POV-Ray : Newsgroups : povray.off-topic : Fast Screencopy? Server Time
21 Mar 2026 04:30:46 EDT (-0400)
  Fast Screencopy? (Message 1 to 7 of 7)
Subject: Fast Screencopy?
Date: 24 Mar 2010 16:12:02
Message: <4baa7212@news.povray.org>
Does anybody here know of a really fast and preferably free software
screencopy-utility for windows xp?
Background:
I have a powerpoint presentation that I would like to export to avi (or
whatever video format). There are tools like MS Producer available (OK - in
this special case >was< available - MS shut this down), but they do not
capture the video- and audio-effects properly. Other programs just take the
the complete slide in its final state and "export" this to a video editor.
Well, for something like this I need no "export" program - I would just
hardcopy the screens myself and use a video editor.
I'd like to have a tool that runs in the background, captures video and
audio from screen (audio would be nice, but not necessary), while I click at
the slides to initiate the effects and transitions.
Just an uncompressed series of screenshots at 25 frames/sec (minimum) would
do, too. Reassembly should be no problem. My own attempts using .net are way
too slow. Any ideas or links to libraries for really fast screencopy would
help.
My own attemps via .net and bitblt stop at 5 about fps. Better than Corel
Capture which stops at 1 fps.
So my current solution is to connect the tv-output of the graphics-card to a
videograbber. While this works with 25 fps, the resulting output is quite
low-res and thus the text seems washed out.
Alternatively, an open source tool that easily animates bitmaps and texts
(zoom, blend, rotate & slide around the screen along predefined paths) and
has the ability to export the result to avi would help, too.
I have googled for some time now and tried quite a few programs - no real
success.
Subject: Re: Fast Screencopy?
Date: 24 Mar 2010 17:25:58
Message: <4baa8366$1@news.povray.org>
Le 24/03/2010 21:12, TC nous fit lire :
> Background:
> help.
Got a good result with camstudio, once the codec used was not too big
nor too cpu intensive (made a record at about 20fps, then replayed the
12 minutes at 30fps to reduce the movie to 8minutes).
I did not capture the sound but it was possible.
Just do not ask it to do a flash encoding. Better process the frames in
your video editor.
Otherwise, I got good echo from fraps, but not free.
Date: 24 Mar 2010 17:28:50
Message: <4baa8412$1@news.povray.org>
POV-Ray? xD
Date: 24 Mar 2010 17:50:23
Message: <4baa891f$1@news.povray.org>
> POV-Ray? xD
I wanted easy - you know, like composing a slide and effects in under 2
hours.  ;-)
Date: 24 Mar 2010 18:08:59
Message: <4baa8d7b$1@news.povray.org>
Thank you! I just tried it and it does what I like. The framerates I got
with the default codec show the effects smooth enough for my purposes. Audio
capture does not seem to work except from microphone, but since the source
is included I can try to modify this. But then, I can add sound later if it
is really necessary.
Date: 25 Mar 2010 19:03:52
Message: <4babebd8@news.povray.org>
Windows Media Encoder?
   Yes, we're traveling togeher,
   but to different destinations.
Date: 25 Mar 2010 20:54:56
Message: <4bac05e0$1@news.povray.org>
Tried it. Not fast enough - blinks - no smooth animation. I suppose it
captures at about one fps - feels like this. But thank you.
