POV-Ray : Newsgroups : povray.off-topic : Probability question Server Time
18 Oct 2026 03:48:52 EDT (-0400)
  Probability question (Message 1 to 38 of 38)
Subject: Probability question
Date: 8 Feb 2010 03:08:23
Message: <4b6fc677@news.povray.org>
If a weighted coin is tossed N times, count the times it lands heads as H.
The probability of landing heads is P(H).
I assume the expected value of H is N*P(H).
But how do I find out what range of H is X% likely to happen?  For example,
I want to be able to say that in 90% of cases H will be in the range (A,B).
What I've done so far is for 0<=H<=N calculated (N choose H)/P, where P is
the total permutations of N items in N.  This should give me the probability
of exactly H heads coming up, yes?  I can keep a cumulative total of these
probabilites for each H, and then figure out the range of H between (say)
10% and 90%.  But it seems a bit long-winded, I can't figure out how to
calculate the range directly.  Also Excel can't figure out the permutations
when N is bigger than 150 or so, I want it to work for higher values of N.
Any ideas?  Hopefully it's something obvious!
Subject: Re: Probability question
Date: 8 Feb 2010 04:56:08
Message: <4b6fdfb8$1@news.povray.org>
> H. The probability of landing heads is P(H).
I presume by this you explicitly mean that P(H) /= 50%?
Yes. That would be the definition of "probability". (Assuming all the
trails are independent.)
> example, I want to be able to say that in 90% of cases H will be in the
> range (A,B).
Now you're talking about probability distributions. If you can decide
what probability distribution this experiment has, you can [potentially]
directly compute the result you're after.
Wikipedia informs me that what you're looking for is a "binomial
distribution". According to this, we have the probability of getting
exactly K heads as
   (N choose K) * P(H)^K * (1 - P(H))^(N-K)
More usefully for you, the cumulative probability - the probability of K
heads OR LESS, is given by
   I[1 - P(H)] (N - K, N + K)
where I[x](a, b) represents the regularised incomplete beta function,
http://en.wikipedia.org/wiki/Regularized_incomplete_beta_function
Unless Excel has a built-in function to compute I(), I would suggest it
would be simpler and easier to directly compute the sum over the
individual probabilities. (Especially since you want the probability for
a value between K1 and K2, not between K1 and 0.)
You can also compute the cumulative probability by the integral
   (N - K) (N choose K) integral[0 .. 1-P(H)] t^(N-K-1) (1 - t)^K dt
But I'm guessing Excel can't do that.
Apparently you can also estimate the maximum probability by
   exp( -2 * (N * P(H) - K)^2 / N )
(The true cumulative probability is less than or equal to this.
Apparently for P(H) = 50% it's quite a good approximation, but I'm not
sure for other values.)
Date: 8 Feb 2010 05:20:44
Message: <4b6fe57c@news.povray.org>
http://reference.wolfram.com/mathematica/ref/BetaRegularized.html
So Wolfram Alpha will compute it, for example.
But that doesn't matter:
http://office.microsoft.com/en-us/excel/HP052090051033.aspx
Date: 8 Feb 2010 05:37:13
Message: <4b6fe959$1@news.povray.org>
> distribution".
Thanks - that was the key I needed!
> According to this, we have the probability of getting exactly K heads as
That *is* useful, at least using this formula I get correct results,
although it's still a bit clumsy.
I will continue with Excel now trying to make it a bit neater.
Date: 8 Feb 2010 05:40:19
Message: <4b6fea13$1@news.povray.org>
>> distribution".
See my other post; Excel has a function to directly compute a binomial
distribution, apparently. (And cumulatively, if you wish.)
Date: 8 Feb 2010 06:09:54
Message: <4b6ff102@news.povray.org>
I need the inverse function though, I want to tell it the cumulative
probability (eg 10% and 90%) and it tell me how many successful trials that
relates to.  There seems to be no BINOMDISTINV function.
Date: 8 Feb 2010 06:43:36
Message: <4b6ff8e8$1@news.povray.org>
> that relates to.  There seems to be no BINOMDISTINV function.
Wikipedia claims that for large N, the binomial distribution
approximates the normal distribution. (If you plot the normal
distribution with expected value N * P(H) and varience N * P(H) * (1 -
P(H)).)
This approximation works best for large N and for P(H) near to 50%.
I presume it's relatively easy to work out the inverse function for a
normal distribution...
Date: 8 Feb 2010 07:13:53
Message: <4b700001$1@news.povray.org>
> Wikipedia claims that for large N, the binomial distribution approximates
Yes, it seems my parameter values fit in ok for this approximation to be
pretty accurate.
Excel has a built in function to do this, so this looks like the way to go.
Date: 8 Feb 2010 07:26:48
Message: <4b700308$1@news.povray.org>
> pretty accurate.
Central Limit Theorum FTW! :-D
Cool.
So are you *really* trying to estimate coin flips? Or is there some more
complex problem you're trying to solve here?
Also... I'm impressed that I managed to find an actual solution to this
using nothing but Wipikedia and an incomplete understanding of probability.
PS. Apparently Wolfram Alpha can plot all these distributions for you if
you type in something suggestive like "binomial distribution, n=100, p=0.2".
Date: 8 Feb 2010 08:07:27
Message: <4b700c8f$1@news.povray.org>
Not really more complex, just a game that is played repeatedly and you have
a certain % chance of winning (say 57%).  I just want to know if you play
10,100, 1000 times what is the *likely* number of wins in some kind of worst
case and best case scenario.  ie it's obviously possible to win every single
game, but that is *really* unlikely, I want to know how many you'd win with
90% or 99% confidence.
Date: 8 Feb 2010 08:42:55
Message: <4b7014df$1@news.povray.org>
>> more complex problem you're trying to solve here?
> have a certain % chance of winning (say 57%).  I just want to know if
> you play 10,100, 1000 times what is the *likely* number of wins in some
> kind of worst case and best case scenario.  ie it's obviously possible
> to win every single game, but that is *really* unlikely, I want to know
> how many you'd win with 90% or 99% confidence.
Right. So it's ye olde "2SD = 95% confidence" rule then.
Date: 8 Feb 2010 11:07:17
Message: <4b7036b5$1@news.povray.org>
Actually it's impossible to analytically compute.  Fortunately many
pieces of software have a built in function to numerically compute it.
Date: 8 Feb 2010 11:12:02
Message: <4b7037d2$1@news.povray.org>
Define "analytically".
Last time I checked, it's impossible to compute the square root of a
number "exactly" - and yet it's trivially easy to approximate it to any
desired accuracy.
Date: 8 Feb 2010 11:22:21
Message: <4b703a3d$1@news.povray.org>
As a closed-form expression.  As I said, it's still possible to compute
numerically.
Date: 8 Feb 2010 11:32:41
Message: <4b703ca9$1@news.povray.org>
Kevin Wampler wrote:
>>>> a normal distribution...
> numerically.
And Sqrt[2] erf^-1 (2z - 1) doesn't count because...?
Date: 8 Feb 2010 11:54:18
Message: <4b7041ba$1@news.povray.org>
>> compute numerically.
erf isn't an elementary function.  See:
http://en.wikipedia.org/wiki/Closed-form_expression
http://en.wikipedia.org/wiki/Error_function#Taylor_series
Date: 8 Feb 2010 11:58:00
Message: <4b704298$1@news.povray.org>
>>>>>> for a normal distribution...
Right. So what you're actually saying is that you can't compute the
confidence interval exactly using a finite number of applications of a
particular arbitrarily chosen set of functions - the elementary functions.
Date: 8 Feb 2010 12:04:53
Message: <4b704435$1@news.povray.org>
That is indeed the definition.
This obviously doesn't matter for scott's case since he just wants a
numeric answer and Excel seems to have erf built in, I just wanted to
point out that far from being "relatively easy" to work out, the
cumulative distribution function of a Gaussian is generally the first
function people encounter which is impossible to actually compute in
closed form (normally this will come up in first or second year calculus
at some point).  I'll agree that at first glance it certainly *looks*
like it would be simple to compute though, which is part of why it's
interesting.
Date: 8 Feb 2010 13:38:41
Message: <4b705a31$1@news.povray.org>
>> functions.
> interesting.
Well, the sine and cosine functions can't be computed by a finite number
of additions, subtractions, multiplications, divisions and exponents.
But since sine and cosine are included in the arbitrary "set of
permissible functions", they don't count. But erf is not, so it does count.
To me, it seems that approximating erf (or its inverse) is no harder
than approximating a sine or cosine - and we do that all day.
http://blog.orphi.me.uk/
Date: 8 Feb 2010 13:59:44
Message: <4b705f20@news.povray.org>
  They can if you allow the parameters to be complex numbers (which is why
trigonometric functions are included in the set of elementary functions).
Date: 8 Feb 2010 14:05:24
Message: <4b706074$1@news.povray.org>
OK, but that just brings us back to the fact that the exponential
operator has to be approximated. ;-)
Date: 8 Feb 2010 14:41:40
Message: <4b7068f4@news.povray.org>
Nice, that link crashed my browser :) Clearly Microsoft and KDE don't like
each other.
Date: 8 Feb 2010 15:22:52
Message: <4b70729c$1@news.povray.org>
>>> number of additions, subtractions, multiplications, divisions and
>>> exponents.
>> why
Did you read the Wikipedia page on closed form expressions?  It's not
very long and all of these points are addressed there.
Date: 8 Feb 2010 15:49:21
Message: <4b7078d1$1@news.povray.org>
> each other.
Crashed it? Or just upset it?
Microsoft may use proprietry features and write terrible markup, but if
a browser crashes when fed the wrong data, methinks the browser should
be rewritten to fail gracefully. ;-)
The only unusual thing I can see about the page [other than too much
JavaScript] is a flash advert.
Date: 8 Feb 2010 15:56:13
Message: <4b707a6d$1@news.povray.org>
...OK, just read it. Doesn't seem to address very much.
Also, I've often wondered how the **** you compute something like the
Gamma function or the Bessel-J function. I mean, have you *seen* the
definition?!
Date: 8 Feb 2010 16:16:28
Message: <4b707f2c$1@news.povray.org>
I was thinking of:
" constants, one variable x, elementary operations of arithmetic (+ – ×
÷ –), nth roots, exponent and logarithm (which thus also include
trigonometric functions and inverse trigonometric functions)."
and
"For purposes of numeric computations, being in closed form is not in
general necessary, as many limits and integrals can be efficiently
computed."
Which seem to exactly cover both of the points you recently mentioned,
but perhaps I misunderstood what points you were making.
> definition?!
Yes.  If you take a look at the Wikipedia article for the gamma function
you'll see that it includes a couple of nice representations in terms of
infinite products.  The Bessel functions seem a bit more involved, but
it has representations in terms of a sum over terms involving the gamma
function, a hypergeometric series, and a recursive relation to a
continued fraction -- so there seem to be many ways to go about
computing it (I didn't look up what the standard approach in practice was).
I know that you say that you have trouble digesting the Wikipedia
articles on these in full (entirely understandable, they are very dense
and not always well written) but you still can answer these questions by
spending a minute or two just skimming over them without trying to
understand everything.
Date: 9 Feb 2010 04:20:59
Message: <4b7128fb$1@news.povray.org>
> I was thinking of:
> and
> computed."
Oh, I see. I thought it was going to say something more insightful than
that. (How the hell do you compute a limit or an integral anyway?)
>> definition?!
> infinite products.
But you can't compute an infinite product.
Uh...OK.
Heh. Some of them explain things quite clearly, but others are
incomprehensible. That's the trouble with a reference source written by
bored Internet surfers; first it's a reference, not an introduction, and
second the quality is *highly* variable. ;-)
Date: 9 Feb 2010 05:46:28
Message: <4b713d04@news.povray.org>
>> have a certain % chance of winning (say 57%).  I just want to know if you
>> play 10,100, 1000 times what is the *likely* number of wins in some kind
>> of worst case and best case scenario.  ie it's obviously possible to win
>> every single game, but that is *really* unlikely, I want to know how many
Indeed.  It turns out in my game that you break even if you win 54% of the
time, and in practise you can only realistically expect to win 57% of the
time if you are good at the game.  These two facts mean that after even 1000
games there is still a huge variation in how much profit you can expect to
make - 95% confidence you will make between -7 and 607 arbitrary units of
profit.
Date: 9 Feb 2010 11:42:04
Message: <4b71905c@news.povray.org>
Ahh, no nothing more insightful, just that it did address the major
points you were worrying about.
Also, I'll assume you mean "how do you numerically compute a limit or
integral?":
If it's a limit, just compute it for numbers as close as possible to the
limiting value (or really really big numbers if the limiting value is
infinite).  The closer (or the bigger) the number you compute it for the
closer your answer will be.
If it's an integral do something like this:
http://en.wikipedia.org/wiki/Riemann_sum
If the product converges (which it does, otherwise you couldn't define a
number/function with it) then you can by definition get an arbitrarily
good approximation by computing the product of the first n terms for a
large enough n.
You might want to read up on these, they're pretty much fundamental to
all of calculus and many many other ways of defining things over the
real (or complex) numbers (Taylor expansions, Fourier series, numeric
optimization and root finding, etc.):
http://en.wikipedia.org/wiki/Limit_(mathematics)
http://en.wikipedia.org/wiki/Limit_of_a_sequence
Out of curiosity have you ever had a calculus class?  I'd think that
these things should have been covered there, and it makes me wonder if
maybe the UK curriculum is somewhat different that what I'm used to.
Date: 9 Feb 2010 11:49:03
Message: <4b7191ff$1@news.povray.org>
>> than that. (How the hell do you compute a limit or an integral anyway?)
> integral?":
Wouldn't that be increadibly unstable, numerically?
I see. (Although I'm still not sure how you compute an infinite integral
this way...)
> large enough n.
I don't see how that is the case.
If you have an infinite *sum*, then as long as the terms get
progressively more tiny and never get larger again, you can disregard
all the terms after a certain point. But if you're taking a *product*
then any term, anywhere in the series could radically alter the final
result.
I've never had *any* maths class!
(Unless you count what we did at school. This simply involved filling
out hundreds of thousands of pages of long-division problems over a
7-year period...)
Hypothetically I shouldn't be able to do algebra at all...
Date: 9 Feb 2010 11:58:08
Message: <4b719420$1@news.povray.org>
How could it be?  If you're taking the limit of something that's going to a
finite value in a continuous curve, how could your calculation of the value
closer to the limit have more error than the error calculated farther from
the limit?
   Forget "focus follows mouse." When do
   I get "focus follows gaze"?
Date: 9 Feb 2010 12:04:49
Message: <4b7195b1$1@news.povray.org>
>> the limiting value (or really really big numbers if the limiting value
>> is infinite).  The closer (or the bigger) the number you compute it
>> for the closer your answer will be.
How much a a problem this is depends on the limit.  For most limits that
I've ever numerically computed it's worked fine.  If you're taking the
limit of a series (as opposed to the limit of a function) then it'll
almost certainly be fine.
> this way...)
Combine this definition with how you compute the limit of an infinite
sum.  So you'll have two approximations, one in approximating the
integral with an infinite sum, and another with approximating the
infinite sum with a finite one.  If you're doing this, it'd be wise to
prove that these approximations both converge to the correct value.
>> a number/function with it) then you can by definition get an
>> arbitrarily good approximation by computing the product of the first n
>> terms for a large enough n.
> result.
The same is true for a sum actually.  The point is proving that an
infinite sum or product *converges* is to show that this doesn't happen.
  Basically you show that the partial sums/products form a convergent
sequence (see the "Limit of a sequence" Wikipedia article I linked).
Then you know by definition that you can get a good approximation by
computing a large enough partial sum/product.
In the case of a sum this requires that the terms progressively get
closer to zero, for a product it'll require they get closer to one.
> 7-year period...)
That's too bad, it seems like you would have greatly enjoyed being able
to do some math that was more advanced than long division.
Date: 9 Feb 2010 12:10:21
Message: <4b7196fd@news.povray.org>
> to a finite value in a continuous curve, how could your calculation of
> the value closer to the limit have more error than the error calculated
> farther from the limit?
According to Google calculator, sin(1e-14)/1e-14 = 1, but
sin(1e-15)/1e-15 = 0.
Date: 9 Feb 2010 12:38:23
Message: <4b719d8f@news.povray.org>
*caveat: unless the product converges to zero.
Date: 10 Feb 2010 04:15:25
Message: <4b72792d@news.povray.org>
>> calculated farther from the limit?
Indeed, this was going to be my example. When x is small, sin(x) is
approximately equal to x. But whatever, sin(x)/x when x is small
involves division by a tiny number - which is equivilant to
multiplication by a huge number. It's numerically unstable.
(Of course, the limit of sin(x)/x as x approaches zero is just 1, which
you don't need to "estimate" in the first place. But if you had a
similar formula which approximates some irrational quantity...)
Date: 10 Feb 2010 04:17:11
Message: <4b727997$1@news.povray.org>
>>> value is infinite).  The closer (or the bigger) the number you
>>> compute it for the closer your answer will be.
> How much of a problem this is depends on the limit.
True enough.
>>> If the product converges then you can by definition get an
>>> n terms for a large enough n.
>> result.
I guess it's just the case that an infinite sum or product can be
convergent, and yet converge really, *really* slowly...
>> 7-year period...)
Well, I *did* go to a school for stupid people, after all...
Date: 10 Feb 2010 13:47:56
Message: <4b72ff5c@news.povray.org>
>> like each other.
Crashed. A khtml::BidiContext object supposedly on the memory address
0xffffffffffffffff had one of its member methods called. *Boom*.
I filed a bug: http://bugs.kde.org/show_bug.cgi?id=225954
Date: 11 Feb 2010 04:09:30
Message: <4b73c94a$1@news.povray.org>
>>> like each other.
OK, that's not good...
