Actually, one place I think C++ style templates beat out generics is in this:
In MS's simple game libraries, there's a class called GameComponent.
It inherits from IUpdatable, IDrawable, and IMumble, each of which provides
the declaration of one of the main routines in a game (update, draw, and
initialize, respectively).
Now, if I wanted (and I do) to make a collection of things that act like
GameComponent objects but aren't necessarily game components, I don't think
I can do that in C#. I would have to have a collection parameterized on all
three of those interfaces. GameComponent supports a bunch of things that i
might not want to have to support, but I can't make a collection that'll let
me add "anything with those three routines, including GameComponent."
I think this is something that Google's Go did better, if I understand it.
C++ templates don't have that problem, but that's because you don't compile
them separately, so what would normally have to be a runtime check gets done
at compile time.
In any case, it's rather annoying. :-) I might have to figure out how to
patch up MS's samples to also host a collection of game components as well
as the scene-activation/deactivation they do.
Yes, we're traveling together,
but to different destinations.
> this:
As I've written before, AFAIK these are two entirely unrelated
technologies that do totally different things.
> provides the declaration of one of the main routines in a game (update,
> draw, and initialize, respectively).
> think I can do that in C#. I would have to have a collection
> parameterized on all three of those interfaces. GameComponent supports a
> bunch of things that i might not want to have to support, but I can't
> make a collection that'll let me add "anything with those three
Heh, just use a language that has first-class functions, and store a
collection of functions. ;-)
Who are you and what have you done to our friend Darren?
(I know, I know, very old joke. But I just *had* to.)
> at compile time.
I wouldn't say it's that simple with C++ templates either.
You can write a template function which takes an object which "behaves like
a GameComponent" and does things to it ok. However, making a collection (data
container) is a slightly different issue.
If all the objects in the container are of the exact same type, then it's
possible and trivial. Problems start if, in the situation you describe, you
would want to store objects of different types in the container (even if they
all behave like a GameComponent).
You could store *pointers* to the objects in your container, but then you
would end up with the same problem as in C# (if I understood correctly): You
would have to decide the type of the pointer (which has to be the same for
all the container elements).
Am 13.04.2010 00:41, schrieb Darren New:
> this:
From the little I could find ad-hoc on the internet, there seems to be
an interface IGameComponent, so probably all you have to do is make sure
that all classes you want to store in that thing implement
IGameComponent, and use an IGameComponent container.
That's what interfaces are for, after all.
Invisible wrote:
>> in this:
Yep.
Except I want objects, and not just functions. They all have state, and
(worse) they tend to keep pointers to each other. The gridplane needs to
remember how big you want the grid, and it also needs to know where the
camera is so it can draw itself, for example. The guy in the maze needs to
know where the camera is, needs the maze structure, needs the reference to
the gamepad, etc.
> to know where the camera is, needs the maze structure, needs the
> reference to the gamepad, etc.
It wasn't an entirely serious suggestion. (Although you could probably
make it work. Just have the functions point to the state you want them
to mutate...)
IGameComponent implements the "Initialize" method.
IDrawable implements the "Draw" method.
IUpdatable implements the "Update" method.
GameComponent inherits IGameComponent, IDrawable, IUpdatable.
There's no way to make a "collection of objects that implement
IGameComponent, IDrawable, and IUpdatable" as far as I know.
Yeah, and it would have been nice if IGameComponent included most or all of
the methods that GameComponent implements.
Heh.
That's a point I hadn't considered, yes.
Actually, I think that clued me in a bit. They *are* all of type "object". ;-)
So I could just have a list of objects, and when I get an update,
(dynamic)-cast each element to a IUpdatable and invoke that if it works;
when I get a draw, cast each to an IDrawable and invoke that if it works, etc.
Ugly, but it'll do the trick, I think.
I still don't want to implement all the other mechanics going on there, and
I *do* want to implement somewhat different mechanics to make things more
self-contained. (As it stands, for example, there's no good place to "add
yourself to the list" during initialization. The object that is creating you
has to add you to the list of objects it knows about, which is inconvenient
in some ways.)
Anyway, maybe I'll grope thru the brand new 4.0 release and see what they
have there. They really changing a bunch of this sort of stuff around each
release, while leaving the basic underlying drawing calls alone, so maybe
they realized people need more support for the kind of problem I'm trying to
solve.
> "object". ;-)
> works, etc.
Ah yes, ye olde "upcast everything to Object" antipattern. :-D
> to mutate...)
We already have that. We call them "objects". ;-)
No, seriously, what do you think a pointer to an array of closures all
referencing the same variable is?
I suppose you could subclass a collection of IGameComponents
and add run-time type checks to only allow adding objects which
also implement IDrawable and IUpdatable.
Invisible wrote:
>> "object". ;-)
>> works; when I get a draw, cast each to an IDrawable and invoke that if
>> it works, etc.
Well, it gives me the advantage that I could use the same container as a
"service provider." So as soon as you create something that inherits from
a specific interface, you can also retrieve that thing from other
components. This should work out better with what I'm trying to do, which
is more a scene manager (opening screen, start menu, options menu, game,
high-score list, cutscenes, etc) than a single-screen game. The services
manager that comes with XNA is tied to the overall game, meaning you
couldn't have (say) different gamepad managers or different cameras for the
different sections.
But yeah, it would be a generic bag'o'objects, which is certainly not the
best way of doing things.
http://msdn.microsoft.com/en-us/library/microsoft.xna.framework.gameservicecontainer.getservice.aspx
Yeah. I think I'm just going to make it an array of objects, and only act on
the ones that have the right routines defined.
Unfortunately, GameComponent also implements a whole bunch of stuff that
isn't in the interfaces, like LoadContent (for loading textures and such
whenever the screen resolution changes) and UpdateOrder (for determining
what order to update the components in).
I think I'll just do it myself. The stuff that's already there isn't that
sophisticated, and the promise of lots of people building standard
components apparently didn't materialize because MS never released the
point-and-click "designer" part that would let you build games out of
components the way you build Windows apps out of widgets.
Invisible <voi### [at] dev null> wrote:
> > "object". ;-)
> > works, etc.
Yeah, that kind of OO programming has always been considered bad design.
If C# offered multiple inheritance (I don't know if it does), then you
could inherit all the objects you are using from GameComponent and your
own "base class", which is what the container then contains.
(Of course this solution wouldn't help if you have to store objects
which have been eg. instantiated by the library framework itself because
those would not have been inherited from your "base class".)
Am 13.04.2010 22:46, schrieb Warp:
I guess the typical C# approach to this type of problem would be wrapper
classes, which IIRC are not too difficult to write in C#. Such wrappers
could then just implement a common interface you intend to support.
Actually, in this case, it kind of makes sense. You want to call draw() on
things with a draw() function, call initialize() on things with an
initialize() function, etc. Basic duck typing.
Only via interfaces. Much like Java in that respect.
> then you
Then everything would be of type GameComponent, and that wouldn't really fix
that I wanted to use both GameComponents and my own stuff. :-)
In other words, I wanted a generic list that would hold both GameComponents
that other people wrote that I don't have the source to, as well as my own
components that have the same routines but a different base class.
Oh. Yes, right, that's the problem. Other people are writing those
components. That's what makes them "components." :-)
Altho I found another sample project that the documentation makes it look
like it's using the same framework I want to use (same class names, layouts,
etc), as well as talking about using custom GameComponents as part of it, so
I need to take time to dig into that source and see if they changed the
framework to invoke the right routines of a GameComponent as needed.
I really can't understand what would be the problem in supporting
full-fledged multiple inheritance.
If your answer contains the term "diamond inheritance", then forbid
diamond inheritance, not multiple inheritance.
(Could this be, perhaps, related to garbage collection? It makes GC a lot
more complicated if references don't always point to the beginning of the
allocated memory block?)
If you add multiple inheritance to a language where every class inherits
from a common base class (Object), every time you multiple-inherit you're
getting a diamond.
> getting a diamond.
Then don't make every class inherit from a common base class. Interfaces
don't, so why should classes?
If you really want must have classes inherit from Object, then simply
allow interfaces to have member variables and function implementations.
Then you'll have full-fledged multiple inheritance without diamond
inheritance.
Complexity, perhaps.
Also, remember the CIL is designed to support multiple languages. Granted,
you're going to have trouble accessing objects from COBOL, but it's likely
that MI would just make it that much more difficult. There's already kludgey
work-arounds for (e.g.) getting to properties and indexers from languages
that don't have properties.
Impossible if everything inherits from Object. :-)
That's certainly part of it, but you don't need to support multiple
inheritance in the same way C++ does it. Eiffel has multiple inheritance,
garbage collection, and O(1) virtual dispatch. (That last would probably be
quite difficult if you didn't compile everything at the same time, of course.)
C# allows you to inherit from multiple interfaces that define the same
method names and distinguish between them at compile time and runtime.
(I.e., you can already have a Dog::Run interface and a Thread::Run interface
and invoke them that way and have different implementations.) So it's not
just a problem with the metadata and naming. (Eiffel has a different
solution to this problem.)
Some of the rules of the language are based on superclasses. If you throw an
object, it has to descend from Exceptions. A class with value semantics has
to descend from "Values" or something like that. A delegate (like an OO
function pointer) has to descend from Delegate. Etc. Maybe that's part of
the problem.
But really, I don't think there are any obvious technical problems that
couldn't be solved with enough work.
Because then you can put routines on that common base class that are common
to every class, like ToString() and Equals() and HashCode() and such.
> inheritance.
That certainly sounds like a good idea to me. :-)
Of course, the way it works now is that an interface doesn't actually change
what's in the class. It's more a promise that the class implements a
particular set of routines. So it's not unlike a pure abstract class. If you
already implement a routine called Run, whether you inherit from Runnable
doesn't change what's in your class, only what's in your metadata. So adding
that feature isn't as much of a no-brainer as it might otherwise be.
On the other hand, maybe it wouldn't be a bad idea to have inheriting from
an interface actually insert code into your class as necessary. It would
certainly be a trivial way to make that work in C# at least, if not in other
languages based on the CIL.
Where have you found multiple inheritance particularly useful in C++? Eiffel
uses it all the time to good effect in its data structures, but I've never
really seen anything in C++ that used it, in part maybe because of the way
it's implemented in C++ with classes nested inside other classes and such
and not being able to inherit from basic types.
I think that a class for which it doesn't make any sense to have something
like "ToString()" it would be bad design to force it to have it after all.
I wonder if it would make garbage collection more complicated because now
you can have references pointing to the middle of an object rather than the
beginning (and it may be the *only* reference pointing to that object, so
the object must not be collected as long as this reference exists, but it
may be more complicated for the GC engine to know this).
Wherever implementing multiple interfaces (or a base class and one or
more interfaces) is useful in any OO language, in cases where it would
actually be useful if the "interface" methods could have default
implementations, or if it would be useful if the interface provided
auxiliary methods for the derived class to use.
The problem with "interfaces" is that they are not *helpful* at all.
The don't offer any functionality, any default implementations or any
data. These "interfaces" could often become a lot more helpful if they
actually offered something for the derived class so that it doesn't have
to implement everything from scratch every time.
I'm not saying that every single program I have written (or even a
significant amount of them) uses multiple inheritance, but it has been
useful sometimes.
As I have mentioned before, you can cast an object pointer to an
incompatible type assuming that:
1) Both the source and destination types have a virtual table (in C++ it's
created by making at least one member function virtual; usually at least the
destructor should be in these cases).
2) The actual object to which this pointer is pointing to has been
multiple-inherited from both the source and destination types (even if
by a very long inheritance chain).
The dynamic cast checks at runtime whether the casting is ok or not
(if it isn't, it returns a null pointer). If the object is of a type
which has been multiple-inherited from both, the dynamic cast will return
a pointer which will point to the destination type part inside the object.
Curiously, the code which performs the cast doesn't need to know that
the multiple-inherited class even exists or what it looks like, and the
cast will still work properly.
I wonder if Eiffel supports this as well.
I think there's a reasonable "ToString()" for every class. There aren't many
routines in Object, but the ones there are pretty universal. "What type am
I?" "What code defines this type?" "What's my address?" Stuff like that.
In the CIL, I haven't memorized exactly what's there, and some stuff like
that might be in other libraries. But it's usually pretty universal.
For something managed, I think that would be the wrong way to implement MI.
It's still just one object, even if it inherits data and code from multiple
classes. For example, Python has MI and doesn't have pointers into the
middle of objects.
You could also do it as a sort of "automatic delegation", where each of the
multiple parent classes is represented as a separate object on the heap, for
example, and the child class delegates all the non-overridden calls to the
parent class. In this case, you'd have no significant overhead if the parent
class contributed only code (as the JIT would optimize out the additional
redirection on first invocation). You might be able to also jit-compile the
multiple classes and rearrange their code to use different offsets for the
instance variables when you load the CIL code for a class that has multiple
parents, for example.
The only reason C++ carries pointers to the middle of objects (as far as I
can tell) is that they can't rewrite the object code to use different
offsets in the child class compared to the parent class, and of course
because it can since there's no memory compaction.
So the "mix in" sort of inheritance. OK.
That would definitely be useful, yes. Maybe a later version will add it.
Probably right after the folks working on Java do. ;-)
Right. I'm not sure what that had to do with what I was saying.
I was trying to say that Eiffel holds only one pointer to any given object,
and that points to the start of the instance. This way, Eiffel gets simpler
GC. It also does multiple inheritance in fairly complex ways, and has an
efficient dispatch to handle it (i.e., no run-time lookups up the
inheritance chain).
I believe the mechanism relies on knowing at compile time what every class
in the system will be. You don't get the O(1) lookup in Eiffel if you don't
have the source to all the classes you inherit from when you compile the
class. You might not even get it if you don't have the source code for those
classes when you compile the callers, but I'm not sure.
Eiffel lets you cast up and down the heirarchy. All methods are semantically
virtual (even if the compiler optimizes them to direct jumps), so the fact
that you're casting up and down doesn't make it "invalid". You can't cast a
reference to an object to a type that isn't in that object's parent class
heirarchy.
There is one class called "ALL" that everyone inherits from. There is one
class called "NONE" that inherits from everyone, and which has only one
instance, called "Null". :-) So NULL can cast to any type, and any type can
cast to "ALL" (which serves as Object).
Oh, and it's definitely helpful to have a class to which everything else can
be cast. Imagine C if you didn't have the functionality of void*.
> middle of objects.
That sounds like it would be somewhat inefficient. If the pointer always
points to the beginning of the object, then it would always need to resolve
the offset to the members it wants every time it wants to access them
(because in a multiple-inherited object the members of the base class you
want do not necessarily start from the beginning of the object the pointer
is pointing to, but could start from anywhere).
> parent class.
That sounds like you would need several steps of indirection in order
to access a base class member using a derived class pointer. And checks
for this would need to be done for *all* accesses, even in situations where
there's no inheritance at all (because the code which tries to access the
object through the pointer cannot know if the object it was given was a
derived object or not, without always checking).
It's more efficient when code which handles objects of a certain type
doesn't need to perform any checks to see if the object is really of that
precise type, or whether it's some inherited type. From the point of view
of that code the object looks exactly like if it was exactly of that
precise type (all the member offsets are always the same) regardless of
what the actual type of the object is.
(Things like virtual inheritance can complicate this a bit, though.)
Well, the Java people added their crippled version of templates to the
language regardless of all the arguments why templates are bad, so maybe
there's hope that MI will also be added, regardless of all the arguments
why it's bad.
(It has always amused me how in the dawn of Java people constantly
preached how Java was like "C++ done right", yet it seems to lack most
things which are *good* and/or useful in C++, like RAII, destructors,
typedefs, enums, templates, multiple inheritance, handling objects by
value, operator overloading and whatnot.)
It's useful mostly if you have some way of casting back to the original
type.
Nothing. Not everything has to be a direct answer to what has been written.
It's chatter.
You mean it doesn't support precompiled libraries? (Why does that seem to
be so common with "higher-level" languages?)
> heirarchy.
Does that mean "no"?
Note that in the case I was talking about you are not casting only up or
only down in the hierarchy. You are actually casting down and then up in one
go (in a multiple inheritance situation), without seeing any of the
intermediate classes directly.
> type.
Exactly. In languages where everything comes from Object, they're usually
either dynamically typed or they have the equivalent of dynamic_cast<>.
Otherwise, it wouldn't really be useful. Handy when you want to do
something like "Print this array of objects with that string as the format
specifier" a la printf.
>> middle of objects.
Yep. Python is very dynamic. You can, for example, turn
xyz.pdq = 5
into a function call on xyz that passes the string "pdq" as the first
argument and 5 as the second. It's not supposed to be efficient. It's
supposed to be expressive. :-)
>> parent class.
Yep. Either that or, as I said, have the JIT do it the first time.
> And checks
Well, what I meant was that if you have Alpha::Hello() and Beta::There() and
you create a Gamma that inherits from both, you could actually copy the code
of Alpha::Hello and Beta::There into Gamma, adjusting the offsets of local
variables as you go. With clever vtable layout, you could have Alpha::Hello
and Gamma::Hello at the same offset in the vtable, and the same with
Beta:There and Gamma::There. (That's what Meyer invented for Eiffel.)
Yes. But that's not really the problem. The problem is that it's *machine*
code you're dealing with in C++, where all the information about what local
variables you're using has been lost. In the CIL, I have no trouble taking
a method and making every reference to "the first member variable" and
changing it to "the third member variable". And then you JIT that and you
get equally efficient code.
> why it's bad.
Well, not templates as such. Nothing near as useful. Just generics, using
the same awful C++ syntax. :-)
Yep. Altho I never heard it as "C++ done right", but usually "C++ done
better." :-)
> It's chatter.
OK. Just checking. :-)
It does, but I think you need more than just the object code in there. Kind
of like the way C# is "precompiled" I guess. I'm not sure of the actual
implementation details.
And it's not like C++ supports precompiled templates, either. :-)
>> heirarchy.
I wasn't 100% sure what the "this" was.
Oh. Honestly, I'm not so up on Eiffel I could answer that without looking it
up. But I would suspect not. I mean, if you have Gamma inherit from Alpha
and Beta, and you have a variable declared as Beta and you want to assign it
to a variable of type Alpha, while you could get Gamma to do that, I don't
think you could compile that without first casting the Beta to a Gamma or
something. I really don't know, honestly.
JIT-compiling can't help if the *same* code has to handle objects of
different types.
> > And checks
Wouldn't that be difficult to do if Alpha and Beta are precompiled?
> > why it's bad.
That's why I said "crippled version of templates".
Not to create new code (obviously), but you can precompile explicit
instantiations of template code into a library. If the user is expected
to use only those specific types with the library, then you don't actually
have to provide any code. (You lose the flexibility of templates from the
user's point of view, but you still have the flexiblity from the point of
view of the library developer.)
> >> heirarchy.
You have two completely unrelated classes A and B (ie. they don't inherit
from each other in any way, or have anything in common), and you can do this:
void foo(A* aPtr)
B* bPtr = dynamic_cast<B*>(aPtr);
if(bPtr)
The dynamic_cast will succeed if the object pointed by aPtr is in actuality
of a type which has been multiple-inherited from A and B (even if by a very
long inheritance chain). The foo() function doesn't need to know anything
about that class in question, and can eg. be precompiled into a library.
> different types.
I'm not sure that's true.
To machine code? Yes. That's why I said I thought Eiffel had a hard time
with that. (Doing that optimization in Eiffel takes minutes, while a quicky
test compile takes a second or two.)
In CIL? No, not that difficult, because you know what the instructions
*mean* in the CIL. Rearranging the local variables inside a class compiled
down to CIL isn't difficult.
>>> why it's bad.
In all honesty, it's a crippled version of generics, let alone templates.
They didn't even change the class file format to support it. All they did is
add sugar to do the casting from object back to the real type without you
having to type it.
That's what I thought you meant. I know you can't do it with a non-dynamic
cast in Eiffel, but I don't remember if you can do that in one step with a
dynamic cast. In all honesty, I would expect not. Meyer isn't that sort of
person. :-)
I can see where that could be handy, and even moreso if it weren't an
explicit dynamic cast. (I.e., if you could just pass aPtr into a function
expecting a bPtr and have it work automagically if the actual type inherited
from both.)
> think I can do that in C#. I would have to have a collection parameterized
If you cannot (or don't want to) derive your custom class(es) from
GameComponent then the common base class will be System.Object. You then
have to make a collection of these if you want to store both GameComponent
and your custom class, eg:
List<Object> myList;
foreach( Object o in myList )
if( o is IUpdatable )
(o as IUpdatable).Update();
Yeh, I think the XNA management classes are only meant to be simple ones to
get you started, most things I've read advocate replacing the whole
GameComponent system with your own (usually based on "screens" and adding
components to each "screen").
That was the conclusion I came to.
> to get you started, most things I've read advocate replacing the whole
> adding components to each "screen").
Yes, I'm taking their samples and making them reusable now. It seems the
whole "component" idea that was touted in XNA2 kind of never really
materialized in XNA3. Now "components" in their samples are more like
"screen management component" and "audio management component" rather than
"make the camera bob when you walk" component or "explosion component".
Linux: Now bringing the quality and usability of
open source desktop apps to your personal electronics.
