One of the better ones I've seen.
http://web.mit.edu/~axch/www/writing_rant.html
The question in today's corporate environment is not
so much "what color is your parachute?" as it is
"what color is your nose?"
It's funny how everybody keeps repeating the same mantras about C++,
yet I don't experience them myself. It must be a different C++.
I *honestly* can't remember when was the last time I got a segmentation
fault in a C++ program of mine. Maybe sometimes it happens, but really,
really rarely. I'd say that during the past year I might have got perhaps
one segmentation fault.
Memory leaks? *That's* a really, really long time. I'd estimate 10 years
maybe?
Out-of-bounds access is a lot easier to get, especially since off-by-one
mistakes are very easy to do (regardless of the language you are using,
at least if it's an imperative one). Don't remember the last time I had
to actually seriously hunt for one, though.
Well, maybe it's just me. Since everybody keeps repeating the same mantras
then it must be true.
I imagine a large part of the difference if that you've learned a set of
programming techniques in C++ which go a long way in avoiding these
problems. If, however, one hasn't programmed in C++ enough to make
these things second nature then I think that it is indeed a relatively
perilous language since part of its design philosophy is not to waste
resources protecting you from yourself unless you explicitly ask for it.
In fact, I'd wager that some of the programming techniques which you
use in C++ are exactly the sort of things that a higher-level language
would do for you automatically (memory management, bounds checking,
etc.), but which you had to learn/be told to do in C++. Granted I
rather like this design philosophy, but it took some work before I could
program in C++ without being frustrated.
Also, his quip about cryptic compile-time error messages is definitely
justified IMHO (at least as far as g++ goes).
> etc.)
Certainly. In most programming languages you don't have to care *at all*
about certain things which you have to be careful about in C++ (at least
in larger programs). Also many languages offer out-of-the-box features
that C++ doesn't (except as third-party libraries).
On the other hand, it feels like in most of the "higher-level" languages
these features are usually mutually incompatible with memory efficiency
(and sometimes even speed). There are some languages which offer both the
features and the possibility of efficient resource usage, but these languages
often seem to lack good compiler support for most platforms (either there are
no compilers, or they are limited, awkward to use and don't interact with
the rest of the system very well). Many scripting languages are better in
the portability side, but they often also tend to be inefficient.
If it's your first time compiling C++ programs with gcc, the error
messages can be quite cryptic, but having used gcc for quite many years
I can recognize all the relevant parts quite fast. It's rare to get
messages I have hard time deciphering. (Usually you get quite far by
simply skipping all the "instantiated from" lines.)
(gcc has improved a lot in its error messages. gcc 2.x tended to produce
extremely lengthy and cryptic messages, especially with template code, but
the current gcc has simplified it quite a lot.)
I fully believe that. I think the problem is you're not dealing with other
peoples' code. I think the people who bust on it are people who have had to
deal with suboptimal code.
I'm dealing with crappy code now. When I say "this giant library core dumps
when I do X, Y, and Z", and they say "It doesn't core dump on our test
program. Must be your problem." then it's easy to get frustrated with C++
not being able to pin down who is at fault.
I think you're probably rarely talented. :-)
I certainly agree, and I actually rather like the approach that C++ has
taken for tasks where I do care about the efficiency. But I can see
where the "knife fight" analogy came from (perhaps a better related
analogy if it weren't so obscure is using a urumi -- very effective but
you'd better know what you're doing or else you'll end up hurting yourself).
Hmmm, even with the my current version of g++ (4.4.1) I still find the
error messages to be cryptic. This isn't to say that I have trouble
understanding them, but I feel like this is due to gaining skill at
decrypting them and learning that when I see message "x" it probably was
actually caused by mistake "y". Perhaps it's just a difference in what
we mean by "cryptic". That said, I do think that there's some further
evidence for the need for better error messages by the attempted
introduction of concepts into the C++0x standard (even if they didn't
make the final cut).
I was actually pretty impressed by the C# IDE from MS. I wrote
void do_it(int a, int b, int c = 0) { ... }
and the error message wasn't ") or , expected" or "syntax error", but rather
a pointer to the = and the message "C# does not support default arguments."
I was also impressed when I started up my program under test in full screen
and the IDE bumped its debugger windows over to the second screen and put
them back when the program exited. Cool attention to detail. Not that this
has anything to do with the current thread.
How have you liked C# so far? I last tried it when it was a pretty new
language and it came across as a slightly altered version of Java, but I
imagine it's changed a fair bit since then.
But is that kind of message the rule or the exception?
And it's not like gcc didn't have similar-sounding error messages:
error: ISO C++ forbids declaration of 'x' with no type
He missed "Pseudocode", which I'd write as:
Coding in pseudocode is like a metaphor.
Jim
I like it! (although given your sentence construction shouldn't that be
"simile", or alternatively "Coding in pseudocode is a metaphor"?)
I do. I've been using it on and off from early on.
Well, at first glance it looks like that, but deeper in it has a whole lot
of good stuff Java doesn't. Until you start going into complex stuff, it's
just "Java, fixed." Once you start trying to do something difficult (like
access to native languages, deployment, web scripts, generating code at
run-time, etc) it's way better.
Indeed it has. C# 1.0 was sort of "Java, improved." C# 3.x by now has all
kinds of goodies in it that Java lacks.
The error messages are all good, but I usually don't get an error at compile
time because the IDE puts a red squiggly under compile-time errors and a
green or blue squiggly for warnings, as you type. The IDE is really an order
of magnitude better than anything else I've ever used.
That was just surprising, because MS anticipated that someone would do that
and special-cased the parser just to handle a common error message.
I've gotten a few of those and not understood them, actually. I don't
remember what I had, but having something more along the lines of "you
forgot an #include" would be a better error message, I think. :-)
Technically, I guess "simile" would be correct there - I always get the
two mixed up. :-)
Jim
> two mixed up. :-)
At least I have something to show for all the effort my teachers spent
hammering the difference into my head!
>> I last tried it when it was a pretty new language and it came across
> lot of good stuff Java doesn't. Until you start going into complex
> stuff, it's just "Java, fixed." Once you start trying to do something
> difficult (like access to native languages, deployment, web scripts,
> generating code at run-time, etc) it's way better.
Makes sense. I think the runtime code generation was what I was
particularly interested in, and I'm pretty sure it didn't have much in
the way of that when I last looked at it. Now that I have Visual Studio
maybe I'll take a look at it again sometime.
Coding in Haskell is like having sex with a girl
that wears horn rimmed glasses, you'll never quite
understand her, but it's a lot of fun.
Dude, what the HELL...?? o_O
The one for C++ seems about right. All the others don't match my
experience at all. (E.g., since when does Java "always get the job done
eventually"? I've lost count of the number of programs I was unable to
finish because Java just makes it too difficult, lacks the necessary
feature, or the spec sheet says the feature exists but it's not actually
implemented!)
I'd say that Perl is like a tool that somebody wrote to solve the one
particular problem they were trying to solve that day, and then tried to
claim it was a general-purpose tool. It makes a small class of problems
really easy to solve, and everything else almost impossible. The whole
thing seems to be a steaming pile of ad hoc solutions with no unifying
form or structure. Kind of like learning English, but harder.
I'm not familiar with Ruby, Scheme, or Mozart. Of course I've heard of
all these things, but I don't know anything about them. (I started
reading a Ruby tutorial, but the random inconsistant syntax put me off.
And the ham.)
So anyway, since I'm sure you're all expecting it anyway... I'd say that
coding in Haskell is like doing highschool algebra. (In more ways than
one.) At first it seems weird and complicated. And then, assuming you
"get it", it suddenly seems really simple and easy and "obvious". And
then as you try to tackle harder problems, it starts seeming difficult
again...
It seems to me that C++ is a language designed for experts. If you're a
C++ expert, it works very well. If you're a clueless newbie, it works...
not so well.
Still, at least it's better than C.
You can get that one if you write eg. "static x;"
It should be rather clear: You have defined a static variable named 'x',
but with no type. (In C it would default to int, but the C++ standard forbids
omitting the type, which is what the error message is saying.)
"Tim Attwood" <tim### [at] anti-spam comcast net> wrote in message
news:4b878b55$1@news.povray.org...
Coding in SNOBOL is like writing a phone book because... well, because that
was all it was ever used for.
Jack
Huh. That's one part I don't think changed that much. The code generation
is used by the compiler(s) as well as in various places in the libraries.
(For example, regular expressions compile down to IL and then native code if
you set the flag.)
The other one is the LINQ thing, where you can set a flag that says "give me
this expression as a parse tree rather than generating code", but that's
limited to LINQ so far.
It's the "Reflection.Emit" namespace you want.
Ah, I see. Yes. A similar thing, that. I think I got it because the
47K-long compile line was missing one of the -D instructions that would have
made
static UINT32 x;
into a valid declaration or something. Which is why looking at it, it made
no sense, and I couldn't find the header file that defined it.
Well, it's better than C for experts. For newbies, I think C is probably
easier, since there's less magic going on you need to know.
PHP is exactly this, yes.
> And the ham.)
Yep. And the fact that the guy who wrote the most definitive texts doesn't
actually know what the language does. (At several points in the Axe book,
the author says "It seems to do this" or "it apparently does that.") And the
fact that between minor version 18 and minor version 19 they made a bunch of
unneccesary and seemingly trivial changes to defaults that would
nevertheless break any program that relied on those defaults. Those are the
main reasons I never really pursued it.
Oh dears.
>> off. And the ham.)
> doesn't actually know what the language does. (At several points in the
> Axe book, the author says "It seems to do this" or "it apparently does
> that.") And the fact that between minor version 18 and minor version 19
> they made a bunch of unneccesary and seemingly trivial changes to
> defaults that would nevertheless break any program that relied on those
> defaults. Those are the main reasons I never really pursued it.
Yes.
And the thing with the ham...
It's also entirely possible that I'm remembering
incorrectly/incompletely here.
Wow, it's not often I hear that language mentioned. Apparently it was
also somewhat popular with people in non-technical academic fields since
they found the string processing capabilities useful.
One of these days I'm going to learn it just because I'm curious about
it, but I haven't gotten around to it yet.
You mean newbies don't need to handle dynamically allocated memory?
Exactly which part of C is simpler for newbies than C++?
Simpler /= easier. ;-)
(If anybody out there still thinks simple and easy are in any way
correlated, try learning the Waltz. It has THREE STEPS IN IT, and yet
nobody can do it right for at least the first 20 minutes.)
It *is* relatively primitive. But then, you *are* creating essentially
machine code. :-) I just don't remember hearing of any significant changes.
You don't have to deal with constructors, destructors, exceptions, the
difference between casing classes and casting pointers to classes, etc.
It's simpler *because* it's less powerful, in the same way that using an axe
is simpler for newbies than using a chainsaw.
It's sort of like Perl, only more ... tabular, somehow. People don't use it
any more because computers are powerful enough to run things like Perl now.
Why would a beginner need to deal with constructors, destructors,
exceptions and the like?
No, C is a lot more complicated for the beginner precisely because it's
less powerful.
In C++ the beginner can write things like this:
std::string concatenate(const std::vector<std::string>& strings)
std::string result:
for(int i = 0; i < strings.size(); ++i)
result += strings[i];
return result;
Show me the same function implemented in C and explain how it would be
easier for a beginner (especially without any danger of memory leaks).
And here I didn't even get to the things that the C standard library
doesn't support.
> it any more because computers are powerful enough to run things like
> Perl now.
As I understand it's pattern matching uses a recursive backtracking
algorithm, which should give it a bit of a Prolog flavor too. This
seems distinct from the Perl way of doing things (although historically
the latter seems to won out as being more useful in practice).
Not that I know SNOBOL or Perl mind you, so I'm talking based mostly on
my impressions of Icon and Ruby respectively plus a bit of extra reading.
>>> be "simile", or alternatively "Coding in pseudocode is a metaphor"?)
>> two mixed up. :-)
LOL
Because they'll be using libraries that require such. Even in your example,
you'd have to talk about the std::string constructor and how it creates an
empty string if you don't pass it arguments. As opposed to (say) integers,
that don't get initialized to zero. And what happens if you run out of
memory in your concatenate function.
> less powerful.
I disagree. It's more complicated to get things done, but easier to understand.
> std::string result:
> return result;
It would be easier to explain what's happening. I don't have to explain the
syntax for method invocation, const, references, the difference between
references and pointers, the differences between method invocations on
references and pointers, overloaded operators, or what namespaces are. The
function will be longer and more dangerous, but the only "unusual" things to
be explained are pointers and strings. Basically, in the C equivalent, the
only *confusing* part is that C doesn't allocate multi-word objects for you.
I take it you've never actually taught beginner computer programming
classes, yes?
It's not "how much power do you have." It's "how much do you have to
dismiss as magic before you have a full understanding of the entire language."
You don't have to deal with constructors. You can simply say "if you create
a string without initializing it, it defaults to an empty string".
As opposed to char*, which defaults to... what?
> As opposed to (say) integers, that don't get initialized to zero.
Well, in C++ they decided that if you don't initialize an integer, its
value is not guaranteed. Bummer, but nothing to do with constructors.
Your program will be ended because it ran out of memory.
> > less powerful.
You seriously claim that eg. pointer arithmetic, null-terminated strings
and the standard C string manipulation functions are easier for a beginner
to understand than C++'s std::string? (And that's just one example.)
Does the beginner really need to know what the compiler is doing under
the hood in this case?
> I don't have to explain the syntax for method invocation
There was no method invocation in my example. (Ok, operator+() *is* a
method, and it's being called, but the beginner doesn't need to know that
in order to use string concatenation.)
> const, references
The C version will also have a const (the function should take a const
pointer) if it's well written. So it's not all that different.
If you really want to avoid the reference in the C++ version, you can:
std::string concatenate(std::vector<string> strings)
It will still work (although will probably be less efficient). No such
luck in C, though. You can't pass an array of strings by value. You'll
have to have a pointer (a const one, preferably).
> the difference between references and pointers
You don't need to know the difference between references and pointers in
order to implement the "concatenate" function in my example. (And as
mentioned, you don't *necessarily* even need references at all if you
really want to avoid them.)
My example didn't need any such thing.
The beginner doesn't need to know that to implement that example.
Is it really a bad thing that the beginner is introduced to namespaces
from the very beginning? It's not like they are very hard to understand.
> The
No. The C version would require explaining lots of things about how C
null-terminated strings work internally (which you don't have to with
std::string), how you allocate space for them in your code (which you don't
have to with std::string), how you make sure you have allocated enough space
for the result (again, no need with std::string) and how you concatenate
the strings with strcat (the only thing more or less equivalent to the
+ operator of std::string).
You would also need to explain that if the function returns a pointer to
a new C string it allocated itself, how the calling code needs to make sure
that it's not leaked. (Again, no such need with std::string.)
So the C++ version is enormously simpler than the C version in all possible
regards. The newbie needs to learn a lot less and can start doing some
practical (and safer) code much more quickly.
No, it isn't. You have to understand null-terminated strings, how to
calculate the length of strings, and how to manually manage the memory
for the strings before you could write such a function in C.
> algorithm,
Now that you mention it, yes, I remmber that.
And they ask "what does an integer default to?" And then they ask why.
Uninitialized. Like every single automatic variable in C, nothing gets
initialized before you assign to it.
Yes, if you actually want to understand it. If you want to treat std::string
as magic, then no.
If you want to treat the standard template library as magic, no.
strings.size() isn't a method invocation? And in this case, += and [] are as
well, but I agree you could probably skip over that bit.
So you're arguing that the complexity can be brushed off as "magic you don't
have to worry about." That's OK, but in my experience that's not a good way
to teach beginners.
I wasn't talking specifically about your example in some of these cases, but
about the difference between teaching C++ and C in general.
To beginning programmers, *everything* is hard to understand.
True.
Yes yes and yes.
We'll just have to disagree.
Yep. Those aren't confusing, tho. They're tedious, and may seem like silly
rules, but not *confusing*. You can explain that stuff with pictures.
Based on my experience teaching classes, treating something as "magic you
don't have to understand", and having several elements that perform the same
role differently, is what leads to confusion. You immediately start down the
cargo-cult programming path, where you do it like this not because it's
right, but because that's what the teacher said to do and you don't know why.
Plus, the concatenate example is a terrible example for teaching. There's no
I/O, it's not a stand-alone program, and it's not complete.
> two mixed up. :-)
Analogies are endofunctors in the category of bad explanations.
http://blog.orphi.me.uk/
>> two mixed up. :-)
Now, of those, which is the hypernym and which is the hyponym? ;)
Jim
One would *presume* that analogy is a hyponym of bad explanation...
Certainly from your sentence construct, that would seem to be the
case. :-)
Jim
I believe this to be vaguely relevant:
http://i.imgur.com/hF6mS.jpg
my gosh! So many messages and all of them irrelevant!
what is truly amusing about this is that it was written by Peter Parker himself!
o_0
Right; instead, you have to deal with a dozen different library
implementations of object construction, destruction and error handling;
such as GObject :)
Another example: POV-Ray 3.6 has virtual functions reinvented in C (to call
"intersect with ray" on any Object* without knowing if it's a Sphere or an
Isosurface). It's harder to figure out what's going on than if you just had
a C++ class with virtual methods, because no other C program does it
**exactly** the same way as POV 3.6.
http://en.wikipedia.org/wiki/Ruby_(programming_language)
http://en.wikipedia.org/wiki/Scheme_(programming_language)
http://en.wikipedia.org/wiki/Wolfgang_Amadeus_Mozart
Actually, I don't. Note the term "newbies". :-)
I honestly wouldn't teach either one as a first language. Even Pascal is
pushing it, IME.
Yep. And the problem is that no C program can possibly do it the same way as
C++ in any sort of portable way. So every C++ library that uses any of this
sort of feature is incompatible with being called by any sort of C program.
Hence, the proliferation of such faux-OO libraries.
