POV-Ray : Newsgroups : povray.off-topic : NSIS Server Time
26 Jun 2026 09:45:21 EDT (-0400)
  NSIS (Message 1 to 10 of 15)
Subject: NSIS
Date: 22 Mar 2010 11:28:36
Message: <4ba78ca4$1@news.povray.org>
Anybody here happen to know anything about NSIS?
I was under the impression that NSIS is supposed to make building an
installer "easy" - but this is manifestly not the case. The
documentation is terse and unhelpful, the examples are opaque and don't
cover what I'm actually trying to do, and it's just extremely hard to
work out how to do anything.
The installation scripting language is extremely low-level; I'm
basically having to resort to writing a program in a high-level language
to autogenerate the NSIS script, because it's too painful to write by hand.
I especially love the way that if you say "install every file that
matches *.txt", it keeps the directory structure, but it you say
"install the file doc\v21\readme.txt", it loses the directory structure.
Really ****ing helpful, that.
I did have a look at MSI, but that's even harder, with even more
arbitrary limitations.
Man, when I started out yesterday, I thought I was trying to do
something really easy. I guess not!
Subject: Re: NSIS
Date: 23 Mar 2010 06:43:51
Message: <4ba89b67$1@news.povray.org>
So apparently that's a "no" then.
Ah yes, wonderful documentation. Currently I'm trying to figure out how
to make NSIS actually *react* to errors, rather than blindly ignore
them. You would think that a product designed specifically for the
purpose of making complex installers would support you by making this
kind of thing drop-dead easy... but no. Apparently you have to script it
like you're writing psuedo-assumbly language. Yuck!!
Well, I have at least got to the point where the installer works when
everything goes according to plan. Trouble is, if there's a problem, the
installer merrily continues as if nothing's wrong. Not very graceful!
Subject: Re: NSIS
Date: 23 Mar 2010 18:43:58
Message: <4ba9442e$1@news.povray.org>
Le 23/03/2010 11:43, Invisible nous fit lire :
I had enough troubles with *.inf file with signed *.sys & *.cat to just
install a driver (on the 3 supported cpu) to have learned one thing:
Stay away from Microsoft if you can! If not, keep it very VERY very
basic. And double + triple checks before delivering... twice!
Debian installation is on the other hand a real pleasure for dedicated
binaries.
(But I have yet to install from sources for multi-architecture)
Even with a basic *.inf, I ended up installing a x386 driver on a amd64
system... no complains, until the reboot where the service was not
started... only clue was file size.
Installing a corrupted (but signed while clean) file ? No complains
either, you could think they check the signature at installation time,
at least... no!
Subject: Re: NSIS
Date: 24 Mar 2010 07:28:18
Message: <4ba9f752$1@news.povray.org>
> binaries.
And yet, I can get Windows to work, but Debian consistently frustrates
my attempts to make it do what I want.
(E.g., do a default install of Debian. Click the button marked "change
screen resolution". In the window that comes up, the slider to change
resolution is disabled. Yeah, that's really helpful.)
> at least... no!
I wouldn't mind, but NSIS is touted as this great free tool to take the
hassle out of building complex installers. And yet, most of the time the
"hassle" is figuring out how to get around the limitations of NSIS. Even
something as trivial as finding out which of three possible files exists
is stupidly complex!
As I say, I did look at making an MSI file, but that is apparently
drastically more complex still. (And it's even less-well documented. I
can find the pages that tell you all about how fantastic MSI is, but not
the pages they tell you HOW TO MAKE ONE!)
Subject: Re: NSIS
Date: 24 Mar 2010 07:33:50
Message: <4ba9f89e@news.povray.org>
This was the same in Windows before XP.  I can't remember the number of
times I had to go looking for graphics card drivers while not being able to
change out of 640x480x8bit resolution...
Subject: Re: NSIS
Date: 24 Mar 2010 07:47:43
Message: <4ba9fbdf$1@news.povray.org>
> to change out of 640x480x8bit resolution...
If you don't have the necessary driver installed, it is impossible to
drive the card at a higher resolution.
If Debian wasn't finding the correct driver and defaulting to some
horribly low resolution, I could understand that.
However, the *actual* problem is that Debian is defaulting to a
resolution larger than my monitor, and I'd like to *reduce* it to, say,
1024x768 or something. But nooo...
As petty as it sounds, this is the main reason I'm using OpenSUSE. It
defaults to a sane resolution, and it seems to somehow "know" it's
running under VMware, so things like mouse integration work out of the box.
(I tried installing VMware tools on Debian, but it can't compile it
because there's no compiler. So I installed the compiler, but then it
complained that I don't have the kernel headers. So I installed the
kernel headers. And then it complained that the kernel was compiled with
a different compiler than the one I installed. So I looked for the
version it's asking for... and it's not listed in the Debian package
database. At this point, I gave up in utter frustration.)
It's a pitty really - Debian starts up much faster than OpenSUSE. (Not
that "faster" is the same as "fast", mind you...)
Subject: Re: NSIS
Date: 24 Mar 2010 17:18:57
Message: <4baa81c1$1@news.povray.org>
This is SOP. Please refer to articles 34234-5434 and 52334-235, where we
explain why this is a wonderful way to document things and became SOP,
but not how it actually works. lol
void main () {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Subject: Re: NSIS
Date: 25 Mar 2010 18:41:04
Message: <4babe680@news.povray.org>
You were the one asking about the benefits of using an IDE, yes?  ;-)
   Yes, we're traveling togeher,
   but to different destinations.
Subject: Re: NSIS
Date: 25 Mar 2010 18:43:52
Message: <4babe728@news.povray.org>
Heh, there are IDEs that can do *that*?
http://blog.orphi.me.uk/
Subject: Re: NSIS
Date: 26 Mar 2010 03:49:49
Message: <4bac671d$1@news.povray.org>
I don't know anything about the detail of installers or how they work, I
just click "Publish" in Visual Studio and tell it where to put the
installer.  You can also tick boxes for which prerequisites your installer
also checks for and installs (eg the .net framework, a certain version of
Windows Installer, XNA framework, various SQL servers, etc) - this seems to
be intelligently correct by default though...
