like a bipolar setup...
But don't assume a "logic low" output will be exactly -V, it is only
guaranteed to be within the range of voltages given for "logic low" in the
data sheet.
> 40 mA...
What you mean is, they draw *up to* 40 mA?  How much they actually draw
depends on what value series resistor you put in there.  Using Ohm's law and
the V-I curve of the LED from the datasheet you can work out exactly what
resistor size you need for a given current.
Date: 19 May 2010 09:47:35
Message: <4bf3ebf7$1@news.povray.org>
Am 19.05.2010 15:29, schrieb scott:
>> rail" and logic low meaning "not connected to anything".
> and "logic low" is very important when working with data busses. If you
> have several devices all with their outputs connected to a data bus,
> then only one device at a time must be driving the data lines to logic
> low/high, the rest must set their outputs to floating.
... except of course in data buses that operate with one dominant and
one recessive symbol (e.g. CAN), in which sending the recessive symbol
is perfectly equivalent to not sending anything - which allows for some
neat tricks to deal with collisions (i.e. the situation where two
devices start sending simultaneously).
Date: 19 May 2010 09:51:56
Message: <4bf3ecfc$1@news.povray.org>
> voltages.
Indeed. You can use any two states you want, so long as it's easy to
distinguish them, and all the components are using the same rules.
There is that...
> the data sheet.
Heh. It gets weirder and weirder...
>> you're using, they supply about 20 mA. But some of the LEDs I'm
>> looking it draw 40 mA...
No idea. The spec sheet just says "forward current".
> and the V-I curve of the LED from the datasheet you can work out exactly
> what resistor size you need for a given current.
Heh. And here I was thinking it's just a case of "if the voltage is less
than X, you don't need a resistor"...
Date: 19 May 2010 09:52:45
Message: <4bf3ed2d$1@news.povray.org>
Hey, check this out:
http://www.maplin.co.uk/Media/PDFs/N24AZ.pdf
They only want £7 for it too. I have literally *no idea* what 98% of the
content of this datasheet means! :-D
Date: 19 May 2010 10:03:18
Message: <4bf3efa6@news.povray.org>
>> later). Best to always tie your inputs to whatever you want them to be.
> test.
So, you put it on a breadboard with each pin tied to a pull-up or
pull-down resistor, and probe with the opposite sense. If your resistor
is pull down (i.e. connected to GND) then use VCC to probe (or better
yet, just get a dip switch ...) If the resistor is connected to VCC,
then use ground to set the signal to 0
> common case...)
Yes. 5v is high, ground is low, not connected is neither of these,
though TTL does float high, a non-connected input on a CMOS chip can
lead to erratic behavior, or even destructive oscillation. It also
leaves the chip wide open for ESD damage. FETs are interesting in that
they don't sink or source any current on their inputs. without anywhere
for the voltage to go, a charge can stay on that input. That charge can
go dangerously (for the chip) high can cause a dielectric breakdown of
the gate's insulating layer. Some CMOS gates will have a high-value
resistor tied to ground on the input to bleed away some of the stray
voltage as a safety measure for ESD. Don't rely on that.
LED anode connected to VCC, cathode connected to out. ;) Not too strange
when you think about it. A logic output is either connected to VCC or GND.
One other thing to be cautious of: If a TTL chip has an open collector
output, make sure to use a pull-up resistor before connecting it to a
CMOS chip. High is floating on an open collector output.
Oh! and by the way: with TTL chips VCC is *critical* due to the nature
of the bipolar transistors used in the gates, they must have a regulated
voltage. Look at Falstad's circuit simulator to figure out why. They
have a resistor set to a particular value to bias the transistor. If the
supply voltage goes out of range, the transistor is no longer properly
biased, which will cause misinterpretation of signals.
CMOS doesn't require a bias, so can run on any voltage (within limits)
~Mike
Date: 19 May 2010 10:04:52
Message: <4bf3f004$1@news.povray.org>
Ah, neat!
Most of the books I've seen only cover the 7400, 7401, 7402, etc., and
don't mention things like the 741G00. Could be useful to know. (Except
that Maplin don't seem to sell this stuff... *sigh*)
Date: 19 May 2010 10:16:28
Message: <4bf3f2bc$1@news.povray.org>
While we're here, does anybody comprehend what VCC, VSS, VDD and related
symbols mean?
Date: 19 May 2010 10:29:51
Message: <op.vcyijvve7bxctx@toad.bredbandsbolaget.se>
> symbols mean?
http://en.wikipedia.org/wiki/IC_power_supply_pin
FE
Date: 19 May 2010 10:48:56
Message: <4bf3fa58$1@news.povray.org>
It's probably under a section titled "typical operating conditions" or
"absolute maximum ratings".  There should also be a graph showing a curve of
current against voltage, from zero up to the absolute maximum current
rating.  Usually with LEDs the light output is fairly linear with respect to
current, but certainly not with voltage.
>> How much they actually draw depends on what value series resistor you put
>> in there.  Using Ohm's law and the V-I curve of the LED from the
>> datasheet you can work out exactly what resistor size you need for a
>> given current.
If you want to run the LED at 10 mA you look up on the V-I curve in the LED
datasheet what forward voltage corresponds to 10 mA.  Say for example 2.8 V.
If your logic output is 5 V (and the other side of the LED is connected to
0V), then you want 2.8 V across the LED and hence 2.2 V across the series
resistor.  So your resistor needs to drop 2.2 V with a current of 10 mA,
that makes it a 220 Ohm resistor.
Connecting the LED directly with no series resistor to a voltage source is
usually a bad idea (even if you think the voltage is correct), because even
slight changes in the voltage cause large differences to the current the LED
draws which might damage your circuit.
Date: 19 May 2010 10:51:05
Message: <4bf3fad9$1@news.povray.org>
I can send you a longer one if you want :-)
Date: 19 May 2010 10:54:49
Message: <4bf3fbb9$1@news.povray.org>
>> the content of this datasheet means! :-D
Why thank you, you're too kind. :-}
Date: 19 May 2010 10:56:08
Message: <4bf3fc08$1@news.povray.org>
>> less than X, you don't need a resistor"...
> LED datasheet what forward voltage corresponds to 10 mA.  Say for
> example 2.8 V. If your logic output is 5 V (and the other side of the
> LED is connected to 0V), then you want 2.8 V across the LED and hence
> 2.2 V across the series resistor.  So your resistor needs to drop 2.2 V
> with a current of 10 mA, that makes it a 220 Ohm resistor.
> is usually a bad idea (even if you think the voltage is correct),
> because even slight changes in the voltage cause large differences to
> the current the LED draws which might damage your circuit.
With my old electronics kit, if I'm remembering this rightly, you
connect through a resistor if you're using the 3V power source, and skip
the resistor if you're using the 1.5V source.
Oh, and *don't* connect the LED to the 9V source at all. I did that once
by mistake... that particular LED doesn't do anything now.
Ah, life seemed so much simpler back then. :-(
Date: 19 May 2010 10:57:00
Message: <4bf3fc3c@news.povray.org>
>> related symbols mean?
OK, thanks for that...
Date: 19 May 2010 11:09:52
Message: <4bf3ff40$1@news.povray.org>
Reminds me of an interesting story.  We got a complaint from a customer that
about 25% LCDs they have from us have a dark edge to the picture, either on
the left or the right side.  When we checked the faulty ones we found that
always the left or right LED was not working in the backlight (I think there
were 8 in total).  This puzzled us for a long time, why would it always be
the far left or far right LED that stopped working, and why were they
breaking in the first place?
In the end we figured out what happened.  Actually *every* LCD we shipped
had one broken LED, it's just they never noticed it when it was one of the
central LEDs.  And it turned out the equipment at our outgoing inspection
test was set to the wrong voltage, so the tester was just blowing one LED on
every backlight that went out :-)
Date: 19 May 2010 11:31:19
Message: <4bf40447@news.povray.org>
Am 19.05.2010 16:04, schrieb Invisible:
AFAIK they usually come in SMD packages only - which in turn means
they'll usually be sold in bulk. And anyway - why would you buy, say,
one 74x1G00 NAND and one 74x1G32 OR gate when you can get a 74x00 4xNAND
IC for the same (or even lower) price, and wire up three of the gates to
simulate the OR gate? (The 74x265 is also a neat beast - with its two
(N)AND gates and two inverters/drivers it's an ideal candidate to
simulate quite a wide variety of 2-gate combos you can imagine).
I guess the single-gate ICs are mainly targeted at applications where
space, routing, speed or EMI constraints are serious enough to forbid
sharing the gates of a single multi-gate IC among different sections of
the circuitry.
Date: 19 May 2010 11:52:48
Message: <4bf40950@news.povray.org>
Am 19.05.2010 15:52, schrieb Invisible:
Ah yes, the typical cheap alphanumeric LCD.
I guess most of the datasheet information says, "this thing does exactly
the same as other manufacturers' devices of this type".
Date: 19 May 2010 11:56:19
Message: <4bf40a23$1@news.povray.org>
There's even a name for that trick: Charlieplexing.
The 3 state had to be simulated by switched, but here's a circuit for
the Falstad simulator (http://www.falstad.com/circuit/):
$ 1 5.0E-6 10.20027730826997 50 5.0 50
L 224 176 176 176 0 1 false 5.0 0.0
L 224 224 176 224 0 1 false 5.0 0.0
162 352 176 352 224 1 2.1024259 1.0 0.0 0.0
162 384 224 384 176 1 2.1024259 1.0 0.0 0.0
w 352 176 336 176 0
w 384 176 368 176 0
w 352 224 336 224 0
w 384 224 352 224 0
w 368 176 352 176 0
L 224 272 176 272 0 1 false 5.0 0.0
w 384 272 352 272 0
162 416 176 416 272 1 2.1024259 1.0 0.0 0.0
w 416 272 448 272 0
w 416 176 448 176 0
162 448 272 448 176 1 2.1024259 1.0 0.0 0.0
w 416 176 384 176 0
w 352 272 336 272 0
162 384 272 384 224 1 2.1024259 1.0 0.0 0.0
s 272 176 336 176 0 0 false
s 272 224 336 224 0 0 false
s 272 272 336 272 0 0 false
w 384 272 416 272 0
162 352 224 352 272 1 2.1024259 1.0 0.0 0.0
r 272 176 224 176 0 100.0
r 272 224 224 224 0 100.0
r 272 272 224 272 0 100.0
~Mike
Date: 19 May 2010 12:03:30
Message: <4bf40bd2$1@news.povray.org>
Ah, sweet! Thanks for that link! <Bookmarked>
~Mike
Date: 19 May 2010 12:58:13
Message: <4bf418a5$1@news.povray.org>
Yep. Indeed, there are a lot of busses that are organized such that you have
an output to it and an input, and you start putting your address on the bus
bit by bit until you see a bit different than your address. That means
someone else put on a 0 while you put on a 1 (assuming floating high). Every
packet gets delivered with no contention, with lower addresses getting
priority.  It's a kind of cool way to work it.
    Ada - the programming language trying to avoid
    you literally shooting yourself in the foot.
Date: 19 May 2010 12:59:26
Message: <4bf418ee$1@news.povray.org>
It's a DED component. It emits dark.
Date: 19 May 2010 13:00:58
Message: <4bf4194a$1@news.povray.org>
Cute. Is there a name for when you have a red LED in one direction and a
green LED in the other and you use AC to make it yellow? I want to use that
around my colleges and sound like I know what I'm talking about. ;-)
Date: 19 May 2010 13:07:50
Message: <4bf41ae6@news.povray.org>
Hey, so long as it doesn't start emitting negative light...
http://blog.orphi.me.uk/
Date: 19 May 2010 13:09:18
Message: <4bf41b3e$1@news.povray.org>
> that around my colleges and sound like I know what I'm talking about. ;-)
Most people call that a tri-colour LED - but sometimes that term is used
to refer to an LED with three different-coloured dies inside it (and
hence 3 pins). Which is obviously a different component.
Date: 19 May 2010 13:14:08
Message: <4bf41c60@news.povray.org>
OK, so if I'm understanding this right... The 74126 (go look it up)
contains 4 "buffers" - gates who's output is logically equal to their
input. But each gate also has an "enable" pin. When the enable pin is
high, the gate works like normal. When the enable pin goes low, it's
like the output pin isn't connected to anything any more.
And it seems that this allows you to connect several outputs together,
forming a kind of wired-OR configuration, provided that at all times
only one gate is "enabled".
Is that right?
Date: 19 May 2010 13:16:58
Message: <4bf41d0a$1@news.povray.org>
Am 19.05.2010 16:16, schrieb Invisible:
> symbols mean?
According to JEDEC,
VBB = substrate power voltage (bias voltage), a voltage < VSS/GND.
VCC = logic power voltage, serving as a reference for high signal levels
(often sharing a common rail with VDD, in which case they may be used
interchangeably).
VCCQ = output stage logic power voltage, separate (positive) power rail
to drive output loads.
VDD = drain power voltage. separate (positive) power rail to drive the
chip's internals.
VDDQ = output stage drain power voltage. Effectively the same as VCCQ.
VEE = emitter power voltage. Only used for ECL devices.
VHH = special function enable voltage. An extra-high voltage to enable
certain special functions of a device.
VPP = programming voltage. An extra-high voltage to supply the power for
the programming function of a device (e.g. EPROM)
VREF = reference power supply, serving as a special reference voltage,
e.g. for ADC inputs.
VSS = GND = ground reference / source power voltage, serving as both
(negative) power rail and low signal level reference.
VSSQ = GNDQ = output stage source power voltage / ground reference,
serving as both a (negative) power rail and low signal level reference
specifically for output signals (should always be at the same level as
VSS=GND).
(This is just a subset of all the symbols used; for instance,
digital/analog devices such as programmable amplifiers or ADCs/DACs
often use separate voltage rails for the analog signals.)
Date: 19 May 2010 13:22:29
Message: <4bf41e55@news.povray.org>
clipka wrote:
> According to JEDEC,
> interchangeably).
> chip's internals.
> VSS=GND).
Suddenly the picture becomes even more complex than you feared...
Thank god I don't have to deal with anything analogue yet! ;-)
Date: 19 May 2010 14:45:54
Message: <4bf431e2$1@news.povray.org>
I spent hours trying to figure out why an op-amp wouldn't give me the
output I was expecting. It finally clicked when I read the warning on
the data sheet that pulling an input within 0.5v of V- would cause it to
latch-up and force the output to near V+ no matter the state of the
inputs. I went through a few chips thinking they were defective.... or
that I toasted one (got V+ and V- reversed, which is apparently bad for
op-amps...)
~Mike
Date: 19 May 2010 15:38:25
Message: <4bf43e31$1@news.povray.org>
See for yourself:
http://www.maplin.co.uk/Module.aspx?ModuleNo=35702
"Forward current: 25 mA"
If you can figure out what the hell that means, be my guest...
Date: 19 May 2010 16:36:51
Message: <4BF44BE6.5010501@gmail.com>
I think I resist any urge to comment on this. Other than "RTFM" and "buy
any 'electronics for dummies book'" before embarking on such a project.
Date: 19 May 2010 16:59:33
Message: <4bf45135$1@news.povray.org>
I don't think electricity comes with a manual. Neither do ICs, usually...
> and "buy
Hey, what do you *think* I've got a dad for? ;-)
Date: 19 May 2010 17:31:59
Message: <4BF458D2.9050601@gmail.com>
They do, they are called datasheets.
>> and "buy any 'electronics for dummies book'" before embarking on such
>> a project.
Hard to say, other than the obvious task of a father ;) . But I guess
you mean that he is the actual dummy that didn't know that a floating
input is seen as a '1'?
Have you ever looked at e.g.
http://en.wikipedia.org/wiki/File:TTL_npn_nand.svg ?
Date: 19 May 2010 23:41:53
Message: <4bf4af81$1@news.povray.org>
On Wed, 19 May 2010 20:38:21 +0100, Orchid XP v8 wrote:
> See for yourself:
http://wiki.answers.com/Q/What_is_forward_current
Date: 20 May 2010 00:50:03
Message: <web.4bf4bf0c72dd7c5cae92d9930@news.povray.org>
A good place to start would be Don Lancaster's two books, TTL COOKBOOK and CMOS
COOKBOOK. Wonderfully easy to read and comprehend. My copies are *old*,
dog-eared and marked up with my comments--I basically taught myself digital
electronics and logic from them, starting from scratch. The best books on these
subjects that I've ever run across.  (I see that they are still available at
Amazon.)
Ken
Date: 20 May 2010 02:58:07
Message: <4bf4dd7f$1@news.povray.org>
> high, the gate works like normal. When the enable pin goes low, it's like
Yes exactly.
> forming a kind of wired-OR configuration, provided that at all times only
Yep, you could make a simple address decoder logic circuit (ie have a 2 bit
binary input to select which of the 4 buffers to enable) - that way you
would guarantee only 1 would be active at a time.  If you were to connect a
2-bit counter to the 2-bit address lines you would then have a 4-bit
parallel to serial converter :-)
Date: 20 May 2010 03:08:03
Message: <4bf4dfd3$1@news.povray.org>
> See for yourself:
Load up the actual PDF spec that is linked from that page, it has more
detail, just stating the forward current like that means nothing.
On page 3 there is the "Absolute max" table, the continuous current here is
listed as 20/25/30 mA depending on the colour.  That is the maximum, above
that they do not guarantee the LED will work.
On page 2 you see they've done all the spec values at 20 mA forward current.
Now look at the lower part of page 3, some interesting charts there
(assuming the Bright Red colour, the others are on the next pages).
The one in the top right shows "brightness" against current.  You see it's
linear up to 10 mA and then flattens out.  This is saying there isn't much
point using more than 10 mA, it won't be very efficient.
The one in the top left tells you what current will be drawn for a
particular voltage across the LED.  If you want 10 mA then you're going to
need to give the LED 2.1 V.  You also see here that even adding just 10% to
that voltage makes the LED current almost 3x higher!
Date: 20 May 2010 03:11:17
Message: <4bf4e095@news.povray.org>
Cool - is there also a name for when you connect a tiny speaker to two
output pins and give one pin a square wave, and the other the inverse of the
square wave - to make your speaker 2x louder than everyone elses? :-)
Date: 20 May 2010 03:56:41
Message: <4bf4eb39$1@news.povray.org>
Am 20.05.2010 09:11, schrieb scott:
> the square wave - to make your speaker 2x louder than everyone elses? :-)
That would be differential audio (also frequently but incorrectly
referred to as balanced audio).
Date: 20 May 2010 04:06:48
Message: <4bf4ed98$1@news.povray.org>
> Yes exactly.
> bit binary input to select which of the 4 buffers to enable) - that way
> you would guarantee only 1 would be active at a time.  If you were to
> connect a 2-bit counter to the 2-bit address lines you would then have a
> 4-bit parallel to serial converter :-)
I was thinking more about routing bundles of signals from place to
place. The "obvious" thing to do is use logic gates to combine the
signals, but I guess using these weird 3-state systems allows you to
save a few logic gates (and hence ICs, wiring, and ripple time).
Date: 20 May 2010 04:20:41
Message: <4bf4f0d9$1@news.povray.org>
Oh, right. I hadn't even noticed that hidden away in a corner there! I
noticed some of the other pages had this, but in *light grey* it's not
especially prominent.
> is listed as 20/25/30 mA depending on the colour.  That is the maximum,
> above that they do not guarantee the LED will work.
I see.
> it's linear up to 10 mA and then flattens out.  This is saying there
> isn't much point using more than 10 mA, it won't be very efficient.
Right. So it will light up with just 10 mA, just not quite at full
brightness. (On the chart I'm looking at, 15 mA looks like it's
meaningfully brighter, but any higher than that has negligable effect.)
> to need to give the LED 2.1 V.  You also see here that even adding just
> 10% to that voltage makes the LED current almost 3x higher!
Right. So I'm looking at 2.1 V or 2.2 V or thereabouts.
Now looking at <http://focus.ti.com/lit/ug/scyd013b/scyd013b.pdf>, on
page 231 (which is actually page 236 of the PDF file), we see that for
the 74HC00 I'm looking at using, we have Icc <= 0.02 mA, Iol = -Ioh <= 4
mA, and tPLH = tPHL <= 27 ns. Now, if I actually knew WTF that means...
Date: 20 May 2010 04:22:13
Message: <4bf4f135$1@news.povray.org>
Wait - DON'T ANSWER THAT! >_<
Date: 20 May 2010 04:31:03
Message: <4bf4f347@news.povray.org>
Am 20.05.2010 10:06, schrieb Invisible:
For unidirectional point-to-point connections, 3-state logic doesn't
help you much, as there's no sane way to properly identify the
"floating" state (unless you care to use some kind of ADCs at the
receiving end).
Date: 20 May 2010 04:39:00
Message: <4bf4f524$1@news.povray.org>
Yes, every LED datasheet has a brightness against current curve.  Even for 1
mA or 0.1 mA it will light up, but obviously it won't be very bright!  Note
that even for 0.1 mA you probably still need a least a volt or so, which is
why LEDs don't light up at all below a certain voltage.
> Now looking at <http://focus.ti.com/lit/ug/scyd013b/scyd013b.pdf>, on page
> 231 (which is actually page 236 of the PDF file), we see that for the
> 74HC00 I'm looking at using, we have Icc <= 0.02 mA, Iol = -Ioh <= 4 mA,
Dunno, what Icc means here, maybe the current consumption of the device
itself?
From this page:
The HC series can sink and source up to 4 mA on the output pins if you want
the signals to still be valid (eg for input to further logic gates).  If you
are just using them to drive LEDs then apparently up to 20 mA is OK.
