POV-Ray : Newsgroups : povray.off-topic : What's in an IDE? Server Time
1 Nov 2026 22:21:36 EST (-0500)
  What's in an IDE? (Message 1 to 50 of 66)
Goto Latest 50 Messages Next 16 Messages >>>
Subject: What's in an IDE?
Date: 27 Feb 2010 05:20:25
Message: <4b88f1e9$1@news.povray.org>
OK, so apart from syntax hilighting, what does an IDE actually do?
Obviously I haven't used many IDEs, but watching a discussion about the
topic, there seem to be two camps of opinion:
1. Expert programmers using powerful programming languages don't need an
IDE. (Alternatively, "if you need an IDE, you're a bad programmer or
you're using an inferior language".)
2. Large systems require an IDE. (Alternatively, "if you don't need an
IDE, you're only writing toy programs. Or you're just too stupid to
realise that you need an IDE.")
Can anybody throw some light on this?
http://blog.orphi.me.uk/
Subject: Re: What's in an IDE?
Date: 27 Feb 2010 07:06:59
Message: <4b890ae3@news.povray.org>
  Do you know what a makefile is?
  Make a system which automatically builds a "makefile" behind the scenes
and keeps it up-to-date as the source code changes (ie. by updating all the
dependencies between files), and you have gone a long way towards an IDE.
Date: 27 Feb 2010 07:48:58
Message: <4b8914ba$1@news.povray.org>
Sure do!
What, you mean like
   ghc -M RootModule
or similar?
(This generates a file named "makefile", containing instructions for how
to compile and link RootModule and everything it [recursively] depends on.)
Of course, most people will just do
   ghc --make RootModule
This (re)compiles everything that RootModule [indirectly] depends on,
and links the result into a single executable. Unlike a makefile,
1. The "make" program is not required. (Useful on Windows.)
2. You don't have to restart the GHC binary for each source file.
3. GHC can determine what needs to be recompiled based on information
more sophisticated than file modification time.
Then again, GHC only knows about dependencies between *Haskell* source
files. If you had, say, a Haskell program which writes a Haskell
program, GHC wouldn't know about that.
Fortunately, the -M switch is configurable. In particular, it can append
the autogenerated stuff to a hand-written makefile. (And it uses magic
comments so that successive runs of -M can delete the previously added
dependencies before adding the current ones.) In this way, it should be
possible to track all dependencies in a project.
Date: 27 Feb 2010 08:35:31
Message: <4b891fa3@news.povray.org>
> What, you mean like
>    ghc -M RootModule
> or similar?
  That goes a long way, but makefiles support more than purely compiling
the program.
  For example, a source code file might depend on a file which contains
data (eg. autogenerated code), which in itself may depend on a different
program, which itself is compiled separately, and/or on some other files
(which are used to autogenerate the data).
  There's no way for a program to automatically know that a data file
depends on program X and on input files Y and Z, so the programmer must
be able to specify those dependencies manually in addition to the automatic
dependencies.
Date: 27 Feb 2010 08:39:09
Message: <4b89207d$1@news.povray.org>
> dependencies.
Which is why, as I said, GHC allows you to easily combine the
autogenerated dependencies with hand-written stuff.
Date: 27 Feb 2010 09:20:44
Message: <4b892a3c@news.povray.org>
"Orchid XP v8" <voi### [at] devnull> wrote in message
news:4b88f1e9$1@news.povray.org...
It's not really the size but the nature of the development. (Visual) IDE's
save a lot of time and effort with the tedious, design related (be it DB or
GUI), "non-coding" type tasks. And it's hard to draw the line nowadays
between IDE's and programmers' editors. Syntax highlighting used to be an
IDE job, now every notepad replacement does it. Same for code folding, maybe
to a lesser degree. Refectoring is probably next. As both IDEs and editors
get more complex, today's IDE becomes tomorrow's editor. Use what's right
for the job, instead of following the hype.
Date: 27 Feb 2010 09:25:04
Message: <4b892b40$1@news.povray.org>
I use a text editor to edit my source, a CLI tool for version control,
the compiler itself tracks source dependencies, I use Glade for GUI
design, and so on. It's a "development environment", but it isn't
"integrated".
Yeah, I got that feeling also.
> Use what's right for the job, instead of following the hype.
That's surely good advice for anything! :-)
Date: 27 Feb 2010 12:09:08
Message: <4b8951b4$1@news.povray.org>
	I think all expert programmers use IDE's. They just don't call them that.
Depend on the rabbit's foot if you will, but remember, it didn't help
the rabbit.
Date: 27 Feb 2010 13:11:20
Message: <4b896048$1@news.povray.org>
http://en.wikipedia.org/wiki/Microsoft_Visual_Studio#Features
They may not need an IDE to code, or perhaps to debug. But an IDE does more
than just the code. Hence the "integrated" part. It draws forms, generates
code, lets you edit database schemas, lets you generate code to easily
access your database schema from code, runs tests, checks code in and out of
the repository, generates documentation, packages for distribution, etc.
The IDE in big projects does the parts that aren't code, like drawing
pictures of the over-all flow of data through the 15 different programs that
may or may not touch it between source and destination.
   The question in today's corporate environment is not
   so much "what color is your parachute?" as it is
   "what color is your nose?"
Date: 27 Feb 2010 14:51:06
Message: <4b8977aa$1@news.povray.org>
...so an IDE is a text editor, debugger, profiler, UI painter, VC
interface and doc-gen tool, except that it's one program instead of several?
> more than just the code. Hence the "integrated" part.
Mmm, right.
> It draws forms,
> generates code, lets you edit database schemas, lets you generate code
> to easily access your database schema from code, runs tests, checks code
> in and out of the repository, generates documentation, packages for
> distribution, etc.
I've seen IDEs do some of this, but other items sound surprising to me.
For example, I've seen IDEs that can generate pages of useless
boilerplate that you don't want at the touch of a button, but I've never
seen an IDE that can write *useful* code for you. Certainly I've never
seen an IDE write GUI code, and I've never seen an IDE that has any
functionallity of any kind even slightly related to database access.
I also haven't personally seen an IDE that can handle version control -
although it seems like an obvious and easy feature to add, so I can
believe that one.
> that may or may not touch it between source and destination.
That sounds more like a CASE tool. (Does anybody still use those?)
I think the main contention is that certain languages (e.g. Java) are so
verbose and require so much boilerplate code that you need an IDE to
autogenerate some of it for you just to stay sane. The argument then
goes that if your language doesn't suck so much that you need to write
so much cruft in the first place, you don't need an IDE. I am not
entirely convinced by this argument.
Every IDE I've ever used has made my job harder, not easier. Then again,
maybe they just means that an IDE is overkill for small projects.
Date: 27 Feb 2010 17:14:21
Message: <4b89993d$1@news.povray.org>
> several?
An IDE is an integrated development environment. I offered a list of example
features that an IDE might integrate. It doesn't mean it's all one program.
It doesn't mean that all IDEs have that particular list of features.
Well, go download one. ;-)
> believe that one.
Well, go download one. Visual Studio 2008 is free and pretty much
top-of-the-line, altho the free one integrates fewer tools.
Sure. And if you integrate it into your development environment, what do you
have?
It's a decent argument, but it sounds like it's being made by someone who
thinks "development" means "coding." Boilerplate has nothing to do with
ensuring that unit tests run before you check in the code, nor with making
sure that the right version of the documentation is distributed with the
release you pressed to the disk.
Or your IDE sucks.
Date: 27 Feb 2010 17:22:02
Message: <4b899b0a@news.povray.org>
>> several?
> example features that an IDE might integrate. It doesn't mean it's all
> one program. It doesn't mean that all IDEs have that particular list of
> features.
Sure. But the saliant point is, an IDE is something that integrates
several features /such as/ the above into something which is notionally
a single "product"?
Hold on, let me check...
...yeah, thought so. It's already installed on my home PC. (I attempted
learning C++ a while back, remember?)
> you have?
Heh. Roses are Rational...
> who thinks "development" means "coding." Boilerplate has nothing to do
> with ensuring that unit tests run before you check in the code, nor with
> making sure that the right version of the documentation is distributed
> with the release you pressed to the disk.
There are all sorts of tools I can think of which can do these things.
But they're not "integrated". You'd have to set them all up one at a time.
>> again, maybe they just means that an IDE is overkill for small projects.
> Or your IDE sucks.
They tell us that Borland JBuilder and Microsoft VisualStudio J++ are
supposed to be the best of the best. To me, they both seemed slow and
buggy. (That was a while ago, obviously.)
Date: 27 Feb 2010 18:05:44
Message: <4b89a548$1@news.povray.org>
> a single "product"?
Yes.
Well, now yo uknow, then.
Yes. You have a development environment, non-integrated.
Date: 27 Feb 2010 20:43:29
Message: <4b89ca41$1@news.povray.org>
> believe that one.
	Really? What IDE's /have/ you seen, then?
the rabbit.
Date: 28 Feb 2010 04:53:25
Message: <4b8a3d15$1@news.povray.org>
>> believe that one.
Borland Turbo Pascal 5.5 for MS DOS (if that even counts as an IDE).
Borland JBuilder.
Microsoft VisualStudio.
So yeah, I haven't used very many...
Date: 1 Mar 2010 02:50:04
Message: <4b8b71ac@news.povray.org>
TBH syntax highlighting is one of the least useful features of an IDE for
me.
Things I find most useful:
1) Auto-complete with popup help
2) The debugger
3) The GUI Form designer
4) The red underlining of compiler errors as you're typing (in MS C# IDE)
5) Auto compile/link/run with one keypress
6) "Template" projects for a Windows app
Date: 1 Mar 2010 02:57:25
Message: <4b8b7365$1@news.povray.org>
Even the free version of VS has a GUI for setting up and accessing local and
remote databases from your code (Data -> Add New Data Source gets you
started).  It also writes the GUI code based on what you design in the Form
Designer GUI.  It also will create distribution packages for you with
installers etc automatically.  I think you need the paid version to get all
the version control stuff, but I could be wrong (never looked into that
myself).
This sounds familiar to your argument that 3D Studio Max is rubbish because
you only figured out how to work 1 feature of it (out of 10000) :-)
Date: 1 Mar 2010 04:18:57
Message: <4b8b8681$1@news.povray.org>
> for me.
> 1) Auto-complete with popup help.
I found this to be possibly the most irritating feature of IDEs. It
*sounds* like it should be useful, but it isn't.
The whole UI slows down while it opens and populates the list of
options. Sometimes it doesn't show up when you want it to. If you're
trying to invoke a method of the current class, no matter what you do it
won't populate the list. (Even once the source is compiled. Even though
you can *see* the damned property pane right next to the code window,
showing all the class properties. It still won't offer to autocomplete
them.) And even when it *does* work, there is apparently no way to say
"please use the currently selected alternative to complete what I'm
typing", other than by using the mouse. If you press enter, it inserts
the selection AND A NEWLINE. This is extremely annoying.
(And then there's the fact that every IDE I've seen refuses to let you
indent your code correctly... but that's nothing to do with
auto-complete as such.)
> 2) The debugger.
That's useful.
> 3) The GUI Form designer.
After the horror of building a GUI the hard way, I always use a GUI
designer if I have a choice. (Like I've said, you don't need an IDE for
that necessarily.)
That's useful IF IT WORKS CORRECTLY, which it doesn't always do IME.
I usually leave a CLI window open. To compile, just press the up arrow
and enter. But sure, I'm certainly not *against* such a feature! ;-)
What does that do?
Date: 1 Mar 2010 04:33:17
Message: <4b8b89dd$1@news.povray.org>
> and remote databases from your code
Even the Java version from 10 years ago?
> the Form Designer GUI.
I saw that you can select "Java Applet" or something like that, and it
generates a class with 200 miles of boilerplate that you will never ever
need or want, which you then have to manually delete. Alternatively,
"blank Java project" generates a class file with much less boilerplate
in it to delete. (Mostly just verbose comments.)
I didn't try using the UI painter, so I couldn't say whether they
implemented it for Java, whether it was any good, or whether it writes
code for you.
> you with installers etc automatically.
Yes, I recall there were a whole bunch of options for how to package up
your project when you're done. (This was in the early days of Java. I
believe you could compile it down to a Windows executable, or just a
normal Jar file.)
> version to get all the version control stuff, but I could be wrong
> (never looked into that myself).
I haven't looked either. Presumably you need a 3rd-party VC system
before this will work? (I.e., there isn't VC capability build into VS
itself.)
> because you only figured out how to work 1 feature of it (out of 10000) :-)
Well, it was an old version of Max. But, as far as I could tell, it only
renders triangles. (There's probably a way to move the points around; I
didn't look too hard for it.) The texturing options seemed pretty
extensive though...
As for VS, it was a struggle to figure out how to make it compile Hello
World and run it. You would have expected this to be the most trivial
thing, but no... Given the difficulty of doing this, I didn't exactly
hunt around for the button that embeds SkyNet into your program.
Date: 1 Mar 2010 04:46:50
Message: <4b8b8d0a$1@news.povray.org>
> The whole UI slows down while it opens and populates the list of options.
Not here.
Not here, unless you made a typo (it's actually a good indicator to know
you've typed something wrong if the pop-up list doesn't appear).
> If you're trying to invoke a method of the current class, no matter what
> you do it won't populate the list.
Seems to work fine here...
...even without the source compiled.
> typing", other than by using the mouse. If you press enter, it inserts the
Not here it doesn't.
BTW this is with VS C# express edition (it's free), your experience with
other IDEs may vary :-)
> that necessarily.)
It's helpful that it's integrated though, apart from the obvious reasons of
not having to load and switch programs and save etc, it means if you for
example rename one of the icons or something it can update the references to
it in all your other code files.  Also when you add an event handler the IDE
can automatically auto-insert the method skeleton into your code and
register it to be called for that event, so all you need to type is actually
what you want to be done for that event.
Which IDE? in VS C# Express it works flawlessly IME.
> What does that do?
You can go "File -> New -> Windows App" and it generates all the necessary
code and resource files for a ready-to-compile form application.  You then
simply add in whatever extra bits you need.  I guess you could do the same
by creating all the files by hand first, and then copying&pasting in
explorer and renaming everything everytime you wanted to start a new
project.
I remembered another one:
7) Code refactoring.  Like if a function is getting a bit long, you can
select a block of code and say "extract this to another function".  All
parameters and return values will be handled automatically.  Or if you type
a function name that doesn't exist yet, you can click and say "generate the
boilerplate code for this function".  Or you can go to "Insert -> New Class"
and it will create a new file with the new class template in it.  Or rename
a variable and get the option to rename all instances of it in all files.
Sure, each of the above are fairly small things, but in total it makes
programming way faster.
Date: 1 Mar 2010 04:55:06
Message: <4b8b8efa$1@news.povray.org>
Dunno, I'm using the ones you can download from here:
http://www.microsoft.com/express/Windows/
> extensive though...
> thing, but no... Given the difficulty of doing this, I didn't exactly hunt
In VS C# I can just go to "File -> New Project -> Console Application", up
pops a "Program.cs" source code file with about 10 lines of code, a class
containing an empty "Main" method.  I write "Console.WriteLine("Hello
World!");" and press F5.  Job done.
Note that as I typed Con the autocomplete list popped up and Console was
highlighted so I just pressed enter, then when I pressed "." the next list
popped up of methods/properties of "Console", after I typed "W" it
highlighted "Write", but then I saw that "WriteLine" was below so I pressed
down arrow and enter again, then I typed "(" and I was given a list of
overloaded methods I could call, I just ignored that and entered my string,
assuming there would be one that took a string.  Also if I made any mistake
(or paused for too long typing before completeing the statement) it got
underlined in red...
Date: 1 Mar 2010 05:16:48
Message: <4b8b9410$1@news.povray.org>
>> Hello World and run it. You would have expected this to be the most
>> trivial thing, but no... Given the difficulty of doing this, I didn't
>> exactly hunt around for the button that embeds SkyNet into your program.
> up pops a "Program.cs" source code file with about 10 lines of code, a
> class containing an empty "Main" method.  I write
> "Console.WriteLine("Hello World!");" and press F5.  Job done.
As I recall, with VS J++, if you do "console application", it generates
a Java class file with about 30 lines of JavaDoc comment stubs, argument
parsing and exception handling, and so on. (E.g., main() parses the
argument list, and if it sees "--help", it calls a stub method named
help() which you're supposed to fill in.)
Now you could sit there and delete all this crap, or you could select
"empty project". That way, you get to decide what to name your class,
and you can write Hello World quite easily. You then have to configure
VS to know which class is the "main" that you want it to run. (And
whether you want it to run in normal mode or debug mode, and a whole
bunch of other stuff.) And THEN you can actually run it.
Seemed like a whole lot of work, but once you've spent an hour puzzling
out how to do it, it's reasonably easy the next time around.
Oh, and do NOT try to delete or rename classes. VS apparently doesn't
like this at all.
All of this happened a while ago, but my recollection is that when you
remove or rename a source file, the compiled class files hang around,
littering up the place. And trying to figure out where VS stores them is
nontrivial, given that there are normal and debug versions of them. In
the end, I decided that the easiest way to refactor was to create a
brand new, empty project, and import the files from the old project one
at a time. It was just the least painful way to get the job done.
(Again, this seems like a lot of work just to keep VS happy. If I were
just using Notepad and javac, I wouldn't have to do it.)
> list popped up of methods/properties of "Console", after I typed "W" it
> pressed down arrow and enter again, then I typed "(" and I was given a
> list of overloaded methods I could call, I just ignored that and entered
> my string, assuming there would be one that took a string.  Also if I
> made any mistake (or paused for too long typing before completeing the
> statement) it got underlined in red...
That sounds about right - except, as I say, whenever I pressed enter, it
would move to the next line as well as entering the selected text, so
I'd have to hit backspace to get back to where I was.
Date: 1 Mar 2010 05:29:06
Message: <4b8b96f2$1@news.povray.org>
Well, maybe they've fixed it since I used VS J++ a few years ago. Who knows?
(Some to think of it, I don't recall VS attempting to do any
autocomplete when I did that C++ stuff last year... Maybe it did and I
just don't remember. Hmm.)
>> for that necessarily.)
> of not having to load and switch programs and save etc, it means if you
> for example rename one of the icons or something it can update the
> references to it in all your other code files.
Now that actually sounds useful.
> event handler the IDE can automatically auto-insert the method skeleton
> into your code and register it to be called for that event, so all you
> need to type is actually what you want to be done for that event.
As does that, assuming it does it properly. (IME, VS usually prefers to
have all autogenerated code perform its function in the most
over-complicated way feasible.)
>>> IDE)
Maybe the parsing rules for C# are simpler than Java or something? Or
maybe they've just ironed out the bugs now... As I recall, it *usually*
worked OK, but not always.
>> What does that do?
> necessary code and resource files for a ready-to-compile form
> application.  You then simply add in whatever extra bits you need.  I
> guess you could do the same by creating all the files by hand first, and
> then copying&pasting in explorer and renaming everything everytime you
> wanted to start a new project.
I think this is perhaps part of the reason for the "you only need an IDE
if your language sucks" argument.
When you say it "generates all the necessary code and resource files",
what do you mean exactly? How much stuff do you need to make a form
application that opens one blank form? I would have thought you only
need to write a handful of lines of code - in which case, having it
autogenerated isn't saving you much effort.
In Haskell, I can fire up Glade, paint my UI, save it, and then write
maybe 6 lines of code in Haskell, hit compile, and I've got a GUI
application.
(Unfortunately if you want the application to *do* something, you start
having to write boilerplate code. For each button, you write one line of
code that says what function to run if somebody clicks it. That's pretty
much as minimal as boilerplate can *get*, but it's still tedious for a
complex UI.)
In something like Java, you end up writing miles and miles of
housekeeping boilerplate code just to get the thing to work. And that's
probably why people see an IDE as "necessary" when writing Java code.
The language itself is so unhelpful that you need an IDE to make the
task tractable.
I'm not saying IDEs are unecessary. I'm saying this is probably where
the "only pathetic languages need an IDE" argument comes from.
Now that does sound potentially useful.
So, what, it passes everything in scope as parameters? Or just
everything referenced?
> Or if you
> type a function name that doesn't exist yet, you can click and say
> "generate the boilerplate code for this function".
What's to generate? I'm presuming it just makes a one-line function
stub... unless you mean it does something more complex than that?
> Or you can go to
> "Insert -> New Class" and it will create a new file with the new class
> template in it.
Again, shouldn't an empty class be trivial to write in the first place?
> Or rename a variable and get the option to rename all
OK, now does it blindly rename it *everywhere*? Like just a find &
replace? Or does it actually apply scoping rules so that it knows it's
renaming "the same" variable throughout?
Smalltalk VisualWorks had a feature to rename a method, but
unfortunately it was a blind find & replace. If you wrote a class and
discovered that one of your method names as the same as some other
random class and you wanted to make it different, *all* the method calls
would get renamed. (Then again, Smalltalk doesn't have static class
information, so it's hard to do any better than that. Something
statically typed should be able to do this right.)
I can see how that might work...
It's also quite nice having the property pane that tells you what's in
your source file at a glance. (Especially if you're working with
something like JavaDoc that forces you to put unrelated junk in amoungst
the working code.)
Date: 1 Mar 2010 06:16:36
Message: <4b8ba214$1@news.povray.org>
> knows?
Most likely it's been improved a lot.
In C# to handle events you register the method you want called with the
event, it's 1 line:
button1.Click += new System.EventHandler(MyMethod);
The GUI automatically adds this line to the Form Design source file when you
tell it to (usually you don't need to open this file, it is just called from
the main source file).  But of course you can write that line yourself
anywhere to add/remove event handlers at runtime.
Well there's a "Form designer" file that holds any GUI elements you add,
that starts life as a pretty empty class definition (it just sets the class
name, Form title text and so on).  The main code file is again just an empty
class definition with an initialisor method that calls the form definition
file (about 10 lines total).  It also adds references to the project for the
assemblies you are likely to need (System.Windows.Forms, System.Drawing
etc), and a few settings for Windows forms.
> I would have thought you only need to write a handful of lines of code -
> in which case, having it autogenerated isn't saving you much effort.
You're right it doesn't save that much effort, but it's certainly easier to
start with that nice organised template rather than starting from scratch
each time.
>> Like if a function is getting a bit long, you can select a block of code
>> and say "extract this to another function".  All parameters and return
> So, what, it passes everything in scope as parameters? Or just everything
> referenced?
Everything that is used/needed by the code you selected that isn't
accessible from outside the original function is passed as parameters.  It
"just works" if you click it and then compile.
>> Or if you type a function name that doesn't exist yet, you can click and
>> say "generate the boilerplate code for this function".
eg if I type in "bool result = NewFunction(width,height);" and tell it to
make the stub, it will insert this immediately below the existing function:
private bool NewFunction(double width, double height)
 throw new NotImplementedException();
Again, not a huge timesaver, but it's so easy to use and it comes up so
often it's worthwhile.
>> Or you can go to "Insert -> New Class" and it will create a new file with
Sure, but it's something so common to do that even saving 30 seconds is a
benefit, especially if you want it in a new file, and that file to be saved,
added to the current project and opened in the IDE.
Of course it applies scoping rules, it would be a bit useless if it didn't.
> Smalltalk VisualWorks had a feature to rename a method, but unfortunately
> it was a blind find & replace. If you wrote a class and discovered that
> one of your method names as the same as some other random class and you
> wanted to make it different, *all* the method calls would get renamed.
That wouldn't really work in .net, as the same common variable names and
methods are used repeatedly in a huge number of classes (eg the "Value" or
"Text" property, or the ToString() method).  Of course people continue these
same conventions in their own code.
> your source file at a glance. (Especially if you're working with something
> like JavaDoc that forces you to put unrelated junk in amoungst the working
> code.)
Oh one more:
8) Right click and "Go to definition" on a method.  And of course the
View -> Navigate Back button afterwards :-)
Date: 1 Mar 2010 06:31:01
Message: <4b8ba575$1@news.povray.org>
>>> and say "generate the boilerplate code for this function".
> to make the stub, it will insert this immediately below the existing
> function:
It actually throws an exception to remind you that you need to implement
it, rather than just silently doing nothing? Oh, that's nice...
Is there some way to quickly find all the stubs you haven't filled out
yet? (Other than just running the program and hoping it throws an
exception so you can see the stack trace.)
> a benefit, especially if you want it in a new file, and that file to be
> saved, added to the current project and opened in the IDE.
OK, fair enough. I don't know about C#, but an empty class file in Java
is 2 lines. You tell VS what the class name is, and (hence the file name
MUST match the class name) it automatically saves it in the right place
with the right name. But sure, why not have it type the class
declaration as well? I guess it all helps. (Just so long as it doesn't
try to "help" by writing the entire application for you...)
OK, good.
> methods are used repeatedly in a huge number of classes.
Yah, that's kind of the problem. ;-)
As I say, in Smalltalk, you can't tell which class a given variable is,
so you can't tell if you're calling #reset on a network socket or a
customer object. Which means if you want to rename the customer class's
#reset method... yeah, good luck with that.
With a statically typed language, an IDE ought to be able to do better.
(And from the sound of it, VS does.)
> Oh one more:
So it's not just me who occasionally forgets where the **** I actually
defined the matrix inversion method? :-D
Date: 1 Mar 2010 12:15:22
Message: <4b8bf62a$1@news.povray.org>
Right. Because most people actually want that when writing code complicated
enough to need an IDE.
That said, you're aware that Java sucks in this regard, right? :-)
> like this at all.
You have to do it right. In my versions, renaming the file also renames the
class and all references to it.
> nontrivial,
Everything generated is in obj or bin, depending on whether it's
intermediate files or final executables. Does "nontrivial" mean "I had to
actually go take a look or read some documentation"?
Date: 1 Mar 2010 12:19:45
Message: <4b8bf731$1@news.povray.org>
Invisible wrote:
> If you're
I dunno. Just tried it, and "this." brought up the list of methods.
> typing",
Tab. Just like every other auto-complete system in existence.
Edit->Advanced->Reformat entire document
Dude, maybe rather than bitching that IDEs suck, you should give it a rest
until you've tried one written this millenium.
You know, that works pretty poorly if you have anything other than code
involved. If you're doing a video game and you need to import the audio,
graphics, models, and animations, once command line is unlikely to do it.
OK, so you have your development environment, non-integrated. So? What's
your point?
> What does that do?
Try it! Or at least google it. :-)
Date: 1 Mar 2010 12:27:11
Message: <4b8bf8ef$1@news.povray.org>
Actually, button1.Click += MyMethod;
works too, because one of the compiler passes sees this and fixes it for you.
It also sets up all the other stuff you need in a real commercial project,
like initializing the version number, adding a copyright to the executable's
properties box, etc.
A lot of what it does assumes you're writing a real program that more than
one person might some day use.
Plus, it initializes it with a bunch of namespaces you're likely to need in
that kind of class.
Control minus gets you back, also, if you want the keyboard shortcut.
You can also find all references to that method or class or variable
(excluding references to other variables with the same name).
Date: 1 Mar 2010 12:31:44
Message: <4b8bfa00$1@news.povray.org>
Of course. Search for NotYetImplemented.
(I'm kind of surprised there's no comment reading
    // TODO: Implement this
to make it show up in your to-do list.)
> is 2 lines.
It is in C# too, as long as you don't want to import any namespaces or have
a constructor or anything.
Date: 1 Mar 2010 14:58:11
Message: <4b8c1c53$1@news.povray.org>
> application.
Same in C#.  Actually, you don't have to write any code at all. The
boilerplate is created for you. What do you think Glade is doing, if not
generating boilerplate.
When you want to (for example) code a Windows service, or a plug-in for a
web browser, or a custom type for a SQL server, you're going to have more
boilerplate to hook those two together.
A sufficiently advanced language can turn any "boilerplate" into "library
code", but that's generally done by having the compiler running library code
at compile time.  Hence, LISP macros, FORTH dictionaries, etc. An IDE does
that for languages where the syntax doesn't include running arbitrary code
at compile time.
Date: 1 Mar 2010 16:13:23
Message: <4b8c2df3$1@news.povray.org>
...there's a regard in which Java does *not* suck?
(Actually, yeah, there is: The idea. It was a good idea. Unfortunately
they did it wrong...)
>> like this at all.
Right. Well let's not like anybody shows us how to use VS or anything.
They just acted like it was "obvious" or something.
>> And trying to figure out where VS stores them is nontrivial,
> to actually go take a look or read some documentation"?
If you're doing this stuff yourself by hand, you have a folder full of
*.java files. When you compile them, it creates *.class files. Oh, and
you have to have subfolders to patch the package structure, but that's
about it.
Create a VS project and you've got source files, project metadata,
several different compiled versions of the stuff, resource files,
packaged-up deployment files, JavaDoc files... It's not like you need to
be Leroy Gibbs to figure it out, but it's certainly not trivial.
Date: 1 Mar 2010 16:16:46
Message: <4b8c2ebe$1@news.povray.org>
>> application.
Actually it saves the GUI description as an XML file, which your program
then loads and parses at runtime.
> a web browser, or a custom type for a SQL server, you're going to have
> more boilerplate to hook those two together.
Now, see, to me these kinds of tasks all belong to the set of things
which are "impossible" in the first place, so I guess I don't tend to
think about it. You can't write web browser plugins unless you're a C
programmer, unfortunately.
> "library code", but that's generally done by having the compiler running
> library code at compile time.  Hence, LISP macros, FORTH dictionaries,
> etc. An IDE does that for languages where the syntax doesn't include
> running arbitrary code at compile time.
Heh, maybe.
Date: 1 Mar 2010 16:20:45
Message: <4b8c2fad$1@news.povray.org>
>> typing",
Hmm, I never thought of that. (This is before I encountered Unix.)
Wouldn't that just apply the incorrect formatting to the whole document?
> rest until you've tried one written this millenium.
I didn't say IDEs suck, I said autocomplete sucks. ;-) Or at least, the
two implementations of it I tried sucked...
...which is why people write batch files. ;-)
> your point?
No "point" as such, I'm just trying to get a handle on what the
perceived advantages of IDEs are, since it's apparently not possible to
live without one.
>> What does that do?
A human being is far more likely to give a useful overview. (Let's face
it, if I try it, I'll just spend an hour not being able to figure out
what it's supposed to be for.)
Date: 1 Mar 2010 17:26:06
Message: <4b8c3efe$1@news.povray.org>
Well, by "doign it right", it means anwering the right answer on the menu
that pops up, that says "Hey, you renamed a class, do you want me to rename
the references?"  Or "You renamed a file, do you want me to rename the class?"
> about it.
Yep. Now go add some native code, the icon that Windows should use for the
application, the icon it should use for documents, the files that translate
your UI into other languages, the prerequisites that have to be installed
(like other JAR files or the JVM runtime of the right version), the sample
data, the documentation, and the installer.
It's trivial to figure out where the compiler-generated files are. They're
in the subdirectory obj if they're intermediate object files, or bin if
they're executable binary files to be distributed. Since the idea of "obj"
vs "bin" has been around since roughly 1970, those terms shouldn't be a
suprise to any programmer.
Date: 1 Mar 2010 17:27:10
Message: <4b8c3f3e$1@news.povray.org>
Yes. As does Visual Studio. And what do you think the boilerplate does there
beside "load and parse at runtime" that XML? :-)
Of course you can.
Date: 1 Mar 2010 17:32:32
Message: <4b8c4080$1@news.povray.org>
It applies the formatting rules you asked it to apply. If you tell it to use
the "wrong" formatting rules, you'll get consistent but "wrongly" formatted
code. Which would be "the" incorrect formatting?
>> code involved. If you're doing a video game and you need to import the
>> audio, graphics, models, and animations, once command line is unlikely
>> to do it.
So you're going to maintain a batch file that first compiles the code needed
to parse the video game animations, then the code that writes them out, then
runs the animations through that, then put them in the right place?
Why in the world would you do that when it has already been written for you?
And again, yes, people write batch files because they're unfamiliar with
IDEs. You realize that's not a *good* thing, right?
> live without one.
It is if you're doing something small enough. But then, you can live without
batch files too if you never type the same command more than twice.
The advantages of an IDE over a DE is that it's integrated.
>>> What does that do?
You know what a template is in documents, right? Corporate report template?
Vacation time reporting template? Request for purchase of networking
equipment template?
Same thing, for code.
I want to write a game. I want to write a windows service. I want to write a
new type for a SQL database engine.  I want to build a web application.
 > I'll just spend an hour not being able to figure out what it's supposed
to be for.
That's because you never practice the skill, so you never improve at it.
Date: 1 Mar 2010 17:32:34
Message: <4b8c4082@news.povray.org>
> the dependencies between files), and you have gone a long way towards an
> IDE.
I use the CMake build system, where you just write this:
add_executable(myraytracer main.cpp spheres.cpp lights.cpp)
...and it handles the dependency mess for you. You don't need an IDE for
that.
I also use the KDevelop IDE, which does not ever edit the makefile (or
CMakeLists) for you.
Date: 1 Mar 2010 17:35:21
Message: <4b8c4129$1@news.povray.org>
Or QMake. By the time you need this sort of stuff, your program has grown
wildly out of the norm tho. :-)
Date: 1 Mar 2010 18:19:52
Message: <4b8c4b98@news.povray.org>
> that.
  I said that automatic dependency resolving goes a long way towards an IDE,
I didn't say it's sufficient. I also nowhere said that "you need an IDE if
you want to resolve dependencies automatically".
  (Besides, what is *your* definition of "IDE", if CMake isn't one?)
Date: 1 Mar 2010 19:21:32
Message: <4b8c5a0c$1@news.povray.org>
CMake is just a new version of make, or a makefile generator, I forget
which. It's not integrated, and it's not an environment, any more than make
itself is.
Date: 1 Mar 2010 19:59:05
Message: <4b8c62d8@news.povray.org>
> itself is.
  You said what CMake is/isn't, not what an "IDE" is...
Date: 1 Mar 2010 20:47:02
Message: <4b8c6e16$1@news.povray.org>
>> itself is.
You weren't talking to me. :-)  I wasn't sure you knew what cmake was, so I
was clarifying that it wasn't an IDE. :-)
I don't consider cmake a development environment. It's one tool that's part
of some development environments.
Date: 2 Mar 2010 00:00:01
Message: <web.4b8c9a47c7641e1cfbacf1b0@news.povray.org>
> > itself is.
bash is a pretty good IDE to me.  It integrates/glues all other dev tools
needed. :)
Date: 2 Mar 2010 04:35:42
Message: <4b8cdbee$1@news.povray.org>
>> program then loads and parses at runtime.
> there beside "load and parse at runtime" that XML? :-)
Surely it's just 1 line of code? (Unless you want to do something
special to determine where to find the XML file...)
> Of course you can.
Oh, yeah, I forgot. You could be a C++ programmer. ;-)
Date: 2 Mar 2010 04:54:04
Message: <4b8ce03c$1@news.povray.org>
Or rather, it applies the default formatting rules, whatever they happen
to be for the IDE in question.
For example, both JBuilder and VS put the opening bracket of a function
on the same line as the function declaration, rather than on the next
line where it belongs. They also indent everything by 8 spaces rather
than the usual 2. And so on. (I'm not even sure *what* formatting rule
they apply to if-statements...)
> needed to parse the video game animations, then the code that writes
> them out, then runs the animations through that, then put them in the
> right place?
> you?
Yeah, if your application was actually that complex, you'd probably use
make or similar.
> without batch files too if you never type the same command more than twice.
OK, fair enough.
Large numbers of people apparently think that it's just infeasible to
write any code of any kind unless you have an IDE specifically targetted
at the programming language you're using. But to me, it looks like an
IDE is only really beneficial if you're actually doing something
complex. (And, further more, it looks to me that the tipping point is
when you start writing something more complex than any program I've ever
attempted in my entire life - so an IDE is probably of little to no use
to me...)
>>>> What does that do?
> template? Vacation time reporting template? Request for purchase of
> networking equipment template?
Sure. But "Windows app" template? What could possibly be in it?
It's like, you have a template for a purchase request. Or a template for
a procedure document. But you know what you *don't* have a template for?
A document. Because, let's face it, what would a template for "a
document" actually contain?
Similarly, "a Windows application" could be absolutely anything. How do
you template that?
> write a new type for a SQL database engine.  I want to build a web
> application.
Maybe it's because I've never written any of these things, but I can't
imagine what (for example) two games would have in common. (And hence,
what you'd put into a template.)
>> supposed to be for.
This statement is not falsifiable.
Date: 2 Mar 2010 05:18:15
Message: <4b8ce5e7$1@news.povray.org>
Actually if you install XNA with VC# then you can go File -> New -> Windows
Game and then press F5 and you will have running a game skeleton program
which is very easy to add stuff too.  In fact you can also choose
"Platformer Starter Kit" as a new project and have a playable platform game
as a template!  Then go Build -> Publish... and it creates a standalone
installer to distribute, it doesn't get any easier than this to code games
on Windows/XBOX!
Date: 2 Mar 2010 05:36:47
Message: <4b8cea3f$1@news.povray.org>
> For example, both JBuilder and VS put the opening bracket of a function on
> the same line as the function declaration, rather than on the next line
> where it belongs.
In VS Express (the free one):
Options -> Text Editor -> (Language) -> Formatting -> New Lines -> "Place
open brace on new line for xxxx" where (xxx) is a number of different
options.  Feel free to tick all these (actually they seem to all be ticked
by default, it's the style I prefer too).
>  They also indent everything by 8 spaces rather than the usual 2. And so
> on. (I'm not even sure *what* formatting rule they apply to
> if-statements...)
Options -> Text Editor -> (Language) -> Tabs -> "Tab Size" or "Indent size"
Why don't you just spend 5 minutes setting the options to your preference?
Err, the headers and namespaces for graphics, audio and input libraries,
build processors set up for graphics files, meshes, sound files etc, a game
loop with empty functions for you to add your game logic and graphics code,
pre-existing code for initialising the graphics API and painting the updates
into the window each frame, a framework for adding "components" to your game
that can be easily enabled/disabled and automatically called/rendered, etc.
Just download VC# and XNA and ask it to make a new "Game" project - there's
a lot of useful common stuff in there that makes your job way easier.
Date: 2 Mar 2010 05:55:42
Message: <4b8ceeae@news.povray.org>
>> function on the same line as the function declaration, rather than on
>> the next line where it belongs.
> "Place open brace on new line for xxxx" where (xxx) is a number of
> different options.  Feel free to tick all these (actually they seem to
> all be ticked by default, it's the style I prefer too).
When I looked at this stuff, there were 3 different options you could
select. I tried all three, and none of them did what I want. (Curiosly,
there didn't seem to be an option for "disable all autoformatting and
just let me do it by hand".)
As I say, when I tried it there wasn't much you could adjust.
> game loop with empty functions for you to add your game logic and
> graphics code, pre-existing code for initialising the graphics API and
> painting the updates into the window each frame, a framework for adding
> "components" to your game that can be easily enabled/disabled and
Now, to me, that sounds like it's just going to build a bunch of
boilerplate code for how the designers invesage a game would be
structured, and if you want your game structured a different way you're
going to have to waste time deleting the template stuff and rewritting
it the way you want it.
Similarly, I obviously haven't written many games (currently at zero and
counting), but I would have hoped that "initialising the system" would
already be a fairly painless task. (Isn't this what we have libraries for?)
I'm not quite sure what "build processors set up for graphics files,
mashes, sound files etc" is supposed to mean.
> there's a lot of useful common stuff in there that makes your job way
> easier.
Well, yeah, there is always that. (Although not understanding C#,
presumably none of it will make sense anyway...)
Date: 2 Mar 2010 06:15:44
Message: <4b8cf360$1@news.povray.org>
> going to have to waste time deleting the template stuff and rewritting it
Sorry but I never heard of anyone making a game that didn't have a "game
loop" and methods for rendering and methods for the game logic.  Obviously
you are free to delete those and make your own, or just start from scratch.
They are just providing the most common structure, as most people will want
that anyway.
> for?)
Sure, it's just the odd line here and there for creating a
GraphicsDeviceManager, a content loader object, a sprite/texture manager
object, method calls to clear and redraw the frame, that sort of thing.  No
more than a handful of lines of code, but it's easier to have it done for
you in a nice structure than to have to start from scratch each time.
So that you can go "Add to project..." and include a JPEG, PNG, WAV, MP3,
BMP, X (3D mesh) or whatever and at the build stage it will convert your
file into a format suitable/optimised for the game (eg mipmaps for the
textures).  It saves you have to export all your data files in some specific
format just to get them to work with your API, the build processor just does
it seemlessly (obviously it detects if there has been an update or not).
FYI here's the raw template code it gives you when you create a new game (it
looks better in the IDE than in plain text):  Now maybe it's just me, but I
quite like it doing that automatically for me rather than having to
remember/type that all each time I want to mess about quickly with a little
graphics demo or whatever.
using System;
using System.Collections.Generic;
using System.Linq;
using Microsoft.Xna.Framework;
using Microsoft.Xna.Framework.Audio;
using Microsoft.Xna.Framework.Content;
using Microsoft.Xna.Framework.GamerServices;
using Microsoft.Xna.Framework.Graphics;
using Microsoft.Xna.Framework.Input;
using Microsoft.Xna.Framework.Media;
using Microsoft.Xna.Framework.Net;
using Microsoft.Xna.Framework.Storage;
namespace WindowsGame3
    /// <summary>
    /// This is the main type for your game
    /// </summary>
    public class Game1 : Microsoft.Xna.Framework.Game
        GraphicsDeviceManager graphics;
        SpriteBatch spriteBatch;
        public Game1()
            graphics = new GraphicsDeviceManager(this);
            Content.RootDirectory = "Content";
        /// <summary>
        /// Allows the game to perform any initialization it needs to before
starting to run.
        /// This is where it can query for any required services and load
any non-graphic
        /// related content.  Calling base.Initialize will enumerate through
any components
        /// and initialize them as well.
        /// </summary>
        protected override void Initialize()
            // TODO: Add your initialization logic here
            base.Initialize();
        /// <summary>
        /// LoadContent will be called once per game and is the place to
load
        /// all of your content.
        /// </summary>
        protected override void LoadContent()
            // Create a new SpriteBatch, which can be used to draw textures.
            spriteBatch = new SpriteBatch(GraphicsDevice);
            // TODO: use this.Content to load your game content here
        /// <summary>
        /// UnloadContent will be called once per game and is the place to
unload
        /// all content.
        /// </summary>
        protected override void UnloadContent()
            // TODO: Unload any non ContentManager content here
        /// <summary>
        /// Allows the game to run logic such as updating the world,
        /// checking for collisions, gathering input, and playing audio.
        /// </summary>
        /// <param name="gameTime">Provides a snapshot of timing
values.</param>
        protected override void Update(GameTime gameTime)
            // Allows the game to exit
            if (GamePad.GetState(PlayerIndex.One).Buttons.Back ==
ButtonState.Pressed)
                this.Exit();
            // TODO: Add your update logic here
            base.Update(gameTime);
        /// <summary>
        /// This is called when the game should draw itself.
        /// </summary>
values.</param>
        protected override void Draw(GameTime gameTime)
            GraphicsDevice.Clear(Color.CornflowerBlue);
            // TODO: Add your drawing code here
            base.Draw(gameTime);
Date: 2 Mar 2010 06:28:45
Message: <4b8cf66d@news.povray.org>
> MP3, BMP, X (3D mesh) or whatever and at the build stage it will convert
> your file into a format suitable/optimised for the game (eg mipmaps for
> the textures).
Oh, OK. I didn't realise there was a conversion step there.
> (it looks better in the IDE than in plain text):
That's actually not too bad...
