POV-Ray : Newsgroups : povray.off-topic : More math fail Server Time
17 Jan 2026 11:02:07 EST (-0500)
  More math fail (Message 1 to 10 of 13)
Subject: More math fail
Date: 17 Jan 2010 15:42:00
Message: <4b537618$1@news.povray.org>
All these years, I thought the correct way to compute the cross product
of two vectors is
   x3 = y1 z2 - z1 y2
   y3 = x1 z2 - z1 x2
   z3 = x1 y2 - y1 x2
But, apparently, I was wrong. The correct way is in fact
   x3 = y1 z2 - z1 y2
   y3 = z1 x2 - x1 z2
   z3 = x1 y2 - y1 x2
In particular, this results in y3 having the opposite sign. No wonder my
program can't construct an orthogonal vector basis! >_<
FAIL.
The best part? I got this wrong in a library I released. Yes, my program
is failing due to a bug in my own damned library... :'{
http://blog.orphi.me.uk/
Subject: Re: More math fail
Date: 17 Jan 2010 16:33:17
Message: <4B53821D.2090000@hotmail.com>
> of two vectors is
>   x3 = y1 z2 - z1 y2
>   y3 = x1 z2 - z1 x2
>   z3 = x1 y2 - y1 x2
>   x3 = y1 z2 - z1 y2
>   y3 = z1 x2 - x1 z2
>   z3 = x1 y2 - y1 x2
You should have caught that based on symmetry.
Date: 18 Jan 2010 04:49:36
Message: <4b542eb0@news.povray.org>
>> product of two vectors is
>>   x3 = y1 z2 - z1 y2
>>   y3 = x1 z2 - z1 x2
>>   z3 = x1 y2 - y1 x2
>>   x3 = y1 z2 - z1 y2
>>   y3 = z1 x2 - x1 z2
>>   z3 = x1 y2 - y1 x2
Well, the rule seems clear: the expression for (say) Y involves every
coordinate except Y itself. I never realised it actually matters which
order you put them in...
Date: 18 Jan 2010 05:11:59
Message: <4b5433ef$1@news.povray.org>
Your initial algorithm would fail even the most basic test of the cross
product:
x cross y = z
y cross z = x
z cross x = y
where x = (1,0,0), y = (0,1,0), z = (0,0,1)
Date: 18 Jan 2010 05:13:51
Message: <4b54345f$1@news.povray.org>
>>>   x3 = y1 z2 - z1 y2
>>>   y3 = x1 z2 - z1 x2
>>>   z3 = x1 y2 - y1 x2
>>>   x3 = y1 z2 - z1 y2
>>>   y3 = z1 x2 - x1 z2
>>>   z3 = x1 y2 - y1 x2
My rule is rather a rotation (X->Y->Z->X) and yes, order matter.
You can write the first line as you want, but for the next lines, the
rotation must be applied on it strictly.
Basic check: X.Y gives Z, Y.Z gives X, Z.X gives Y, it's always a XYZ
sequence in loop. (X Y Z X Y Z...)
Real software engineers work from 9 to 5, because that is<br/>
the way the job is described in the formal spec.  Working<br/>
late would feel like using an undocumented external procedure.
Date: 18 Jan 2010 05:38:03
Message: <4b543a0b$3@news.povray.org>
Yes, that does appear to be the correct method...
Date: 21 Jan 2010 18:35:33
Message: <4b58e4c5$1@news.povray.org>
> of two vectors is
> x3 = y1 z2 - z1 y2
> y3 = x1 z2 - z1 x2
> z3 = x1 y2 - y1 x2
Oh dear. Use the determinant form - easiest to remember:
http://en.wikipedia.org/wiki/Cross_product#Matrix_notation
I'm addicted to placebos. I'd give them up, but it wouldn't make any
difference. - Steven Wright
Date: 22 Jan 2010 04:33:56
Message: <4b597104$1@news.povray.org>
...except that then I'd have to somehow remember the correct way to do
matrix multiplication. (Something which I never get right with more than
50% probability...)
Date: 22 Jan 2010 04:35:51
Message: <4b597177@news.povray.org>
> 50% probability...)
  Then you just end up using left-handed coordinates for your cross product
rather than right-handed. In other words, it only affects the sign of the
result.
Date: 22 Jan 2010 04:45:47
Message: <4b5973cb$1@news.povray.org>
>> 50% probability...)
> result.
Oh, does it?
With general matrix multiplication, getting it wrong tends to really
mess things up. But in the specific case of a cross product, maybe it
doesn't...
