POV-Ray : Newsgroups : povray.off-topic : Virtual Box Server Time
21 Mar 2026 10:43:14 EDT (-0400)
  Virtual Box (Message 1 to 6 of 6)
Subject: Virtual Box
Date: 7 Jan 2010 07:58:47
Message: <4b45da87$1@news.povray.org>
Or not.
Well I managed to set up a Windows virtual machine easily enough.
Although there is the *minor* problem of how to activate it. At work
it's a non-issue; we have a volume license, so we can install as many
copies as we want. But at home, I only have a regular single-user
license, and I'm using that for my physical machine. Legally you're
supposed to *buy* another license for the VM. Which is especially
galling, given that MICROSOFT DON'T SELL THEM ANY MORE! >_< So I really
have no idea what the legal way to proceed is here.
I tried to set up a Linux VM, but the installer tells me that the VM
doesn't support 64-bit mode. I check the Virtual Box manual, and it says
you have to turn on these particular settings. I turn them on; still
nothing. (For some reason, some of the options are disabled; but they
seem to be set correctly. I just can't change them, is all.)
So then I discover that you can also control Virtual Box from the
command-line, and this gives you access to a bazillion options that you
can't get at from the GUI. In particular, I had set the OS type to
"OpenSUSE", but from the CLI I get access to an extra option called
"OpenSUSE_64", which doesn't appear in the GUI. (Oh, that's nice!)
Now when I start up the VM, it instantly gives me some error about
virtualisation hardware not being enabled in the BIOS. So I hunt around
in the BIOS; no options available to change. So I start doing some
digging...
...yes, that's right. I possess one of the last AMD CPUs ever to be made
which does *not* support AMD-V. In fact, no processor supporting AMD-V
has ever been made for socket 939. So if I want AMD-V, I must upgrade to
a newer motherboard. And since Virtual Box won't do 64-bit on a 32-bit
OS unless you have AMD-V (or Intel VT-x), that means I just plain can't
run a 64-bit OS *at all*. At least, not using Virtual Box.
Well that's just awesome. *sigh*
In not entirely unrelated news:
Um... ouch.
always pay that much - or more - if you desire. But this is THE CHEAPEST
stuff, so I suppose it's not *that* pricey. And hey, it's Kingston-branded.
Clearly I will have to sit down and see how this equation computes for
various other platforms. (Core i5, Core 2 Quad, Phenom II...)
Subject: Re: Virtual Box
Date: 7 Jan 2010 08:11:20
Message: <4b45dd78$1@news.povray.org>
Now I'm wondering if it doesn't show up in the GUI *because* the
necessary hardware is unavailable, or whether it's just a big oversight...
Subject: Re: Physical Box
Date: 7 Jan 2010 09:52:47
Message: <4b45f53f$1@news.povray.org>
> Um... ouch.
A similar bunch of stuff to run an Intel Core 2 Quad (specifically, a
On the other hand, we have:
   AMD Phenom II X4 995: 3,770 PC Marks
   Intel Core 2 Quad Q9550: 4,178 PC marks
   Intel Core i7 920: 5,451 PC Marks
If you do an X-Y scatter plot, you'll vividly see that the first two
systems are of approximately similar price and power, with the Core 2
being slightly faster and slightly more expensive. The Core i7, on the
other hand, is something like 45% faster but 65% more expensive.
Just for completeness, I asked Tom's Hardware:
   http://tinyurl.com/y97nhje
Unfortunately there doesn't seem to be a way to graph these numbers.
Most of the benchmarks paint a picture similar to PC Mark (i.e., Phenom
II and Core 2 are comparable, Core i7 is significantly faster). A few
benchmarks show all three practically identical, and sometimes Core 2 is
a tad slower than Phenom II.
(It appears that the Phenom II has greater memory bandwidth, but the
Core 2 has greater ALU performance, so it varies depending on whether a
given benchmark makes use of more of one than the other. The Core i7,
however, is superior on both counts.)
As you can see, this conclusively proves... something.
(Now, if the Internet had become the searchable database that many
people invisenged, I could just do an SQL query against the XML data
holding the benchmark rules and plot the data in Excel. But nooooo...)
Date: 11 Jan 2010 10:35:01
Message: <web.4b4b450a887d277e1ccf29180@news.povray.org>
Have a look at the 800 series of the i7 in the 1156 socket.
They're just as fast.
Even the RAM interface is as fast because it has faster clocks but the boards
are cheaper.
Date: 11 Jan 2010 10:45:17
Message: <4b4b478d$1@news.povray.org>
> are cheaper.
It appears the main difference between the 800 series and 900 series is
that the 900 has triple-channel RAM, while the 800 series uses "only"
dual-channel.
That would certainly make one hell of a difference to the price of the
motherboard, but I wonder what it does to performance?
The solution, of course, is to compile a parts list, price it up, look
and the performance benchmarks, and see where it slots in...
http://blog.orphi.me.uk/
Date: 11 Jan 2010 11:06:14
Message: <4b4b4c76@news.povray.org>
http://tinyurl.com/y8bdj8a
For whatever reason, Tom's Hardware only has data for the Core i7 870,
the most powerful 800-series model. Comparing this against a 900-series
model with identical clock speed (and several other parameters, as it
happens) produces this chart.
It seems the 900-series has higher theoretical bandwidth and ALU power,
and yet on a couple of the benchmarks it gets beaten. But then, if a
task takes almost 5 minutes to complete, does anybody care about 2
seconds one way or the other? The long and short of it is that, yes,
these two CPUs are in fact quite well-matched.
