POV-Ray : Newsgroups : povray.off-topic : Baffling Server Time
7 Mar 2026 21:06:31 EST (-0500)
  Baffling (Message 1 to 10 of 216)
Subject: Baffling
Date: 26 Apr 2010 04:19:46
Message: <4bd54ca2$1@news.povray.org>
http://www.xkcd.com/732/
This puzzles me too.
I mean, if you're going to force everybody to buy a new TV, new
receiver, new type of disk and a new machine to play it, why it increase
the resolution *significantly*? Why only increase it by a small amount?
I don't understand that.
(And hell, half the equipment and content that says "HD" on it isn't
even full resolution anyway... Why allow half a dozen resolutions when
it would have been far simpler for the designers and less misleading for
the public if they allow only one resolution?)
Hell, when I was at uni ten years ago we had computers exceeding these
resolutions. With Windows NT 4.0, Service Pack 4. Has technology not
moved on since then? It's not like there's any technical challenge to
using a higher resolution, after all...
PS. I am similarly baffled by the current fashion for "widescreen" TVs.
Given that 99.998% of all video content ever created is in 4:3 aspect,
what the hell is the advantage of buying a TV with a 16:9 aspect?? I
don't understand.
Subject: Re: Baffling
Date: 26 Apr 2010 04:32:24
Message: <op.vbrgoas17bxctx@toad.bredbandsbolaget.se>
Cost, both for producing the TV and for producing the content.
Again, cost.
Did you have a 40" computer monitor ten years ago? How much did it cost?
> don't understand.
I take it you have never watched a movie then.
Also, cost. Moving to widescreen -- while maintaining the same diagonal
length -- reduces the panel area.
FE
Date: 26 Apr 2010 04:51:55
Message: <4bd5542b$1@news.povray.org>
>> why not increase the resolution *significantly*?
Producing the content I can understand. It presumably costs more money
to shunt larger volumes of data around...
>> for the public if they allow only one resolution?
> Again, cost.
How is it *cheaper* to design something more complicated?
No. But you would think that making a large monitor with a high
resolution would be much cheaper than making a small monitor with a high
resolution. (That would require a greater dot-pitch.)
>> TVs.
Some movies are widescreen. But by no means all of them. Besides, the
time spent watching movies is utterly dwarfed by the time spent watching
normal TV - which is never widescreen. (Hell, even when the movie is
widescreen, they usually show it in 4:3 aspect anyway.)
Ah. So that's the true reason...
Date: 26 Apr 2010 05:12:32
Message: <op.vbrii5v87bxctx@toad.bredbandsbolaget.se>
On Mon, 26 Apr 2010 10:51:55 +0200, Invisible <voi### [at] devnull> wrote:
>>> Why allow half a dozen resolutions when it would have been far simpler
>>> for the designers and less misleading for the public if they allow
>>  Again, cost.
1. If a TV supported *only* 1080p, any video source you connected to it
would also have to support it.
2. A video-scaling circuit is dirt-cheap compared to the cost of the panel
and the back-light.
3. Calling all those resolutions "HD" lets them make TVs with lower
resolutions and still market them as "HD".
Making a high-resolution panel is expensive. Making a large panel is
expensive. Making a large high-resolution panel is *really* expensive.
Most movies are widescreen. However, most movie producers traditionally
took care to make the movies easily convertible to 4:3 (typically through
Pan&Scan) specifically because TVs used to be in that format.
> Besides, the time spent watching movies is utterly dwarfed by the time
> spent watching normal TV - which is never widescreen.
That may be true for you, but you really need to stop assuming that
everyone in the entire world has the same behavior and preferences as you.
> (Hell, even when the movie is widescreen, they usually show it in 4:3
> aspect anyway.)
Once again, cost. Some networks save money by reusing the same tapes they
have been using for decades. Since those tapes were already prepared for
4:3, that is what you get. Newer movies, and also older movies shown by
less stingy networks, are almost always shown in widescreen.
FE
Date: 26 Apr 2010 05:20:14
Message: <4bd55ace$1@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:4bd54ca2$1@news.povray.org...
Bandwidth. Your LCD is connected to your computer by a 4 foot cable that
carries a single "channel". Now think about the number of channels and the
distances involved in broadcast TV.
I'm with you on this one.
> don't understand.
Movies (on disk).
Date: 26 Apr 2010 05:25:13
Message: <4bd55bf9@news.povray.org>
>>>> simpler for the designers and less misleading for the public if they
>>>  Again, cost.
How about if it supported only SD (which is one resolution) or only HD
(in one resolution)?
Yeah. This is exactly the part I don't like.
>> high resolution. (That would require a greater dot-pitch.)
I thought it's a high dot-pitch which is expensive? (The "resolution" of
the finished item being the area of the panel multiplied by the
dot-pitch.) By that reconing, a large 1080p display would be cheaper
than a small 1080p display, because the dot-pitch is lower.
> through Pan&Scan) specifically because TVs used to be in that format.
OK. Might be true I guess...
Well, I'm only talking about the UK. I don't know what's happening in
other parts of the world, but in the UK everybody's acting like HD is
this Really Big Deal that everybody should be excited about. As far as I
can tell, there isn't really much of a difference.
Similarly, it has now become virtually impossible to buy anything in a
normal aspect ratio; only widescreen TVs and monitors (and even
laptops!) are for sale. And I have no idea why. (What the hell is the
advantage of a widescreen *laptop* for goodness' sake?!)
>> aspect anyway.)
> they have been using for decades. Since those tapes were already
> prepared for 4:3, that is what you get.
OK, fair enough.
Question: Why aren't there any widescreen cinemas yet?
Date: 26 Apr 2010 05:34:51
Message: <4bd55e3b$1@news.povray.org>
My monitor is connected via an analogue (or, if I'm lucky, uncompressed
digital) link. Video signals tend to be highly compressible. Indeed, at
higher resolutions the data may even become *easier* to compress.
But sure, I guess if you're trying to transmit stuff, there is only
finite bandwidth to work with. You'd think all this would be less
problematic for playback from disk though...
On the other hand, greating a succession of slightly higher resolution
platforms gives manufacturers a way to charge you more money as you
constantly upgrade all your equipment. :-P
Date: 26 Apr 2010 05:38:41
Message: <4bd55f21@news.povray.org>
> Producing the content I can understand. It presumably costs more money to
For the same size TV, increased resolution (smaller pixels) is more
expensive for many reasons:
- Bigger backlight needed
- More/bigger driver ICs
- More expensive components due to higher pixel clock rate
- More RAM for frame buffer
- More powerful DSP/CPU for manipulating frame buffer
- More connections to the panel (worse reliability)
- Panel yield reduced due to roughly constant probability of pixel failure
Because not everyone can afford the top of the range model.  It's a well
known economics method to introduce several products with varying
performance and price to get more money overall.
> No. But you would think that making a large monitor with a high resolution
> would be much cheaper than making a small monitor with a high resolution.
No, the cost of panel area outweighs all the things I mentioned above.
Every LCD factory is run at almost 100% capacity, they measure income in $
per square metre, a panel that is twice the size is going to be roughly
twice the cost (plus or minus a bit depending on the factors I mentioned
above).
> Some movies are widescreen. But by no means all of them. Besides, the time
> spent watching movies is utterly dwarfed by the time spent watching normal
Funny how radiotimes.com indicates almost every TV program is broadcast in
widescreen :-)  You need to fix your TV if you are not seeing a widescreen
picture from normal TV.
Date: 26 Apr 2010 05:40:25
Message: <4bd55f89$1@news.povray.org>
WTF?
Date: 26 Apr 2010 05:49:43
Message: <4bd561b7@news.povray.org>
...in other words, the entire reason for multiple resolutions existing
is to extract more money from people.
>> high resolution.
Oh, OK. I assumed the difficulty of manufacturing a higher dot-pitch was
the main problem...
> in widescreen :-)  You need to fix your TV if you are not seeing a
> widescreen picture from normal TV.
I especially love how I have a widescreen TV, but you have to manually
flip between 4:3 and 16:9 aspect. Even though it's connected by a
digital link, so you'd think it could *detect* which kind of signal it's
receiving...
That being the case, it's not entirely easy to tell whether you're
watching a widescreen broadcast, or a normal one with the top cut off.
(Unless of course you configure the TV to show black bars at the side -
but it's my mum's TV, and she always complains when I configure it that
way.)
