POV-Ray : Newsgroups : povray.off-topic : Wave energy Server Time
1 Nov 2026 20:37:19 EST (-0500)
  Wave energy (Message 1 to 15 of 15)
Subject: Wave energy
Date: 7 May 2010 14:25:53
Message: <4be45b31$1@news.povray.org>
So I have a small question for the POV-Ray memetic search engine: How
much energy does a wave have?
I actually can't figure this one out. Presumably the energy of a wave is
a function of its amplitude, but I have a feeling frequency is involved
as well. (But I'm not sure in which polarity.)
http://blog.orphi.me.uk/
Subject: Re: Wave energy
Date: 7 May 2010 15:18:04
Message: <4be4676c$1@news.povray.org>
Am 07.05.2010 20:25, schrieb Orchid XP v8:
As the potential gradients are higher, I'd guess high-frequency waves
have a higher energy (given a fixed amplitude) - just like with EM waves.
Date: 10 May 2010 03:02:44
Message: <4be7af94$1@news.povray.org>
> So I have a small question for the POV-Ray memetic search engine: How much
What sort of wave?
> I actually can't figure this one out. Presumably the energy of a wave is a
> function of its amplitude, but I have a feeling frequency is involved as
The energy of a photon is easy to look up, and depends only on the
wavelength (lower wavelength = more energy).  Obviously then you can figure
out how many photons are required for a certain power level, and then how
much time is needed to transfer a given amount of energy.
In electric circuits you can figure out instantaneous power flow by using
P=IV.  Then you can integrate this power over time to get energy.  For
example a sine wave has a known result, because it is so common in AC
circuits, that is where RMS voltage/current comes from.
For water waves, I would imagine you need to look at the potential energy of
the water as it moves up and down, look up Wave Energy on wikipedia - it has
some formulas and example calculations.
Date: 10 May 2010 07:03:54
Message: <4be7e81a@news.povray.org>
  Are you sure the energy does not depend on amplitude? One would think
that you need more energy for a larger amplitude.
Date: 10 May 2010 07:09:19
Message: <4be7e95f@news.povray.org>
> What sort of wave?
Does it make a difference? I thought the properties of waves were fairly
universal.
Or, to put it another way, higher frequency = more energy.
> energy of the water as it moves up and down, look up Wave Energy on
> wikipedia - it has some formulas and example calculations.
Sound waves are what really interest me, but presumably water waves
being mechanical have similar properties...
Date: 10 May 2010 07:41:01
Message: <op.vchmqkuo7bxctx@toad.bredbandsbolaget.se>
In the case of photons, the "amplitude" of the "wave" is just a measure of
how many photons there are. The energy of an individual photon depends
only on its wavelength/frequency.
FE
Date: 10 May 2010 07:43:32
Message: <4be7f164@news.povray.org>
Yes, the formula for energy of a photon only has one variable, wavelength.
> One would think
You do, but that's just because you have more photons, not because each
photon has more energy.
Date: 10 May 2010 07:54:27
Message: <4be7f3f3$1@news.povray.org>
> Sound waves are what really interest me, but presumably water waves being
I guess in water there are really two types of "wave".  The huge waves that
you see on the surface and crashing against the coast moving in 2D are one
type, but the other type is disturbances under the surface that are
transmitted as pressure waves in 3D.  Those are probably more similar to
sound waves.
Wikipedia has several pages about sound and pressure/power:
http://en.wikipedia.org/wiki/Sound
http://en.wikipedia.org/wiki/Sound_power
Date: 10 May 2010 08:04:43
Message: <4be7f65b@news.povray.org>
"Invisible" <voi### [at] devnull> a écrit dans le message de news:
4be7e95f@news.povray.org...
A big difference is that water waves propagation speed depends on wavelength
http://www.exo.net/~pauld/activities/waves/waterwavespeed.html
Marc
Date: 10 May 2010 08:22:40
Message: <4be7fa90$1@news.povray.org>
> that you see on the surface and crashing against the coast moving in 2D
> are one type, but the other type is disturbances under the surface that
> are transmitted as pressure waves in 3D.  Those are probably more
> similar to sound waves.
Waves only "crash" near to the shore, due to the solid seabed
interrupting the wave cycle. (Apparently.) Waves on the surface of a
"deep" (WRT wavelength) body of water do not exhibit this effect.
Date: 10 May 2010 08:23:16
Message: <4be7fab4$1@news.povray.org>
Presumably *all* waves are subject to dispersion, it just depends on
whether or not it's "significant".
Date: 10 May 2010 08:24:26
Message: <4be7fafa$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> a écrit dans le message de news:
4be7e81a@news.povray.org...
>                                                          - Warp
Welcome in a quantic world :)
Marc
Date: 10 May 2010 08:34:19
Message: <4be7fd4b$1@news.povray.org>
4be7fab4$1@news.povray.org...
>> wavelength
Phase velocity is proportional to period...
What has dispersion to do in this case?
Marc
Date: 10 May 2010 12:20:23
Message: <4be83247$1@news.povray.org>
If you mean "amplitude" in the quantum mechanical sense of the word, no. If
you mean "amplitude" in the sense of "strength", then no, all photons are
100% identical and fungible, so they all have the same energy content,
except for the "wavelength" which is controlled by how you're moving
relative to the source etc.  But each photon of a given frequency has the
same energy as any other photon of a given frequency.  A brighter light is
just more photons.
    Ada - the programming language trying to avoid
    you literally shooting yourself in the foot.
Date: 10 May 2010 13:11:27
Message: <4be83e3f$1@news.povray.org>
That's what dispersion *is* - different frequencies propogating at
different speeds.
