POV-Ray : Newsgroups : povray.off-topic : This is what I like pov-ray for Server Time
30 Jul 2026 15:30:47 EDT (-0400)
  This is what I like pov-ray for (Message 1 to 10 of 15)
Subject: This is what I like pov-ray for
Date: 3 Apr 2010 14:39:02
Message: <4bb78b46$1@news.povray.org>
http://meatfighter.com/labyrinth/
It's not my code or idea or anything. But the ability to play with
algorithms like this and then output SDL instead of pixels is I think much
better than having to write the ray-tracer yourself just cause you have a
good idea for a picture. :-)
I like the whole randomly-generated maze bit too. :-)
   Yes, we're traveling together,
   but to different destinations.
Subject: Re: This is what I like pov-ray for
Date: 5 Apr 2010 06:46:56
Message: <4bb9bfa0$1@news.povray.org>
Am 03.04.2010 20:39, schrieb Darren New:
> much better than having to write the ray-tracer yourself just cause you
> have a good idea for a picture. :-)
I wonder whether it would be possible to write a POV-Ray patch to
implement a "repeating CSG" object type, repeating a set of objects /ad
infinitum/ in one, two or three directions (while still retaining the
possibility of placing individual non-repeating objects, which seems
reasonably difficult to me with the "infinity box" approach). Ideally
with some pattern parameter to pick one out of multiple object sets for
each "cell"...
Date: 5 Apr 2010 10:19:31
Message: <4bb9f173@news.povray.org>
Le 05/04/2010 12:46, clipka nous fit lire :
> each "cell"...
First question: what would be the space filling pattern ?
The cubic system comes first to mind, but there is a few other (where
are cristallographers when you need them ?)
Short of the system to fill the space, it might just be an issue of
having a "csg" object to hold your repeated construction (inside a unit
sphere ? rather than a unit cube ?) to translate on the fly the ray
intersection's computation (whenever the ray would hit a sphere, a
transformation (translation) is done to the ray to perform the children
intersection, children assumed to be at origin)
Caveat: all_intersection method should be limited to a depth, or we are
going to have issue.
Hint: intersection with planes might be enough to restrict the
repetition amongst various dimension.
Nevertheless, a 1D & 2D repetitions addition might be welcome for
computation's time. Both infinity, or 0 to infinity is also some
options, I would prefere only both infinity.
(and default repetion in 1D to be along X, 2D: X,Y)
How would you name them ?
clipka1D, clipka2D, clipka3D ?
CubicClosePacking (face centered cubic: ABCABC hexagonal of 12 spheres)
HexagonalClosePacking (ABAB alternance, 12 spheres)
CubeTiling (classical x,y,z cubic repetition)
? (derivative for 1D/2D/3D ?)
Date: 5 Apr 2010 12:19:58
Message: <4bba0dae$1@news.povray.org>
Am 05.04.2010 16:19, schrieb Le_Forgeron:
Any and all periodic space tiling in 2D or 3D cartesian space can be
projected to an equivalent square/cubic tiling simply by applying affine
transformations and choosing suitable tiles.
Thus, all you'll really need for parameterization - besides the set of
objects to repeat - is a set of up to 3 vectors (depending on whether
you want to repeat along a line, a plane, or in 3D space) to specify the
- possibly skewed - axes (and periods) of a suitable periodic tiling
scheme. (Note that your set of objects might in itself have to duplicate
certain substructures already.)
Whatever the repeated object's bounding box, I'd suggest.
That depends on implementation: If the actual handling would be done by
object code, you're perfectly right; if it would be handled by tracing
code, all_intersections could be left untouched (but care would still
need to be taken to prevent endless iterations where.
Of course! :-P
Then again, a syntax like
   union {
     repeat {
       [ VECTOR [, VECTOR [, VECTOR ] ] ]
       [ max_recursion FLOAT ]
would have the benefit of not adding any new keywords ;-).
Date: 5 Apr 2010 14:08:06
Message: <4bba2706$1@news.povray.org>
> Of course! :-P
Hey, Warp got his POV-Ray keyword, why not you?
Date: 5 Apr 2010 15:03:43
Message: <4bba340f$1@news.povray.org>
Le 05/04/2010 18:20, clipka nous fit lire :
Adding a keyword is not difficult, and would avoid confusion of the
final users. (if you use the same keyword all over, we will end up with:
"a rose is a rose is a rose is a rose..." which are nice but painful to
understand)
repeat is currently used in warp, so it might be best to avoid it.
And it should be a name, which "repeat" is not.
due to mathematical background about infinity, what about:
aleph1, aleph2 & aleph3 ?
(well, strictly, the first one would be aleph0, but the number might be
clearer as the dimension... or not, aleph0/1/2 might be fine too)
duplicate ?
replica ?
I'm not sure the transformation from 3D filling to cubic would be
obvious (and you might need holes on some places, and it might be better
to code it once for each filling rather than applying specific
transforms all the time)
Date: 6 Apr 2010 02:21:24
Message: <4bbad2e4$1@news.povray.org>
> aleph1, aleph2&  aleph3 ?
> duplicate ?
> replica ?
How about, say_again, say_again_again, say_again_again_again? :-)
Best Regards,
Date: 6 Apr 2010 17:54:22
Message: <4bbbad8e$1@news.povray.org>
Am 05.04.2010 21:03, schrieb Le_Forgeron:
> understand)
The policy is to avoid introducing more keywords where sensible, to
avoid unnecessarily breaking legacy scenes that happen to use the same
word for a variable.
Repeat is currently used in warp for pretty much the same purpose as
proposed (at least for the 1D repeat): Specifying a vector and distance
for repetition (though it has some limitations with warp). So why call
the same thing differently?
Is "translate" or "rotate" a name?
I guess macros should be enough to fill that gap.
Date: 6 Apr 2010 19:55:01
Message: <web.4bbbc92df36de93034d207310@news.povray.org>
Shameless plug, from 1999!
http://www.irtc.org/ftp/pub/stills/1999-06-30/paths.jpg
Date: 6 Apr 2010 21:41:56
Message: <4bbbe2e4$1@news.povray.org>
Very sweet. :-)
