POV-Ray : Newsgroups : povray.off-topic : HDMI cable confusion/paranoia Server Time
1 Nov 2026 22:19:57 EST (-0500)
  HDMI cable confusion/paranoia (Message 1 to 50 of 128)
Goto Latest 50 Messages Next 50 Messages >>>
Subject: HDMI cable confusion/paranoia
Date: 5 Mar 2010 11:16:56
Message: <4b912e78@news.povray.org>
I recently bought a new HDTV along wtih a Blu-Ray player.  Prior to the
purchase, I spent a lot of time trying to understand the technology.  One of
the things that struck me, was the fact that Walmart's HDMI cables cost
between $30 to $40+ for a 6 foot cable.  I can find other HDMI cables from
various reputable sources for less than $10.  Heck, when I bought my new LCD
monitor last Fall, it came with a "free" HDMI cable.  I've used it and it
works great.  Certainly, the manufacturer would not have included a $30
Cable with the monitor.  In fact, they probably wouldn't even include a $5
cable.
Since HDMI is a digital connection, any cable capable of handling a 1080p
connection (Blu-Ray) is good enough right?  Short answer, "Yes."  Long
answer, "Maybe..."  As the length of the cable grows, the quality of the
cable becomes more important.  Gizmodo.com actually did a really good write
up on the issue, eventually concluding that while way overpriced, the
"Monster" brand cables were actually higher quality, but again, so what?  If
you have an 8-bit-color 1080p signal, any cable shorter than 10' should be
able to handle the job.
What's interesting is to read reviews of the Monster HDMI cables where they
sell a 3-foot HDMI cable for around $100.  Some poor saps are saying, how
it's well worth the money, because it's so much better than composite video.
Well, yeah, HDMI is much better, but you're still stupid for spending $100
on a 3-foot cable that you should be able to find for a few bucks.  Others
claim that the $100 Monster cable gives them such a better picture than the
other (mon-Monster) HDMI cables.  Unless I'm missing something, that's like
saying your Internet looks a lot better since you switched from a cat 5
ethernet connection to cat 6.  In the analog realm, high quality cables
meant a lot.  In the digital realm, anything capable of handling the signal
should be as good as any other, although I've seen my share of really crappy
quality ethernet cable, as well.  But they either work, or they don't.
Sometimes you may have partially working ethernet cables, but with HDMI,
your picture would be getting noticeably screwed up.  i.e. a bad cable would
become very apparent, very quickly, because you'd see a very screwed up
picture on your TV, or no picture at all.
Another thing I hear mentioned is the higher bandwitch capacity of Monster
(and other) HDMI cables.  Again, I'm a bit confused here.  Some day, when
Blu-ray discs start using 12-bit color or perhaps higher resolutions, then
the higher bandwidth might be necesary.  But for now, what good is it?
Isn't that the same as running 100 megabit ethernet on a cable that can
handle gigabit ethernet?  Yeah, it's nice for the future, but it's not going
to give you anything extra in the present.  Am I wrong about this?  This is
the part that confuses me the most, because I see a lot of reviewers
claiming that the higher bandwidth capacity actually works better for them.
I believe 1080p/60Hz/24-bit with audio is about 6GB/s, so why would a cable
capable of handling 15GB/s make anything any better?  Isn't it still
transmitting at 6GB/s?
Finally, 120Hz LCD.  I suppose in the future, we may have a 120Hz signal
from a Blu-Ray (or whatever), but currently 60Hz is the max.  So, you're
still transmitting a 60Hz signal into a 120Hz TV, so I don't see how a
better quality cable would help there either.  In fact, I'm still not
convinced that 120Hz LCD makes any sense whatsoever.  With CRT's, it made a
LOT of difference, because it substantially reduced flicker.  LCD doesn't
have flicker.  It has response times, and lowering the response times does
make a difference.  I'm not convinced that a 5ms 60Hz screen would be any
different from a 5ms 120Hz screen, or even a 5ms 240Hz screen.
There it is.  Let me know if I'm wrong.  I can't believe that I could be
right about all of this stuff, as there seem to be so many people out there
who seem to think I'm wrong.
Subject: Re: HDMI cable confusion/paranoia
Date: 5 Mar 2010 12:15:49
Message: <4b913c45$1@news.povray.org>
> there who seem to think I'm wrong.
One thing that I learned quickly was that if you start looking based on a
specification (1.2 vs 1.3 vs 1.3b), you're only looking at the connector
quality, not the actual cable quality.
I picked up a 50-foot cable from Firefold (whom I've been quite happy
with) for about $15, and it's generally worked well for me - though I did
have issues with losing HDMI sync (that I seem to have resolved) when the
system was cold (but after it warmed up for about 20 minutes, it was
usually fine).  The thing to look at is apparently the cable gage and
shielding (which would be important as well).
Another thing to consider, though, is if the equipment being used has a
signal booster in it.  Our Harmon/Kardon AVR-254 does signal boosting,
and that's probably why I can use a lower grade cable with greater
success.
Jim
Date: 5 Mar 2010 12:20:17
Message: <op.u83uf2q9mn4jds@phils>
And lo On Fri, 05 Mar 2010 16:19:21 -0000, Jeremy "UncleHoot" Praay
<jer### [at] questsoftwarecmo> did spake thusly:
> One of
> from
> LCD
> $5
> cable.
<snippety>
The latest which magazine had a quick segment where they sent a 6.2Gb per
second data stream through a £10, £20, and £100 HDMI cable of unspecified
length without a single error occurring.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 5 Mar 2010 13:31:13
Message: <4b914df1@news.povray.org>
  If a 120Hz LCD shows each frame of a 60Hz input twice per output frame,
then there ought to be no difference. However, if the LCD does some kind
of interpolation each other frame then there might be some visible
difference. I don't know if they do, though.
Date: 5 Mar 2010 13:51:07
Message: <4b91529b$1@news.povray.org>
Both of you are assuming this is "Blue Ray" that is the issue too. Game
systems, I think, can output in native 120Hz, and computers certainly
can and *must* in some cases, if you want decent video. If you are
running 3D shutter glasses through them, then its mandatory, etc. And,
that looks like something coming up soon with Blue Ray. Also, you are
assuming that Blue Ray isn't using the full Hz, if available, which
might be true of the cheaper units, but.. I wouldn't bet on it a) being
that way with all of them, or b) staying that way.
void main () {
   If Schrödingers_cat is alive or version > 98 {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 5 Mar 2010 13:59:49
Message: <4b9154a5$1@news.povray.org>
You want few errors. How many errors you actually get depends on your
environment and your cable length.
Remember that cables don't carry digital signals. They carry analog signals
that your equipment interprets as digital values. The cable has to not
degrade the signal enough that *your* end equipment can still understand the
digital values. You can't hook the cable up to laboratory-quality test
equipment and say "Yep, no errors."
Which is not to say cheap cables aren't sufficient. It's merely to say that
cheap cables aren't necessarily sufficient just because it's digital.
It's the same reason you can only get ADSL service at certain distances from
the telco CO. It's an analog signal. It's only digital once it gets inside
your computer.
It wouldn't, unless you're actually getting bit errors.
Understand that there's a processor inside the TV that's interpolating
frames. It's not just painting the same frame twice. It's actually drawing
something different every frame, based on the motion vectors in the image.
   The question in today's corporate environment is not
   so much "what color is your parachute?" as it is
   "what color is your nose?"
Date: 5 Mar 2010 14:49:57
Message: <4b916065$1@news.povray.org>
"Patrick Elliott" <sel### [at] npgcablecom> wrote in message
news:4b91529b$1@news.povray.org...
Woops.
> Game systems, I think, can output in native 120Hz, and computers certainly
120Hz or 120fps?  Sometimes the two terms are interchangeble, but not
always.  It's true that getting 120fps on a 60Hz monitor won't look as
smooth as a 120Hz monitor.  I don't think any console systems on the market
today output at 120Hz, but I could be wrong.
> If you are running 3D shutter glasses through them, then its mandatory,
> etc. And, that looks like something coming up soon with Blue Ray.
That would be awesome.
> Also, you are assuming that Blue Ray isn't using the full Hz, if
> available, which might be true of the cheaper units, but.. I wouldn't bet
> on it a) being that way with all of them, or b) staying that way.
My Blu-Ray player has the capability to output 12-bit color.  Last I
checked, there were no Blu-Ray discs that contain 12-bit color.  My TV is
8-bit.  So, while some of the technology is there, it's definitely not all
there yet, but it probably will be in the next couple years, but it's not
going to enhance my viewing experience.  Likewise, I'm pretty sure that no
Blu-ray discs are being produced at 120Hz, nor is that likely to happen over
the next several years.  Heck, if Hollywood would start filming at a mere
60fps, it would be a huge improvement.
One of the things that most HDTV's do is anti-judderring, which is
synchronizing a 24fps signal with a 60Hz monitor.  I've read that with the
120Hz TV's, they can really smooth-out a 24fps signal, and it looks a lot
like video-tape (in smoothness, not quality).  That's neat if you want your
movies to look like video tape.  But I wanted more of an authentic feel, so
I went with the Sony TV, which shows a 24fps Blu-ray movie at, you guessed
it, 24Hz.  This seems like a simple solution to a simple problem.
Date: 5 Mar 2010 15:05:29
Message: <4b916409$1@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:4b9154a5$1@news.povray.org...
> signals that your equipment interprets as digital values. The cable has to
> not degrade the signal enough that *your* end equipment can still
> understand the digital values. You can't hook the cable up to
> laboratory-quality test equipment and say "Yep, no errors."
> that cheap cables aren't necessarily sufficient just because it's digital.
> from the telco CO. It's an analog signal. It's only digital once it gets
> inside your computer.
Yes, but if the bits start out as 101 and end-up as 101 on both the high
quality cable and the low quality cable (every time), then even though the
high quality cable is transmitting the analog signal better, it really makes
no difference, as they both interpret the digital portion the same way.  I
think we're both on the same page here.
It doesn't just paint the same frame?  Hmmmm...  If so, then it's similar to
the anti-judderring (or an extension of it).  That's more interesting, now.
Date: 5 Mar 2010 17:15:47
Message: <4b918293@news.povray.org>
Right. I'm just saying that the equipment at each end determines how good
quality cable you need. You can't test a cable on lab equipment and say "we
got no errors, so you won't either."   It's like saying "we put X brand
gasoline in our car and got 40MPG, so you will to."
I think we understand each other. :-)
That's what they *say*.  Whether they're just full of it, I couldn't say.
The demos make it look better, but then they would.
Date: 5 Mar 2010 17:29:32
Message: <4b9185cc@news.povray.org>
  Maybe if there's nearby interference (not completely unthinkable given
how much electronics there are in today's homes) the likelihood for the
bits to get garbled during transport is lessened with the higher-quality
cable.
Date: 5 Mar 2010 17:34:00
Message: <4b9186d8$1@news.povray.org>
You seem to have encountered the High-Def equivalent of extreme
audiophiles. You can find the same people buying CD/DVD/Blue-ray
de-magnetizers, because it makes the sound/image quality better. Or
wooden knobs for their amps, for the tonal quality. Or acoustic rocks,
after-market power cords infused with nitrogen, R-Type stickers that
make their cars go faster . . . wait, slipped off topic for a bit there.
All said, there can be a difference in cable quality. I would not try
pushing 10Gbps ethernet over cat5 cable for any distance. HDMI, if it
were supporting 1080p, 60 Hz frame rate, 12 bit per color with no
compression, would have to support a data rate close to 4.5 Gbps. (G is
SI, not 1024M here). I don't think I would try sending that over
unfolded cloths hangers wrapped together with gaffers tape. But, for the
normally short distances between a TV and other components, just about
any braided copper wire will do, if properly shielded from cross-talk
and such which, I would think, the HDMI standard should cover. If you
get problems between two components then you can look at just those
cables involved, and figure out if they are really bad cables or if the
components need a better cable to communicate over.
For 120Hz, and now 240Hz, some (most?) of those TVs blend frames
together, to blur the change between each frame. Watching the
side-by-side demos in stores hasn't impressed me too much, maybe because
the compression artifacts are so pronounced when you stand that close to
these big TVs. Maybe when 3D becomes more used, I will check them out again.
Date: 5 Mar 2010 18:31:21
Message: <4b919449$1@news.povray.org>
> these big TVs.
You know, I used to think that.  I used to work on compression algorithms,
so I got really good at seeing the kind of artifacts that jpeg and mpeg
produce. Every time I went in the store and looked at the HDTV, I saw all
the compression artifacts in the background and thought 'wow, that sucks.'
Then my TV died, so we bought a big-screen LCD TV. The difference between
the SD channels on cable and the HD channels on cable is stunning. Stadium
crowds that used to look like a Monet painting now all have faces and stuff
even in the background. You can see grass blades. Etc.
Yes, the compression artifacts are still there, but they're *still* smaller
than the analog blurring and color drift artifacts on a TV set that size. :-)
Date: 5 Mar 2010 22:14:24
Message: <4b91c890@news.povray.org>
>> these big TVs.
> algorithms, so I got really good at seeing the kind of artifacts that
> jpeg and mpeg produce. Every time I went in the store and looked at the
> HDTV, I saw all the compression artifacts in the background and thought
> 'wow, that sucks.'
I could ignore them on my old small TV, when cable started
rebroadcasting very compressed signals. Now I have a large 1080p tv, but
I get programing over the air, so the local news and such comes in very
clear while other programing varies.
> between the SD channels on cable and the HD channels on cable is
> stunning. Stadium crowds that used to look like a Monet painting now all
> have faces and stuff even in the background. You can see grass blades. Etc.
> smaller than the analog blurring and color drift artifacts on a TV set
> that size. :-)
Oh, yeah. It's the angle the they have you viewing the TVs at in stores
that make the difference. I am not likely to watch the tele from 1 foot
away, nor from 6 feet under the box staring up a wall at it. It benefits
the high end TVs that do some filtering, which I suspect all have a
higher margin for the stores.
Date: 5 Mar 2010 22:56:38
Message: <4b91d276@news.povray.org>
news:4b919449$1@news.povray.org...
>> these big TVs.
I'm not sure if it's just the Walmart in my neighborhood, or if all of them
are like this, but they have lots and lots of TV's all running the same
signal, and their TV's look like crap.  For one thing, most (if not all) are
using shared analog connections of some kind.  Plus, the demo they have
running has TONS of compression artifacts in it.  Any time the on-screen
text should look clear and crisp, it looks like an awful, lossy JPEG.  It
certainly doesn't impress.
Ironically, that's where I bought my TV.  :-)
Date: 5 Mar 2010 22:59:31
Message: <4b91d323$1@news.povray.org>
"Sabrina Kilian" <ski### [at] vtedu> wrote in message
news:4b91c890@news.povray.org...
>>> these big TVs.
>> 'wow, that sucks.'
Digital compression on my old 27" TV bothered me, but I guess I could handle
it.   Once we got the 46" screen, it was painful to watch.  Generally
speaking, I only watch the HD channels now, and by and large, they look
pretty good.  (DISH Network)
Date: 6 Mar 2010 05:19:09
Message: <4b922c1d$1@news.povray.org>
ADSL is a digital signal modulated into an analogue one. (And carried
over cables supplied by the lowest bidder, specified to carry voice data
only, at the minimum quality level necessary for it to be vaguely
comprehendable.) HDMI is a raw, unmodulated digital signal.
http://blog.orphi.me.uk/
Date: 6 Mar 2010 05:24:51
Message: <4b922d73@news.povray.org>
>> these big TVs.
> 'wow, that sucks.'
> that size. :-)
Well, let me see now.
On my mum's old CRT TV, there was really no noticable difference between
analogue and digital. Both looked equally fuzzy.
(I once plugged my laptop into the TV, and even if I set the resolution
absurdly low and made all the fonts huge, they were unreadable.)
Now my mum has this shiny new LCD TV. And suddenly digital looks
*awful*! As soon as anything moves faster than 2 MPH, it's blocky and
unrecognisible. Although... it seems to vary by channel somewhat.
(And that of course is the other undesirable thing about digital TV.
There used to be, like, 5 channels, 4 of them containing high quality
programming. Now there's 500 channels and they're *all* showing utter
crap that nobody would ever want to watch...)
I've only seen HD stuff in shops, but from what I can tell, there's no
visible difference between HD and SD. If I ever get time to set up my
mum's new BluRay player, maybe I can test for myself. But seriously,
everybody's going on like it fundamentally transforms your viewing
experience. But it's only 4x the resolution. Not 40x or 400x, just 4x.
And, from what I've seen, this equals to a slight increase in constrast,
and not much else.
Date: 6 Mar 2010 11:57:14
Message: <4b92896a@news.povray.org>
There is no such thing. Digital is your imagination.
Date: 6 Mar 2010 12:00:41
Message: <4b928a39$1@news.povray.org>
That's exactly what I'm talking about. There's really a tremendous
difference, but you have to notice it by switching back and forth between HD
and SD.
It's like playing a game with all the graphics turned up, vs playing in 256
colors at 640x480.
I do like bluray better than hddvd. I'm glad they won. I prefer the
speckly-dithering to the blocky compression, especially at more than a foot
from the screen.
And digital, meaning no blur or color smear.
Date: 6 Mar 2010 12:23:54
Message: <4b928faa$1@news.povray.org>
There's a big difference between recognising a DC signal, and
recognising a sine tone with a specific frequency.
Date: 6 Mar 2010 12:25:22
Message: <4b929002$1@news.povray.org>
> between HD and SD.
> 256 colors at 640x480.
Well, the shops have all this split-screen stuff, with one side in SD
and the other side in HD. The only difference I can see is that the HD
is very slightly less blurry. But it's a tiny difference - certainly not
worth paying £20,000 for.
...there's a difference between them?
Meaning no blur *if* the signal is uncompressed - which it never ever
will be.
In reality, we just swapped analogue distortion for compression
artifacts. (And - if you're talking about transmission - a different
failure mode in case of interference. Although admittedly it takes more
interference now to make it fail.)
Date: 6 Mar 2010 12:29:14
Message: <4b9290ea@news.povray.org>
  Of course there is.
  Modulation means encoding the information into the higher frequencies of
a base carrier signal. For instance radio transmissions work that way: You
have a carrier signal at a certain base frequency, and then the sound is
encoded into it by slightly modifying its amplitude (AM) or frequency (FM).
  Modems work that way too: The bits are encoded in a similar way as
variations of a carrier signal.
  Sending a raw digital signal over a cable doesn't require modulation.
It can be as simple as "no current = 0", "current = 1". (Of course the
actual process is a bit more complicated due to synchronization problems
and such, but basically it's just that.) There's no carrier signal, hence
no modulation.
Date: 6 Mar 2010 12:39:16
Message: <4b929344@news.povray.org>
20k£? Where do you shop? :O
Yes. OTOH the digital signal fails fully when it fails, with analog
signal you're still able to get the information from the news with even
very bad signal (while you don't want to see a movie with such signal).
-Aero
Date: 6 Mar 2010 12:57:12
Message: <4b929778$1@news.povray.org>
	Max Planck begs to differ.<G>
I'm not afraid of heights... I'm afraid of depths.
Date: 6 Mar 2010 12:59:18
Message: <4b9297f6$1@news.povray.org>
	Get a plasma TV next time (or a better LCD TV).
> and not much else.
	Woah! There's a *big* difference in quality. Try playing 1080p content
if your TV can handle it. If not, even 720p should be noticeable. Many
stores I've been to just show trash.
Date: 6 Mar 2010 14:49:33
Message: <4b92b1cd$1@news.povray.org>
On 3/5/2010 12:52 PM, Jeremy "UncleHoot" Praay wrote:
> "Patrick Elliott"<sel### [at] npgcablecom>  wrote in message
> Woops.
Actually, in the case of LCD, the general case is, if its not 120Hz, its
not "possible" to be 120fps. The reason being that, without the higher
Hz, you can't get a fast enough refresh to handle a doubling of the
frame rate (at all), or.. well, not if you want it to not look like
total crap compared to a LCD display for a computer, which are, now,
almost 100% 120Hz (with a few cheaper exceptions). To get the same on a
TV requires going all the way up to a 34", or something, in most cases.
Its really kind of annoying. Guess the cost of the tuner gets traded
from the cost of the extra refresh, so the small TVs and the small
monitors stay close to the same price, but... I find it more than a
little frustrating (Had my TV blow some caps a while back, so bought a
smaller one, for a temp, intending to possibly use it as a display
later. Never did, precisely due to that issue.)
void main () {
   else
Date: 6 Mar 2010 14:57:11
Message: <4b92b397$1@news.povray.org>
>>> these big TVs.
>> the HDTV, I saw all the compression artifacts in the background and
> them are like this, but they have lots and lots of TV's all running the
> same signal, and their TV's look like crap. For one thing, most (if not
> all) are using shared analog connections of some kind. Plus, the demo
> they have running has TONS of compression artifacts in it. Any time the
> on-screen text should look clear and crisp, it looks like an awful,
> lossy JPEG. It certainly doesn't impress.
Yeah, never got that myself. Use crappy splitters, which are expensive,
but the cable guy, when I showed him one goes, "There isn't even an
specs on the thing, I have no way of knowing what the variance is in the
signal attenuation!", with some crappy splitter box, which has been
turned on for 4 years, and is in 80% failure, then expect people to look
at the images and go, "Wow! I will buy that one!" lol
Mind, even when they use digital, they use the some similar splitter,
and *it* is invariably cheap, flaky, and in partial failure.
void main () {
   else
Date: 6 Mar 2010 15:01:04
Message: <4b92b480$1@news.povray.org>
And where does "recognising" happen? In the signal, or in the signal processor?
Date: 6 Mar 2010 15:03:43
Message: <4b92b51f$1@news.povray.org>
Except it's impossible to recognise the difference between "current" and
"shouldn't be current but there's minute noise on the line."
In other words, you need some minimum amount of current before you say it's
actually a 1, right?
And if the current you detect is right on the border between what you
consider "zero current" and "one current", then it's not digital. And that
happens every time the current goes between a zero and a one.
Indeed, the whole *reason* for using digital is to make broader swaths of
analog come out to the same value. If you actually *could* transmit digital
signals, you wouldn't *need* to.
Date: 6 Mar 2010 15:06:08
Message: <4b92b5b0$1@news.povray.org>
t
It's kind of hard to know when you're being crazy and when you're just be
ing
dense. :-) I can get an excellent 46" LCD screen for like $1500. What the
heck are you paying £20,000 for?
Stick with analog.
> artifacts.
True, but missing the point of what I was sayign.
Date: 6 Mar 2010 15:08:03
Message: <4b92b623$1@news.povray.org>
Given what he describes happening with movement.. Some place where the
TV people are being robbed blind by companies selling them bad
compression, and the people delivering it the same. Or.. He has
satellite. lol That is the thing they "don't" tell you with the whole,
"satellites have more bandwidth" BS. First, its basically a lie. I get
the same number of channels + high speed digital internet over my cable,
so.. the idea there isn't bandwidth is just silly. So.. How do they get
that extra "bandwidth" they claim? Simple... they compress the hell out
of the signal, so much so that your HD signals look as bad as my
**better** standard signals look "good". In other words - make up the
space lost by sending you the signal, by sending you 10% less data in
the signal, or what ever it is.
Mind, this is likely no the case with the re-broadcasts, since such
signals still need to be used to transmit to the cable people, but those
are **not** what you get from Direct TV, or the like. You are getting
their version of DSL, while the signal to the cable company is more
like.. T1. The only way to end up with "less" bandwidth is if the cable
company decides to screw you too, with crappy compression, to give
themselves more bandwidth than they need (which I don't doubt happens).
So, yeah.. What your picture looks like is going to vary, even if there
isn't anything wrong with the TV at all. Its all dependent on if the
people sending you the signal figure they can get by with it, or not.
void main () {
   else
Date: 6 Mar 2010 15:10:52
Message: <4b92b6cc$1@news.povray.org>
Oh, and yes, recognising the sine tone is far, far easier, if you use analog
components.
Date: 6 Mar 2010 15:32:12
Message: <4b92bbcc$1@news.povray.org>
> analog components.
Yep. That's why all digital electronics uses this method internally.
Oh, wait a sec...
Date: 6 Mar 2010 15:35:09
Message: <4b92bc7d$1@news.povray.org>
Darren New wrote:
> What the heck are you paying £20,000 for?
Nothing. My point is, anything that says "HD" on it - whether it's a TV
or a coffee mat - instantly becomes drastically more expensive than the
"non-HD" version. Which seems silly, given the minimal difference in
quality.
It just puzzles me that if they were going to make everything
incompatible so they could up the resolution, why didn't they up it to
something really high? You know, so you can *see* a difference?
Then again, I suppose you usually sit sort of 12 feet away or something...
> Stick with analog.
Not an opion, sadly.
>> artifacts.
...OK...
Date: 6 Mar 2010 15:39:41
Message: <4b92bd8d@news.povray.org>
>> analog components.
What part of "if you use analog components" did you miss?  Have you ever
tuned a guitar?
Date: 6 Mar 2010 15:41:51
Message: <4b92be0f$1@news.povray.org>
>>> artifacts.
> ...OK...
... which was that no, I thought the same as *you* do when *I* only saw them
in stores, but in an actual home environment, the difference is stunning.
And the resolution is already pushing the limits of technology.
Date: 6 Mar 2010 16:26:45
Message: <4b92c895$1@news.povray.org>
> them in stores, but in an actual home environment, the difference is
> stunning.
Oh, right. OK. Well if I can GET to the side of the room where the TV
is, maybe I'll try it. ;-)
Date: 6 Mar 2010 17:38:06
Message: <4b92d94e@news.povray.org>
  I have no idea what that has to do with modulation.
Date: 6 Mar 2010 19:02:20
Message: <4b92ed0c$1@news.povray.org>
I'm not talking about modulation. I'm pointing out that there's no such
thing as a digital signal, unless you start getting into quantum
cryptography or something.  It doesn't matter if it's modulated or not.
There's no such thing as a digital signal. There's only a signal that you
choose to interpret in a digital way. But that's a feature of
interpretation, not a feature of the signal.
For example, digital CDMA cell phones do not operate if the actual
over-the-air signal is digital. They rely on looking at the analog
properties of the radio waves to sort out the digital signals. Beyond just
the tuning bit.
Date: 6 Mar 2010 21:40:00
Message: <web.4b9311a1977651427220e2710@news.povray.org>
Perfect analysis.  You know how software makers are able to get a lot of money
from consumers blissfully ignorant at how software works?  Audio-video industry
is just about as horrendous.
Date: 6 Mar 2010 22:23:40
Message: <4b931c3c@news.povray.org>
> In reality, we just swapped analogue distortion for compression artifacts.
Yep.  In some cases, it's more pronounced than in others.  Initially,
satellite HDTV was horrible in comparison to what's available now.  They
simply didn't have the bandwidth to support it.  Even now, I can notice it a
little bit, but for the most part, I don't see the artifacts.  Artifacts are
most noticeable in dark images.
Date: 6 Mar 2010 22:27:07
Message: <4b931d0b$1@news.povray.org>
> being dense. :-) I can get an excellent 46" LCD screen for like $1500.
$780 USD for my Sony 46" 1080p.  Other brands are cheaper.
Date: 6 Mar 2010 22:31:43
Message: <4b931e1f@news.povray.org>
"Neeum Zawan" <m.n### [at] ieeeorg> wrote in message
news:4b9297f6$1@news.povray.org...
>> and not much else.
Agreed.  The stores suck.    And the difference in quality is huge.  Anyone
who doesn’t see the difference should switch back to a 640x480 interlaced
analog monitor.  ;-)
Date: 6 Mar 2010 22:34:00
Message: <4b931ea8@news.povray.org>
"nemesis" <nam### [at] gmailcom> wrote in message
news:web.4b9311a1977651427220e2710@news.povray.org...
>> the
>> like
>> signal
>> crappy
> money
> industry
I suppose that if I spent $100 for a 3-foot cable, I'd delude myself too,
though.  Admitting that I just paid 20 times more than a reasonable price
would just be too difficult for me.  ;-)
Date: 6 Mar 2010 23:55:01
Message: <web.4b9330a9977651427220e2710@news.povray.org>
> >> and not much else.
> analog monitor.  ;-)
I seriously think Andrew's glasses are wearing out, but the stores may be guilty
indeed:  many of them just play regular blurry DVDs on HDTVs.  Talk about truly
awful marketing skills...
Date: 7 Mar 2010 13:18:18
Message: <4b93edea$1@news.povray.org>
Or if he wants a big picture but without a TV:
http://www.pixmania.co.uk/uk/uk/2018129/art/sanyo/plv-z700-video-projector.html
I'm pretty sure Andrew could get The Best dvb-tuner in the world for the
19k£ that's left...
-Aero
Subject: There is no spoon
Date: 7 Mar 2010 16:52:28
Message: <4b94201c$1@news.povray.org>
OK, so I set up the BluRay player today and took it for a spin.
The player is hooked up to the LCD TV via an HDMI cable. Apparently the
TV is in 1080p mode. (Presumably that means 1080 scanlines with
progressive scan?) I've played some DVDs and some BluRay disks.
There *is* a difference. But it still seems quite small. The main place
you see it is actually in the setup menues, weirdly enough. The
texturing seems sharper. Once the film itself is playing, you don't
really see a whole lot of difference. Except sometimes in shots that are
very still, or have lots of close-up detail.
I can only guess that most of the time, large parts of the frame are out
of focus anyway, so there's no extra detail to capture except on the
foreground objects which are in sharp focus. And also, if the objects
are moving around a lot, there's so much motion blur that you don't see
any extra detail.
So in summary, apart from the occasional shot where you go "oh, that
looks a little sharper than usual", there's not much to see. (And most
especially, when you first start watching it seems a little sharper, but
after 20 minutes you've forgotten all about it.) It's certainly not the
"OMG, your eyeballs will drop out of your skull in sheer amazement"
effect that everybody keeps promising.
Now I've got Harry Potter and the Half-Blood Prince. The box contains
the exact same film on BD and DVD, so I can actually compare like for
like. But I haven't done so yet.
The main thing is, I can now throw away the *useless* DVD player we've
been using! :-D
Subject: Re: There is no spoon
Date: 7 Mar 2010 19:35:00
Message: <web.4b9445bcdc4ab097b0d02ed10@news.povray.org>
hey, how about paying a visit to your ophthalmologist? :D
Date: 7 Mar 2010 20:20:01
Message: <web.4b944f9adc4ab097b0d02ed10@news.povray.org>
BTW, here's a spot on comparison I caught from another forum.
DVD shot, upscaled to 1080p:
http://i166.photobucket.com/albums/u98/adzez/Gone%20With%20The%20Wind/4ac8c10f.png
Bluray:
http://i166.photobucket.com/albums/u98/adzez/Gone%20With%20The%20Wind/03a3bde1.png
guess for someone calling Mozart bland it's all equally blurry, but I can see
details of the dress, faces and background foliage in bluray HD glory. :)
and that's a very old movie, with blurry images by default!  The difference is
much more pronounced in the crisp images of modern movies like, say, Pixar
movies:
http://www.pixartalk.com/2009/06/17/the-blu-ray-difference-with-pixar/
Date: 7 Mar 2010 21:23:11
Message: <4b945f8f$1@news.povray.org>
Yeah, it really doesn't help to watch something recorded when color film was
new and amazing on blu-ray.
Do the same comparison with something like Batman.
And remember that DVD is significantly better than VHS and (most) broadcast,
while HDTV has only compression artifaacts to worry about.
