POV-Ray : Newsgroups : povray.off-topic : Bad journalism Server Time
21 Mar 2026 09:19:51 EDT (-0400)
  Bad journalism (Message 1 to 10 of 59)
Subject: Bad journalism
Date: 29 Jan 2010 14:20:30
Message: <4b6334fe$1@news.povray.org>
http://www.nytimes.com/2010/01/14/nyregion/14fire.html?adxnnl=1&adxnnlx=1264791670-GxVD+sfKjvw04Ji/zop/fQ
	It fails to explain how exactly the test discriminated. I looked at
some other articles, and none gives any detail whatsoever.
CONgress (n) - Opposite of PROgress
Subject: Re: Bad journalism
Date: 29 Jan 2010 14:46:08
Message: <4b633b00@news.povray.org>
  It's puzzling indeed. I'm trying to think how you could create an exam
which would be disadvantageous to black people, and I can't think of anything.
How could one possibly make a test disadvantageous to people with a certain
skin tone? I just can't fathom it.
  (I'm assuming that all applicants are given the exact same test, as the
article doesn't seem to imply anything else. Thus I cannot even imagine
how the suitability of the exact same test could depend on skin tone.)
Date: 29 Jan 2010 15:22:36
Message: <4b63438c@news.povray.org>
There are certain tests you can give that would discriminate. Perhaps blacks
are more poor or worse educated, so if you asked about proper grammar or
financial questions, you could discriminate.
I can't imagine any test that would discriminate against blacks and have
something to do with fire fighting, tho.
I remember reading about this - they had to drop the test a couple of years
because none of the blacks who applied for the promotion that the test
enabled actually passed the test.
It seems to me if the test is actually a valid test of necessary skills and
you can't pass the test, you shouldn't be risking your life and mine in a
job like that, even if the test has a correspondence between skin color and
pass rate.
Yes.  It just happens that blacks don't pass the test as easily as whites.
It would be fascinating to see the test.  I can't imagine a set of questions
that would so reliably discriminate without being obvious about it.  Usually
these cases come when 23% of the applicants are minority but only 21% of
those passing the test are minority, but from what I've read, the rates are
way out of line.
Note that in this country, the simple fact that blacks don't pass the test
makes it very difficult to legally claim the test isn't "discriminatory" in
the sense that this article means it. Folks claiming that don't have to
prove there's something biased on the test. You have to prove there's some
other reason that skin color corresponds to success rate.
   Forget "focus follows mouse." When do
   I get "focus follows gaze"?
Date: 29 Jan 2010 15:37:51
Message: <4b63471f$1@news.povray.org>
"Neeum Zawan" <m.n### [at] ieeeorg> wrote in message
news:4b6334fe$1@news.povray.org...
The test "discriminated" because African-Americans (and possibly Hispanics)
scored lower than their White peers. And since requiring applicants to be
somewhat educated is such a repugnant idea, the obvious solution is of
course to dumb down job requirements while sweeping the root cause of the
problem, which would take actual work and money to fix, under the rug. It's
always better to have semi illiterate constituents who you make to believe
that you are doing them a favour than literate ones who don't need favours
from you to stand on their own feet.
Date: 29 Jan 2010 17:07:06
Message: <4B635C0F.2030401@hotmail.com>
It is not the skin tome, it is the cultural background. (almost) all IQ
test favour white Europeans, because they refer in subtle ways to things
that appear to be common knowledge by the people who design these tests.
They also put an emphasis on things that we as Europeans (or is
Caucasian the term mostly used in the US?) find important. Sometimes
that is valid and sometimes it is not.
If a test uses a phrase that became well known because of being used in
a 60's sitcom, people with a social background that included a TV in the
60's will have an advantage. Use one from a 90's black sitcom and
another group is a at an advantage.
One of the things that my sister mentions in her book on cultural
background in the job market is that it appeared that a disproportionate
number of Dutch citizens from a non-Dutch background failed the written
test for nurse. The reason turned out to be that in the questions a lot
of expression were used that were derived from our famous 17th century
bible translation. Even if the tested persons were familiar with the
bible, they too often did not know our particular translations. One
could argue that that would indeed imply that they would not be able to
communicate effectively with the rest of the staff and the patients. One
could also argue that these expression seldom turn up in spoken
communications, especially if the one you are talking to is easily
identified as probably not a 5th generation pure bread Dutch. Also note
that the reciprocal problem is never mentioned. The persons that made
the test might not be able to communicate effectively with a subgroup of
patients.
Creating a good set of questions is a skill. Most that are used today
fail to meet the principle that they only test the relevant skills. The
test that I gave today to my students is an example of such a biased
test. I know it is, I can identify (some of) the questions that are
contaminated by cultural bias. I know many people would not even notice,
but I did and I didn't find a way to solve it.
So, I know that even a test on digital technology can have a cultural
bias. Therefore it wouldn't surprise me if a test for fireman would
also. You would have to see the actual test to see if that bias is
justified or not.
Does this answer your question?
Date: 29 Jan 2010 17:14:29
Message: <4b635dc5@news.povray.org>
  Even if that's so (ie. black people in the US having in average a poorer
education), I don't see how it's discriminating against blacks per se.
If anything, it would be "discrimination" against uneducated people (if
such a thing is feasible). Any person, regardless of skin tone, would score
poorly in such a test. How is this discrimination against black people?
  If the problem is that black people are in average more uneducated, the
proper solution to that problem is not to dumb down admission tests (which
in itself ought to have rather negative consequences related to job
performance and perhaps in some cases even safety), but to educate them.
(If black people, for whatever reason, do not *want* to get educated, well
that's hardly a problem with the fire department, is it?)
  In fact, if the reason for the justice system to demand dumbing down the
tests so that black people can score better is because they are uneducated,
I see an irony here: By trying to be "politically correct" and offer "equal
opportunity", the justice system is actually openly admitting that black
people are uneducated compared to white people. What kind of message is
this sending to the population?
  How is that the fire department's fault or problem? If they are applying
the exact same test equally and fairly to all applicants, that's the very
definition of non-discrimination.
  Discrimination is when some people get preferential treatment over others.
  Hate to sound like an antimulticulturalist again, but it really doesn't
surprise me in the modern world that when a protected minority scores poorly,
the fault cannot be said to be in that minority, but in the test instead
(completely regardless of how the test is performed). If the protected
minority scores poorly, the test *must* be discriminatory in some way,
there's no other explanation.
Date: 29 Jan 2010 17:16:30
Message: <4b635e3e@news.povray.org>
  By demanding the test to be dumbed down, the justice system is actually
openly admitting (probably without realizing it) that some groups of people
are poorly educated. What they won't admit is that it's the actual problem.
The problem must be in the test itself, of course.
Date: 29 Jan 2010 17:23:20
Message: <4b635fd8@news.povray.org>
  I don't think that's true. Maybe it was true 50 years ago, but nowadays
IQ tests are specifically designed to be detached of all cultural backgrounds.
  Education can have some effect on IQ tests (because education can eg.
train a person to think geometrically), but AFAIK in the US and especially
Europe all people have had the exact same education for quite many decades.
  If some group of people doesn't *want* to get educated, that's a different
problem. It's *their* problem, not the problem in IQ or aptitude tests.
> justified or not.
  I have hard time thinking of a question in a fireman test which a white
citizen of the US is able to answer due to his culture but a black citizen
of the US isn't, especially if both have gone to the same schools.
Date: 29 Jan 2010 17:49:46
Message: <4b63660a@news.povray.org>
> course to dumb down job requirements.
...and *this* is why the world is utterly broken.
http://blog.orphi.me.uk/
Date: 29 Jan 2010 17:50:09
Message: <4B636625.7060809@hotmail.com>
They are more aware of the problem, that does not mean it is solved,
besides they are still using old ones too. Ask my sister ;)
No they haven't. May I remind you of the private school debate here some
time ago. Remember who started that thread?
I can't see where this one comes from. Are you aware that this could be
interpreted as a racist remark? I am sure you don't mean to, but
suddenly starting to talk about "people that don't *want* to get
educated" in a discussion on how race influences test results is not a
smart move IMHO.
>> justified or not.
> of the US isn't,
I know you find that hard. You have said similar things many times. Yet,
Tatsachen" you might get what I meant, but the majority here will
probably not. In fact on average more white people would get it than
black. Yet it has nothing to do with color. The same mechanism works in
almost all tests, albeit often more subtle.
well, they didn't (on average), that is precisely the point.
