POV-Ray : Newsgroups : povray.off-topic : 99 lines of C++ for an unbiased ray tracer Server Time
2 Nov 2026 00:06:14 EST (-0500)
  99 lines of C++ for an unbiased ray tracer (Message 1 to 50 of 65)
Goto Latest 50 Messages Next 15 Messages >>>
Subject: 99 lines of C++ for an unbiased ray tracer
Date: 13 Jan 2010 21:22:18
Message: <4b4e7fda$1@news.povray.org>
http://www.kevinbeason.com/smallpt/
Cute. Hard to read, but cute. :-)
   Forget "focus follows mouse." When do
   I get "focus follows gaze"?
Subject: Re: 99 lines of C++ for an unbiased ray tracer
Date: 13 Jan 2010 21:37:30
Message: <4b4e836a$1@news.povray.org>
yes.  I wonder how it'd look like in Haskell. ;)
It was also the basis for SmallptGPU:
http://davibu.interfree.it/opencl/smallptgpu/smallptGPU.html
Date: 14 Jan 2010 01:04:51
Message: <4b4eb403$1@news.povray.org>
Hey, I have an idea. Has anyone ever considered porting POV-Ray to the GPU?
I bet it would be a lot faster.
Date: 14 Jan 2010 01:31:42
Message: <4b4eba4e@news.povray.org>
> GPU? I bet it would be a lot faster.
Nice one! What a good idea. ;)
Best Regards,
Date: 14 Jan 2010 01:34:47
Message: <4b4ebb07$1@news.povray.org>
Hey, I bet it couldn't take more than a few minutes to move all the code
that direction. I mean, it can't be too much larger than 99 lines of code.
Date: 14 Jan 2010 03:10:26
Message: <4b4ed172$1@news.povray.org>
Not being a coder myself I will have to take your word on that. I’m sure
Chris could do it standing on his head or at least upside down ;)
Best Regards,
Date: 14 Jan 2010 04:45:52
Message: <4b4ee7d0$1@news.povray.org>
In any language, I suspect the answer will depend on:
- Which libraries are you allowed to use? [Get a ray tracing library and
the program surely becomes trivial...]
- How fast does it have to be? [A highly-efficient program is likely to
be a lot bigger than a program written specifically to demonstrate how
terse you can be.]
Date: 14 Jan 2010 05:43:49
Message: <4b4ef565$1@news.povray.org>
Wait... THE WALLS ARE GIANT SPHERES?! o_O
Well that's *one* way to cut down the code size... No ray/plane
intersection test to code.
44:  double n=sizeof(spheres)/sizeof(Sphere);
Well... that's... one way to figure out how big an array is. :-.
Evidently my C++ is weak, but... how is
53:  Vec nl=n.dot(r.d)<0?n:n*-1;
different from "nl = -abs(n.dot(r.d))"?
Also, where THE HELL is "Xi" defined? I can see it *used* in several
places, but I can't find a definitions.
Line 79 means each row of pixels is computed in parallel, right?
Date: 14 Jan 2010 06:00:34
Message: <4b4ef952@news.povray.org>
a?b:c evaluates to b if a is true, or c otherwise.
Line 82, after the x=0 definition.
I guess so.
Date: 14 Jan 2010 06:07:30
Message: <4b4efaf2@news.povray.org>
Ah, wait, I misread that as calculating something, assigning it to n,
and then checking whether n is negative and if not negating it. On
closer inspection, that's not what this does...
Wait - you can define MORE THAN ONE variable in a loop initialisation??
Date: 14 Jan 2010 06:41:59
Message: <4b4f0307$1@news.povray.org>
Don't see why not, would be a pointless limitation to put in on purpose that
just reduced the flexibility, should anyone want it.
Date: 14 Jan 2010 07:49:02
Message: <4b4f12be$1@news.povray.org>
Anybody got any theories on line 55?
   if (++depth>5) {if (erand48(Xi)<p) f=f*(1/p);} else return obj.e;
   if (++depth>5) {if (erand48(Xi)<p) f=f*(1/p); else return obj.e;}
I can't decide which "if" the "else" belongs to. o_O
(I also have approximately no idea whatsoever what f=f*(1/p) is in aid
of...)
Date: 14 Jan 2010 08:14:58
Message: <4b4f18d2$1@news.povray.org>
The else always belongs to the closest if at the same scope level...
Which means it's:
I think it's part of the Russian Roulette method (which is what the
comment R.R. stands for I suppose). I don't remember the details but you
can probably look it up by yourself...
Vincent
Date: 14 Jan 2010 08:27:24
Message: <4b4f1bbc$1@news.povray.org>
Ouch. This isn't going to be pretty...
Clearly it flips a coin to decide whether to process further [all of the
code paths beyond this point involve sending out a new ray] or just stop
here. However, "f" is the object colour, and I have absolutely no idea
why it's being scaled by the reciprocol of the brightest component...
Date: 14 Jan 2010 08:37:28
Message: <4b4f1e18$1@news.povray.org>
LPC might be a little different, but can't you negate a variable by
saying a=-a;?  Saves a little CPU cost.
Tim Cook
http://empyrean.freesitespace.net
Date: 14 Jan 2010 08:47:47
Message: <4b4f2083$1@news.povray.org>
> LPC might be a little different, but can't you negate a variable by saying
I think he would have to define the unary minus operator for the vector
class before he could write -n instead of n*-1.
Date: 14 Jan 2010 08:58:32
Message: <4b4f2308@news.povray.org>
What do you mean?
I think that it's the part that makes the method unbiased. You have to
scale the rays that you keep in order to account for the fact that you
don't keep them all, or something like that.
Vincent
Date: 14 Jan 2010 09:01:09
Message: <4b4f23a5$1@news.povray.org>
> What do you mean?
I mean implementing this in a language where the else-part is
*mandatory* for all if-blocks makes this slightly tricky to do. (But not
as tricky as I thought; I've found a clean way to do it.)
>> absolutely no idea why it's being scaled by the reciprocol of the
Well, we'll see I guess...
Date: 14 Jan 2010 11:33:27
Message: <4b4f4757$1@news.povray.org>
Invisible escreveu:
> terse you can be.]
That's what I'm willing to know.  That piece of code is not using a
"raytracing library", just implementing algorithms from well-known papers.
a game sig: http://tinyurl.com/d3rxz9
Date: 14 Jan 2010 11:33:41
Message: <4b4f4765@news.povray.org>
I had a go at implementing this, but I have clearly screwed up the math
somewhere, because the program is behaving very strangely.
(I've turned off all the fancy stuff until it's just a normal depth-1
ray tracer, and the image still just consists of a few bent lines.)
So far I've found at least a dozen bugs in the ray/intersection code, a
typo in the cross-product (typed an X instead of a Z), and I'm still
finding more. What can I say? I fail at math! o_O
Date: 14 Jan 2010 11:39:57
Message: <4b4f48dd$1@news.povray.org>
Invisible escreveu:
perhaps you just fail at translating crazy C++ code, which is perfectly
fine.
Date: 14 Jan 2010 12:24:05
Message: <4b4f5335$1@news.povray.org>
> fine.
I don't find it really crazy, actually I was expecting far worse before
opening the file...
It uses some tricks to achieve compactness but it's still mostly
legible. I've seen far worse as far as variables names are concerned,
for instance :-\
Vincent
Date: 14 Jan 2010 12:46:45
Message: <4b4f5885$1@news.povray.org>
> opening the file...
Me too, honestly.  You can see what it's doing, and you could probably
translate it by hand into some other OO imperative language without even
knowing what it's trying to do.  It's not obfuscated as much as terse.
Date: 14 Jan 2010 12:50:08
Message: <4b4f5950$1@news.povray.org>
That's the usual way to figure out how big an array is in C and C++.
In the lack of needing to define the abs() function?
Line 48. It's an argument to the function. Note that text search will
usually answer that sort of question on a C program, and often on a C++
program too.
Not always, mind, but usually.
Got me. It looks like someone is asking the compiler to do that if it can.
Date: 14 Jan 2010 14:06:31
Message: <4b4f6b37$1@news.povray.org>
http://en.wikipedia.org/wiki/Openmp#Work-sharing_constructs
Date: 14 Jan 2010 14:07:41
Message: <4b4f6b7d$1@news.povray.org>
It's using the OpenMP directives
(http://en.wikipedia.org/wiki/OpenMP)... I discovered that last year,
can be pretty useful and makes it quite easy to take advantage of
multiple cores when the algorithms are already mostly suited to being
run in parallel.
Vincent
Date: 14 Jan 2010 14:18:53
Message: <4b4f6e1d@news.povray.org>
>> before opening the file...
It's just shoved together into a very small space, so it's a big awkward
to read.
What I've probably done is got a plus sign instead of a minus somewhere,
or something equally trivial, which has none the less completely screwed
up the math. And damn, it's going to take a while to find it! :-/
http://blog.orphi.me.uk/
Date: 14 Jan 2010 14:21:46
Message: <4b4f6eca$1@news.povray.org>
It is surprising to me that this actually works. I was under the
impression that C does not actually distinguish between pointers and
arrays (and integers and booleans and...)
No, I misread the code. It's actually deciding whether to negate n based
on a function of n, not n itself.
No, it's an argument in the radiance() function, I meant where is it
defined in main().
> program too.
Yeah, I tried that too...
Date: 14 Jan 2010 14:38:41
Message: <4b4f72c1@news.povray.org>
  Yes, but since 'nl' is of type struct Vec, he would have to define
operator-() for it for that to work. Maybe he wanted to save one line
of code.
Date: 14 Jan 2010 14:43:12
Message: <4b4f73cf@news.povray.org>
> run in parallel.
  The advantage of OpenMP is that the routine will run in parallel if
the compiler supports it, but if the compiler doesn't support OpenMP,
it doesn't matter: The program will still compile and work properly
(it will just be single-threaded). Compilers ignore #pragmas they don't
recognize (per the standard), so the addition #pragma openmp's don't
matter.
Date: 14 Jan 2010 14:44:35
Message: <4b4f7423@news.povray.org>
  A small pitty that it's not 100% standard C++, as erand48() is not part of
the standard (it's a glibc extension). OTOH, better use erand48() than rand(),
as the latter is just plain horrible in quality.
Date: 14 Jan 2010 15:03:58
Message: <4b4f78ae@news.povray.org>
  There is a big difference between a pointer and an array in C (and hence
in C++).
  Basically each array is a type of its own, defined by the element type
and the number of elements. What makes an array distinctly a type of its
own is that sizeof() always returns the number of bytes that a type
requires when allocated in memory, and an array is no different: sizeof()
for an array returns the amount of bytes taken by the entire array. This
is drastically different from a sizeof() of a pointer, which will always
return 4 or 8 (depending on whether you are compiling a 32-bit or 64-bit
program).
  Since sizeof() of an array returns the total amount of bytes taken by
an array, if you divide it by the amount of bytes of one element, you get
the total number of elements.
  For example if in C++ you instantiate a template using an array as a
template parameter, a distinct instanstiation will be made for each specified
type and size of array.
  Of course what makes this confusing is that an array implicitly casts to
a pointer of the element type. In other words, wherever a pointer of the
element type is required, you can give an array of that type instead (there
will be an implicity cast to the pointer type).
  Also the syntax of indexing an array and indexing memory using a pointer
is identical, adding to the confusion.
  It can sometimes be difficult to distinguish between an array and a
const pointer (a pointer which cannot be changed to point somewhere else).
sizeof() is one thing which makes the distinction.
> defined in main().
  Line 82.
Date: 14 Jan 2010 15:18:04
Message: <4b4f7bfc@news.povray.org>
> in C++).
Really?
This is plain. What surprises me is that sizeof() can give you an
accurate size in the first place.
Ah. I didn't know that. All the books I've seen claim that they are *the
same type*.
This makes more sense now...
>> defined in main().
>   Line 82.
Yes, we've established that now. I wasn't aware that you could actually
define more than one variable in a loop initialiser...
Date: 14 Jan 2010 15:37:52
Message: <4b4f809f@news.povray.org>
  Why wouldn't it? The compiler has to know the size of the array if it
wants to allocate it in memory.
Date: 14 Jan 2010 15:51:40
Message: <4b4f83dc$1@news.povray.org>
Plus, you can't pass an array to a function, at least in C.
Date: 14 Jan 2010 16:41:40
Message: <4b4f8f94@news.povray.org>
All that stuff about "C does not know the size of an array at run-time,
and does not check array bounds". But then, this is from the same books
that claim that pointers *are* arrays... Certainly if you asked for
sizeof() on a pointer, you wouldn't get the size of the array it points to.
Date: 14 Jan 2010 17:05:11
Message: <4b4f9516@news.povray.org>
  That talks about dynamically allocated arrays, not statically allocated
ones. They are different.
Date: 14 Jan 2010 17:06:27
Message: <4b4f9563@news.povray.org>
  Not directly, but you can do it indirectly if you enclose the array inside
a struct (in that case the array (inside the struct) is truly passed by
value rather than by-pointer).
Date: 14 Jan 2010 17:12:06
Message: <4b4f96b6$1@news.povray.org>
...you really have been doing this for a long time, haven't you?
Date: 14 Jan 2010 17:14:25
Message: <4b4f9741@news.povray.org>
  Well, it's rather basic C.
Date: 14 Jan 2010 17:51:23
Message: <4b4f9feb$1@news.povray.org>
He's right, tho. C doesn't know the size of an array at run time. sizeof()
is a compile-time operator.
Date: 14 Jan 2010 17:51:59
Message: <4b4fa00f$1@news.povray.org>
And in the original versions of C, you couldn't pass a struct by value
either. :-)
But yah, that's a good point I hadn't considered.
Date: 14 Jan 2010 18:18:49
Message: <4b4fa659@news.povray.org>
  If it knows it at compile time, it knows it at runtime. It's not like
it forgets somewhere in between... :P
Date: 14 Jan 2010 18:19:41
Message: <4b4fa68c@news.povray.org>
Out of curiosity I changed the location of the light to see that it really
renders it properly:
http://warp.povusers.org/images/smallpt.jpg
Date: 14 Jan 2010 23:50:25
Message: <4b4ff411@news.povray.org>
Well, no, I disagree. How do you find the size of an array at runtime?
That's exactly why you have to pass it around along with the pointer.
OK, I'll grant you that the generated code has that available, in the sense
that the loader avoids overwriting that space with other stuff, but it's not
available to the C-level program in any way at runtime.
You can take sizeof(x) at compile time, and store that somewhere that
runtime can find it, but there's nothing like Ada's myvariable'size
expression that would tell you at runtime what the size is for an arbitrary
array. There's no way to apply sizeof() to a non-array-name and find out the
size of an array (i.e., no way to say "what's the size of the array this
pointer points to").
Hmmm... If you put an array in a struct, can you ask
"sizeof(myrecord.thearray)" and get an appropriate size? I suppose you
could, but still I wouldn't count that as such.
Date: 15 Jan 2010 07:00:28
Message: <4b5058db@news.povray.org>
  It's a constant integral value, hence known at runtime.
  Now you are confusing dynamically allocated arrays with static arrays.
They are not the same thing.
  The size of dynamically allocated arrays cannot be resolved either at
runtime nor at compile time (eg. you cannot use the size of a dynamically
allocated array somewhere where a compile-time constant is expected).
  Yes, actually.
> I suppose you
  "As such"? What? Runtime? sizeof() always works at compile time.
Date: 15 Jan 2010 09:48:31
Message: <4b50803f@news.povray.org>
Warp escreveu:
did you make it coincident with the surface?
Date: 15 Jan 2010 11:08:26
Message: <4b5092fa@news.povray.org>
nemesis <nam### [at] gmailcom> wrote:
> Warp escreveu:
  I have hard time deciding whether that was humorous or a serious question.
Date: 15 Jan 2010 11:20:32
Message: <4b5095d0@news.povray.org>
Warp escreveu:
>> Warp escreveu:
serious.  Did you put right where the left sphere surface would hit?
Date: 15 Jan 2010 11:44:07
Message: <4b509b56@news.povray.org>
> Warp escreveu:
> >> Warp escreveu:
  Unbiased monte-carlo rendering sends rays in a random fashion. It starts
extremely grainy, but the graininess gets reduced over time as the number
of samples gets increased. That image is the result of 30 minutes of
rendering in my computer (a virtually grainless result would have taken
days).
