POV-Ray : Newsgroups : povray.off-topic : Another philosophical religious thought... Server Time
18 Oct 2026 00:52:21 EDT (-0400)
  Another philosophical religious thought... (Message 1 to 35 of 35)
Subject: Another philosophical religious thought...
Date: 18 Apr 2010 22:43:48
Message: <4bcbc364$1@news.povray.org>
Let's consider that JHVH is the first mover, the effect with no cause,
because He has been around forever and was never created.
Now let's consider that JHVH created Man in His own image.
Doesn't that discredit the Watchmaker's argument?
I mean, if God modeled humans after God, then God has eyes, right? And if
God has eyes (and all those other irreducibly complex systems) the God
didn't create those systems.
So doesn't
1) God has always existed
2) God made Man in his Image
3) Man has Irreducibly Complex Systems
imply that irreducibly complex systems have always existed and didn't need
to be designed?
   Linux: Now bringing the quality and usability of
   open source desktop apps to your personal electronics.
Subject: Re: Another philosophical religious thought...
Date: 19 Apr 2010 06:11:29
Message: <4bcc2c51$1@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:4bcbc364$1@news.povray.org...
Not necessarily. If God has eyes (two, I assume, in the front of his head),
can I sneak up behind it? Wouldn't that limit his omniscience? And wouldn't
only having a couple of hundered billion neurons severely limit its
knowledge and ability?
Obviously, it doesn't make sense if one replaces the "image" with "physical
analogue". In fact, I don't think any major sects believe that God is
physical in the sense we come to understand it, so the whole "in his image"
business needs a deeper understanding (if you are religious) or is simply
just another nonsense (if not). Either way, the premise you start with is
not valid.
Date: 19 Apr 2010 12:32:38
Message: <4bcc85a6$1@news.povray.org>
Maybe not any more. Certainly when he was walking around the Garden looking
for Adam and Eve he was. And he wasn't omniscient or he wouldn't have been
calling out trying to find them. :-)
> so the whole "in his image" business needs a deeper understanding
Certainly. But then, if we aren't like him physically, and we weren't
created in his moral image, and we are still incapable of understanding how
he thinks, in what sense are we his image?
Date: 19 Apr 2010 13:39:37
Message: <4bcc9559$1@news.povray.org>
Darren New escreveu:
> if God has eyes (and all those other irreducibly complex systems) the
> God didn't create those systems.
Man was created in His own image, but you don't go telling eyes of
statues are the same as yours. ;)
a game sig: http://tinyurl.com/d3rxz9
Date: 19 Apr 2010 15:13:09
Message: <4bccab45@news.povray.org>
> So doesn't
> need to be designed?
Hmm. If you follow from your starting premise, maybe. The problem of
course that (3) is in error anyway. You can *get* irreducible systems,
without either needing them to be designed *or* previously existing.
Basically, lets say that:
GTG did something specific and unique, and so did GTT, but you can have
mutations, like GTGG, or GTTT, GTGT, or even GTTG, which work like their
original versions. So, lets say 's' counts as a stop. What you do is
start with GTTs, make a copy GTTsGTTs, then you mutate it a few
different ways:
GTTsGTGs
GTTsGTTGs
GGTsGTTs
The last one of those copies is defective, but you still have a working
copy anyway, and it allows for later getting: GTGTsGTTs But, the GTGs
version would be "irreducible", once other related genes become
dependent on that form, causing the GTGTs and GTGGs, etc. versions to
"break" the system.
The trick here is, if you get several of these tweaks, which are
inter-reliant, the *intermediary* versions may work with a larger number
of variations and errors than the final version. At some point though,
you are likely to run into dependency issues, where your GTGs, or
variation **must** have that combination it in, to work with the other
gene some place else, which underwent a similar change, and in the
process produced new behaviors/functions.
Of thousands of genes involving body plan, segmentation, symmetry, limb
formation, etc., all of them are derived from a relatives *small* number
of codes. In some cases the codes are nearly identical for the gene
that, say, makes fingers grow, but the transcription and developmental
code is different, producing a new pattern of growth. Other cases "both"
the transcription/development code *and* the control genes differ, but
they are still identifiably variations on existing genes, that do
similar things. Any irreducibility seems to come from a duplicate copy
changing, and linking up with other changes, to produce a unique result,
then undergoing subtractions, which fail to disable the new effect, but
which render reversal to an earlier form impossible.
Given that, they neither could have previously existed, nor is adding a
designer anything other than adding an unnecessary complication, unless
you can present grounds to show that one is doing it.
void main () {
   If Schrödingers_cat is alive or version > 98 {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 19 Apr 2010 15:54:04
Message: <4bccb4dc$1@news.povray.org>
Certainly. And even if you found an irreducible system that you could
*prove* could *not* have evolved on its own, that still doesn't point to the
necessity of a God.
After all, we already have systems like that. Indeed, the whole
"watchmaker's" argument is predicated on the fact that the watch is indeed
irreducible enough to need to be designed. It doesn't follow from that that
God created watches.
Date: 19 Apr 2010 16:32:00
Message: <4bccbdc0$1@news.povray.org>
> the necessity of a God.
> indeed irreducible enough to need to be designed. It doesn't follow from
> that that God created watches.
you guys would enjoy God of War. :)
Date: 19 Apr 2010 16:48:07
Message: <4bccc187$1@news.povray.org>
http://www.escapistmagazine.com/videos/view/zero-punctuation/1595-God-of-War-III
Date: 19 Apr 2010 18:39:14
Message: <4bccdb92@news.povray.org>
Unless making man in God's image means that man was gifted with free
will, a very common interpretation.
John
Date: 19 Apr 2010 18:42:05
Message: <4bccdc3d$1@news.povray.org>
> looking for Adam and Eve he was.
Unless that is an analogy using the words that come closest to what God
was doing.
> And he wasn't omniscient or he wouldn't have been calling out trying
 > to find them. :-)
By that reasoning, math teachers don't know what two plus two is.
> how he thinks, in what sense are we his image?
We *were* created in His moral image, that of sinless perfection.  But
all of us have blown it through sin.
John
Date: 19 Apr 2010 18:47:16
Message: <4bccdd74$1@news.povray.org>
> different ways:
> GTTsGTGs
> GTTsGTTGs
> GGTsGTTs
> "break" the system.
So in essence you are arguing that any irreducible complexity was
preceded by reducible complexity.
John
Date: 19 Apr 2010 19:26:44
Message: <4bcce6b4@news.povray.org>
Obviously not.
Clearly it was sinful to disobey God, to realize that God was lying, and to
do both of these things without knowing they were sinful. If we were morally
sinlessly perfect, we wouldn't have original sin, now would we?
If we were created morally, sinlessly perfect, why would ever single human
being to ever live be sinful?  That's like saying "every single human being
stands over three meters tall, except those who are shorter, which is all of
them."
Also, obviously not. Having eaten from the tree of knowledge, it is clear
that sins are not heritable. Punishments from God, perhaps, but not sins.
That's clearly a bad interpretation as well, unless you are saying that the
serpent was also gifted with free will and hence created in God's image, and
hence also sinlessly morally perfect, which seems to be pushing the analogy.
Date: 19 Apr 2010 19:28:19
Message: <4bcce713@news.povray.org>
Darren New wrote:
> So doesn't [that]
Even if it did, I thought the problem was with irreducibly complex
systems coming into existence without being designed?  I don't think
many proponents of irreducible complexity would have a problem with
irreducibly complex eternal things.
Date: 19 Apr 2010 20:24:24
Message: <4bccf438$1@news.povray.org>
Kevin Wampler wrote:
> Darren New wrote:
>> So doesn't [that]
This is what I'm saying:
Assuming that "made man in God's image" is interpreted in a straightforward
way. If so, God didn't design the eye.  God didn't design himself - he was
always here. And he copied his eye for use with humans. Where did the design
of the eye come from? It has always been here. No need for a designer at
all.  :-)
Clearly God is an irreducibly complex system that wasn't designed. Any
irreducible thing patterned on God thus came into existence without being
designed, just like parents don't "design" their children's eyes.
Was just a silly passing thought.
> I don't think
I'm not sure what you mean by "external" there, especially w.r.t. God. Plus,
"we know it was designed" doesn't imply "it must have been God" either.
Date: 19 Apr 2010 20:30:01
Message: <web.4bccf578cc2a99fe7b8c8aa30@news.povray.org>
haha, very fun.  Even though I couldn't manage to get more than 50% of it.  man,
that dude should be rapping...
Yes, it's pretty much like that, except the parody review doesn't account for
the mindblowing audio-visual artwork backing up the frantic pure arcade action
with puzzles in between.  It's impact is huge in setting the mood and I'd say
this is the best take on greek mythology in mainstream entertainment in ages.
Hollywood's recent Clash of the Titans pales by comparison, not just to the
artistry, but even the lame-o script.
The theme of revenge may be quite tiresome, but they've put quite an imaginative
spin to dozens of elements of the myths, binding them together in rather amusing
ways.  I've replayed the first 2 games just now, eager to get my hands on a
PS3...
I've seen people saying they play the game in very easy mode just to
effortlessly enjoy the ride. :)
except to PS3... :))
Date: 19 Apr 2010 22:02:53
Message: <4bcd0b4d$1@news.povray.org>
I find of the games he and I have both played, I liked what he liked and
disliked what he disliked for the same reasons. They're serious reviews, but
he tries to tell you the bad stuff without telling you the good stuff for
the most part.
Check out his review of Batman, or SaintsRow or Prince of Persia. There are
a few he likes. :-)
I usually wind up going thru most games on easy, and even switching into
godmode at some point, just because I find it pointless to bash my head
against the same boss more than five or six times.  The nice thing about the
XBox is when they don't have god mode, they do seem to tone the game down to
where easy is beatable without being tedious.
(Most recent, trying 4 or 5 times to get thru the endgame of Batman,
actually killing the bad guy, only to get wiped out by his giant corpse
sliding across the floor and smashing me against the wall. :-)
I'd love to go thru Serious Sam on god mode, just to look at the levels.
The first couple of Thief games were cool because on the easy mode you
couldn't even get to the whole level. There were walls where there would be
doors on the harder levels, which was kind of cool when I realized that.
Date: 19 Apr 2010 23:50:14
Message: <4bcd2476$1@news.povray.org>
> straightforward way. If so, God didn't design the eye.  God didn't
> design himself - he was always here. And he copied his eye for use with
> humans. Where did the design of the eye come from? It has always been
> here. No need for a designer at all.  :-)
> being designed, just like parents don't "design" their children's eyes.
Ahh, I did not understand that was the point you were making.  Of course
even so then there's still cephalopod eyes and such that would need
actual design.  Unless of course you hold that God would just "know" how
such eyes were made and wouldn't need to actually "design" them, which
lease you right into the rather odd (and sort of useless imho) question
as to what degree an all-knowing entity could perform something we would
call "design".
On a related issue, I wonder just how common that particular
interpretation of "made in God's image" is.  It seems pretty difficult
to defend against even simple counter-arguments.  Not that that means
it's necessarily unpopular though.
>> I don't think many proponents of irreducible complexity would have a
>> problem with irreducibly complex eternal things.
> Plus, "we know it was designed" doesn't imply "it must have been God"
> either.
By "eternal things" I meant God, or an eternal universe or multiverse
etc.  Mostly I was pointing out that I had thought the irreducible
complexity argument only applied to the development of complexity and
didn't relate to complexity that has "always been there".  At the time I
thought you were making a different point than it appears you were.
I was never making the argument the "designed" implies "designed by
God".  As far as I'm aware this implications isn't generally (well,
generally publicly) endorsed by irreducible complexity proponents.  This
was made quite explicit as part of the whole (largely unsuccessful)
attempt to avoid the separation of church and state issues that would
otherwise keep intelligent design out of public textbooks as I
understand it.
Date: 20 Apr 2010 00:02:46
Message: <4bcd2766@news.povray.org>
> actual design.
Nah. They're obviously inferior to the eyes God made in His own image.
Otherwise, God's eyes wouldn't be the best, and God would thus be imperfect,
right? Hence, they're merely God's eyes with imperfections added in. ;-)
> call "design".
Yeah. Pretty much any absolute in this field leads to logical contradictions.
I would think it's actually pretty common. Depictions of God, Jesus, Angels,
etc all wind up being human-like. Certainly in the religions where the gods
have dog-heads or something it gets mentioned often enough you'd think you'd
notice.
Actually, yeah, it is, but they tried to cover it with a snow-job. :-)
I've been amused several times by pointing out that naturally-evolved aliens
could have designed irreducibly-complex humans just as easily as God could,
and been answered with "But there's no evidence of aliens!!"
Date: 20 Apr 2010 01:06:51
Message: <4bcd366b$1@news.povray.org>
> contradictions.
I'm not sure it's so much contradictions in this particular case as it
is the generally difficulty linguistically describing (or even
comprehending) something that's supposed to be infinite in the sense
that God is.  Overall though, yeah, I agree that it's generally pretty
difficult to precisely define something like that without causing some
logical problem or another.
I think the same principal is actually true of physics as well (for
instance as it applies to the origin of the universe), although in that
case there's the advantage of having a more or less well-defined way of
definitively detecting such contradictions, which probably makes them
easier to remove.
> Angels, etc all wind up being human-like. Certainly in the religions
> where the gods have dog-heads or something it gets mentioned often
> enough you'd think you'd notice.
It's mostly that I've never the description be so, well, anatomical.  I
mean, how many people would really argue that God has a functioning
digestive tract?  It's possible people would I suppose, but I've rarely
even heard the view the human similarity to God was physical at all, let
alone that it extended to the function and structure of individual organs.
Date: 20 Apr 2010 03:00:24
Message: <op.vbf8ebbtufxv4h@go-dynamite>
> So doesn't
"Image" does not mean "clone". An image is not a copy, but rather
something that _looks_like_ something else. For example photographs, and
statues. Neither a photograph nor a statue can see with their eyes.
Effectively an image uses less dimensions than the original. So we are 3
or 4 dimensional images of the multidimensional Creator. We don't even
know what other dimensions are like, scientists are still speculating
about nth dimensions. So our DNA is not necessarily clone of God's DNA,
but a method of reproducing and image representing only 3 dimensions of
features of God.
BTW, a multidimensional being would need only one multidimensional eye to
be able to see all around, even if it is on the front of the head :)
Since we do not know everything about all dimensions that exist, we cannot
know how the universe started because we do not have enough information.
Heh. Maybe someday someone will write an AI program that comes to the
conclusion that humans don't exist!
-Nekar Xenos-
Date: 20 Apr 2010 04:25:01
Message: <web.4bcd63c0cc2a99fef3872a2f0@news.povray.org>
> the most part.
Truly threw away the good stuff:
http://ps3media.ign.com/ps3/image/article/107/1076575/god-of-war-iii-20100310054652777.jpg
http://ps3media.ign.com/ps3/image/article/107/1076575/god-of-war-iii-20100310054646278.jpg
http://ps3media.ign.com/ps3/image/article/107/1076575/god-of-war-iii-20100310054637903.jpg
http://ps3media.ign.com/ps3/image/article/107/1076575/god-of-war-iii-20100310054725807.jpg
http://208.53.138.111/soundtracks/god-of-war-ii-ost/cofjnrbthc/04-colossus-of-rhodes.mp3
http://208.53.138.111/soundtracks/god-of-war-ii-ost/cbucjcdtpn/11-exploring-the-isle.mp3
http://208.53.138.111/soundtracks/god-of-war-ii-ost/lurqbwlurv/12-the-isle-of-creation.mp3
http://208.53.138.111/soundtracks/god-of-war-ii-ost/hptfiuchdw/18-crossing-the-lowlands.mp3
http://208.53.138.111/soundtracks/god-of-war-original-soundtrack/qzedfjrkwa/15-the-great-sword-bridge-of-athena.mp3
http://208.53.138.111/soundtracks/god-of-war-original-soundtrack/jwrqjsfzag/11-athens-rooftops-fighting.mp3
http://208.53.138.111/soundtracks/god-of-war-original-soundtrack/lbtsxmnvxc/21-the-architect-s-mysteries.mp3
In any case, my point for bringing up God of War in a kinda off-topic manner is
because it features a mortal bringing death to the Gods of Olympus and the end
of myths.  I interpret it as the ultimate allegory for atheism, nihilism and
hedonism.  Like Kratos himself puts it:  "I have lived in the shadows of the
Gods for long enough!"  And they say videogames are just mindless fun. :P
anyway, I saw it as kinda fitting here, I guess...
Date: 20 Apr 2010 09:22:50
Message: <4BCDAAA7.4050207@gmail.com>
>> course even so then there's still cephalopod eyes and such that would
>> need actual design.
> imperfect, right? Hence, they're merely God's eyes with imperfections
> added in. ;-)
You mean imperfections like letting the light pass through a layer of
vasculature and horizontal cells before reaching the photosensitive cells?
IIRC the octopus eye is much better designed than a human one and many a
vertebrate eye is more sensitive than ours but that is probably not the
point you are making.
Date: 20 Apr 2010 11:11:34
Message: <4bcdc426$1@news.povray.org>
I think he focuses on gameplay and leaves media to last. But those are some
sweet snaps. :-)
I suppose, yes.
Date: 20 Apr 2010 11:16:16
Message: <4bcdc540$1@news.povray.org>
>> contradictions.
> that God is.
Yet oddly enough, many will be happy to tell you exactly what this infinite
incomprehensible entity wants from you personally. ;-)
> easier to remove.
Certainly. Plus the ability to say "We don't know yet, or maybe never."
I'm certainly taking it to extremes, yes. :-)
> I mean, how many people would really argue that God has a functioning
You never heard the argument over whether angels have navels and such?
I think the general idea is that God is human-like, until it became
scientifically obvious that was absurd.  I mean, most every other God is
human-like (certainly all the major ones), God has a face (as in, "look upon
the face of God") and a back to be turned, etc...
Date: 20 Apr 2010 11:17:59
Message: <4bcdc5a7@news.povray.org>
>>> need actual design.
>> added in. ;-)
Yes, exactly.
... so to speak.
> and many a
Right.
Altho "Mr. Deity" had a funny line...
Skeptic: "If you're trying to use intelligent design to reveal yourself, why
would you put a blind spot in the eye?"
Deity: "Where else would I put a blind spot?"
Date: 20 Apr 2010 11:21:07
Message: <4bcdc663$1@news.povray.org>
But God *can* see with his eyes. Perfectly, at that. So in what sense did
God have to design our eyes, if he already has perfect ones to base things on?
> to be able to see all around, even if it is on the front of the head :)
It depends how many dimensions he wants to look into. :-)
> cannot know how the universe started because we do not have enough
> information.
Yet, oddly enough, there are huge numbers of people who will tell you it is
all carefully documented!  Imagine that!
Not yet, but they already made one that concluded everyone is famous. They
were programming it with encyclopedias and watching its deductions, and it
eventually deduced that everyone is famous.
Date: 20 Apr 2010 11:32:58
Message: <4BCDC927.5080309@gmail.com>
> They were programming it with encyclopedias and watching its deductions,
> and it eventually deduced that everyone is famous.
Didn't know that story. I do remember the one that deduced the existence
of rice pudding and income tax.
Date: 20 Apr 2010 16:12:13
Message: <4bce0a9d$1@news.povray.org>
Actually, think someone wrote as fairly simple gear program that
torpedoed that too. What is necessary is that change between versions be
*possible*, and that the thing in question produce such *copy versions*.
Watches need watchmakers, not because they are irreducibly complex, but
because watches do not copy themselves, with or without modifications.
If they did, they wouldn't need watchmakers either.
void main () {
   else
Date: 20 Apr 2010 16:26:27
Message: <4bce0df3$1@news.povray.org>
>> have mutations, like GTGG, or GTTT, GTGT, or even GTTG, which work
>> like their original versions. So, lets say 's' counts as a stop. What
>> you do is start with GTTs, make a copy GTTsGTTs, then you mutate it a
>> few different ways:
>> GTTsGTGs
>> GTTsGTTGs
>> GGTsGTTs
>> working copy anyway, and it allows for later getting: GTGTsGTTs But,
>> the GTGs version would be "irreducible", once other related genes
>> become dependent on that form, causing the GTGTs and GTGGs, etc.
>> versions to "break" the system.
>> number of variations and errors than the final version. At some point
>> though, you are likely to run into dependency issues, where your GTGs,
>> or variation **must** have that combination it in, to work with the
>> other gene some place else, which underwent a similar change, and in
>> the process produced new behaviors/functions.
>> limb formation, etc., all of them are derived from a relatives *small*
>> number of codes. In some cases the codes are nearly identical for the
>> gene that, say, makes fingers grow, but the transcription and
>> developmental code is different, producing a new pattern of growth.
>> Other cases "both" the transcription/development code *and* the
>> control genes differ, but they are still identifiably variations on
>> existing genes, that do similar things. Any irreducibility seems to
>> come from a duplicate copy changing, and linking up with other
>> changes, to produce a unique result, then undergoing subtractions,
>> which fail to disable the new effect, but which render reversal to an
> Regards,
> John
Not my argument, its the argument of biologists, and has been both shown
to work in simulation *and* within some cases of actual DNA, where
identification of the genes involved show that they are modified
versions of existing ones (and, I believe, in a few cases, new changes
have been identified, in the state of 'reducible complexity', where its
not to hard to see where minor changes would make it irreducible). But,
yes. That is how it seems to work, and there is no evidence that it
did/had to work any other way.
Oh, and, just for an odd bit, I mentioned fingers. Turns out that
fingers grow from the middle out. There are two control genes in place,
one determines when the pattern ends, and a second reacts to that
deactivation by forming a "thumb". If you get an error in the code, you
end up with more or less fingers, or not having a thumb at all,
depending on which one changed. This is why the most common result in
such errors is extra, or less, fingers, but the thumb is almost always
still there. Now *most* people imagine that they all grow at once, or
that they grow starting with the thumb, or pinkie, then run across in
sequence.
Another odd bit is being observed in lizards. Some are in progress of
becoming snake like. Seems that the gene involved is responsible for
forming ribs. It doesn't shut off correctly, so just keeps making more
and more ribs, which elongates the body. This seems to also muck up limb
formation, reducing the structures from which those form to a point
where they nearly disappear. But, you will still find snakes with
vestigial limbs, under the skin.
Its really quite interesting to read about how it all works, and which
types of genes are involved, as well as, in some cases, how small the
changes need to be. Though, most of them are not visible stuff. Like
having two copies of a gene to produce saliva, and having one of them
mutate to produce venom instead. Or quirks in eyes, like the fact that
*some* rare humans end up with an extra copy, and an error, which result
in them seeing 4 colors, not the normal 3, a trait that birds have.
void main () {
   else
Date: 20 Apr 2010 16:34:09
Message: <4bce0fc1$1@news.povray.org>
>> with humans. Where did the design of the eye come from? It has always
>> been here. No need for a designer at all. :-)
> call "design".
Bah. Its all quite pointless. The truth has already been presented at
http://www.mrdeity.com/ God, you see, is a lazy, vindictive, bastards,
and decided to go with a self-design genetic algorithm, instead of going
into all the effort of actually designing anything. He then went on with
his plan anyway, as though it all had been designed, only didn't bargain
for the fact that his creations would be smart enough to come up with
science and discover that it all worked without him having actually done
anything to rate being worshiped. lol
I just had to by their "E=M^r.d^e'+y/d'd 1t" T-Shirt. ;)
void main () {
   else
Date: 20 Apr 2010 16:48:24
Message: <4bce1318$1@news.povray.org>
> torpedoed that too.
Well, yes, but that's using actual science and logic. If you want to accept
the accuracy of science, you don't need philosophy to shoot down most religions.
Date: 20 Apr 2010 16:49:35
Message: <4BCE135A.4040604@gmail.com>
> torpedoed that too.
you mean the one in http://www.youtube.com/watch?v=mcAq9bmCeR0?
perhaps also good to mention is that watches, like all technology, did
actually evolve. If you look at one of the latest mechanical watched
made, you can not understand how someone could design that from scratch.
In fact you would need to retrace part of the history to understand that.
Better, if you would try to make that watch or something similar from
scratch (i.e. while you would also need to build the equipment to make
the parts) you would probably fail.
Why I find this fascinating? because to build something so refined you
need to make tools and you need to make the tools to make the tools.
Etc. And for some of the technology needed, the skills have been lost
and left no fossils. Which gives an interesting twist to the watchmaker
argument.
Date: 21 Apr 2010 14:59:50
Message: <op.vbi0d0igufxv4h@xena>
>> and statues. Neither a photograph nor a statue can see with their eyes.
> did God have to design our eyes, if he already has perfect ones to base
> things on?
I am not saying He can't see with His eyes. I am saying He might have n
dimensional eyes as well that aren't visible in our 3 dimensions.
Hmm. Well if He is omnipotent, He could look anyway he wanted to and maybe
he just likes that specific form. Also the eyes are the most beautiful
asexual part of the human body...
>> information.
> is all carefully documented!  Imagine that!
I believe that the Bible was meant for everyone. It would have been
confusing to the people of that time if God had revealed science as well.
Apparently today only about 10-15% of all people are interested in
science, so it really doesn't make much sense to go into all that
scientific stuff. From the view of a normal observer the sun rises in the
east and sets in the west. We know it's the earth that's actually turning
on it's own axis, but we still call it sunrise... :-)
Was that before or after Facebook? :)
-Nekar Xenos-
"The spoon is not real"
Date: 21 Apr 2010 16:58:44
Message: <4bcf6704$1@news.povray.org>
>> torpedoed that too.
> accept the accuracy of science, you don't need philosophy to shoot down
> most religions.
Funny. Philosophy was once a branch of science, or the other way around,
until someone came up with the unfortunate point that, "Science tends to
reflect what seems to actually happen, while the rest of this stuff,
well... doesn't." lol
void main () {
   else
Date: 21 Apr 2010 17:02:13
Message: <4bcf67d5$1@news.povray.org>
>> torpedoed that too.
>> What is necessary is that change between versions be *possible*, and
>> that the thing in question produce such *copy versions*. Watches need
>> watchmakers, not because they are irreducibly complex, but because
>> watches do not copy themselves, with or without modifications. If they
> argument.
Well, that is true too. After all, it would be damn hard to find the
"in-between" forms, i.e., fossil record, for the transition from candle
clocks to water clocks, or water clocks to hour glasses (though that may
be a bit easier), and its *very* unclear how you got from either of
those to spring driven ones, never mind ones with the same gears as the
spring driven ones, but a little battery and electric motor pushing the
gears. So, yeah, you get some similar things happening in technology
too, even *with* design.
void main () {
   else
