POV-Ray : Newsgroups : povray.off-topic : Baffling Server Time
1 Nov 2026 20:33:51 EST (-0500)
  Baffling (Message 1 to 50 of 216)
Goto Latest 50 Messages Next 50 Messages >>>
Subject: Baffling
Date: 26 Apr 2010 04:19:46
Message: <4bd54ca2$1@news.povray.org>
http://www.xkcd.com/732/
This puzzles me too.
I mean, if you're going to force everybody to buy a new TV, new
receiver, new type of disk and a new machine to play it, why it increase
the resolution *significantly*? Why only increase it by a small amount?
I don't understand that.
(And hell, half the equipment and content that says "HD" on it isn't
even full resolution anyway... Why allow half a dozen resolutions when
it would have been far simpler for the designers and less misleading for
the public if they allow only one resolution?)
Hell, when I was at uni ten years ago we had computers exceeding these
resolutions. With Windows NT 4.0, Service Pack 4. Has technology not
moved on since then? It's not like there's any technical challenge to
using a higher resolution, after all...
PS. I am similarly baffled by the current fashion for "widescreen" TVs.
Given that 99.998% of all video content ever created is in 4:3 aspect,
what the hell is the advantage of buying a TV with a 16:9 aspect?? I
don't understand.
Subject: Re: Baffling
Date: 26 Apr 2010 04:32:24
Message: <op.vbrgoas17bxctx@toad.bredbandsbolaget.se>
Cost, both for producing the TV and for producing the content.
Again, cost.
Did you have a 40" computer monitor ten years ago? How much did it cost?
> don't understand.
I take it you have never watched a movie then.
Also, cost. Moving to widescreen -- while maintaining the same diagonal
length -- reduces the panel area.
FE
Date: 26 Apr 2010 04:51:55
Message: <4bd5542b$1@news.povray.org>
>> why not increase the resolution *significantly*?
Producing the content I can understand. It presumably costs more money
to shunt larger volumes of data around...
>> for the public if they allow only one resolution?
> Again, cost.
How is it *cheaper* to design something more complicated?
No. But you would think that making a large monitor with a high
resolution would be much cheaper than making a small monitor with a high
resolution. (That would require a greater dot-pitch.)
>> TVs.
Some movies are widescreen. But by no means all of them. Besides, the
time spent watching movies is utterly dwarfed by the time spent watching
normal TV - which is never widescreen. (Hell, even when the movie is
widescreen, they usually show it in 4:3 aspect anyway.)
Ah. So that's the true reason...
Date: 26 Apr 2010 05:12:32
Message: <op.vbrii5v87bxctx@toad.bredbandsbolaget.se>
On Mon, 26 Apr 2010 10:51:55 +0200, Invisible <voi### [at] devnull> wrote:
>>> Why allow half a dozen resolutions when it would have been far simpler
>>> for the designers and less misleading for the public if they allow
>>  Again, cost.
1. If a TV supported *only* 1080p, any video source you connected to it
would also have to support it.
2. A video-scaling circuit is dirt-cheap compared to the cost of the panel
and the back-light.
3. Calling all those resolutions "HD" lets them make TVs with lower
resolutions and still market them as "HD".
Making a high-resolution panel is expensive. Making a large panel is
expensive. Making a large high-resolution panel is *really* expensive.
Most movies are widescreen. However, most movie producers traditionally
took care to make the movies easily convertible to 4:3 (typically through
Pan&Scan) specifically because TVs used to be in that format.
> Besides, the time spent watching movies is utterly dwarfed by the time
> spent watching normal TV - which is never widescreen.
That may be true for you, but you really need to stop assuming that
everyone in the entire world has the same behavior and preferences as you.
> (Hell, even when the movie is widescreen, they usually show it in 4:3
> aspect anyway.)
Once again, cost. Some networks save money by reusing the same tapes they
have been using for decades. Since those tapes were already prepared for
4:3, that is what you get. Newer movies, and also older movies shown by
less stingy networks, are almost always shown in widescreen.
FE
Date: 26 Apr 2010 05:20:14
Message: <4bd55ace$1@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:4bd54ca2$1@news.povray.org...
Bandwidth. Your LCD is connected to your computer by a 4 foot cable that
carries a single "channel". Now think about the number of channels and the
distances involved in broadcast TV.
I'm with you on this one.
> don't understand.
Movies (on disk).
Date: 26 Apr 2010 05:25:13
Message: <4bd55bf9@news.povray.org>
>>>> simpler for the designers and less misleading for the public if they
>>>  Again, cost.
How about if it supported only SD (which is one resolution) or only HD
(in one resolution)?
Yeah. This is exactly the part I don't like.
>> high resolution. (That would require a greater dot-pitch.)
I thought it's a high dot-pitch which is expensive? (The "resolution" of
the finished item being the area of the panel multiplied by the
dot-pitch.) By that reconing, a large 1080p display would be cheaper
than a small 1080p display, because the dot-pitch is lower.
> through Pan&Scan) specifically because TVs used to be in that format.
OK. Might be true I guess...
Well, I'm only talking about the UK. I don't know what's happening in
other parts of the world, but in the UK everybody's acting like HD is
this Really Big Deal that everybody should be excited about. As far as I
can tell, there isn't really much of a difference.
Similarly, it has now become virtually impossible to buy anything in a
normal aspect ratio; only widescreen TVs and monitors (and even
laptops!) are for sale. And I have no idea why. (What the hell is the
advantage of a widescreen *laptop* for goodness' sake?!)
>> aspect anyway.)
> they have been using for decades. Since those tapes were already
> prepared for 4:3, that is what you get.
OK, fair enough.
Question: Why aren't there any widescreen cinemas yet?
Date: 26 Apr 2010 05:34:51
Message: <4bd55e3b$1@news.povray.org>
My monitor is connected via an analogue (or, if I'm lucky, uncompressed
digital) link. Video signals tend to be highly compressible. Indeed, at
higher resolutions the data may even become *easier* to compress.
But sure, I guess if you're trying to transmit stuff, there is only
finite bandwidth to work with. You'd think all this would be less
problematic for playback from disk though...
On the other hand, greating a succession of slightly higher resolution
platforms gives manufacturers a way to charge you more money as you
constantly upgrade all your equipment. :-P
Date: 26 Apr 2010 05:38:41
Message: <4bd55f21@news.povray.org>
> Producing the content I can understand. It presumably costs more money to
For the same size TV, increased resolution (smaller pixels) is more
expensive for many reasons:
- Bigger backlight needed
- More/bigger driver ICs
- More expensive components due to higher pixel clock rate
- More RAM for frame buffer
- More powerful DSP/CPU for manipulating frame buffer
- More connections to the panel (worse reliability)
- Panel yield reduced due to roughly constant probability of pixel failure
Because not everyone can afford the top of the range model.  It's a well
known economics method to introduce several products with varying
performance and price to get more money overall.
> No. But you would think that making a large monitor with a high resolution
> would be much cheaper than making a small monitor with a high resolution.
No, the cost of panel area outweighs all the things I mentioned above.
Every LCD factory is run at almost 100% capacity, they measure income in $
per square metre, a panel that is twice the size is going to be roughly
twice the cost (plus or minus a bit depending on the factors I mentioned
above).
> Some movies are widescreen. But by no means all of them. Besides, the time
> spent watching movies is utterly dwarfed by the time spent watching normal
Funny how radiotimes.com indicates almost every TV program is broadcast in
widescreen :-)  You need to fix your TV if you are not seeing a widescreen
picture from normal TV.
Date: 26 Apr 2010 05:40:25
Message: <4bd55f89$1@news.povray.org>
WTF?
Date: 26 Apr 2010 05:49:43
Message: <4bd561b7@news.povray.org>
...in other words, the entire reason for multiple resolutions existing
is to extract more money from people.
>> high resolution.
Oh, OK. I assumed the difficulty of manufacturing a higher dot-pitch was
the main problem...
> in widescreen :-)  You need to fix your TV if you are not seeing a
> widescreen picture from normal TV.
I especially love how I have a widescreen TV, but you have to manually
flip between 4:3 and 16:9 aspect. Even though it's connected by a
digital link, so you'd think it could *detect* which kind of signal it's
receiving...
That being the case, it's not entirely easy to tell whether you're
watching a widescreen broadcast, or a normal one with the top cut off.
(Unless of course you configure the TV to show black bars at the side -
but it's my mum's TV, and she always complains when I configure it that
way.)
Date: 26 Apr 2010 05:50:01
Message: <web.4bd560a5e7ce4e796dd25f0b0@news.povray.org>
At risk of entirely misunderstanding the question, all cinemas have shown all
films in 16:9 or wider for almost a hundred years.
Date: 26 Apr 2010 05:52:48
Message: <4bd56270$1@news.povray.org>
Really?
Huh, well, you learn something every day. The picture always looked
fairly square to me...
Date: 26 Apr 2010 05:53:08
Message: <op.vbrkeupl7bxctx@toad.bredbandsbolaget.se>
Then you would ignore the market segment that consists of people that want
something better than SD but cannot (or do not want to) pay the full price
of 1080p.
I am by no means an expert on LCD panel production, but I do not think
there are significant cost savings associated with an excessively large
dot-pitch; certainly not enough to offset the cost of a larger panel.
Making pixels really tiny is difficult/expensive, but making them really
large becomes a matter of diminishing returns.
The issue of whether there is an appreciable difference has been discussed
before, at great length, in this very forum.
> (What the hell is the advantage of a widescreen *laptop* for goodness'
> sake?!)
1. Watching movies on the go.
2. A better match for the aspect ratio of the keyboard.
3. Cost (remember that thing about the diagonal and the surface area).
Are you smoking something, or have you simply never been to a cinema?
Practically all cinemas are widescreen. Heck, they can even adjust the
aspect ratio on the fly.
I have to ask: Is Milton Keynes like one of those little tribal villages
sometimes found deep in some jungle, where technology has not improved for
centuries?
FE
Date: 26 Apr 2010 05:57:17
Message: <4bd5637d$1@news.povray.org>
Am 26.04.2010 11:38, schrieb scott:
... which, to make things worse, does not just have a /linear/ effect on
panel yield, but an /exponential/ one.
Date: 26 Apr 2010 06:00:19
Message: <4bd56433$1@news.povray.org>
Am 26.04.2010 11:49, schrieb Invisible:
The entire reason for HDTV /per se/ is to extract more money from people.
They call it capitalism: The desire to extract more money from people as
the primary driving force for innovation.
Date: 26 Apr 2010 06:04:21
Message: <4bd56525$1@news.povray.org>
Damn. And here I was thinking it was supposed to improve picture quality...
Date: 26 Apr 2010 06:17:41
Message: <4bd56845$1@news.povray.org>
Am 26.04.2010 12:04, schrieb Invisible:
No; that's just a semi-rare collateral effect...
Date: 26 Apr 2010 06:32:58
Message: <4bd56bda$1@news.povray.org>
> ...in other words, the entire reason for multiple resolutions existing is
Of course, why else would any company do anything?
> the main problem...
No, that's technically easy.  Besides pixels can be made orders of
magnitudes smaller than what is needed for TV (computer monitors, cell phone
screens, LCDs for projectors, etc.).
> flip between 4:3 and 16:9 aspect. Even though it's connected by a digital
> receiving...
Don't know about that, I have a widescreen TV and all the TV programs I
watch come in widescreen format, so I never need to adjust anything and it
always looks fine.  Where are you getting 4:3 content from?
> way.)
With 99% certainty anything you are watching from UK TV will be widescreen.
It is very rare anything is broadcast in 4:3, I certainly haven't seen
anything and looking through radiotimes.com I can't find anything either.
Quite often you will see the text and captions on the TV will be formatted
within some "safe" area for 4:3 (so won't use the left/right edges), but the
main feed will be 16:9 format. Like this:
http://img.photobucket.com/albums/v467/jonchoo/954963b2.jpg
Date: 26 Apr 2010 07:23:33
Message: <op.vbrolshlmn4jds@phils>
And lo On Mon, 26 Apr 2010 10:19:45 +0200, Invisible <voi### [at] devnull> did
spake thusly:
> don't understand.
To all those giving an answer of "movies" to this question may I point out
that most aren't 16:9 but are in 21:9 cinema proportions. 16:9 was the
compromise yet now we have the option of purchasing yet another television
at this proportion from Philips.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 26 Apr 2010 07:55:30
Message: <op.vbrp21v6mn4jds@phils>
And lo On Mon, 26 Apr 2010 11:53:08 +0200, Fredrik Eriksson
<fe79}--at--{yahoo}--dot--{com> did spake thusly:
> for centuries?
No that'd be Scotland... ooooo channeling Frankie Boyle there.
Phil Cook
Date: 26 Apr 2010 07:55:47
Message: <4bd57f43$1@news.povray.org>
I don't mind paying money when I actually get something in return.
>> was the main problem...
> phone screens, LCDs for projectors, etc.).
I often wonder why we don't have monitors with 300dpi or 600dpi yet.
Then the text on screen would be nearly print-quality.
(Except that, to this day, changing resolution makes everything come out
too small. How many managers have you seen turn down the resolution to
make the text bigger?)
>> it's receiving...
> it always looks fine.  Where are you getting 4:3 content from?
Even the adverts?
Which channels are you watching?
> widescreen. It is very rare anything is broadcast in 4:3, I certainly
> haven't seen anything and looking through radiotimes.com I can't find
> anything either.
Perhaps I live in a different country or something then? Most of what we
receive doesn't appear to be widescreen.
(Or are you talking about the HD channels? We only receive SD.)
Date: 26 Apr 2010 07:57:59
Message: <4bd57fc7$1@news.povray.org>
> spake thusly:
>> TVs. Given that 99.998% of all video content ever created is in 4:3
>> aspect, what the hell is the advantage of buying a TV with a 16:9
>> aspect?? I don't understand.
> out that most aren't 16:9 but are in 21:9 cinema proportions. 16:9 was
> the compromise yet now we have the option of purchasing yet another
> television at this proportion from Philips.
Well, the monitor I'm watching right now actually has a 8:5 aspect, and
the one at home has (I think) a 11:6 ratio. No idea what that means...
Date: 26 Apr 2010 08:04:18
Message: <4bd58142$1@news.povray.org>
> want something better than SD but cannot (or do not want to) pay the
> full price of 1080p.
I'm of the opinion that "full price 1080p" shouldn't be that expensive
in the first place, and we should all be saving up for 4096p or
something. But I guess that's next year's money draw...
>> sake?!)
OK. If you accept that there is movie content available in widescreen
then that makes sense.
That works. In fact, my (widescreen) laptop is the very first laptop
I've ever seen with a numpad. Usually laptops omit it.
Fair enough.
> for centuries?
Milton Keynes hasn't actually existed for a complete century yet, so...
no. (Although for some strange reason almost nobody seems to have heard
of it or know where it is. And whenever shows or events happen, they
happen in Northampton. Not Milton Keynes. No idea why!)
I did once see a film at Loughborough Cinema [there is only one]. That
was an experience; no surround sound, for a start. It's surprising how
much of a difference that makes!
Date: 26 Apr 2010 08:30:01
Message: <web.4bd586f2e7ce4e796dd25f0b0@news.povray.org>
Lightbulb overhead *ping*!
Are you by any chance still watching the analogue signal? Everything on freeview
that was made within the last 5-10 years will be widescreen, but I seem to
recall that PAL is only 4:3...
Date: 26 Apr 2010 08:38:11
Message: <4bd58933$1@news.povray.org>
>> villages sometimes found deep in some jungle, where technology has not
>> improved for centuries?
Oi! Do ye like hospital food? ;-)
Best Regards,
Date: 26 Apr 2010 08:43:22
Message: <4bd58a6a$1@news.povray.org>
Most people feel the same way, and obviously people selling stuff realise
this too.
> I often wonder why we don't have monitors with 300dpi or 600dpi yet. Then
Because you view a computer monitor from further distance than a book, an
arbitrarily increasing the ppi is a waste of money and electricity.
On the other hand cell-phones, which you often do use much closer, have much
higher resolution displays.  200-300 dpi on high-end phones is normal, for a
computer monitor at normal viewing distances I doubt there would be much
improvement going from 100 -> 300 dpi, and going to 600 dpi would be pretty
much invisible at normal viewing distances.
> too small.
You can change the ppi setting somewhere in windows, but IME some badly
behaved programs don't like it.
> Even the adverts?
Yeh I think so, I would have probably noticed if they weren't.
Just the usual, BBC1-3 and red button, ITV1&4, C4 etc.
No I only get SD too, everything I've seen is widescreen, again check your
favourite listings magazine or website if you don't believe me.
"Most digital broadcasts from the BBC and the other main broadcasters are
now in widescreen format"
http://www.bbc.co.uk/reception/digitaltv/widescreen.shtml
Oh wait, you're not still receiving analogue signal are you?  That might be
different.
Date: 26 Apr 2010 08:47:27
Message: <4bd58b5f$1@news.povray.org>
IIRC they made computer monitors 16:10 rather than 16:9 so that you could
watch a 16:9 movie and have a little space for the GUI whilst still seeing
the film at full size.
Date: 26 Apr 2010 08:49:24
Message: <4bd58bd4@news.povray.org>
> Really?
  I'm beginning to suspect that this is not Andrew, and instead some troll
is posting using his nickname.
  If even TV is not square (it's 4:3), how in the world could you ever
think that movies are square? I don't get it.
  The narrowest aspect ratio used in movies for the past 20+ years has
usually been 1.85:1. The most common aspect ratios for big movies today
is 2.25:1 and even 2.35:1 (that's well over twice as wide as tall).
Date: 26 Apr 2010 08:55:02
Message: <4bd58d26@news.povray.org>
  "Looks fine" is not saying much...
  Well, I'm not saying you are one of those people (and I'm in fact
assuming you aren't), but I have seen *way* too many people who vehemently
deny seeing *anything* wrong *at all* in a 4:3 picture which has been
stretched horizontally to cover the entire 16:9 screen area.
Date: 26 Apr 2010 08:57:49
Message: <4bd58dcd@news.povray.org>
> an arbitrarily increasing the ppi is a waste of money and electricity.
I can see the pixels on my monitor. But yeah, maybe 600dpi would be
overkill. Perhaps just 150 or something?
>> out too small.
Hell, there are programs that ignore you if you change the default
window colours. Or programs that don't like it if Windows is installed
on D: rather than C:. ;-)
>> we receive doesn't appear to be widescreen.
> No I only get SD too, everything I've seen is widescreen.
Mmm, OK. I shall investigate further...
> be different.
I don't *think* we are... I thought we were using Freeview.
(Then again, my grandparents use FreeSat. Their TV physically has a 4:3
aspect [it's an old CRT], and the picture seems to fit natively, so...)
Date: 26 Apr 2010 09:00:30
Message: <4bd58e6e$1@news.povray.org>
This is the best part of widescreen! :-D
You can choose between:
1. Black bars at the side of the screen. (I.e., all that extra screen
area you just paid money for being completely unused.)
2. A stretched image where everybody has elliptical heads.
3. One of the various "zoom" modes which distorts the image non-linearly
to supposedly give a better picture than a linear distortion.
4. Cut the top and/or bottom off the picture to make it fit.
Everybody seems to hate #1, but lots of people apparently see nothing
wrong with #2 or #3. *shudders*
Date: 26 Apr 2010 09:14:19
Message: <4bd591ab$1@news.povray.org>
What dpi is it?  How far away are you from it?
> But yeah, maybe 600dpi would be overkill. Perhaps just 150 or something?
My laptop has a 150 dpi screen.  My desktop monitor is 103 dpi and from
normal viewing at my desk (60 cm) I cannot see any jagged edges from the
pixels (maybe that's just because of the AA settings though).  Maybe the
fact that Windows is not good at scaling has meant that making a 150 or 200
dpi monitor that is used from "desktop" viewing distances would be
impossible to use due to the tiny physical size of the fonts and other GUI
items?
> Hell, there are programs that ignore you if you change the default window
> colours. Or programs that don't like it if Windows is installed on D:
> rather than C:. ;-)
I was running it for a while on my laptop with a non-standard dpi setting.
On the whole Windows and Office was fine, but IIRC my CAD software screwed
up, with some buttons being shifted outside of the window so you couldn't
get to them!
Most stand alone sat/freeview boxes I've seen have an option to output to
4:3 which just crops the left/right edges of the 16:9 signal (I assume if
it's built into a TV it will be set accordingly to match the TV).  This is
why they always put any important information in the central part of the
screen, as they know some people are still chopping the sides off to watch
4:3.
Date: 26 Apr 2010 09:14:48
Message: <4bd591c8@news.povray.org>
  And that's wrong because...?
  I have been thinking about an explanation for that psychological phenomenon
for years, but come up with nothing. It still baffles me.
  Clearly I'm different than 99% of people. The stretching bothers me a
lot, but the black bars on the side not at all. This seems to be the exact
opposite of what those 99% of people feel. But why? I have no idea.
Date: 26 Apr 2010 09:18:43
Message: <4bd592b3@news.povray.org>
Maybe it makes them feel better if everyone else looks fatter on TV :-)
Still interested to know where you're getting your 4:3 TV feed from that
requires one of these "fixes".  Are you using a separate
freeview/cable/satellite box?  That might be configured to 4:3 rather than
16:9?
Date: 26 Apr 2010 09:19:24
Message: <4bd592dc$1@news.povray.org>
It's wrong that I should have to pay extra for a bunch of additional
pixels that I'm never going to use.
However, if I've already paid that money, I'd rather see black bars than
squashed heads.
Join the club.
Date: 26 Apr 2010 09:19:35
Message: <op.vbrty7bpmn4jds@phils>
And lo On Mon, 26 Apr 2010 14:28:34 +0200, Bill Pragnell
<bil### [at] hotmailcom> did spake thusly:
> freeview
> to
Nope not even that, the analogue widescreen broadcasts are anamorphic so
despite being 4:3 they expand to 16:9. Even prior to Freeview most films
on my 4:3 CRT were black-barred top and bottom. I'm trying to think of any
current broadcasts in 4:3... the older items obviously particularly those
 from the USA; oh and one channel on Freeview - Viva
Phil Cook
Date: 26 Apr 2010 09:25:21
Message: <4bd59441$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> a écrit dans le message de groupe de discussion
: 4bd58d26@news.povray.org...
Truly, lots of people are blind to wrong image ratios. Some years ago the
photos in my university's facebook had been stretched horizontally, turning
hundreds of students into flattened toads. Nobody found that odd. Recently,
I saw a framed print of a painting where the image had been squeezed because
the original image's ratio was wider than the frame's ratio. Why bother to
crop the image or find the right frame? Making movies in widescreen is a
real waste: filmmakers could film everything in 1.37:1 as in the old times,
stretch them to 2.39:1 and few people would notice.
G.
Date: 26 Apr 2010 09:27:24
Message: <4bd594bc@news.povray.org>
> turning hundreds of students into flattened toads. Nobody found that odd.
> Recently, I saw a framed print of a painting where the image had been
> squeezed because the original image's ratio was wider than the frame's
> ratio. Why bother to crop the image or find the right frame? Making movies
> in widescreen is a real waste: filmmakers could film everything in 1.37:1
> as in the old times, stretch them to 2.39:1 and few people would notice.
I think it's because we are used to often seeing things at an angle during
everyday life, so our brain is quite good at automatically correcting aspect
ratios for us.
Date: 26 Apr 2010 09:28:16
Message: <4bd594f0$1@news.povray.org>
No idea what the dpi rating is. It's 1400x900 and it's probably about
30cm tall or something? And I'm sitting maybr 40cm or so away from it.
(I don't have anything to actually measure it with.)
Yeah, AA hides a multitude of sins. ;-) Curiosly, they don't seem to
have invented AA for mouse pointers yet. (Except in computer games...)
> Maybe the
> 200 dpi monitor that is used from "desktop" viewing distances would be
> GUI items?
Plausible.
> setting. On the whole Windows and Office was fine, but IIRC my CAD
> software screwed up, with some buttons being shifted outside of the
> window so you couldn't get to them!
Haha! And I bet that CAD software was the most expensive thing on the
whole PC, by a mile... ;-)
>> 4:3 aspect [it's an old CRT], and the picture seems to fit natively,
>> so...)
> to 4:3 which just crops the left/right edges of the 16:9 signal (I
> assume if it's built into a TV it will be set accordingly to match the
> TV).  This is why they always put any important information in the
> central part of the screen, as they know some people are still chopping
> the sides off to watch 4:3.
Maybe that's it then. Maybe the reason I still see all broadcast signals
in 4:3 aspect is because the receiver is resizing them?
Date: 26 Apr 2010 09:32:37
Message: <4bd595f5@news.povray.org>
Yeh, I think it is about 10x the price of the laptop itself :-)
I would definitely check the settings on the receiver.
Date: 26 Apr 2010 09:37:42
Message: <4bd59726$1@news.povray.org>
Only 10x? Bargin!
Oh, wait - what laptop do you have? I'm thinking about the £300 laptops
that *I* usually work with...
>> signals in 4:3 aspect is because the receiver is resizing them?
Mkay...
Date: 26 Apr 2010 09:49:39
Message: <4bd599f3@news.povray.org>
Some HP one, with Intel T9600 CPU and nVidia FX770M, it's quite nifty and
surprisingly the battery lasts for 4 or 5 hours if you're not doing anything
particularly CPU or GPU intensive.
> I'm thinking about the £300 laptops that *I* usually work with...
I think mine was about 1500 GBP, although I think our IT guy has some scam
going with the supplier, because his prices always seem to be way more than
I find them for on other websites ;-)
Date: 26 Apr 2010 09:57:46
Message: <4bd59bda$1@news.povray.org>
> and surprisingly the battery lasts for 4 or 5 hours if you're not doing
> anything particularly CPU or GPU intensive.
Yeah, I'm still quite surprised at how well the batteries on my laptop
last. It's always been my experience that the battery specs on the
packet are nonesense and the battery *actually* lasts about 20 minutes.
But my current laptop _really will_ run for over an hour without needing
charge.
(And, since it's the first laptop I've seen with a *working* glidepad,
you can ACTUALLY USE IT ON YOUR LAP! Amazing...)
> I think mine was about 1500 GBP.
I'm glad I was already sitting down. :-)
Man, 10x that... that's expensive! Hell, it's almost worth stealing the
laptop just for the software that's stored on it! ;-)
Date: 26 Apr 2010 10:25:40
Message: <4bd5a264$1@news.povray.org>
Yeh good luck with that, assuming you managed to get past the hard drive
encryption somehow, the software won't run without a license.  It picks up
the license from the network (you can "borrow" it for up to 14 days if you
want), so you'd either need to hack my VPN account too, or get physical
access to our site somehow.  Anyway, once we knew it was stolen I'd
definitely notice if that machine had picked up the license, and then I'd
ask IT to block it :-)
Easier to just download the software from bitTorrent along with a crack...
Date: 26 Apr 2010 11:03:24
Message: <4bd5ab3c$1@news.povray.org>
Partly bandwidth related. The UHF/VHF frequency space has only a certain
amount of bandwidth per channel. Now, while a HD broadcast in 1080p at
an "acceptable" compression ratio might fit nicely within the allotted
bandwidth for a channel, doubling the horizontal and vertical
resolution, for example quadruples the number of pixels on the screen.
Eventually, the video would need to be compressed to the point where the
image would be nothing more than a macroblock-fest.
We're in a transitional period right now. Give it time. What really irks
me is the way the cable company has been handling content. They have
allotted no fewer than 4 channels per local station, which is, IMO
completely unnecessary, and (if the channels aren't just aliases, and
some aren't: they're analog variants!) it's a horrible waste of
bandwidth. I can understand simulcasting the analog variant for those
who do not have HD equipment, but do not want to rent a box.
In both the digital flat panel and the CRT's case there is some
technical challenge to higher resolutions: Eventually the frequencies
involved get so high that capacitance becomes VERY important, and
circuit design becomes exceptionally tricky, to the point where traces
at certain distances from each other (whether on the same layer, or
overlapped in different layers of the board) will essentially act as a
low-pass filter killing the signal.
> don't understand.
Movies.
Going back to why movies went widescreen (they used to be displayed at a
square ratio, even!) has to do with how the human visual field works, we
have a wider angle of view on the horizontal axis than we do on the
vertical.
~Mike
Date: 26 Apr 2010 11:06:38
Message: <4bd5abfe$1@news.povray.org>
Most of what's created today 16:9 or some other widescreen format.  Older
stuff?  Maybe not "99.998%", but certainly a majority of the content ever
created by mankind is likely a 4:3 aspect.  Except movies.
> don't understand.
If you watch more modern content, then you can better utilize the space
for a larger system.  Me, I use my 16:9 projection system mostly for
watching HDTV and movies, so 99.998% of what I watch is actually 16:9.
Jim
Date: 26 Apr 2010 11:13:06
Message: <4bd5ad82$1@news.povray.org>
Quadrupling the number of pixels doesn't necessarily mean that the
*compressed* signal takes more bandwidth. I'm sure I'm not the first
person to notice that using higher resolutions tends to make the video
more compressible. (Although, sure, I imagine there's a limit to how far
you can feasibly go.)
Then again, since we replaced our old CRT with a shiny new LCD, suddenly
I notice that just about *everything* on TV has DCT artifacts all over
it. (I guess the CRT was too blurry to show this.) It's quite annoying.
Date: 26 Apr 2010 11:15:28
Message: <4bd5ae10$1@news.povray.org>
Ooo, here's a random thought: Do you think there will ever be a day when
the Internet becomes fast enough to watch TV-quality video in realtime?
When do you think that day will be?
Date: 26 Apr 2010 11:19:09
Message: <4bd5aeed$1@news.povray.org>
> receiving...
Heck, the device producing the signal even does this:
http://en.wikipedia.org/wiki/Widescreen_signaling
There is a slight issue, of course with HD signals, since they're only
intended for the 16:9 aspect ratio, if a program was originally intended
for the 4:3 ratio, it will be "pillar-boxed", but the signal is still
16:9, so you must manually change the TV's widescreen mode if you want
to fill the screen.
> way.)
I don't care for the stretching, though when viewing 4:3 full-screen on
my TV it's not as severe as some, the only reason I do stretch it,
though is because my TV is an old-school CRT projector and prone to
burn-in. If it weren't for that, I'd display 4:3 in its native format.
Perhaps your mother has the same concerns?
~Mike
Date: 26 Apr 2010 11:23:29
Message: <op.vbrzpfg37bxctx@toad.bredbandsbolaget.se>
About five years ago.
Are you sure you are not living in the jungle?
FE
