http://www.nytimes.com/2010/01/14/nyregion/14fire.html?adxnnl=1&adxnnlx=1264791670-GxVD+sfKjvw04Ji/zop/fQ
It fails to explain how exactly the test discriminated. I looked at
some other articles, and none gives any detail whatsoever.
CONgress (n) - Opposite of PROgress
It's puzzling indeed. I'm trying to think how you could create an exam
which would be disadvantageous to black people, and I can't think of anything.
How could one possibly make a test disadvantageous to people with a certain
skin tone? I just can't fathom it.
(I'm assuming that all applicants are given the exact same test, as the
article doesn't seem to imply anything else. Thus I cannot even imagine
how the suitability of the exact same test could depend on skin tone.)
There are certain tests you can give that would discriminate. Perhaps blacks
are more poor or worse educated, so if you asked about proper grammar or
financial questions, you could discriminate.
I can't imagine any test that would discriminate against blacks and have
something to do with fire fighting, tho.
I remember reading about this - they had to drop the test a couple of years
because none of the blacks who applied for the promotion that the test
enabled actually passed the test.
It seems to me if the test is actually a valid test of necessary skills and
you can't pass the test, you shouldn't be risking your life and mine in a
job like that, even if the test has a correspondence between skin color and
pass rate.
Yes. It just happens that blacks don't pass the test as easily as whites.
It would be fascinating to see the test. I can't imagine a set of questions
that would so reliably discriminate without being obvious about it. Usually
these cases come when 23% of the applicants are minority but only 21% of
those passing the test are minority, but from what I've read, the rates are
way out of line.
Note that in this country, the simple fact that blacks don't pass the test
makes it very difficult to legally claim the test isn't "discriminatory" in
the sense that this article means it. Folks claiming that don't have to
prove there's something biased on the test. You have to prove there's some
other reason that skin color corresponds to success rate.
Forget "focus follows mouse." When do
I get "focus follows gaze"?
"Neeum Zawan" <m.n### [at] ieee org> wrote in message
news:4b6334fe$1@news.povray.org...
The test "discriminated" because African-Americans (and possibly Hispanics)
scored lower than their White peers. And since requiring applicants to be
somewhat educated is such a repugnant idea, the obvious solution is of
course to dumb down job requirements while sweeping the root cause of the
problem, which would take actual work and money to fix, under the rug. It's
always better to have semi illiterate constituents who you make to believe
that you are doing them a favour than literate ones who don't need favours
from you to stand on their own feet.
It is not the skin tome, it is the cultural background. (almost) all IQ
test favour white Europeans, because they refer in subtle ways to things
that appear to be common knowledge by the people who design these tests.
They also put an emphasis on things that we as Europeans (or is
Caucasian the term mostly used in the US?) find important. Sometimes
that is valid and sometimes it is not.
If a test uses a phrase that became well known because of being used in
a 60's sitcom, people with a social background that included a TV in the
60's will have an advantage. Use one from a 90's black sitcom and
another group is a at an advantage.
One of the things that my sister mentions in her book on cultural
background in the job market is that it appeared that a disproportionate
number of Dutch citizens from a non-Dutch background failed the written
test for nurse. The reason turned out to be that in the questions a lot
of expression were used that were derived from our famous 17th century
bible translation. Even if the tested persons were familiar with the
bible, they too often did not know our particular translations. One
could argue that that would indeed imply that they would not be able to
communicate effectively with the rest of the staff and the patients. One
could also argue that these expression seldom turn up in spoken
communications, especially if the one you are talking to is easily
identified as probably not a 5th generation pure bread Dutch. Also note
that the reciprocal problem is never mentioned. The persons that made
the test might not be able to communicate effectively with a subgroup of
patients.
Creating a good set of questions is a skill. Most that are used today
fail to meet the principle that they only test the relevant skills. The
test that I gave today to my students is an example of such a biased
test. I know it is, I can identify (some of) the questions that are
contaminated by cultural bias. I know many people would not even notice,
but I did and I didn't find a way to solve it.
So, I know that even a test on digital technology can have a cultural
bias. Therefore it wouldn't surprise me if a test for fireman would
also. You would have to see the actual test to see if that bias is
justified or not.
Does this answer your question?
Even if that's so (ie. black people in the US having in average a poorer
education), I don't see how it's discriminating against blacks per se.
If anything, it would be "discrimination" against uneducated people (if
such a thing is feasible). Any person, regardless of skin tone, would score
poorly in such a test. How is this discrimination against black people?
If the problem is that black people are in average more uneducated, the
proper solution to that problem is not to dumb down admission tests (which
in itself ought to have rather negative consequences related to job
performance and perhaps in some cases even safety), but to educate them.
(If black people, for whatever reason, do not *want* to get educated, well
that's hardly a problem with the fire department, is it?)
In fact, if the reason for the justice system to demand dumbing down the
tests so that black people can score better is because they are uneducated,
I see an irony here: By trying to be "politically correct" and offer "equal
opportunity", the justice system is actually openly admitting that black
people are uneducated compared to white people. What kind of message is
this sending to the population?
How is that the fire department's fault or problem? If they are applying
the exact same test equally and fairly to all applicants, that's the very
definition of non-discrimination.
Discrimination is when some people get preferential treatment over others.
Hate to sound like an antimulticulturalist again, but it really doesn't
surprise me in the modern world that when a protected minority scores poorly,
the fault cannot be said to be in that minority, but in the test instead
(completely regardless of how the test is performed). If the protected
minority scores poorly, the test *must* be discriminatory in some way,
there's no other explanation.
By demanding the test to be dumbed down, the justice system is actually
openly admitting (probably without realizing it) that some groups of people
are poorly educated. What they won't admit is that it's the actual problem.
The problem must be in the test itself, of course.
I don't think that's true. Maybe it was true 50 years ago, but nowadays
IQ tests are specifically designed to be detached of all cultural backgrounds.
Education can have some effect on IQ tests (because education can eg.
train a person to think geometrically), but AFAIK in the US and especially
Europe all people have had the exact same education for quite many decades.
If some group of people doesn't *want* to get educated, that's a different
problem. It's *their* problem, not the problem in IQ or aptitude tests.
> justified or not.
I have hard time thinking of a question in a fireman test which a white
citizen of the US is able to answer due to his culture but a black citizen
of the US isn't, especially if both have gone to the same schools.
> course to dumb down job requirements.
...and *this* is why the world is utterly broken.
http://blog.orphi.me.uk/
They are more aware of the problem, that does not mean it is solved,
besides they are still using old ones too. Ask my sister ;)
No they haven't. May I remind you of the private school debate here some
time ago. Remember who started that thread?
I can't see where this one comes from. Are you aware that this could be
interpreted as a racist remark? I am sure you don't mean to, but
suddenly starting to talk about "people that don't *want* to get
educated" in a discussion on how race influences test results is not a
smart move IMHO.
>> justified or not.
> of the US isn't,
I know you find that hard. You have said similar things many times. Yet,
if I made a remark containing the phrase "Umso schlimmer für die
Tatsachen" you might get what I meant, but the majority here will
probably not. In fact on average more white people would get it than
black. Yet it has nothing to do with color. The same mechanism works in
almost all tests, albeit often more subtle.
well, they didn't (on average), that is precisely the point.
I do hope that the fact that education plaid a role is based on some
facts and not on the assumption that because the plaintiffs are black
the issue must therefore be one of education.
If there is no factual base for your claim all subsequent conclusions
are void.
>> different
> smart move IMHO.
Ties back into the comment I made about people insisting they're not
racist, they don't like people with a particular attribute that has
nothing to do with race--but consistently ascribe that particular
negative trait more to a specific racial group than any other.
"I don't hate blacks/hispanics, I hate people who are poorly-educated
(and the only reason to be poorly-educated is that you don't *want* to
learn). It's not racist--nevermind that blacks/hispanics are
traditionally disadvantaged and not given as much education as whites
even in the same classrooms. Learning is entirely up to the individual,
so all students in a given class will learn exactly the same if their
desire to learn is the same."
Tim Cook
http://empyrean.freesitespace.net
The main question is always: are we testing the right things. In general
employers are asking more cultural background than is needed for the
job. Simply because they want the best person, not the one just right
for the job. In doing so they discriminate against people from less
wealthy backgrounds and thereby de facto against black people.
Keep in mind that education of minorities is not a priority for many
white politicians. They tend to support laws that unintentionally hurts
minority education more than that of their own children. All with the
best intentions of course. (note that this is based on a generalization
of what I understand from people and US conservatives in particular. I
don't live there and I don't have explicit examples).
I covered that elsewhere, I think.
No it isn't.
for reasons that are irrelevant to the matter.
To me you just sound like someone from a protected background with
relative little experience in the real world. ;)
>> poorer
>> score
Bingo. Or possible bingo.
I knew when I posted the link people were going to jump to rampant
speculation, and come to conclusions (or close enough) that mirror their
views of the world.
I don't know what was on the test, and no one here seems to. So why are
people coming up with all these conclusions?
Yes, some tests, on occasion _have_ been found to be "discriminatory".
This happens on occasion with things like the SAT exam (a common exam to
get admission into university in the US). It consists of a "verbal" and
a "quantitative" section. The verbal section involves reading
comprehension, and it's easy to believe that questions can be asked that
are biased towards/against a portion of the country (sometimes the bias
corresponds to race, but sometimes other factors).
Likewise the quantitative guys try to be careful. Think probability:
Will everyone know that a deck of cards has 52 of them?
I'm willing to accept that the test was discriminatory - I just want to
know how. My complaint isn't about the ruling, but the journalism
(something everyone who responded seemed to miss).
At the same time, I will confess that I don't think it's beyond some
court to say it was discriminatory just based on the test results
(unfortunately because of the way some laws have been passed). But I'll
give the benefit of the doubt.
One flea to another: "Is there life on other dogs?"
Thanks for letting us know. Can you tell me where I can purchase the
crystal ball that told you that information? Or was it a mirror on your
wall?
One example I remember was something like "You've lost your ball in a
circular field. How can you more efficiently look for it." If you grew up
in a rain forest, with neither balls nor fields, this is a difficult
question to consider.
The IQ tests I had in grade school (maybe 35-40 years ago) definitely had
culture components. Pictures from a cartoon that had to be put in the right
order, involving leaving the house, seeing it's raining, going back for the
umbrella, missing the train because of that, etc. Granted, this wasn't
*supposed* to be applicable to cultures outside where I went to grade
school; I'm pretty sure that even disadvantaged black children knew what
umbrellas were, for example.
Not here. People from poor neighborhoods with crappy schools and overworked
teachers get worse education than those from rich neighborhoods with
expensive lab equipment and books and plenty of teachers per pupil.
Of course, the question is how many generations do you go before you decide
that any residual results of discrimination are no longer significant?
Obviously, the children of newly freed slaves are going to be at a
disadvantage compared to the children of previous rich slaveholders - their
parents don't know as much, don't speak gramatically, can't answer questions
about science, etc. The children of uneducated parents are going to be less
educated than the children of educated parents.
Honestly, it hasn't been that long since blacks here got legally equal rights.
Yeah. Actually, I think this was a test for promotion to some
leadership/management position. It wasn't a test about fighting fires, but
about running a fire fighting company. So I imagine there could be
something on it. It's just hard to believe there's anything on it that
would make *all* 26 black applicants fail the test.
Heck no. There's no well defined standard for education here in the US.
It varies from state to state, and varies quite a bit even within a
state. If you go to one school, your performance may be considered OK.
The same performance in another school may be considered close to failure.
Why are we discussing hypotheticals?
1. That you (or I) can't think of something is not indicative of much.
Don't give yourself too much credit.
2. What gave you the idea that the test was about firefighting? That's
the whole point of my saying "Bad Journalism". The articles that I
looked at didn't give a clue as to what's on the test.
Arguments about racism are often more about culture. Sometimes that
translates to race. The US is not that uniform (even within a city).
54.
I caught it. We were discussing whether the reason the test's discriminatory
nature wasn't disclosed is because nobody can figure out why it's
discriminatory.
The right solution is still not dumbing down admission tests, but to fix
the problems in education.
Dumbing down admission tests can only have a negative effect, especially
in such a critical occupation such as a fireman. A person who is not
qualified for the job can end up hurting himself, his co-workers and
even the people who he ought to save and protect.
Safety, especially when we are talking about people's lives, must always
go first, by a long, long shot. Political correctness comes as a far behind
second.
I consider skin color to be a rather irrelevant thing when talking about
fireman aptitude tests. Dumbing down tests because of skin color *is*
preferential treatment.
> years because none of the blacks who applied for the promotion that the
> test enabled actually passed the test.
No - that was New Haven. This is New York. Different cases altogether.
Well, it's pretty much the definition of "discrimination", in the technical
sense. :-) It apparently did a bang-up job of discriminating between whites
and non-whites, with a very low false-positive rate.
It's "discriminatory" in quotes because the discrimination was based on
"race" (or more properly ethnicity) and the minorities came out behind.
How did a simple written test that apparently does not look discriminatory
to those in charge of administering the test do such a good job of
discriminating between ethnicities? That's a very good question!
OK, thanks! I retract whatever I said based on that misconception. :-)
Are you saying that in the US all firemen studied in private schools and
that's why they got the job?
Besides, at least here what is taught at schools is dictated by law.
You *can't* have a school which skips teaching something, be it private
or not. I don't know how it is in the US.
It has been suggested that black people score more poorly in the fireman
aptitude test because of a poorer education. And why would black people
have a poorer education in the US? Is it because black people are not
taught the same things as white people?
> Are you aware that this could be interpreted as a racist remark?
Of course anything that is not 100% politically correct can be
interpreted as "a racist remark". So?
> smart move IMHO.
Really? And what would be the alternative explanation for the claimed
poorer education? I can think of three possible explanations:
1) Black people in the US are not taught at school to the same extent as
white people. I have hard time believing this to be the case, especially
since, AFAIK, most black people go to the exact same schools as white
people do.
2) For whatever reason (maybe culture?) the average black person is not
interested in educating himself.
3) Black people are unable to learn as efficiently as white people.
#1 doesn't work, unless you can show me some actual proof that black people
are indeed being discriminated at schools in the US and not being educated.
#3 would be the racist point of view, by definition (ie. there's something
about being black that makes the person dumb).
The only non-racist rational alternative is #2.
Making generalizations about a *culture* is not racism. Racism is an
ideology based on the notion that some races of people are genetically
superior to others.
Actually I have no idea what that means. Is it German? (Not that this
invalidates your point.)
You mean that blacks are not taught the same things in the US as whites?
Btw, why couldn't it work in the other direction as well?
For example, the majority of NBA players are black. Isn't this discrimination
against white people?
On 01/29/10 15:31, Darren New wrote:
> 54.
52, if you're doing a mathematics test.<G>
I think your comparison is not very relevant. You are basically comparing
the cultural backgrounds of person who have grown in a western civilization
to that of a bushman who has grown in the jungle.
I mean that it's not very relevant in the specific context of this thread,
where the question is why black people in the US are failing the fireman
test more often than white people. I don't think the implication is that
the black people were raised in a jungle.
IQ tests always assume certain basic knowledge. They have to. You can't
make an IQ test which works the same for Einstein and a fish. Even those
tests which try to be as culture-agnostic as possible still make some
assumptions (such as that you can recognize the shape of a circle, for
instance; or heck, that you can *see*).
I can well imagine that an aptitude test in the US could make some
assumptions that cannot be made about foreigners, such as for example
the applicant knowing who the first president of the US was, or the
name of the 50th state. Depending on the job, such cultural knowledge
might be necessary (not those two things precisely, but similar things
which most US citizens should know).
As I have been saying, the solution to that problem isn't dumbing down
aptitude tests. That's one of the worst possible solutions.
Anyways, it would be interesting to know what is it that it's being taught
at the "rich" schools that is not being taught at the "poor" schools, which
make the "rich" people more apt to become firemen.
I think "discrimination" in this context implies intent. In other words,
that the test would have been specifically designed to favor some people
over others.
You can't talk about discrimination if the different passing rates are
not caused purposefully.
From my understanding, that doesn't hold here. May vary from state to
state. But even if some states mandate some curriculum (including for
private schools), it's fairly minimal.
Quite possibly, yes. Especially if they're poorer. It's fairly well
known that a _public_ school in a rich neighborhood gets a lot more
funding per student than a public school in a poor one. So fewer
resources, and often, worse teachers. Also, the richer school may have
many more programs to educate their students beyond what is considered
"normal".
> people do.
If they're poorer, and there's a high level of segregation (both true
in the last city I lived in), then yes, it is the case. This isn't rare
in the US. And no, in many places, they don't go to the same schools.
The city I last lived in actually had to pass some temporary laws to
ensure that there was a healthy mix in schools by moving students around.
I don't know about Finland, but over here you don't have that much
choice what public school you go to. Hence that temporary law to allow
students to go to other schools.
Quite possible, as well. However, the question still remains as to
whether he is qualified to be a fireman, and the question still is
whether the test was relevant to firefighting.
Of course, one problem with your rhetoric in all 3 points (and perhaps
in other people's messages), is the usage of the phrases "black" and
"white".
This isn't about black or white people in the US, but about them in one
particular locale in the US. It's a big country.
You're brash to assume you have all the possibilities pegged down.
Andrel made a valid point about TV shows. And yes, in parts of the US,
I'm sure you'll find a fairly big discrepancy on the TV shows black
people watch vs white people.
Perhaps the same can be said about sports, music, etc. You've ignored
the possibility of a cultural bias in the exam.
If they're not in the same neighborhood, than often, no.
On 01/29/10 15:28, Darren New wrote:
> their parents don't know as much, don't speak gramatically, can't answer
I'm sure they speak grammatically. Perhaps just not English grammar. ;-)
> but about running a fire fighting company. So I imagine there could be
26 is not a big number. And IIRC, for that case, they didn't rule that
the test per se was discriminatory, did they?
Some more info:
http://jurist.law.pitt.edu/paperchase/2010/01/federal-judge-rules-new-york-city.php
This site links to the actual ruling. I read only the first few pages,
but it seems that the argument was:
1. The test involves written comprehension, which black people in NYC
suck at (I'm dropping political correctness for the rest of this message).
2. It was alleged, and the court apparently agreed, that this wasn't by
accident, but done intentionally by the fire department.
3. The court allowed the city to make the case that the questions (or
perhaps the _format_ of the test) was relevant to being a good
firefighter. The court did not feel the city made the case.
(There may have been subtleties on what constituted a passing mark).
Hence, the court found unnecessary/intentional discrimination occurring.
The argument put forth by the plaintiffs was that being particularly
good at written comprehension to the level needed to pass the test was
not particularly important to being a good firefighter, and the court
agreed.
If someone wants to read it more thoroughly and correct me, please do so.
You can find sample problems here:
http://www.zwire.com/site/news.cfm?newsid=20406299&BRD=2731&PAG=461&dept_id=574907&rfi=onmousedown=return
(They definitely are related to firefighting).
Also, although I don't know if this was used in court and was part of
the decision, a side argument was that for other departments (police
department, etc), the blacks in NYC have little trouble satisfying the
requirements for those departments, so they were hinting that something
fishy was up with the FD.
Yes. I was just describing an example I read of how something that might
*seem* to be a purely mathematical and culture-free question might actually
assume some culture after all.
I wouldn't call blindness a cultural problem. ;-)
Heck, I was in Alaska, in a restaurant with Alaska paraphenalia plastered
all over the walls, including a newspaper page with the headline "Alaska
admitted to the Union!" and I asked the waitress whether Alaska was #49 or
#50, and she didn't know. :-)
I agree with most of what you say, yes. Making it easier for losers to
accomplish should be done by making losers into winners, not by rewarding
loserness.
Now, yes. As slaves (which was my example)? No, probably not. Slaves weren't
allowed to use their own languages or have their own culture either.
As you said, it was a different test, so I don't know. I think I remember
reading that they decided to promote nobody, and the people who passed the
test were understandably PO'ed.
If there were questions that unfairly penalized one sub-culture over another
for no good reason, and it was brought to the attention of those in charge,
and they didn't correct it, then that too could be discrimination. That's
what the article is saying happened.
I don't think anyone wrote the test intentionally trying to keep minorities
out of the job. (You never know, tho.)
news:4b636eb7$1@news.povray.org...
Hispanics)
be
> wall?
You don't need a crystal ball if you are willing to learn from recent
history:
http://en.wikipedia.org/wiki/Ricci_v._DeStefano
and exercise a little bit of reason: As others have noted, it's very
difficult to concoct a test that differentiates skin colour, and *not* level
of education.
I remember reading about this specific case earlier and the objection to the
test was post-facto, that is, it did not result in acceptable quotas for
minorities. It was claimed that the test included too much reading and
comprehension type material, which was unfair to blacks (which ironically is
itself a racist statement). I don't have references handy and cannot be
bothered to look them up for you, do your own homework.
The exam consists of 85 multiple-choice questions.
Some of the questions had long explanations which put
people who can't read well at a disadvantage.
IMO, firemen should be able to read.
The courts seem to think that testing for any "skill cluster" that isn't
strictly part of the job (as defined by the courts) is racist.
http://www.nytimes.com/2009/07/24/nyregion/24firefighters.html?ref=nyregion
Yes. This is clearly and obviously discrimination against white people.
In fact, you know what? Most NBA players are very tall. Obviously
discrimination against short people.
In fact, most NBA players are very thin. Obvious discrimination against
fat people!
And hey, most NBA players are extremely fit. This discrimination against
unfit people is totally unfair!!
It's not discrimination if people without the necessary skills can't get
in. It's only discrimination if people who *do* have the necessary
skills can't get in just because of their skin colour / other arbitrary
irrelevant factor. People need to wake up and realise this.
This stuff is getting stupid. Where my mum works, there's this one black
guy who's bone idle, lazy, incompetant, and has harassed female staff on
more than one occasion. But every time somebody tries to fire him, it's
"oh, this is racially motivated! This is unfair! I'm calling the
police!" And the company backs down, and he gets to keep his job. WTF?
This is of course inverse discrimination; if a white guy did this, he'd
be gone in 5 seconds flat...
On 30-1-2010 0:31, Darren New wrote:
>> want to
> I caught it.
Well I think it was obvious from the subject line that that was your
point. I didn't react to it because it was handled as if the history was
common knowledge. I do remember something in the news about the earlier
ruling and I don't even live there. I felt that a discussion about
whether the journalist did their work and provided enough information
would deteriorate into a discussion on what is common knowledge for whom
and what the intended audience was for that article. (In a round about
way it did.) As a foreigner, i.e. someone not living in NY (the header
says "N.Y./Region"), I felt that I had nothing to say on that matter.
"Darren New" <dne### [at] san rr com> wrote in message
news:4b636f15$1@news.povray.org...
A lot of questions about hockey?
Is this your famous sense of humour again?
I don't know about finland, but here we have "good" and "bad" schools
eventhough they have the same requirement. Apart from the fact that some
are better funded and can therefore provide better education, there is
also the fact that when a school has a lot of people from less well off
background it is much harder to teach there. You loose much more time in
getting everybody's attention.
That was answered many times before. If you still don't get it, I might
reiterate below.
It is not about political correctness. That might have been a valid
argument if your remark was relevant, now you are simply broadening the
discussion to include more racial prejudice.
>> smart move IMHO.
> white people.
Correct, indeed probably the main reason.
> people do.
That is not true unfortunately. Many areas are either predominantly
white or predominantly black or predominantly hispanic etc. Hence they
don't go the the same schools. Primary school is always in the
neighbourhood. If you don't get a good start you chances of making up
are slim. Education is a non-linear process.
partly true
They are for reasons outside of them not for genetic.
See my last remark below and all the other explanations in my and other
peoples posts on this subject.
Ah, so you meant genetic.
That is what you think. In fact it is not non-racial (because there is a
big correlation between race and social environment. At least in the
US). Also it is not the main explanation. #1 is.
> superior to others.
Yes it is German. It refers to the story that Hegel had a theory on
something and someone pointed out that it was at odds with the facts. At
which point Hegel was said to have answered "Umso schlimmer für die
Tatsachen". Which translates roughly as "so much worse for the facts".
To get that you need to know enough German to recognize the story and
you need to have been in an environment where someone was educated
enough in German philosophy that he or she was able and willing to tell
that story to you. In short you need to be white. A black guy with a PhD
in biomedical engineering is less likely to know this then me. Not
because of race, but because he did not live in the same environment as
I did.
Yes, sigh. They don't go to the same schools. They grow up in different
neighbourhoods. Being born in a black neighbourhood will make sure that
you don't get the same amount of attention from the teachers, that your
fellow schoolkids will make it hard to study, that you watch different
programs on TV, that you will have a different pattern in spending your
free time, etc. etc.
> history:
> of education.
Yes, but according to the ruling, the key aspect here wasn't the mere
"discrimination", but the fact that the test didn't test whether they
were qualified to do the job. The court allowed the FD to make the case
that the test format was relevant to the job, and the FD didn't make the
case enough to please the court.
Yes, the objection may have been post-facto, but it wasn't an invalid
objection. Had the test discriminated, and the FD made a valid case that
the test is relevant to the job, then the status quo would have resumed.
When I was young, they told me anyone could become president. Now I'm
beginning to believe it.
That's a sweeping statement. No one said they couldn't read.
Yes, in a sense that's what they ruled. It's racist if that unnecessary
skill cluster showed a discrimination.
I can see it either way. On one level, it could have been a "harmless
accident" (who's supposed to guess that something like reading
comprehension would become such a big issue?). On the other hand, I can
also see it as "We know these guys suck at reading comprehension. Let's
make it a big part of the test, and set the time constraints in a manner
such that they're much more likely to fail."
> people do.
I don't think this is necessarily the case. Children here go to close
schools. Schools are funded by property tax. Children of poor parents go to
schools with less money to pay teachers and books than children of wealthy
parents. Minority parents tend to be more poor, in part because they're less
educated. So it's sort of a vicious circle that needs to be broken. If you
just say "teach everyone the same", it doesn't happen, because the money
isn't there.
I saw a funny black comedian talking about that, going on about sports and
how there are no black people playing hockey. "The only thing in the whole
game that's black is the puck!" And then he goes on to mention Tiger Woods
playing golf.
Very droll.
> > people do.
> isn't there.
Ok, maybe that's so. However, as it turns out, the perceived problem in
the fireman test was related to literacy. One would think that literacy is
such an ubiquitous subject matter in all schools, that at least *that* would
be the same for everybody (after all, it's hard to teach anything to anyone
who can't read and write properly), and if someone doesn't learn how to read
and write properly, the problem is not in the schooling system.
So if the perceived problem with the test was indeed related to literacy,
I think my objection stands.
It's hard to say. It's pretty easy to be literate and still a slow reader.
But yes, the idea that you can't read well and thus the test was unfair
seemed rather odd. I mean, it's a written test, you know? What do you expect?
>>> people do.
>> isn't there.
Why don't you go find a job as a teacher in a primary school in a poor
neighborhood? You seem to be better qualified than the current teachers.
I don't think so.
> I don't think so.
So they don't teach them how to read and write properly in the poor
schools either?
What do they teach there, then?
On 01/30/10 08:33, Darren New wrote:
> unfair seemed rather odd. I mean, it's a written test, you know? What do
> you expect?
And the argument was that it shouldn't be one. The link Tim posted said
that one of the ways they made it better was to include diagrams, etc.
I am reading a very interesting book about anti-gravity. I just can't
put it down.
>> I don't think so.
> schools either?
It's not binary. They teach, but not properly.
put it down.
