POV-Ray : Newsgroups : povray.off-topic : Another random, non geometric problem Server Time
2 Nov 2026 01:06:21 EST (-0500)
  Another random, non geometric problem (Message 1 to 16 of 16)
Subject: Another random, non geometric problem
Date: 15 Dec 2009 21:38:51
Message: <4b28483b@news.povray.org>
You are on a game show. The host says he has hidden money under two cups,
one amount being double the other one. You pick one at random, he turns it
over, it's $100. He gives you a second chance (that he would do so was
determined before the game and not dependent on which cup you'd turn over):
You can switch, or take the $100.
You figure: If I switch, I will either get $50 or $200 with equal
probability. Expected return is thus $50*1/2 + $200*1/2 = $125, which is
larger than the $100 I'd spend to "play" this second game. Looks like a good
deal. Is it?
Subject: Re: Another random, non geometric problem
Date: 15 Dec 2009 22:07:41
Message: <4b284efd@news.povray.org>
Did you initially hear this problem phrased as money under cups, or did
you just change it to that so it's be harder go Google for the answer?
At any rate, it's a very neat problem.
Date: 15 Dec 2009 22:50:25
Message: <4b285901@news.povray.org>
"Kevin Wampler" <wam### [at] uwashingtonedu> wrote in message
news:4b284efd@news.povray.org...
> or did  you just change it to that so it's be harder go Google for the
answer?
Good catch.
Date: 16 Dec 2009 00:09:20
Message: <4b286b80$1@news.povray.org>
> deal. Is it?
Unless I am vastly misreading this, it seems there is a simple way to
set up this problem. Two cups, arbitrarily labeled A and B.
A contains $X, B contains $2X
or
A contains $2X, B contains $X
I don't see an obvious way to turn this into the Boy or Girl, or Monty
Hall, paradox, so I would have to guess that yes, it would be a good bet
to take the switch.
Date: 16 Dec 2009 03:55:10
Message: <4b28a06e@news.povray.org>
> or
> to take the switch.
How can a tactic where you *always* switch the cup be more profitable than
never switching?  In both cases, in the long run you're going to end up 50%
of the time choosing the higher amount and 50% the lower amount.
I'm still trying to figure out where the mistake is in the OP's reasoning...
Date: 16 Dec 2009 08:06:41
Message: <4b28db61$1@news.povray.org>
Le 16/12/2009 09:55, scott nous fit lire :
>> or
>> to take the switch.
> than never switching?  In both cases, in the long run you're going to
> end up 50% of the time choosing the higher amount and 50% the lower amount.
> reasoning...
finding 100$, you do not know if it is the low or high amount.
The computation is NOT $50*1/2+ $200*1/2 ( = $125)
but either :
 $50*1/2 + $100*1/2 = $75
or
 $100*1/2 + $200*1/2 = $150
Which turn out $75*1/2 + $150*1/2 around $112.5... if that was random.
Finding $100, you have no idea yet if you have a good value or a bad one.
It's a one time game, no long run (once you know the best value... that
you learn at the end of the choice), and girl & boy might be coming in.
Date: 16 Dec 2009 08:39:49
Message: <4b28e325$1@news.povray.org>
Indeed, it's a 50/50 chance whether you pick the high or low amount.
> but either :
> or
So you'd always change and take the other box?  Why even bother opening the
1st box, just leave it shut and take the 2nd one.  Oh but hang on, then when
you look inside the 2nd one you might want to change back to the 1st...
Date: 16 Dec 2009 08:46:55
Message: <4b28e4cf$1@news.povray.org>
> the 1st box, just leave it shut and take the 2nd one.  Oh but hang on,
> then when you look inside the 2nd one you might want to change back to
> the 1st...
Isn't this basically the entire premise of Deal Or No Deal?
Date: 16 Dec 2009 12:08:01
Message: <4b2913f1$1@news.povray.org>
Le 16/12/2009 14:39, scott nous fit lire :
>> but either :
>> or
> the 1st...
For optimising my happiness' function, I will take the first box and say
good bye, not wanting to know which case I was playing.
Playing otherwise might diminish my happiness' value, and that's not
something I would risk.
That's not rational, but I'm human, I have the right to make error (as
in 'to err is human') and to seek happiness rather than optimal
solution. (seeking happiness, nothing about getting it!)
P.S.: tuning the numbers, what if the amount ratio instead of 1:2 is 2:3 ?
Found 300€ under your choice, swap for other ? (450€ or 200€)
And for 4:5 ? (found £100, £80 or £125)
and what about 1:100 ? (100, 1 or 10000)
Date: 16 Dec 2009 12:23:50
Message: <4b2917a6$1@news.povray.org>
> answer?
> Good catch.
Well, it was easy since I've always heard this problem with a different
phrasing.  I think I actually like the way you stated it better though
-- it works nicely in the gameshow context.
Date: 16 Dec 2009 18:37:27
Message: <4b296f37$1@news.povray.org>
	Nope - that's rational.
	The economists use "rational" in terms of choosing the path that gives
you the most money. Unfortunately, too many people tend to use the same
definition outside the sphere of economics.
Would the capacity of a Palaeozoic Hard Dive be measured in Trilobites?
Date: 16 Dec 2009 21:44:19
Message: <4b299b03$1@news.povray.org>
"Le_Forgeron" <jgr### [at] freefr> wrote in message
news:4b2913f1$1@news.povray.org...
> solution.
For some, happiness *is* finding the solution.
> Found 300? under your choice, swap for other ? (450? or 200?)
You are onto something here.
Date: 17 Dec 2009 14:13:21
Message: <4b2a82d1$1@news.povray.org>
> deal. Is it?
There are actually four cups. Two cups in the $300 total universe and
two cups in the $150 total universe. No amount of switching will change
the universe in which you exist and that universe was selected before
you chose a $100 cup.
  -Shay
Date: 17 Dec 2009 15:04:37
Message: <4b2a8ed5@news.povray.org>
>  -Shay
Yes! You've got it. :-)
Best Regards,
Date: 17 Dec 2009 17:34:53
Message: <4b2ab20d$1@news.povray.org>
>> change the universe in which you exist and that universe was selected
>> before you chose a $100 cup.
>>  -Shay
Here's how the math really works out, as well as a better explanation of
where Andrew got it wrong.
Andrew counted the built-in profit of the system as "winnings" he showed
for switching.
Four cups, right?
{$50 | $100} ------ {$100 - $200}
I'll change the scenario just a bit to make it clearer. Contestant is
allowed to select one set of two cups ($50-$100 and $100-200) and to
then select one of the two cups from his selected set. His expectation
from this game? ($50 + $100 + $100 + $200) / 4 = $112.50. That's what
he's being *given* for playing the game, so that amount must be
subtracted from his winnings to reveal the profits of his strategy.
So, subtract $112.50 from each of the four cups to get
{-$62.50 | -$12.50} ------ {-$12.50 | $87.5}
Now, back to Andrew's premise. The contestant turns over a cup to find
-$12.50. Should he switch?
Possibility 1: He's in the low set[1] - expectation = -$37.50
Possibility 2: He's in the high set - expectation = +$37.50
A 50% probability either way.
That's the honest math.
  -Shay
[1] Actually, not *the* but *a* high set. There are two ways that could
go, but it doesn't change the problem.
Date: 22 Dec 2009 14:10:15
Message: <4b311997$1@news.povray.org>
> deal. Is it?
Yes.
John
