POV-Ray : Newsgroups : povray.off-topic : Network devices hanging explorer Server Time
18 Oct 2026 02:44:51 EDT (-0400)
  Network devices hanging explorer (Message 1 to 22 of 22)
Subject: Network devices hanging explorer
Date: 8 Mar 2010 04:08:08
Message: <4b94be78@news.povray.org>
On my laptop I have 2 network drives mapped, and a network printer.  It
works fine when connected to the network that these devices are on.  However
if I go to a different network (eg home WLAN) then windows  explorer becomes
almost impossible to use.  Every single time I click a folder or file the
explorer window hangs completely for 10 or 20 seconds.
If I am not connected to any network, or I remove the two network maps and
the printer, this problem disappears.  This makes me think explorer is
somehow searching for these network resources, even when there is no chance
to find them.
How do other people cope with this, I can't be the only one in this
situation?
Subject: Re: Network devices hanging explorer
Date: 8 Mar 2010 04:18:57
Message: <4b94c101$1@news.povray.org>
> folder or file the explorer window hangs completely for 10 or 20 seconds.
That is one of the things I love about Windows Explorer - it's complete
inability to handle delays.
Click on A: by mistake, when there's nothing in the drive, and
essentially the entire Windows UI locks up until it has determined
there's nothing in the drive. And I don't just mean the window in
question. The start menu stops working, windows stop repainting
themselves, virtually the entire damned OS locks up because of one
stupid disk drive! WTF?
Anyway, as to *your* problem... The whole "it locks up for 20 seconds"
deal reeks of "network timeout". BTW, does anybody know why network
timeouts are always set to 7 minutes or something? I mean, if you
haven't got a reply in 800 ms or so, it's *obvious* that you're never
going to get one! Retry or give up. Don't sit there for 7 minutes waiting!
I presume you've tried unmapping the mapped drives. Is the laptop part
of a domain?
Date: 8 Mar 2010 04:23:55
Message: <4b94c22b@news.povray.org>
I bet there's some core code that is still from Windows 1 :-)
> Click on A: by mistake, when there's nothing in the drive, and essentially
> the entire Windows UI locks up until it has determined there's nothing in
> the drive.
Don't remember the last machine I used with an "A" drive, but the same
happens with CDs and DVDs that it can't read properly.
As I said, if I unmap the drives the problem goes away.  Issue is that I
don't want to have to remap them everytime I connect to the network they're
on!
I just couldn't find the "Only try to connect once to mapped drives until
the network connection is changed" checkbox...
> Is the laptop part of a domain?
Yes.
Date: 8 Mar 2010 04:48:54
Message: <4b94c806@news.povray.org>
>> complete inability to handle delays.
Would surprise me. Apparently Windows NT still contains the entire
Windows 3 kernel, unmodified, in case any software wants to use it.
Backwards compatibility is a truly evil thing. (This is why Haskell's
unofficial motto is "avoid success at all costs".)
Or just the drive is empty. You'd think this wouldn't take long to
figure out, but...
> they're on!
> until the network connection is changed" checkbox...
I'm not sure if there is one.
What I'd probably do is write a batch file to unmap the drives, and
another to map them again. Put those two scripts on the desktop, click
'em when required.
> Yes.
It's probably searching for a domain controller to authenticate to so
that it can map the network drives. That's probably what the problem is.
Date: 8 Mar 2010 06:42:16
Message: <op.u88ysvaumn4jds@phils>
And lo On Mon, 08 Mar 2010 09:08:06 -0000, scott <sco### [at] scottcom> did
spake thusly:
> However if I go to a different network (eg home WLAN) then windows
> explorer becomes almost impossible to use.  Every single time I click a
> and the printer, this problem disappears.  This makes me think explorer
> is somehow searching for these network resources, even when there is no
> chance to find them.
> situation?
Hmm okay you don't say which version of Windows you're running, but in
Folder options try turning off "Automatically search for network folders
and printers" if that doesn't work try turning off the SSDP service.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 8 Mar 2010 06:54:29
Message: <4b94e575@news.povray.org>
Ah yes - I forgot that when I get a new PC I always turn this setting
off. Maybe that's why I haven't seen this problem before...
Date: 8 Mar 2010 07:22:00
Message: <4b94ebe8@news.povray.org>
XP 32 bit
> but in  Folder options try turning off "Automatically search for network
> folders  and printers"
Did that already, as it looked liked a useless feature anyway :-)
Done it - will see what happens later at home...
Date: 8 Mar 2010 07:26:31
Message: <op.u880unxdmn4jds@phils>
And lo On Mon, 08 Mar 2010 12:21:57 -0000, scott <sco### [at] scottcom> did
spake thusly:
> XP 32 bit
>> network folders  and printers"
The only other thing I can think of off the top of my head is UPnP
Phil Cook
Date: 9 Mar 2010 02:51:26
Message: <4b95fdfe$1@news.povray.org>
OK I think I've sorted it.  After more googling using some of the info given
here I tracked down a copy of Filemon to see what explorer was doing.  It
turns out that every time I tried to navigate or open a right click menu
explorer was looking for "shell32.dll" in C:\Windows and failing to find it
(it is is the system32 folder), and then it was looking for it in the root
of G:\ (my personal network share).  I have no clue why it was doing this,
but it was doing it mulitple times whenever I tried to do anything in an
explorer window.  Obviously explorer only works in a single thread, so the
call to open a non-existant network file was hanging the entire process for
10 seconds or so.
I simply copied shell32.dll from C:\Windows\System32 into C:\Windows and now
everything is zipping along like a new machine - even with the inaccessible
network shares and printers!
Date: 9 Mar 2010 03:24:43
Message: <op.u9akbgon7bxctx@toad.bredbandsbolaget.se>
Not a good idea.
Try using ShellExView to see if there is a misconfigured shell extension,
or a remnant of some malware.
FE
Date: 9 Mar 2010 03:41:06
Message: <4b9609a2$1@news.povray.org>
> Not a good idea.
OOC why not?
What am I looking for in ShellExView?  A lot of them have
system32/shell32.dll as the filename, but none are pointing to
windows/shell32.dll.  I wonder why explorer.exe is looking there for it?
Date: 9 Mar 2010 04:19:53
Message: <op.u9amvevn7bxctx@toad.bredbandsbolaget.se>
>> Not a good idea.
> OOC why not?
Just off the top of my head:
- Files that share the name, but not the path, of a system file are common
indicators of malware.
- The original file in 'system32' is protected against unauthorised
changes (though less so in WinXP if you are using an administrator
account).
- The original file in 'system32' is affected by system updates.
- You are treating a symptom, not the cause.
>> extension, or a remnant of some malware.
Try searching for it in AutoRuns (from SysInternals). If it does not show
up there, try searching for it in the registry.
Also keep in mind that it might not be registered as
"windows\shell32.dll". It could be "%WINDIR%\shell32.dll",
"%SYSTEMROOT%\shell32.dll" or some other variant.
FE
Date: 9 Mar 2010 04:51:29
Message: <4b961a21@news.povray.org>
> account).
Good point about the auto-updates, maybe I'll make it automatically copy the
shell32.dll from system32 into windows each time I boot to make sure any
updates are reflected.
Nothing showed up, every shell32.dll was referenced in the system32 folder.
I don't know what else to try, but at least I have my computer back working
at a normal speed, even if it is a bit of a hacky temporary fix.
Date: 9 Mar 2010 05:09:11
Message: <op.u9ao5jg17bxctx@toad.bredbandsbolaget.se>
> the shell32.dll from system32 into windows each time I boot to make sure
> any updates are reflected.
That may be difficult if the DLL is actually being loaded by explorer.exe.
> folder. I don't know what else to try, but at least I have my computer
> back working at a normal speed, even if it is a bit of a hacky temporary
> fix.
Grasping for straws here, but check that "Windows\system32" comes before
"Windows" in your %PATH%.
It could also be caused by a crappy shell extension with an import table
entry for "windows\shell32.dll". That would be a little more tedious to
track down, though you could come a long way by simply disabling all
non-essential extensions with ShellExView.
FE
Date: 9 Mar 2010 17:20:03
Message: <4b96c993@news.povray.org>
No. Vista added the ability to cancel an outstanding IO request that was
hanging. XP doesn't have that, so you get a timeout. Known problem fixed
years ago.
That in part is a kernel/driver problem, since it actually *does* hang the
whole machine to a large extent.
> they're on!
Shell scripts to the rescue?
   The question in today's corporate environment is not
   so much "what color is your parachute?" as it is
   "what color is your nose?"
Date: 9 Mar 2010 17:21:09
Message: <4b96c9d5$1@news.povray.org>
SSDP *is* UPnP.
Date: 10 Mar 2010 04:21:27
Message: <op.u9chmarjmn4jds@phils>
And lo On Tue, 09 Mar 2010 22:21:04 -0000, Darren New <dne### [at] sanrrcom>
did spake thusly:
> SSDP *is* UPnP.
I thought SSDP was what found UPnP devices; so it might freeze because
it's looking or it might freeze because it's trying to interface with it.
But yes turning off SSDP should turn off UPnP too.
Phil Cook
Date: 11 Mar 2010 10:37:28
Message: <4b990e38$1@news.povray.org>
> did spake thusly:
>> SSDP *is* UPnP.
SSDP is part of uPnP, yes. It's the equivalent of WINS for netbios, tracking
the announcements.
Date: 11 Mar 2010 12:40:01
Message: <web.4b9929f3acd5574b773c9a3e0@news.povray.org>
they are right after all.  Let's all just hang IE... ;)
Date: 19 Mar 2010 03:46:38
Message: <4ba32bde$1@news.povray.org>
LOL, my AV software has flagged this as a "hacking tool" :-)
Date: 19 Mar 2010 05:01:20
Message: <4ba33d60$1@news.povray.org>
According to SecuROM (or whatever it's called), Process Explorer is a
"cracker tool", and having it installed prevents Crysis from running.
Date: 20 Mar 2010 17:52:14
Message: <4ba5438e@news.povray.org>
My AV used to complain about a Windows port of netcat -.-
