OK, so here's a question: How do you actually type in Unicode characters
that aren't on your keyboard?
It's nice that Unicode exists, and a tiny fraction of software in
existence even supports it, and approximately 3 fonts in the world have
the appropriate glyphs in them. But how do you type those?
(For example, I've discovered that if I want to type, say, "ü", I can
look up the Wikipedia article for "U" and the article for "ü" is linked
from there. But that requires an Internet connection, and seems like an
absurdly long-winded way of going about things...)
http://blog.orphi.me.uk/
can
inked
If you know the code number, it's some keyboard escape, like holding down
the alt key while typing on the numeric keypad or something.
If you don't, the application under Windows is called "Character Map", an
d I
think it's under Accessories in pre-Vista windows.
Forget "focus follows mouse." When do
I get "focus follows gaze"?
Darren New <dne### [at] san rr com> wrote:
> d I
yep, even Ubuntu got that, same location.
You don't even need unicode for that character, ISO-8859-1 has it.
I type it by pressing shift-´ (which is ¨), then 'u'.
For ñ I simply have a separate key.
On Linux, my keyboard layout has some useful Unicode stuff under AltGr +
letters. For example “proper quotes” (AltGr + V and B respectively) or the ©
symbol (AltGr + Shift + C).
Le 31/01/2010 18:05, Orchid XP v8 nous fit lire :
Depend on your application, i guess.
For instance, vi/gvim have a ctrl-v/u/4hex digit sequence as escape for
inputing such characters (as long as your font support it, and you're in
not in need of the extended pages (after 16 bits))
> down the alt key while typing on the numeric keypad or something.
Sure. But there are zillions of Unicode characters you might want to
use. (I forget how many accented vowels there are. And then there's all
the mathematical symbols that somebody like me might use...)
> and I think it's under Accessories in pre-Vista windows.
Right. I guess that's probably the least clunky way to do things...
And of course, a decent text editor will allow you to bind shortcuts to
commonly used Unicode characters. [Now to go find "a decent text editor"
before somebody tells me to start using Emacs. :-P ]
if you have the right language installed. English in general has not
much use for ü so that is not default for Andy.
> I type it by pressing shift-?? (which is ??), then 'u'.
I don't think the question was if Unicode is necessary to get the
character, but instead how to get the unicode character in question.
Are you sure that supports unicode and not just the system default
character mapping (which in Windows would be that Windows extension to
ISO-Latin-1, at least in western countries)?
> If you don't, the application under Windows is called "Character Map", and I
Likewise.
You can switch keyboard mappings, you know.
But I suppose that if you need some special character which is not really
part of any mapping (or any mapping you know or are familiar with), you use
some utility program. Some text editors might have such a feature built in.
If you are writing HTML (or XML), you can write the unicode value directly
as &#xxxx; (IIRC). Might require proper HTML/HTTP headers for the client
program to interpret properly.
On Sun, 16 Oct 2005 09:28:09 +0200, Fredrik Eriksson wrote:
> " Alt+<xxx>, where xxx is the decimal value of a code point, generates
> an OEM-encoded character.
> Alt+<0xxx>, where xxx is the decimal value of a code point, generates a
> Windows-encoded character.
> Alt+<+>+<xxxx>, where xxxx is the hexadecimal Unicode code point,
> generates a Unicode-encoded (UTF-16) character."
>http://www.microsoft.com/globaldev/reference/glossary.mspx
FE
> character mapping
"some keyboard escape like ..."
I know you can type unicode, and I know you can type ASCII, but I don't
remember how to invoke one vs the other.
GIYF
http://www.fileformat.info/tip/microsoft/enter_unicode.htm
Basically, type numeric plus first to get unicode.
If Windows takes the raw Unicode value (as entered by the user) and
encodes it in UTF-16 before passing it to the application, that would
mean that the application must understand UTF-16 as its input from (what
it perceives as) the keyboard.
Which programs actually support that? (And why UTF-16, of all possible
Unicode encoding formats?)
(An alternative to this is that the person who wrote that sentence has
no idea what he's talking about, unless I'm understanding incorrectly the
whole process involved.)
UTF-16 is the internal system encoding in all NT-based versions of
Windows. It is also the encoding in which programs receive incoming
character codes.
I think most Windows programs are capable of handling Unicode these days.
Those that do not will either ignore non-ASCII characters or display them
wrong (typically as boxes or question marks).
FE
> character codes.
I don't understand how that can work. Do programs convert the UTF-16
encoded characters back to raw Unicode values before using them? (Does
this perhaps happen inside the system call which is used to read the
character?)
UTF-encoded text (regardless of which UTF encoding scheme is used)
cannot easily be used directly in programs because characters cannot
be easily indexed (because UTF is a variable-length encoding scheme;
in the case of UTF-16 each character is either 2 or 4 bytes long,
depending on the Unicode value.) I have hard time believing that programs
are internally handling the text in UTF-16 format, so I'm assuming that
a decoding to raw Unicode is done first.
But how do they handle the characters? Do they ask the system for a
(Unicode) character and get a raw Unicode wide char?
>> character codes.
> character?)
>> days.
When dealing with just one character at a time, the application receives
UTF-16 code points and must identify and deal with surrogates if needed.
For display purposes, one can offload some of the work on the Uniscribe
API. Mostly though, strings are passed around as a whole (i.e. as lists of
code points), in which case it "just works"; all standard widgets and
API-functions fully support supplementary characters.
For an application that does not need to deal with "exotic" alphabets
(e.g. Chinese), one can typically get away just fine with treating the
UTF-16 code points as if they were UCS-2.
FE
Hmm, I'm not exactly sure what you mean by "UTF-16 code point".
According to the unicode.org glossary, a "code point" is a value in the
Unicode codespace, ie. a value in the range between 0 and 10FFFF. (Or what
I often refer to as "raw Unicode value".)
UTF-16 is a translation format between Unicode code points and bytes.
In other words, the raw unicode value is taken and encoded into a series
of bytes (2 or 4 of them, depending on the value) using a certain algorithm
(this encoding algorithm is designed to avoid any code point which has a
value larger than 127 into producing a byte with a value smaller than that).
Decoding from UTF-16 back to a Unicode code point is the reverse operation.
Thus I'm not exactly sure what you mean by "UTF-16 code point", as it
seems to be mixing the two things into one concept.
Anyways, if the Unicode-aware program requests a Unicode character from
the system, and the system returns it UTF-16-encoded, I suppose that means
that the program must decode it to a Unicode code point before it can use
it (unless it specifically handles UTF-16 strings directrly, of course).
Hmm, that sounds like a hindrance. Couldn't the system return raw Unicode
code points directly?
OTOH, if a program is Unicode-aware, it should really be prepared to
handle any characters in the entire Unicode codespace.
I mean a single 16-bit value from a UTF-16 string.
Yeah, I should have used "code unit" instead.
> means that the program must decode it to a Unicode code point before it
> can use it (unless it specifically handles UTF-16 strings directrly, of
> course).
Yes, unless...
> Unicode code points directly?
Starting with Windows XP, it can.
FE
Hope the following helps:
Internally .net stores characters as unicode (UTF16). There is an "encoding"
class that helps you to deal with encodings. Windows .net API provides you
with the option to use many different character encodings.
Here some excerpts from the MS online help:
Dim fileReader As String
fileReader = My.Computer.FileSystem.ReadAllText("C:\test.txt",
System.Text.Encoding.UTF32)
MsgBox(fileReader)
Writing goes something like this:
My.Computer.FileSystem.WriteAllText(file ,text ,append ,encoding)
There are a lot of different encodings supported by .net:
ASCIIEncoding
Represents an ASCII character encoding of Unicode characters.
UnicodeEncoding
Represents a UTF-16 encoding of Unicode characters.
UTF32Encoding
Represents a UTF-32 encoding of Unicode characters.
UTF7Encoding
Represents a UTF-7 encoding of Unicode characters.
UTF8Encoding
Represents a UTF-8 encoding of Unicode characters.
Chr uses the Encoding class in the System.Text namespace to determine if the
current thread is using a single-byte character set (SBCS) or a double-byte
character set (DBCS). It then takes CharCode as a code point in the
appropriate set. The range can be 0 through 255 for SBCS characters
and -32768 through 65535 for DBCS characters.
The returned value depends on the code page for the current thread, which is
contained in the ANSICodePage property of the TextInfo class in the
System.Globalization namespace. You can obtain ANSICodePage by specifying
System.Globalization.CultureInfo.CurrentCulture.TextInfo.ANSICodePage.
ChrW takes CharCode as a Unicode code point. The range is independent of the
culture and code page settings for the current thread. Values from -32768
through -1 are treated the same as values in the range +32768 through
+65535.
Numbers from 0 through 31 are the same as standard nonprintable ASCII codes.
For example, Chr(10) returns a line feed character.
Hold down left alt and press some numbers on the keypad. THe only one I can
remember is the one for the plus/minus symbol (Alt+0177) as I use it a lot
and it's not on my keyboard.
Funny I found that most software does support it, otherwise I would be
continually screwed in my job not being able to open documents or understand
email from Japanese people. Here (Vista Business 64bit) I can even create a
file/folder in explorer with Japanese characters, then zip it with WinZip
and everything works fine.
> and approximately 3 fonts in the world have the appropriate glyphs in
> them.
I know when I get Japanese documents, they normally use a special font like
"MS Mincho", I suspect it would be a bit of a wasted effort to make every
font contain every single unicode character. There also seems to be fonts
like "Arial Unicode MS" that maybe contain all (most?) of them (it at least
contains all the Japanese characters).
In Word you can use some keyboard shortcuts...
(ctrl ~)n
(ctrl :)u
(ctrl ^)a
they follow that pattern, so it shouldn't be too
hard to remember, but it's a three key press,
ctrl, shift, whatever.
> (ctrl ~)n
> (ctrl :)u
> (ctrl ^)a
On my German keyboard pressing ^ by itself does that, annoying if you're
trying to type "^error" or something (often in C++ .net) because it comes
out as êrror. Seems like they thought the only possible use of ^ would be
to go above other letters.
Hitting the "^" followed by "SPACE" will give you "^" - but you probably
knew that.
I think this is exactly as it should be - "^" is a kind of decoration (that
indicates pronunciation) like "´" and "`" which work exactly the same way,
giving an "é" when pressing "´" followed by "e" and so on. If you want the
"^" alone you just decorate an empty space.
"scott" <sco### [at] scott com> schrieb im Newsbeitrag
news:4b66ca86$1@news.povray.org...
>> (ctrl ~)n
>> (ctrl :)u
>> (ctrl ^)a
> (that indicates pronunciation) like "´" and "`" which work exactly the
> same way,
I guess I'm in the minority then, by only using ^ for the power operator and
as the reference thingy in .net.
Shouldn't that technically be "↑"? It's just that the original ASCII
standard included "^" (why?) but not "↑". Or that's how I heard it. In
books it's usually written as a superscript or as "↑", but never, ever
as "^" except in programming languages...
> and as the reference thingy in .net.
...which use it because of the historic ASCII standard.
Does that mean it skips some characters?
Invisible wrote:
> It's just that the original ASCII standard included "^" (why?)
It's also a caret. If it got replaced, I imagine it got replaced the same
time left-arrow got replaced by underline.
I was using this stuff a year ago to be able to produce properly encoded
files for Google Maps. Worked for me, so case closed.
I did not try and so I don't know for sure. I would guess negative numbers
map to 32767+. Maybe this is an error in Microsoft's documentation. It
seemed strange to me, too, but I did not use negative numbers, so why
bother?
MS is somewhat notorious for misleading and faulty docs. I remember somebody
saying that the docs for MS WinWord were less a manual but more a work of
fiction. ;-)
> Shouldn't that technically be "?"? It's just that the original ASCII
> standard included "^" (why?) but not "?". Or that's how I heard it. In
> books it's usually written as a superscript or as "?", but never, ever as
My VIC 20 had the ? - which was very useful when programming any game with
ASCII graphics. It made a nice missile. ;-)
...so I'm guessing there was some kind of encoding error with this post.
But I get what you're saying anyway. ;-)
I seem to recall that several 8-bit home computers had codes 128-255
identical to codes 0-127, but with the colours inverted.
"Invisible" <voi### [at] dev null> schrieb im Newsbeitrag
news:4b67f21c$1@news.povray.org...
>> with ASCII graphics. It made a nice missile. ;-)
This shows us the joys of different encodings. ;-)
In my websites I changed all "?" to "EUR", so my customers can easily use
the contents in different portals without having to worry about encoding.
Copying UTF-encoded symbols and pasting the contents into a CMS is like
playing with a wheel-of-fortune... you can never say what you will get.
That's why all those technologies have entity escapes.
