If your answer is "it's not", you can probably stop reading now.
I've been thinking about the things that make Haskell interesting. Of
course, the main one is that it's a 100% functional language (as opposed
to an OOP/FP hybrid like Objective Camal), so if you want to see what
functional programming is like, Haskell is the place to go. But on
reflection, Haskell has several interesting and/or useful attributes
which actually have little or nothing to do with functional programming.
Haskell has automatic type inference, for example. You don't *need* a
functional language for that; you could totally do it in a normal
language. It's just that, historically, nobody has. (I guess the sort of
people who think about computer programs mathematically also tend to be
the sort of people who realise that things like type signatures can be
derived algorithmically.)
Everybody thinks that a programming language has to either have explicit
types (Pascal, C, C++, Java, Eiffel...) or no static typing at all
(Smalltalk, Tcl, JavaScript, every scripting language known to
mankind...) Haskell demonstrates that there is a Third Way: static
typing, but with the types implicit rather than explicit.
Obviously, there are times when either you NEED to be explicit - because
the correct answer is ambiguous, because you want improved performance,
whatever. There are also times when it's just "good style" to be
explicit; top-level functions should usually have type signatures. But
you don't have to write a signature for every single damned expression
and variable you use in the entire program; the compiler will figure it out.
Another thing Haskell has is parametric polymorphism. If you write some
code that makes data around, it shouldn't *matter* what the hell the
type of the data is. I mean, if you don't "do" anything with it other
than move it, what does it matter? So, for example, it should be
possible to write a function that joins two containers together,
regardless of what kind of element data they contain. (Obviously the
type of the containers themselves matters, but not the type of whatever
they contain.)
This pre-supposes that you have type-safe containers in the first place.
In most OO languages, you just create a container of "Object", which can
then contain anything. If you particularly want a container to contain,
say, only Customer objects, you usually have to implement this yourself,
by hand.
More recently, a couple of OO languages have introduced this feature
they call "generics". Eiffel is the first language I'm aware of that did
it, although I gather Java has it too now. What it allows you to do is
write a class parameterised by another class; the typical case being a
container class parameterised by the class of element it contains. (In
Eiffel, integers and floats are classes, unlike the Java brokenness.)
The difference is that Eiffel makes this seem like some highly complex
uber-feature that only a few people will ever need to use, in special
circumstances. Haskell makes it trivial. Defining a parametric type
requires barely a few keystrokes more than defining the same thing with
no parameters.
C++ has templates, and people often compare this to generics. I'm not
sure why. As far as I can tell, templates not even remotely similar to
generics.
- Generics are an extension to the type system which allow the type
checker to handle more sophisticated type signatures.
- Templates are, as best as I can tell, preprocessor macros on steriods.
They automate the process of creating a new, seperate, class for each
combination of parameter values. It's like copy & pasting each time you
want a new container class, except the template preprocessor automates
it for you. This is clearly very much more maintainable, but not the
same as extending the type checker.
It seems that templates can also be used to do things which are
impossible with generics (e.g., making the implementation *different*
for certain special cases). So I'm not sure why people compare them at
all, because they're so totally different.
Another thing Haskell has is algebraic data types. Other languages could
have this. It probably doesn't play well with the OO method though. In
fact, let me expand on that.
The OOP notion of classes, inheritance, substitution and so forth
basically assumes a model where you can always extend the current class
hierachy. For example, you initially decide what (conceptual) properties
every widget must have and write that in an abstract class. Thereafter,
you can always add new kinds of widget. (Or even specific kinds of
widget, of course.) It's a system that works fairly well.
Haskell with its algebraic data types assumes that the data you're
trying to model has a fixed, finite set of possibilities, which you can
describe once and for all. If that sounds stupid and limiting, consider
a binary tree. Every node in a binary tree is either a leaf node or a
branch node. You will never, ever, need to add a new kind of node. (If
you did, it wouldn't be a *binary tree*. It would be something else.)
So the data structure of a binary tree can be described once and for
all. However, the operations you can perform on it is extensible; you
can always add new operations.
Now consider the OOP case. You write an abstract "tree" class with
concrete "leaf" and "branch" subclasses. Each time you want to do
something new with the tree, you write an abstract method in the tree
class and add half of the implementation to each of the two concrete
subclasses.
In Haskell, you write one line of code which says "a tree is either a
leaf containing an item, or a branch containing two subtrees". You then
write as many functions as you like, which handle the leaf and branch
cases together, in one place (not split between three places).
For a binary tree, or an abstract syntax tree, or any number of other
simple, ridigly-defined data structures you could envisage, this
approach is actually much better. If you're writing a compiler or
interpretter, you don't *need* the abstract syntax tree to be
extensible. But you probably *do* need to be able to add new program
passes and code manipulation functions all the time. (And letting the
data structure be parameterised is probably Very Freaking Useful. Part
of the compiler might use strings for names, while another part might
use some more sophisticated structure representing fully-qualified
names, for example.)
Now let's flip this and look at widgets again. Using the ADT approach,
you'd need a giant "widget" type capable of representing any possible
widget. And functions that all know how to handle any possible widget.
And the code for handling a specific widget type is scattered between
all the widget-handling functions.
You're never ever going to need to add new functions for handling "any
possible widget" (although you might want one for handling a *specific*
kind of widget). But you very likely *will* want to add new types of
widget. But, uh, you can't.
In summary:
- If you have a limited number of structures which you want to process
in an unlimited number of ways, ADTs work best.
- If you have an unlimited number of structures which you want to
process in a limited number of ways, a class hierachy works best.
Haskell, of course, has to go one better: Haskell has what it calls
"classes", but really they're "interfaces". And you can add them after
the fact. Which means you can grab a bunch of unrelated data types
(possibly that you didn't even write) and create a single interface for
processing them all.
The one small glitch is that Haskell demands that all types are known at
compile-time. Which means that doing OO-style stuff where types are
changed dynamically at run-time is a little tricky. Haskell 98 (and the
newly-released Haskell 2010) can't do it, but there are
widely-implemented extensions that can. It gets kinda hairy though.
Married side by side with ADTs are case expressions. Now other languages
have case statements, but they tend to be quite feeble. In most
languages they only work on integers; I *think* Pascal lets you use 'em
on enumerations [but I'm not really sure]. And in C-like languages, you
can execute multiple alternatives at once. While this is no doubt
occasionally useful, most of the time it's just a source of
infuriatingly hard to find bugs (i.e., you left off the "break"
statement, so a whole bunch of code gets executed when you didn't want
it to).
In Haskell, case expressions work on *everything*. (Everything who's
internal structural details are in scope, anyway. These internal details
can be hidden from client code.) What is more, they use "pattern
matching". This powerful feature allows you to do things like determine
whether a tree has a particular shape and pluck several deeply-burried
substructures out of it, all in a single transparent 1-liner. For example,
case list of
[[x], [y,_], [z,_,_]] -> foo x y z
This checks whether "list" contains a list with exactly 3 elements, each
of which is a sublist of length 1, 2, 3 (respectively) - and, if all
this is the case, it fishes out the first element of each sublist and
feeds all the data to the "foo" function. All in one easily-readble line
of code. The alternative in Java would be something like
if (list.length == 3)
if (list.At(0).length == 1)
int x = list.At(0).At(0);
if (list.At(1).length == 2)
int y = list.At(1).At(0);
if (list.At(2).length == 3)
int z = list.At(2).At(0);
foo(x, y, z);
which is obviously a hell of a lot longer. What is more, if your Haskell
case expression has multiple cases in it (which it usually does),
because of the declarative form of the patterns, the compiler can
rearrange the code so that each test need only be performed once, and
the compiled code can proceed with the minimum number of branch
instructions. Such things are far, far harder to do with the
deeply-nested forest of if-statements above. (Not to mention that the
expressions in the if-statements might actually alter the program's
state, so changing their order may alter the program!)
Again, this probably doesn't gel too well with OOP, which states that
each data structure ("object") should be responsible for its own
internal substructure. In other words, you shouldn't *need* to fish out
deeply-burried data, the intervening objects in the chain should be
doing this for you. According to "the OO way", the only thing you should
ever do to objects is call methods on them, not inspect them for type
information or substructure.
But something like, say, JavaScript (which isn't really OO in the first
place) could certainly make use of ADTs and/or pattern matching, I think.
Another big deal about Haskell is how functions are first-class. The
fact that functions are pure makes this a really big win, but even
without pure functions, it's still useful. (Smalltalk implements it, for
example.) It doesn't immediately sound very interesting, but what it
enables you to do is write a loop once, in a library somwhere, and pass
in the "loop body" as a function.
A trivial example is a "fold". A fold takes some container (e.g., a
list) and repeatedly applies a binary function to it. The canonical
example is
sum = fold (+) 0
This says that to calculate the sum of a list, you fold it using the "+"
function, and with a starting value of 0. (This also means that the sum
of a completely empty list is 0.) It is obvious that
product = fold (*) 1
but there are plenty of other uses too. For example, the (++) function
joins to lists together, and
concat = fold (++) []
turns a list-of-lists into a single giant list. Other examples include
minimum = fold1 min
maximum = fold1 max
which find the minimum or maximum of a list using the binary "min" and
"max" functions. (The "fold1" function demands that the list be
non-empty, and doesn't require a start value.) I could go on all day,
but it turns out almost all uniform list operations can be implemented
as a fold of some kind.
Other languages have done this. Smalltalk is the obvious example. It has
#do: and #collect: which are approximately equivilent to Haskell's
"map", #select: and #reject: which are Haskell's "filter", and many
more. Of corse, being an object-oriented language, Smalltalk makes all
these methods work nicely for all container types, not just lists.
(Haskell hasn't copied this trick yet. At least, not in the *standard*
libraries. It's not difficult to change container, but it's tricky to
write code that works generically for any container.)
The other thing about first-class function is that in both Haskell and
Smalltalk, it is utterly trivial to spawn a new thread:
forkIO foo [foo] fork
What Smalltalk doesn't do, and Haskell does, is make combining small
functions into larger functions trivial as well. Haskell has anonymous
"lambda functions", it has the function composition operator, it has
curried functions, it has the dollar operator, and so on and so forth.
All of this *could* be put into Smalltalk, or any other OO language for
that matter. (Whether it would be efficient is a whole other matter...)
The final thing that's interesting about Haskell is the rate at which it
changes. Haskell (or rather, GHC) implemented Software Transactional
Memory 5 years ago. I'm not aware of any mainstream languages that have
this yet. GHC added Data Parallel Haskell 2 years ago, and the busy PhD
researchers are still hard at work getting it into a usable state.
(There's even an experimental GPU backend already.) Around the same
time, Type Families were added. (How long did it take Java to do
Generics?) The pace of change is staggering. Lots of new and very cool
stuff happens in Haskell first. (No doubt it will eventually all be
stolen by lesser languages so that people still don't use Haskell itself.)
Invisible <voi### [at] dev null> wrote:
> Of course, the main one is that it's a 100% functional language
I thought that a 100% functional language has no mutable data structures
nor functions with side-effects.
> generics.
Yeah, templates are a lot more powerful and versatile.
Templates are not used only to generate classes, but also functions and
basic types. Template parameters can also be of almost any type (classes,
basic types, other templates, etc.) Also, templates can be recursive, which
is rather huge.
In short, templates allow compile-time polymorphism (as opposed to runtime
polymorphism in most OO and functional languages).
Technically, Haskell is such a language. Technically, a Haskell program
itself doesn't produce any side-effects, it just constructs a data
structure and passes it to the Haskell Runtime System. The Haskell
Runtime System is what performs these side-effects.
That may sound like splitting hairs, since any compiled, runnable
Haskell program consists of your source code AND the Runtime System,
running as a single OS entity. In practical terms, you can "in effect"
mutate things in Haskell, and cause other side-effects. (This is of
course quite deliberate.)
Most "functional" languages allow you to perform side-effect anywhere,
any time you like. It is up to you to not screw this up. Haskell is
genuinely different. All side-effects are tightly constrained and
controlled, and the system provides strong guarantees about them. This
is why I feel it is justified to describe Haskell as "purely functional".
(That and the fact that it clearly has no OO features, no relational
features, no logical features, etc. It's definitely not mixed with any
other paradigm.)
>> generics.
This was my conclusion also.
> basic types.
Yes, I was simplifying. (The paragraph was already bigger than I would
have liked, given the simplicity of the basic point I was attempting to
express.)
Seems like a nice way to sum it up.
I also forgot to mention Template Haskell. This GHC extension allows you
to run arbitrary Haskell code inside the compiler. It can [in principle]
do anything normal Haskell code does - read files, open network sockets,
etc. But it can also do things to the compiler - most obviously, it can
generate source code and feed it into the compiler.
You could use this to (for example) read a text file containing a BNF
grammer and generate the source code for a parser for it. But then, you
could do that without TH; just save the source code as a text file and
then compile it as a seperate step. The interesting part is that TH can
query the compiler. For example, it can read the description of a
datatype and write some boilerplate code for it. (But hey, if you need
to write boilerplate, doesn't that just mean that your language sucks?)
C has cpp, which (as far as I know) is very primitive and not
Turing-complete. C++ has templates, which are quite sophisticated.
Haskell has TH, which is obviously Turing-complete. I have no idea how
Lisp macros work, so I can't compare. (I believe Lisp macros can
generate code at runtime, however, which TH definitely cannot do.)
Lots of languages have this a little. In C# you can say
var x = new Vector2(0,3);
and x gets the type Vector2. Automatic casting in languages is a similar
thing, methinks.
Certainly not to the large scale that Haskell does it.
This hasn't been true for a decade or more. :-) Just because Java sucks,
don't think every statically typed language sucks the same way.
Java kinda sorta has it. It's *really* a container full of Objects, with
syntactic sugar to wrap and unwrap them. (Similarly, "inner classes" are
just regular classes with munged up names.)
> circumstances.
No, Eiffel's complexity is due to inheritance. If you have an array of
Animals, can you put a Dog in it? If you have an array of Dogs, can you pass
it to a routine that expects an array of Animals? Can you return an array of
Dogs from a routine declared to return an array of Animals or vice versa? If
X multiply inherits from Y and Z, can you assign an array of X to an array of Y?
It's not the complexity of the feature as much as its interactions with
other features of the type system.
They get compared because it's as close as C++ has to having real generics,
and C++ aficionados don't want to admit they don't have generics. ;-)
It's interesting that Eiffel is explicitly an attempt to make algebraic data
systems on top of OOP, in a sense. Hence the invariants, preconditions, etc.
Integers are finite?
> subclasses.
I've never seen it done that way. :-)
It depends how complex your tree is vs how complex your operations. If your
data is simple and your operations are complex, you're going to get
different trade-offs than if your data is complex and your operations are
simple. If a tree could have 300 different types of nodes, but you'll only
have 3 operations, which is better? Then invert that.
As you say, it depends what kind of extensibility you want. Add 50 new kinds
of nodes. Add 50 new operations. OOP was envisioned as adding new kinds of
things. New kinds of cars to a traffic simulation, new kinds of bank
accounts to a financial analysis program, etc.
Other than that, I'm not sure I really understood what you're talking about
in terms of "using the ADT approach" bit.
Yes, that. Well, not even a "limited number of ways." The point of OOP is
that you can add new structures *without* changing existing structures *at
all*.
It also means you have to recompile everything whenever you change a type.
Which kind of sucks when it takes several days to compile the system.
> it to).
This is one that C# finally fixed right. Every branch of a switch has to end
with "break" or "goto". You're allowed to "goto" another case label, so you
can emulate "falling through." But even then, you can rearrange cases or
insert another case anywhere in the list without breaking any existing
cases. With a fallthrough, if you add a case without realizing the previous
case falls through, you just broke the previous case.
Pattern matching is indeed cool in some set of circumstances.
Yet, oddly enough, will work on things that *aren't lists*. That's the
point. :-)
Yep. And that's because you can substitute a new object and still use the
same code. Your pattern match wouldn't work at all if you said "Hmmm, I'd
like to use that same function, only with a set instead."
Huh? Javascript is about as OO as Smalltalk is. There's nothing in
Javascript that is *not* an object.
Lots of languages have this, just so ya know. :-)
Smalltalk doesn't have first-class functions. It has first class blocks,
which are closures (or continuations, more precisely). You're not passing a
function to #do:. You're passing a stack frame.
That's because Smalltalk doesn't have functions. It has methods. And blocks.
And continuations.
Not... really. The difference is that Haskell functions work on data, while
Smalltalk only has objects. In other words, you can't invoke a function
without knowing what object that "function" is a method of. (This is also
the case for Javascript, btw.)
C# has lambdas and anonymous expressions and stuff like that. It also has
"delegates", which is a list of pointers to object/method pairs (or just
methods, if it's a static/class method that doesn't need an instance).
> I'm not aware of any mainstream languages that have this yet.
Several languages have implemented this as libraries. Generally not for
threading but for database stuff.
> (How long did it take Java to do Generics?)
It wasn't that generics took a long time. It's that the owners of the
language didn't want them, for whatever reason. Then, once Java was popular,
it was impossible to change the JVM classfile format without killing what
little momentum Java still had, so they had to be shoehorned in. See above.
I.e., it took Java a long time to do Generics *because* people cared about
Java. ;-)
I mean, Python has explicitly said "We're going to not change anything in
the language spec for 2 to 3 years until everyone else writing Python
compilers/interpreters catch up."
It's easy to innovate when you have the only compiler.
That's not hard to do when you have no user base you have to support.
The question in today's corporate environment is not
so much "what color is your parachute?" as it is
"what color is your nose?"
I don't think macros are still around at runtime. What they *can* do is read
user input at compile time, so you can (for example) make up new kinds of
literals.
Assume Haskell doesn't have the "0xABC" kind of syntax for hex literals.
Could you add that with Haskell, or TH?
> thing, methinks.
The next C++ standard will instroduce something similar: The 'auto' type.
The idea is that since the compiler can deduce the type of the variable in
most situations, then why should the programmer have to specify it explicitly?
Thus you will be able to write things like:
for(auto iter = v.begin(); iter != v.end(); ++iter) ...
The compiler can see what is the return type of v.begin(), so there's no
need for the programmer to know it. Hence he can just specify 'auto' as the
variable type.
This will be more than just a convencience shortcut, though. For example,
it allows doing something like this:
template<typename Container>
void foo(const Container& container)
auto element = container[0];
The type of the element may differ from container to container, and if
you need a variable of that type, previously there was no fool-proof way
of doing that. (The usual way around this to define a typedef inside the
container named "value_type" which defines the type of the elements, but
the 'auto' keyword will eliminate the need for that.)
"Invisible" <voi### [at] dev null> wrote in message
news:4b87d781@news.povray.org...
I know it's interesting to *me* because I'd never heard of it before I
started reading this newsgroup. Always like learning something new... :-)
Jack
> variable type.
That's a nice touch. Presumably this also means that if the type of "v"
changes, you don't have to manually change the type of "iter" to match
any more...?
http://blog.orphi.me.uk/
> > variable type.
> any more...?
Right.
Just out of curiosity, just how new *is* C#?
...there are statically-typed OO languages which aren't Java? [Or
Eiffel, which nobody ever uses.]
C++ is statically-typed, but even Warp will agree it's not a
specifically OO language; it's more of a pragmatic hybrid of styles.
>> did it, although I gather Java has it too now.
Oh dears.
> (Similarly, "inner classes" are just regular classes with munged up names.)
Yeah, that's what I would have expected.
>> circumstances.
All I know is that Eiffel makes it seem like this really exotic feature
that you "shouldn't need to use" under normal circumstances, and if you
find yourself using it, you've probably designed your program wrong.
Even C++ templates make it seem like a pretty big deal.
Haskell, on the other hand, makes it trivial.
> data systems on top of OOP, in a sense. Hence the invariants,
> preconditions, etc.
Uh... what?
>> can describe once and for all.
They are if there fixed-precision. ;-)
In fact, if you want to be really anal, if they're stored on a computer
that exists in the physical world, they're finite, since the amount of
matter [and energy] in the observable universe is finite. But I'm sure
that's not what you meant.
>> subclasses.
Oh really? So how would you do it then?
I could have sworn I just said that. ;-)
> kinds of nodes. Add 50 new operations. OOP was envisioned as adding new
> kinds of things. New kinds of cars to a traffic simulation, new kinds of
> bank accounts to a financial analysis program, etc.
Indeed. You do NOT want to design one giant ADT that represents every
possible kind of bank account, and write huge monolithic functions that
understand how to process every possible kind of bank account. It's
non-extensible, and all the code relating to one particular type of
account is scattered across the different account processing functions,
so it's the wrong way to factor the problem.
My point is that there are major classes of problems which *are* the
other way around, and for that ADTs win. For example, the parse tree of
an expression. You are almost never going to add new types of node to
that, but you *are* going to be adding new processing passes all the
time. For this, Haskell's ADT + functional approach factors the problem
"the other way", and that works out better for this kind of problem.
And when it doesn't work out right, you use interfaces and get the
essence of the OO solution.
> Yes, that.
LOL!
> is that you can add new structures *without* changing existing
> structures *at all*.
And I was pointing out that for each thing you want to do to a
structure, you have to add new methods up and down the inheritance hierachy.
Ultimately, if you have a kind of structure that you need to perform a
bazillion operations on, what you'll hopefully do is define a set of
"fundamental" operations as methods of the structure itself, and define
all the complex processing somewhere else, in terms of these more
fundamental operations. (If you take this to the extreme, you obviously
end up with dumb data objects, which usually isn't good OO style.)
>> at compile-time. Which means that doing OO-style stuff where types are
>> the newly-released Haskell 2010) can't do it, but there are
> type. Which kind of sucks when it takes several days to compile the system.
Are there systems in existence which actually take that long to compile?
Anyway, Haskell extensions allow you to do runtime dynamic dispatch.
That means you don't have to recompile your code. [Although you will
have to relink to add in the new types you want to handle, etc.] It's
just that it pisses the type checker off, which means you can't do
things you'd normally expect to be able to do.
(In particular, the basic ExistentialQuantification extension allows
typesafe upcasts, but utterly prohibits *downcasts*, which could be a
problem...)
>> (i.e., you left off the "break" statement, so a whole bunch of code
>> gets executed when you didn't want it to).
Oh thank God...
Aye.
(Jay. Kay. El...)
> point. :-)
Well, you can pattern match on the size of the container (presuming you
have a polymorphic "size" function to get this). It won't be quite as
neat though, obviously.
Secondly, there's actually an experimental extension to Haskell called
"view patterns" which allow you to create sort-of "user defined pattern
matching". This fixes this exact problem. (And a couple of others.)
> the same code. Your pattern match wouldn't work at all if you said
> "Hmmm, I'd like to use that same function, only with a set instead."
Yes, in general pattern matching is used for implementing the "methods"
for operating on one specific type. (Although of course in Haskell they
aren't methods, they're just normal functions.) Your polymorphic stuff
is then implemented with function calls, not pattern matching. But see
my previous comments.
1. Smalltalk has classes. JavaScript does not.
2. Smalltalk has encapsulation. JavaScript does not.
Yeah. Smalltalk, JavaScript, Tcl after a fashion. C and C++ have
function pointers, and you can sort-of cludge the same kind of
techniques as found in Haskell. (But you wouldn't. It would be
horrifyingly inefficient.)
> which are closures.
I won't pretend to comprehend what the difference is, but sure.
> blocks. And continuations.
Plausibly.
>> for that matter. (Whether it would be efficient is a whole other
>> matter...)
> while Smalltalk only has objects. In other words, you can't invoke a
> function without knowing what object that "function" is a method of.
> (This is also the case for Javascript, btw.)
Erm... no, not really.
function foo(x) {...}
var bar = foo;
var x = bar(5);
No objects here, no methods, just assigning a function to a variable and
using it later. You *can* make a function an object method, but you do
not *have* to. JavaScript is like "meh, whatever, dude. I'm green."
> has "delegates", which is a list of pointers to object/method pairs (or
> just methods, if it's a static/class method that doesn't need an instance).
Eiffel has... uh... "agents"? Which are basically GUI callback
functions, but we wouldn't want to have actual functions, would we?
Yeah. Databases have been transactional for decades, and many languages
can access a database. But STM is all internal to the program, and
implements multi-way blocking and conditional branching and all kinds of
craziness.
I'd point you to the paper I just wrote about implementing it using
locks... but then you'd have my real name. The long and short of it is,
it boils down to running the transaction *as if* there are no other
transactions, but not actually performing any real writes. Then, when
we've discovered exactly what the transaction wants to do to the central
store, we take all the locks in sorted order. So the essence of the
whole thing is that by simulating the transaction from beginning to end,
we solve the old "I don't know what I need to lock until I've already
locked stuff" problem. (And make all the locking stuff the library
author's problem, not yours.)
Heh, nice.
> in the language spec for 2 to 3 years until everyone else writing Python
Haskell has a motto: "Avoid success at all costs." The meaning of this,
of course, is that if Haskell suddenly became crazy-popular, we wouldn't
be able to arbitrarily change it from time to time. (In reality, this
point has already long ago been reached.)
And just FYI, there *is* more than one Haskell compiler. Actually, there
are several - it's just that only one has a big enough team working on
it that they produce a production-ready product. [There are people who
*get paid money* to write GHC.] All the others are PhD projects, or
hobbiests. At one time there were several viable production compilers,
but most of them have gone dormant due to the dominance of GHC.
>> The pace of change is staggering. Lots of new and very cool stuff
Heh. Better not tell that to Galois.com, Well-Typed.com, the authors of
the 1,000+ packages in the Hackage DB, or the likes of Facebook, AT&T,
Barclays Analytics or Linspire who all apparently use Haskell internally.
Sure, Haskell is no Java, C# or PHP. But that's not to say that *nobody*
is using it...
See below for some outdated blurb:
http://www.haskell.org/haskellwiki/Haskell_in_industry
Like 7 or 8 years. Newer versions are, of course, younger.
You're trolling here, right?
I thnk you've misread that, since one of the primary purposes in the design
of Eiffel was to provide a language where doing this tricky thing is right.
As long as you don't have inheritance, it *is* pretty trivial.
Oh. I thought Haskell had bigints. Nevermind.
Generally with the same class for nodes regardless of whether they're leaves
or not.
Yep.
> time.
I'd disagree with this, but OK. I get your point. I just think this specific
example is probably wrong.
>> system.
Yep. Hell, it takes about 3 hours to compile the toolchain and 3 hours to
compile Qt on my machine, and that's just C and C++ without anything
sophisticated going on.
Yes, it does. Not in exactly the same way, mind. What do you think
var d = new Date()
is doing there?
Yes, it does. It's just harder and pointless.
>> blocks, which are closures.
A function is a piece of code. A block is a reference to a piece of code
that when evaluated returns a closure. It's the same difference as between
a class and an instance, or a lambda and a closure.
> var bar = foo;
> var x = bar(5);
> No objects here,
Bzzzt. You just don't know javascript very well. What object do you get when
foo or bar references "this"?
I don't remember Eiffel well enough to remember that bit.
> craziness.
Right. And it has been implemented in database access code. Like, when you
have "cloud" services. I think Google's cloud processing arguably uses STM.
I'm pretty sure Erlang's Mnesia database works that way too.
I think you missed "have to" there.
> is using it...
I didn't say nobody is using it. I said you don't have to support it.
Haskell supports hex, octal and exponent floats. (0xff, 0o377, 0.255e+3)
>> literals. Could you add that with Haskell, or TH?
Pretend it doesn't. Could you add it? Can you make a literal syntax for
"list of exactly two elements" that looks like [[-{ alpha / beta }-]] or
something?
You could write a function that converts an ASCII hex string into a
number, and then pass the string to that. So you end up saying
if x == hex "0xABC" then...
or similar.
If you use TH instead, you can write a "splice":
if x == $(hex "0xABC") then ...
This is more typing, but the conversion to hex now happens at
compile-time, not runtime. (It's plausible that calling a function with
a constant will get executed at compile-time anyway, but not guaranteed.
TH guarantees it. And if it errors, it errors at compile-time.)
Alternatively you can use the new "quasi-quoting" feature:
if x == [$hex| 0xABC] then ...
Notice the lack of quote marks. Quasi-quoting is really intended for
where you want to write a big long data literal, but it's too wordy. For
example, rather than writing
x = Expr_Define (Expr_Function (Name_Literal "Sinc") [Expr_Var
(Name_Literal "x")]) (Expr_BinOp BinOp_Divide (Expr_Function
(Name_Literal "Sin") [Expr_Var (Name_Literal "x")]) (Expr_Var
(Name_Literal "x")))
(assuming I even nested all those brackets right!), you write an
expression parser, and then do
x = [$parser| Sinc(x) = Sin(x) / x]
and it generates the same thing, at compile-time. As well as generating
expressions, you can also use it to generate patterns for pattern
matching. (Your parser of course has to distinguish between expression
variables and Haskell variables somehow...)
However, there is no way in Haskell to make it so that some arbitrary
new string can be used as a literal, anywhere in the program. You have
to tell the compiler what function to use to parse this stuff, one way
or another.
...I feel old now. :-(
Can you come up with names?
As you can imagine, I don't really follow this stuff very closely, but
as far as I'm aware, there aren't very many "mainstream" languages out
there.
>> feature that you "shouldn't need to use" under normal circumstances,
>> and if you find yourself using it, you've probably designed your
>> program wrong.
> design of Eiffel was to provide a language where doing this tricky thing
> is right.
The synax seemed overly complex and intimidating to me. The actual rules
for type compatibility are fairly complicated, but seem to intuitively
"do what you'd expect", so that's not too much of a problem.
It does. Currently powered by the GMP. (Apparently they're trying to
change that due to licensing issues or something...)
My point is that even bigints are, technically, finite if executed on a
physical machine. But, like I said, I'm sure that's not what you meant. ;-)
> leaves or not.
Right... so if leaves contain a datum and branches don't... Oh, I
suppose you just use a null-pointer instead or something?
Well anyway, I've never seen anyone implement it that way, but I guess
you could.
>> For example, the parse tree of an expression. You are almost never
>> going to add new types of node to that, but you *are* going to be
>> adding new processing passes all the time.
> specific example is probably wrong.
I wrote a program to interpret lambda calculus expressions. You know how
many kinds of expression there are? 3. Exactly 3. By the formal
definition of "lambda expression". There is always 3, and there will
never be more than 3.
The list of things I might want to *do* to a lambda expression is of
course huge. I might want to find all its free variables, or rename all
variables to be unique, or reduce it to normal form, or just determine
whether it *is* in normal form, or find the maximum nesting depth, or
convert it into a string for display, or...
> to compile Qt on my machine, and that's just C and C++ without anything
Hmm, interesting.
I've also heard people whine that Darcs is "too slow". Which puzzles me,
given that every operation you perform with it takes, like, 0.02 seconds
or something.
> var d = new Date()
> is doing there?
It's running a function that fills out a bunch of fields in the object.
You can completely *change* those fields afterwards. Or you can fill out
the fields manually. An object can be given new fields and have its
methods changed at any time. Sure, it's an object. But it does not have
a well-defined class.
In Smalltalk, object fields are accessible only from inside the object.
This is not the case in JavaScript, and AFAIK it is not possible to make
it the case.
> between a class and an instance, or a lambda and a closure.
What's a closure?
>> var bar = foo;
>> var x = bar(5);
>> No objects here,
> when foo or bar references "this"?
I have no idea. (And no obvious way of finding out...)
It wasn't in the original spec. They added it later, when they figured
out that they didn't want to do the whole Java thing with a bazillion
interfaces. I don't recall off the top of my head how it works.
Ah, right. Well, don't tell that to the Industrial Haskell Group. ;-)
(Does anyone "have to" support Java? Or C for that matter? I can imagine
that some C compiler vendor might have paying customers to support, but
that doesn't stop the designers of C changing the spec...)
That doesn't count.
That's getting closer.
That's fairly close, yes.
LISP works it by (IIRC) passing each token to the "read macros" and seeing
if any of them modify it, so it has to be distinguishable somehow. FORTH
works it by literally letting you read the input stream, as well as calling
a specific function when an unparsable word is encountered. So in FORTH, a
literal works mostly like your quasi-quoting scheme, except there's no magic
characters at the front or end to say "hey, this is quoted." You'd just write
blah blah hex 0xABC blah blah
and the "hex" function would run at compile time and read input off stdin to
determine what comes next. So the function to create string literals is the
double-quotes character. Integers are parsed by having nobody know wtf they
are, so you invoke the thing that says "what's this token" and the integer
parser comes back and says "Hey, I know how to compile that!"
Even Erlang has a mechanism to pss the parse tree thru a number of routines
each of which takes a parse tree and returns a new parse tree. It isn't
quite as flexible as LISP or FORTH, but it lets you add parse-time features
pretty easily, like your splice more than anything
> You have
> or another.
Yeah, but you shouldn't be putting it inline in the stream. You should be
able to say "anything with < on the front and > at the back should parse as
an XML tag."
Delphi. Object-C. Ada. D. Simula. C#. Visual Basic.
Hell, even Fortran is OO for the last 10 years.
> there.
So you having heard of it is what makes it "mainstream"? ;-)
http://en.wikipedia.org/wiki/Eiffel_%28programming_language%29#Genericity
Seems to be as straightforward as I remember. Pretty much the simplest form
of Generics out there.
But they're not bounded in the language. They aren't fixed precision.
They're just not infinite precision. There's no number you can give me that
says "they work up to this value, but not any higher."
You of all folks here should understand the difference between bounded,
unbounded, and infinite, and the distinction between the language and its
invocation on any one machine.
Or a flag. Or a leaf that inherits from a branch. Or a union-like structure.
Or, for an N-ary tree, a list of children that happens to be empty. (After
all, a binary tree is just an N-ary tree with restrictions on what it can hold.)
> you could.
Yeah, but you wouldn't want to in Haskell.
Sure. But that's why lambda expressions were invented in the first place.
That's like looking at a Turing machine and saying "See? No need for
object-oriented features."
http://blogs.msdn.com/ericlippert/archive/2010/02/04/how-many-passes.aspx
Lots of passes, with about half of them being needed only for new features
in the parse tree (compared to V1 of C#, for example). In a real compiler,
it's nowhere near as clearcut. :-)
For example,
Then we run a pass that transforms expression trees into the sequence of
factory method calls necessary to create the expression trees at runtime.
Then we run a pass that rewrites all nullable arithmetic into code that
tests for HasValue, and so on.
Neither of those passes makes sense before you've added the feature to the
parse tree data as well.
> or something.
You're not building real systems.
And you can do all that in Smalltalk too. But OK, Javascript has less of a
"class" concept than Smalltalk does. I'd say neither is as "classy" as a
language without code modification like Java or C++.
Not really true. You can use reflection-type stuff to get to them, such as
in the debugger.
> it the case.
Yes, it is. You use closures instead. It's more painful, so nobody bothers.
http://www.devx.com/getHelpOn/10MinuteSolution/16467/0/page/5
Ugly, but if you really need it, you can do it. Basically, you create a new
object within the current object and only let the current object hold a
reference to it.
> What's a closure?
It's the value that a lambda expression returns. A "new" statement returns
an instance, a lambda expression returns a closure.
>> get when foo or bar references "this"?
Hint: It's called "window".
function foo() {...}
is the same as
window["foo"] = Function(){...}
> interfaces.
Oh yeah. They made a big deal of it at the time. I remember.
OK. But the language designers don't count that as "success" and don't mind
breaking it? I guess if you're using Haskell you just keep the version
you're using around as long as you need it.
Sure.
> seeing if any of them modify it, so it has to be distinguishable
> somehow.
> FORTH works it by literally letting you read the input stream,
> as well as calling a specific function when an unparsable word is
> encountered. So in FORTH, a literal works mostly like your quasi-quoting
> scheme, except there's no magic characters at the front or end to say
> routines each of which takes a parse tree and returns a new parse tree.
> It isn't quite as flexible as LISP or FORTH, but it lets you add
> parse-time features pretty easily, like your splice more than anything
Well, there's no law against you writing a Haskell preprocessor in
Haskell. (Though obviously that's not quite as convinient as the
compiler automatically running it for you.)
>> You have to tell the compiler what function to use to parse this
>> stuff, one way or another.
> be able to say "anything with < on the front and > at the back should
> parse as an XML tag."
The way Haskell does it has advantages.
1. You can tell that stuff is quoted, and what quoting rule it's using.
(Pointless for something like a hex number, but damned useful for a
complex program with a dozen kinds of AST which you might want to quote.)
2. You can't accidentally write a quoting rule which changes the meaning
of a valid Haskell fragment.
3. The new stuff can have completely different parsing rules to Haskell.
(Presumably the Lisp, Forth and Erlang methods can't do that.)
If you could write XML tags literally, then an expression like "if x<y
then if y>z then..." would suddenly parse as an XML tag, which would be
a Very Bad Thing. Really, having to explicitly say you're doing weird
stuff isn't so bad.
> Delphi.
I thought that died 10 years ago?
> Object-C.
I thought that died when C++ came along? (Although I hear Apple still
uses it.)
> Ada. D. Simula.
I wasn't aware those were *ever* popular.
> C#. Visual Basic.
VB is OO now?
People use Fortran? I thought that was only for scientific applications.
(Or am I thinking of Forth?)
Look at job adverts, or websites which talk about programming. They all
mention C, C++, Java, VB, PHP, Perl, Ruby, Python. A few very new ones
might mention C#. Occasionally you'll hear of Erlang. They don't mention
Fortran or Ada. (Like they don't mention Pascal, Eiffel, Smalltalk or
Haskell.)
> form of Generics out there.
Not as simple as Haskell, but sure, I guess that is reasonably easy.
>> a physical machine. But, like I said, I'm sure that's not what you
>> meant. ;-)
OK, sure. What were we debating again...?
> structure. Or, for an N-ary tree, a list of children that happens to be
> empty. (After all, a binary tree is just an N-ary tree with restrictions
If you specifically want a binary tree, the simplest and most logical OO
way would be to make leaves and branches different subclasses. (Unless
every node contains a datum, in which case branch should probably be a
subclass of leaf.) But sure, the others are possibilities. (And if you
might want N-ary trees, then presumably you're doing to use a list or
array or something for the children, as you say...)
>> you could.
I meant I've never seen it done like that in an OO language. In Haskell
you'd obviously use an ADT, since this is the intended use case.
> features in the parse tree (compared to V1 of C#, for example). In a
> real compiler, it's nowhere near as clearcut. :-)
> For example,
> the parse tree data as well.
I'm not quite comprehending the point you're trying to make.
My point is that something like a parse tree usually doesn't need to be
dynamically extensible. If you make an extension to the language, you
typically need to rewrite all the code for processing the parse tree
anyway, so the fact that it's monolithic isn't too much of an issue.
That's what SHE said...
> a "class" concept than Smalltalk does.
We are in agreement.
> as in the debugger.
And you can take a C++ program and use pointer arithmetic to access
private member variables. Does that mean C++ doesn't provide encapsulation?
"Omitting the 'this' keyword makes the variables private to the object.
The 'var' keyword makes the property local (each object instance gets
its own copy of the variable)."
Well, that's news to me...
>> What's a closure?
> returns an instance, a lambda expression returns a closure.
I still don't really understand.
> is the same as
OK. So in what way does this mean that "functions are not first-class"?
> mind breaking it?
As I said, avoiding success so that they don't have to keep things
stable actually went out the window some years ago in reality. Most
people now *want* Haskell to succeed. (Not that I think it will...)
> version you're using around as long as you need it.
Well, there's always that possibility, it's true.
(You could also write a compiler or interpretter yourself too. The spec
is open...)
> Sure.
Oh. Really?
I can imagine there are product written in Java that somebody has to
support, or that there are Java compilers that somebody has to support.
But the Java language itself?
>> point. :-)
What was the original?
case list of
[[x], [y,_], [z,_,_]] -> x+y+z
_ -> 0
If you want it to work for other containers, you're going to have to do
something like
case size c of
3 -> case (size (c ! 0), size (c ! 1), size (c ! 2)) of
(1, 2, 3) -> (c ! 0 ! 0) + (c ! 1 ! 0) + (c ! 2 ! 0)
_ -> 0
_ -> 0
Which isn't nearly as nice.
No, apparently it doesn't. It just lets me write
case c of
(size -> 3) -> ...
instead of
case size c of
3 -> ...
How dissappointing...
No question.
Trivially true of LISP and FORTH, too. LISP syntax is so simple it's hard
not to know what you're quoting, and in FORTH *everything* works that way,
including all the "normal" stuff.
Yeah. That's the only thing you *can* do in Erlang, which is kind of odd.
Erlang, no, because it's already parsed when you get it. FORTH and LISP,
yes, it's exactly the point of it. If you can read arbitrary amount of
input off the input file as you're compiling, you can pretty much completely
change the parsing rules.
Of course, the parsing rule for FORTH is "read up to the next whitespace,
then run that function. Repeat." So the whole point of FORTH is that there
isn't any syntax beyond that defined by the libraries. (For example, the
function to define functions, and the "if" statement, are both library
routines.) It can make things rough, tho.
> stuff isn't so bad.
Yeah, that was just an example I saw. Obviously you'd have to take care. I
haven't used Erlang enough to understand the subtleties of its mechanisms.
> case size c of
> _ -> 0
> _ -> 0
I don't know why, but I got an irresistible urge to write some faux haskell
after seeing that.
case closed in d by
x -> case (open, not!, closed, yes!, 2) because
(1, 2, 3) -> (one, two, three) + x
hence -> yes
hence -> no
To me, it makes exactly as much sense. :P
Orchid XP v8 wrote:
>> Ada. D. Simula.
Ada still goes strong in the areas it is designed for, like safety-critical
firmware.
>> C#. Visual Basic.
> VB is OO now?
It always was. Certainly VB.NET is.
And scientists aren't people?
That's not "mainstream", that's "popular". :-)
Not especially. What about a branch with only one child node? Is that a leaf
or a branch? And what's the value in the second branch?
And yes, even if leaves and branches are separate classes, it doesn't mean
that they both aren't of type "treenode", or the leaf could be a subclass of
branch or vice versa.
You've never seen a N-ary tree in an OO language that used the same class
for branches and leaves? Wow.
I disagree. The whole point of giving you the list of passes was showing you
how modular each pass can be, as well as showing you how modular each parse
node type needs to be.
Yes.
>>> What's a closure?
What is this?
(lambda (x) (x + 1))
It's a lambda expression.
y = (lambda (x) (x + 1))
What is y? It's a closure.
I didn't say it did. I said that everything in Javascript is an object.
There are no functions unassociated with a corresponding instance.
OK, you said
> The difference is that Haskell functions work on data, while Smalltalk
only has objects. In other words, you can't invoke a function without
knowing what object that "function" is a method of. (This is also the case
I wasn't sure what "this is also the case for javascript" meant, but I
thought you meant you can invoke a function without knowing what object it
is a method of. That isn't true of Javascript, altho there is a top-level
object that serves as a global namespace.
Fair enough.
Well, no, there's nobody who has to support the spec, as such. I meant there
are major systems where someone is paid to make sure the Java it's based on
keeps working.
>> Haskell. (Presumably the Lisp, Forth and Erlang methods can't do that.)
> completely change the parsing rules.
The way you said "take each token and pass it through a macro" made it
sound like the input stream gets tokenised first - which means if what
you want to quote has different ideas about what constitutes a "token",
you've got a problem.
>> be a Very Bad Thing. Really, having to explicitly say you're doing
>> weird stuff isn't so bad.
> I haven't used Erlang enough to understand the subtleties of its
> mechanisms.
Square enuf.
It gets tokenized one token at a time. Otherwise, how would your "macro" be
able to read the input? I'm not saying "it looks at the already-parsed
input". I'm saying "it invokes the read() function on stdin to consume input
that was sent to the compiler". The funky syntax is never seen by the
tokenizer (in FORTH and LISP).
>> case size c of
>> _ -> 0
>> _ -> 0
> after seeing that.
> case closed in d by
> hence -> yes
> hence -> no
I think c ! 2 is the third element of c, not unlike c[2].
switch (size(c)) {
case 3:
switch (size(c[0]), size(c[1]), size(c[2])) {
case (1,2,3):
return c[0][0] + c[1][0] + c[2][0];
default:
return 0;
default:
return 0;
It's not *that* hard to figure out. :-)
You should look into playing around with a completely different kind of
programming language not based on C. Erlang or APL or something like that.
> be able to read the input? I'm not saying "it looks at the
> already-parsed input". I'm saying "it invokes the read() function on
> stdin to consume input that was sent to the compiler". The funky syntax
> is never seen by the tokenizer (in FORTH and LISP).
Tokenising isn't parsing; it's just the initial part where you split the
input into tokens. Thing is, each language has different ideas about
what a "token" is...
Obviously I'm never going to use Lisp or Forth, never mind macros. I'm
just mildly curious to know whether you can implement your own
tokenising rules or not.
[] is used almost universally for indexing in most languages (not only
for random access of arrays, but also eg. accessing relational sets (where
the thing inside the square brackets is the key and the return value is the
data)). Is there a logical reason why Haskell chooses an odd syntax of
"x ! y" for the same thing than most other languages express as "x[y]"?
Using ! for the nth element is not very expressive. In mathematics ! is
usually used for factorials, in many programming languages it's used to
express logical negation (granted, not a very logical choice per se, but
quite established), and in natural languages it's used to express shouting
or to emphasize the importance of something (like "WARNING!").
So why choose ! as "the nth element"? Did they run out of obfuscated
one-character operators and it was the only one left? Or is there a logical
reason to choose that symbol out of all possible that I'm not aware of?
(Well, I wouldn't actually be surprised if that symbol had been used for
that purpose in some weird mathematical notations eg. in some lambda
calculus or the like since the 1930's or such.)
I know Haskells undying love for obfuscating brevity, but would it have
hurt to actually use a descriptive *name* for that function? I don't know,
like "c element_at 2" (or even "c at 2") or whatever.
Btw, what is logical not in Haskell?
You're actually reading the input from the file. How could you *not*
implement your own tokenizing rules?
Well, most based on C syntax. The rest (Pascal, Fortran, Ada, etc) use ().
I would guess it makes the thing into an infix operator, while x[y] is
neither prefix, postfix, infix, or ... whatever.
Plus, list literals are [ ... ], so I'm guessing that x [ y ] is ambiguous
as to whether you're calling function x with an argument htat's a
one-element list containing y.
Now, why they picked ! instead of (say) @ is beyond me. "@" is what I've
seen used in all the languages that make this strictly an infix operator.
Warp wrote:
> [] is used almost universally for indexing in most languages.
Granted.
Yeah. "x[y]" would mean a function call, where "x" is the function name,
and the function's argument is a 1-element list containing "y".
To put it another way, Haskell uses square brackets for lists. So you
can't use it for indexing as well.
(Well, OK, if you changed the parsing rules of the language, you could.
You could make it so that if you want "x[y]" to be a function call, you
*must* put a space in there, otherwise it's an index. They already do
this with dots; "x . y" is function composition, but "x.y" is a
qualified name.)
For what it's worth, "!" is used for arrays and dictionaries. For lists
you use "!!". This is because indexing a list is obviously an O(n)
operation, which is bad. So if you find yourself writing "!!", you
should probably go check that there isn't some more performant way to do
what you're trying to do. (Like use an array or something.)
Thus, using "!!" for a list sort-of makes sense. But for an array, "!"
is O(1), so... um...
(Small footnote: You can't have unary operators, so there's no chance of
using "!" for factorial. Unfortunately.)
...pretty much, yes.
Arguably "@" would be more logical - but that's a resurved symbol. I
suppose you could use "@@", but that's not terribly elegant.
I suspect what _really_ happened here is that when Haskell was first
designed, it didn't *have* indexing at all. And then later, when Haskell
became real-world enough to need it, they wrote it as a library, and
didn't want to change the whole syntax of the language just to support
arrays, so they just picked an available symbol name.
You can't do "c at 2", but there's no reason you couldn't do "c `at` 2".
(Hell, if you utter the simple incantation "at = (!)" then the above
will suddenly work. But that's obviously not the same thing has having
the standard libraries implement it that way...)
You're going to love this...
It's "not". As in "not (x == y)".
(Of course, any sane person would write "x /= y" instead. Since most
binary comparison operations have negated versions, you don't often need
the not operator itself.)
For completeness, AND is "&&" and OR is "||". (Since "|" is already used
for pattern guards.) Not too unusual.
Oh, and bitwise operations [which aren't available until you import the
necessarily library] are ".&." and ".|.". No specific reason. Bitwise
not is "complement".
The word you're looking for is apparently "mixfix".
> ambiguous as to whether you're calling function x with an argument
> htat's a one-element list containing y.
Yeah. Although like I said in my other reply, they already made
whitespace significant in the case of the "." character. I'm guessing
this one's a historical accident.
That would have been a better choice, but it's already taken. (And not
even by another library function - it's actually *reserved* in the
syntax rules.)
You could have had "@@", but they chose "!" for whatever reason...
Then again, this is the same language that gives you "^" and "**". Wanna
take a guess what the difference is?
Haskell is a brilliant language, but I never said it was perfect. ;-)
If this were C++, it would actually be "c.at(2)" (in fact, with indexable
STL containers it not only *would* be, but actually *is* like that; well, at
least if you want boundary checks that is.)
But I suppose that since Haskell is not an OO language and its dot operator
probably means something else altogether, making it like that would probably
be difficult (and would probably require a complete syntax redesign).
Why suddenly have one operator be a comprehensible word? Were they
uninspired when they thought up that one? :P
Now you know how lots of people feel when they have to learn UNIX
(command line). At some point, you just tell them, "Hey, that's the way
it is. Weird, obscure, but works, and doesn't really get in your way
once you know it".
Depend on the rabbit's foot if you will, but remember, it didn't help
the rabbit.
Like Scheme using it to warn about bad imperative constructs, like (set! v 1) :)
v!1 is briefer than v[1] :)
> If this were C++, it would actually be "c.at(2)".
OK.
The dot can mean two different things. "x . y" means function
composition. "x.y" is a qualified name. (It means the variables "y" from
module "x".)
Heh. If you mean "why isn't it some random symbol?" then the answer is
"you can only use symbols for *binary* functions, not *unary* functions
such as NOT".
Oh, you're going to love this... The logical AND and OR functions are
"&&" and "||" respectively, but Haskell *also* has functions named "and"
and "or". They take the logical AND or OR of a list of booleans.
Hey, I said Haskell was a great language. I never said the standard
libraries were perfect. ;-) I'm sure you can probably name a few
unfortunately design choices of the C++ libraries too...
ls, cp, mv, rn and friends. Becuase, let's face it, adding two octets to
cp to make copy would be a crime...
So is v@1. But that's not what was chosen.
Personally, I'd kinda like to be able to use v[1], but hey.
>> case size c of
>> _ -> 0
>> _ -> 0
> after seeing that.
> case closed in d by
> hence -> yes
> hence -> no
It makes sense to me, but it's awfully ugly. At present I can't think of
a way to do better...
Heh, yeah. People claim it's the most talked-about language on the
Internet, but I'd never heard of it either until I had a random
encounter one day. And I've never looked back... ;-)
> once you know it".
The difference is that unix is 43 years old and there were no established
conventions back then.
If you develop a new programming language today, there should be a good
reason why you go against general conventions. Making it different just for
the sake of being different is not smart.
>> once you know it".
Perhaps you're forgetting that Haskell is also 20 years old?
Hence a complete newcomer as programming languages are concerned.
Not nearly as new as the likes of Java, Python, Ruby, etc. But sure, not
as ancient as Lisp or C...
Well if you consider 5 years older as "not *nearly* as new"... :P
> Python
Or 1 year older in this case...
> Ruby
Ruby is 5 years newer as well.
> such as NOT".
It could be worse. It could be APL, where functions are in greek.
> such as NOT".
How do you negate an integral or floating point value, then?
>> such as NOT".
Haskell possesses exactly *one* unary operator: unary minus. (Because,
let's face it, not having this would just be annoying.) This is
hard-wired into the language spec, however. You cannot define new unary
operators.
The existence of the unary minus operator causes the following glitch:
(5+) is a function.
(5-) is a function.
(5*) is a function.
(5/) is a function.
(+5) is a function.
(-5) is a number.
(*5) is a function.
(/5) is a function.
Spot the odd one out. (There's a library function named "subtract" so
that you can write "subtract 5" instead of "(-5)" to get a function.)
And it *is* unary minus, not part of the numeric literal syntax; for
example "-x" works just as well as "-5" does.
(Saying "-x" is equivilent to saying "negate x". In particular, since
unary minus is a syntax quirk, you can't define it directly. You define
"negate" directly, and the compiler does the rest. Also, just for
giggles, the default implementation of binary minus is "x - y = x +
(negate y)"...)
So there - aren't you sorry you asked?
You may also have noticed that "sin -5" doesn't work. That's because
it's interpretted as *binary* minus, i.e. "sin - 5", which obviously
doesn't type-check. And *that* is why you have to say "sin (-5)".
Annoying, isn't it?
there were no visual text editors back then. You entered chars and there was a
lag before they were printed. The less chars, the less the chance of errors.
Kinda like the choice of bits too.
When I was briefly in the local council offices, I went into their
central computer room.
Now, this was 1997 or so, but I am not kidding, EVERYTHING WAS BROWN! Do
you have any idea how long ago they stopped making computers in brown
and cream?!?
They had a machine with a big green screen - you know, the kind where
you can actually *see* the scanlines, and text takes a split second or
two to actually fade off the screen. (And you can see what the most
common message is, because it's permanently burned into the phosphor.)
Anyway, when you type on the clunky keyboard, there's a sort of 2-second
delay, and then the character appears on the screen. Apparently the
mainframe you're operating is actually 60 miles down the road, connected
over some kind of telephone link. And the terminal is a *real* dumb
terminal. o_O
I have no idea what kind of system it runs - it wasn't Unix, or at least
didn't appear to be. But if you type in something like "lx 37f7h.b" or
similar, the huge line printer next to it suddenly goes crazy and starts
printing people's benefits cheques.
It wouldn't surprise me if that's how the council's computer systems
*still* work...
