POV-Ray : Newsgroups : povray.off-topic : Brain fail Server Time
12 Apr 2026 11:48:05 EDT (-0400)
  Brain fail (Message 1 to 10 of 41)
Subject: Brain fail
Date: 11 Feb 2010 10:59:44
Message: <4b742970$1@news.povray.org>
OK, so I'm currently failing to figure this out...
How do you compute the smallest possible (axis-aligned) bounding box for
an ellipse (which is not necessarily axis-aligned)?
Apparently such an ellipse can be represented as
   X(t) = Xc + A cos t cos K - B sin t sin K
   Y(t) = Yc + A cos t sin K + B sin t cos K
Clearly you need to find the minimum and maximum values for X(t) and
Y(t). But I am apparently too stupid to do this. (And even Wolfram Alpha
can't work it out. Oh, it'll give me the answer if I remove all the
symbolic constants with actual numbers, but that's no help at all...)
It strikes me that the sum of two sine waves of identical frequency is
another sine wave, but I can't seem to apply this fact to obtain a result.
Subject: Re: Brain fail
Date: 11 Feb 2010 11:24:48
Message: <4b742f50$1@news.povray.org>
When you're looking for the maximum or minimum of a function the first
thing to look for is in general a zero in the derivative.
For example for X:
dX/dt = - A cos K sin t - B sin K cos t
so dX/dt = 0 => A cos K sin t = - B sin K cos t
or assuming A cos K  and cos t are not null (you could make special
cases if needed)
tan t = -B/A tan K
so the bounds for X are
X0 = X( atan(-B/A tan K) )
X1 = X( pi + atan(-B/A tan K) )
Sort and do the same for Y...
Vincent
Date: 12 Feb 2010 06:09:04
Message: <4b7536d0$1@news.povray.org>
My God, man, IT WORKS!
Heh, that should be amusing...
Date: 12 Feb 2010 07:18:35
Message: <4b75471b@news.povray.org>
That's the good thing about math, you know :-)
More than the result you should keep the method in mind, it's useful in
plenty of problems...
Vincent
Date: 12 Feb 2010 07:26:25
Message: <4b7548f1$1@news.povray.org>
I was attempting to work out what the result of
   A sin t + B cos t
is. I was convinced there was a standard identity for this, but I can't
find it. In the end I came up with
   Sqrt(A^2 + B^2) sin (t + atan(B/A))
but I don't even know if that's correct. And I still have to apply it to
my original formula to figure out the result.
Man, who knew a simple ellipse was this complicated?!
Date: 12 Feb 2010 11:27:02
Message: <4b758156@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:4b7548f1$1@news.povray.org...
This is an incredibly important life lesson: the complexity of a phenomenon
is utterly disconnected from the number of syllables needed to describe it.
Sometimes I feel the desire to emphasize this concept to my co-workers with
a heavy, blunt object. Then I take a deep breath, get more coffee, and try
to convince myself that homicide is a detriment to career advancement (well,
in my field, anyway).
Jack
Date: 12 Feb 2010 11:39:40
Message: <4b75844c$1@news.povray.org>
Exhibit A:
http://www.youtube.com/watch?v=58_s6r7PaKo
It's just a swinging pendulum, after all...
Exhibit B: Rule 30 can be stated in 8 equations. Oh, did I mention? It's
Turing-complete. It can compute any computable function.
Note also that simple /= easy.
x^5 - x + 1 = 0 is "simple". Now try solving it...
Similarly, the Waltz is "simple". Try dancing it sometime; you'll
discover that it's surprisingly difficult, despite being so simple.
Date: 12 Feb 2010 12:13:59
Message: <4b758c57$1@news.povray.org>
You know, he says that, but I'm pretty sure a CA with an infinite amount of
initialization counts as Turing-equivalent.
   Forget "focus follows mouse." When do
   I get "focus follows gaze"?
Date: 12 Feb 2010 13:22:08
Message: <4b759c50$1@news.povray.org>
>> It's Turing-complete. It can compute any computable function.
> of initialization counts as Turing-equivalent.
The point being that some rules can't emulate a Turing machine, while
others can. E.g., rule 0 maps every possible input to 0, so you can't do
very much with that. Rule 2 maps each 1-bit input to the same output.
And so on. Only a few of the possible rules are Turing-complete.
http://blog.orphi.me.uk/
Date: 12 Feb 2010 13:43:31
Message: <4b75a153$1@news.povray.org>
I fully understand exactly what he's saying. I'm simply denying that he's
correct, on the grounds that he does an infinite amount of setup before he
even starts running the CA.  If he came up with a small rule that would
create the initial pattern in a finite number of steps, then maybe it would
make more sense. But as he described it, he needs to set up an infinite
number of clock pulses before starting the emulation in order to clock the
emulation. I'm not sure that's allowed, any more than it's allowed to set up
an infinite pattern of states on a turing machine before starting.
