POV-Ray : Newsgroups : povray.off-topic : So, here are my blog postings on building a CPU Server Time
28 May 2026 11:42:44 EDT (-0400)
  So, here are my blog postings on building a CPU (Message 1 to 10 of 10)
Subject: So, here are my blog postings on building a CPU
Date: 17 May 2010 11:58:48
Message: <4bf167b8$1@news.povray.org>
http://guineh.blogspot.com/search/label/cpu%20build
I'll try to keep things current. Still designing the thing.
~Mike
Subject: Re: So, here are my blog postings on building a CPU
Date: 17 May 2010 14:19:17
Message: <4bf188a5$1@news.povray.org>
Looks like fun.  I've been playing around with Verilog code lately, and
am going to be purchasing an FPGA starter kit soon.  A basic CPU is one
of the things that I thought would be fun to do in the FPGA, although, I
imagine it's been done to death.
Kyle
Date: 17 May 2010 14:59:56
Message: <4bf1922c$1@news.povray.org>
Oh, but that's the hardest part. Once you have the finished design,
merely putting a few wires together is *easy* by comparison! ;-)
(Of course, _this_ is the stage where you discover that real electronic
components don't work like in the simulator, and so your design doesn't
work right anyway...)
I must say, this is like the coolest thing *ever*! :-D Almost makes me
want to try again. But I don't have any decent diagramming or simulation
tools, and I don't think my GUI skills are up to the task of creating some.
http://blog.orphi.me.uk/
Date: 17 May 2010 17:00:56
Message: <4bf1ae88$1@news.povray.org>
Here's the sim I'm using:
http://sourceforge.net/projects/circuit/
It's actually a pretty decent app. written in Java, seems up to handling
some pretty complex things. It has a few UI quirks, and has a major
drawback in that you cannot add bi-directional pins to the circuits,
which is a bit annoying when you're designing something that has a data
bus that is mean to be read from and written to.
~Mike
Date: 17 May 2010 17:05:53
Message: <4bf1afb1@news.povray.org>
Yup. but isn't that the point of an FPGA? ;)
I mean... basically to build a custom, application specific, chunk of
logic. If it's a customized CPU (er, say a DSP...), then all the more fun.
It's tempting to get something like an FPGA test board and poke
something into it, though.... but I feel this will take some of the "I
built it myself" satisfaction from the project.
.... I still have to figure out how to pare this sucker down so I can do
the big clacking pile of relays version of it ;)
~Mike
Date: 18 May 2010 04:12:57
Message: <4bf24c09$1@news.povray.org>
 From time to time, people try to build ray tracers using FPGA. And,
occasionally, they make one that out-performs a software ray tracer
running on a quad-core Xeon or something. So don't go thinking that just
because it's FPGA it can't be fast; special-purpose machines can and
sometimes do out-perform general-purpose machines. ;-)
Uh, yeah. Good luck with that.
You know that the first computers filled entire buildings, right? ;-)
Date: 18 May 2010 04:27:28
Message: <4bf24f70$1@news.povray.org>
>> some.
Well, so far I've tried two systems:
1. KLogic. Unfortunately, this crashes constantly, and sometimes gives
you THE WRONG ANSWER. As in, I've drawn circuits which are simple enough
that I damned-well *know* the answer being displayed is incorrect.
2. The freebie version of the Xilinx simulation/synthesis tool. Here you
have to type in VHDL as input, and (IIRC), you don't get any kind of
visual representation of the circuit. And once you've designed the
circuit, you have to type in more VHDL to create a test harness. You
can't just click a button that says "please attach a logic probe here",
you have to actually code it all by hand.
I'll have a look at this and see if it works any better...
Date: 18 May 2010 09:11:16
Message: <4bf291f4@news.povray.org>
>> fun.
I didn't say anything about the speed. Some of them clock at hundreds of
MHz... which is why they would excel in applications such as a
customized DSP.
>> do the big clacking pile of relays version of it ;)
Right. Which is why it must be as simple as possible, because I don't
need to dedicate a 20'x24' room to the thing ;) Thankfully memory is
nice and solid-state, nowadays!, no need for ferrite cores, drums, relay
latches or any of that nonesense.
Of course, the relay-based machine may be simplified to the point where
it can't do anything but play tic-tac-toe...
more than space, my biggest concern is power usage. I need to be able to
operate off of a 15-amp breaker without tripping the thing. (That's 15a
@120v, btw... not 240v!
~Mike
Date: 18 May 2010 09:52:01
Message: <4bf29b81@news.povray.org>
> customized DSP.
I was thinking more along the lines of watching a ray-tracer running in
near-realtime, and knowing you couldn't possibly be doing that unless
you'd built the hardware yourself. But yeah, I guess it's not the same.
(It's also presumably not very easy...!)
With the reinforced flooring, and the custom air conditioning system,
and the specialist PSU, and the team of technitions to tend to the
beast's needs? ;-)
It strikes me that if you had a relay without a spring, you could use a
single relay as a kind of mechanical memory.
It also strikes me that you could really easily "cheat" and hide a small
Z80 under one of the relays and fake the whole exercise! :-D
No, you only need some marbles in matchboxes for that. ;-)
Hmm. Most of your current is going to come from the relays held open.
The closed ones won't use any power. I have no idea how much power a
relay uses, but I shouldn't have thought it's that much... Then again,
just how many are you expecting to have? ;-)
Date: 19 May 2010 09:43:02
Message: <4bf3eae6$1@news.povray.org>
>> where it can't do anything but play tic-tac-toe...
Haha. No. Only if you want to do something complicated like have a
genetic algorithm to solve the tic-tac-toe board ;)
Looking at the spec for a small 5v spdt relay (3A current rating) the
coil draws 40ma.
25 would draw 1 amp.
Using the 5v rail of a cheap PC power supply I could fit 50.
Using the 12v (16a @ 12 v) and using a regulator to obtain 5v, I can fit
quite a few more. But, then there is also money.
~Mike
