POV-Ray : Newsgroups : povray.off-topic : Bounding circle intersection Server Time
18 Oct 2026 06:24:16 EDT (-0400)
  Bounding circle intersection (Message 1 to 43 of 43)
Subject: Bounding circle intersection
Date: 9 Dec 2009 23:34:42
Message: <4b207a62$1@news.povray.org>
This is a problem that comes up once in a while. I'm curious if anyone knows
a good solution.
You have two objects and circles that bound them. For each circle, you know
its position and its radius squared. (You don't have the radius unless you
take the square root, which is undesirable because it's slow, and caching it
isn't a good option.) You want to know if these circles intersect.
Obviously, it's easy to get the distance between the circle's centers
squared. What you want to test is whether dist < radius1 + radius2, but all
you have is distSq, radius1Sq, and radius2Sq.
The best I can do is to square both sides of the test:
distSq < (radius1 + radius2)^2
And then use the fact that (a+b)^2 = a^2 + 2*a*b + b^2 to get:
distSq < radius1Sq + radius2Sq + 2 * radius1 * radius2
And then, since the radii are positive, the right hand side can be changed
to the following, but the test will now succeed more often than it should:
distSq < radius1Sq + radius2Sq + 2 * max( radius1Sq, radius2Sq )
So now we have a test that doesn't require taking any square roots, but it
isn't as "tight" as it could be - it will return true sometimes when the
circles aren't intersecting.
Can this be improved?
 - Slime
 [ http://www.slimeland.com/ ]
Subject: Re: Bounding circle intersection
Date: 10 Dec 2009 01:13:06
Message: <4b209172@news.povray.org>
If you're willing to tolerate an intersection function which has the
possibility of error, it seems like just using bounding squares instead
of bounding circles would give better error bounds if you expect your
circles to often be of very different sizes.
With regard to the actual question you asked, I can't think of a good
way without square roots off of the top of my head, but if you're
willing to tolerate a bit of approximation error then computing them
needn't be slow:
http://en.wikipedia.org/wiki/Methods_of_computing_square_roots#Approximations_that_depend_on_IEEE_representation
Date: 10 Dec 2009 02:32:57
Message: <4b20a429@news.povray.org>
>  - Slime
If the loose test indicates possible intersection then perform the more
expensive exact test using Sqrt().  If you can eliminate the majority of
cases cheaply then the higher cost is amortised.
In a similar case but where I have radius1, radius2 I do the following
to reduce the number of cases requiring more arithmetic operations:
float rSum = radius1 + radius2;
float xDiff = x1 - x2;
if (xDiff > rSum) return false;
float yDiff = y1 - y2;
if (yDiff > rSum) return false;
if (xDiff + yDiff) < rSum return true;
return (xDiff * xDiff + yDiff * yDiff < rSum * rsum)
Sqrt() isn't needed at all but of course this is a different scenario to
yours.
As always, you would need to measure the performance of different
schemes on your actual data and processor.  Too many condition tests and
intermediate operations can end up being more expensive than Sqrt()
given modern FP capabilities.
Date: 10 Dec 2009 05:31:05
Message: <4b20cde9$1@news.povray.org>
If you're that hell-bent on avoiding the square root, it can be
approximated as follows:
   Suppose that the most significant non-zero digit of x is in the 2^n
place. Let y = x / 2^(n/2). Now Sqrt(x) is approximately x / y.
Usually this estimated value is greater than the true square root (but
always by less than 45%). However, exact powers of 2 seem to come out
slightly below the true value. (By about 10^-16.) I don't know if that's
a glitch in my test program or what... It shouldn't be insummountable
though.
Date: 10 Dec 2009 07:07:33
Message: <4b20e485@news.povray.org>
How about more simply:
distSq < 4 * max( radius1Sq, radius2Sq )
Followed by the expensive square root operation to check if they really
intersect?
Obviously the benefits will depend on many factors, like how similarly sized
your circles are, and what % of them intersect.
Is there any history to the comparisons that you could make use of?  Eg a
large number of circles that are being repeatedly tested for intersection
after they move a small amount?  If so you can get much bigger speed-ups
using other methods (eg keeping the list of circles ordered by x
coordinate).
Date: 10 Dec 2009 07:30:59
Message: <4b20ea03$1@news.povray.org>
> sized your circles are, and what % of them intersect.
I would imagine it's quite possible that the extra time required to
perform a square root operation is more than made up for by the decrease
in unecessary work due to false intersections. Square root isn't *that*
slow... But you'd have to measure it to find out for sure.
Date: 10 Dec 2009 10:33:22
Message: <4b2114c2$1@news.povray.org>
> distSq<  radius1Sq + radius2Sq + 2 * max( radius1Sq, radius2Sq )
Have you tried this condition?
((distSq < (radius1Sq+radius2Sq))
or (4*radius1Sq*radius2Sq > (distSq - (radius1Sq+radius2Sq))^2))
Date: 10 Dec 2009 20:43:41
Message: <4b21a3cd$1@news.povray.org>
I wrote a small bit of code to test what the speed of the various
approximation methods was.  The code was complied with g++ and the times
given for each method are for 100000000 calls to the function.  First,
the functions I tested:
// Naive method
inline bool isect1(double aSq, double bSq, double dSq) {
     return sqrt(dSq) < sqrt(aSq) + sqrt(bSq);
// Slime's approximate method
inline bool isect2(double aSq, double bSq, double dSq) {
     return dSq < aSq + bSq + 2*std::max(aSq,bSq);
// Suggested by bart, but with a bugfix.
// Avoids a sqrt, but uses a few multiplies
inline bool isect3(double aSq, double bSq, double dSq) {
     double t1 = aSq+bSq;
     double t2 = dSq - t1
     return (dSq < t1) || (4*aSq*bSq > t2*t2);
// Naive method using a fast approximate sqrt
inline bool isect4(double aSq, double bSq, double dSq) {
     return fastSqrt(dSq) < fastSqrt(aSq) + fastSqrt(bSq);
and now the times under various optimization levels:
---------- O0
time for isect1 = 9.66935
time for isect2 = 2.03143
time for isect3 = 2.18224
time for isect4 = 7.03525
---------- O1
time for isect1 = 5.13777
time for isect2 = 0.413757
time for isect3 = 0.413756
time for isect4 = 0.0376559
---------- O2
time for isect1 = 0.564358
time for isect2 = 0.276049
time for isect3 = 0.305847
time for isect4 = 0.0381372
---------- O3
time for isect1 = 0.564529
time for isect2 = 0.159936
time for isect3 = 0.206905
time for isect4 = 0.0376384
It looks like my initial suggestion implemented in isect4 is the fastest
when you have optimization turned on, by a margin which rather surprises
me.  It takes about as long as simply computing the incorrect formula
'dSq < aSq + bSq', which seems almost impossibly fast.  Nevertheless
I've checked the results and it seems to work pretty well despite the
approximation in the sqrt call.  If you don't want to live with the
approximation, however, bart's method seems to be the best choice.
Date: 10 Dec 2009 20:46:01
Message: <4b21a459$1@news.povray.org>
On second glance, the bug was in how I read his math, and his equation
was entirely correct.
Date: 10 Dec 2009 20:49:35
Message: <4b21a52f@news.povray.org>
> // Naive method
> ---------- O0
> ---------- O1
> ---------- O2
> ---------- O3
How are you doing the "run 100000000 times" part?
The compiler may be optimizing knowing you're runing it on the same input
values each time. For example, only calling sqrt() 3 times and not
300000000.
Date: 10 Dec 2009 21:43:54
Message: <4b21b1ea@news.povray.org>
Smart. I feel stupid now! =) I see the equivalence, but I'm curious how long
you took to come up with that. Was it obvious?
 - Slime
Date: 10 Dec 2009 21:48:13
Message: <4b21b2ed$1@news.povray.org>
> intersect?
Well, I'd have to weigh the cost of doing the square root against the cost
of just going forward and doing the more expensive test. Although I posed
this as a stand-alone question, the actual work I am doing is checking if a
line segment intersects a triangle.
There's probably a bunch of ways to make my code faster, but I became
curious about this particular problem.
 - Slime
Date: 10 Dec 2009 21:48:49
Message: <4b21b311@news.povray.org>
Is there a way to quickly get n for a given number?
 - Slime
Date: 10 Dec 2009 21:53:30
Message: <4b21b42a$1@news.povray.org>
I would want to make sure the additional branches don't make this slower.
You also have to take the absolute value of xDiff and yDiff for the first
two checks, which may add slowness. However, it may be worth it if you know
it's extremely uncommon for the circles to overlap in the X or Y direction
(which I suppose is a reasonable assumption).
 - Slime
Date: 10 Dec 2009 21:59:08
Message: <4b21b57c@news.povray.org>
> possibility of error, it seems like just using bounding squares instead of
> bounding circles would give better error bounds if you expect your circles
I generally prefer bounding circle/sphere checks to bounding box checks
because box intersection tests (at least naive ones) require multiple
branches. Also, in my particular application I'm dealing with a lot of line
segments, for which I have to create the bounding boxes, which I think
requires at least two more branches (to check if x1 < x2 and if y1 < y2). Of
course I'd have to try it to be sure.
 - Slime
Date: 10 Dec 2009 22:00:35
Message: <4b21b5d3$1@news.povray.org>
Thanks for doing all that work! =) Definitely looks like Bart's method is
the best. I would be scared of using an approximation in case it failed to
determine an important intersection. What is your implementation of
fastSqrt?
 - Slime
Date: 10 Dec 2009 22:15:57
Message: <4b21b96d@news.povray.org>
Craziness. I remember finding that invSqrt function a few years ago and
looking it up. I'm always a little worried about portability of this sort of
thing, though.
 - Slime
Date: 11 Dec 2009 00:55:17
Message: <4b21dec5@news.povray.org>
> 300000000.
Ahh, good point.  After fixing this it looks like isect4 is faster than
isect3, but by a pretty slim margin, so bart's method would definitely
be the way to go.
Date: 11 Dec 2009 00:55:36
Message: <4b21ded8$1@news.povray.org>
> fastSqrt?
I just used the one given on Wikipedia.
Date: 11 Dec 2009 02:50:50
Message: <4b21f9da$1@news.povray.org>
> Although I posed this as a stand-alone question, the actual work I am
> doing is checking if a line segment intersects a triangle.
So let me understand this, you are constructing two circles, one around the
line and one around the triangle, then seeing the circles intersect, and if
they do proceeding to check if the line actually intersects the triangle?
Wouldn't it be faster to just directly check the line against the triangle?
Date: 11 Dec 2009 04:08:31
Message: <4b220c0f$1@news.povray.org>
If you don't mind depending on a specific floating-point
representation... sure. Just find out which bits of the number contain
the exponent. (For example, for a double-precision IEEE float, the
bitmask is 0x7FFF000000000000, and you then shift out those zeros and
subtract 0x3FFF to get the real value.)
That's what makes this so efficient. You just need the exponent field
from the float value, so no need to calculate anything. (Indeed, as an
even rougher approximation, just halve the exponent...)
Date: 11 Dec 2009 04:09:45
Message: <4b220c59$1@news.povray.org>
> the line and one around the triangle, then seeing the circles intersect,
> and if they do proceeding to check if the line actually intersects the
> triangle?
It would.
Now, if the circle encloses a few *thousand* triangles, it's probably
way, way faster to check the circle first...
Date: 11 Dec 2009 05:45:53
Message: <4b2222e1$1@news.povray.org>
> triangle?
Well, the one around the triangle is precomputed. Otherwise, yes.
> triangle?
Honestly, I don't know. I'm not sure my code for the triangle-line check is
very good. =)
As far as I can tell, to check for an intersection between a triangle and a
line segment, you need to check that one of the triangle's vertices is on an
opposite side of the line from the other two, and then check that both of
the line segment's endpoints are on opposite sides of at least one of the
triangle's edges, or that both of them are inside the triangle.
I did most of these checks with cross products, and then found I had some
precision problems in some cases, and the code got more complicated when I
tried to avoid them. Since intersections are rare, I figured a bounding
check would be the easiest way to improve performance.
 - Slime
Date: 11 Dec 2009 05:54:20
Message: <4b2224dc$1@news.povray.org>
>> triangle?
> very good. =)
Er... yeah, that's not terribly good. ;-)
Do a quick google for "ray triangle intersection". There are several
methods for doing this kind of thing, some of them highly optimised.
Date: 11 Dec 2009 06:28:25
Message: <4b222cd9@news.povray.org>
That tends to give results for a 3D problem, whereas my problem is 2D.
 - Slime
Date: 11 Dec 2009 06:46:53
Message: <4b22312d@news.povray.org>
Many of the methods work for 2D as well though.
But now I'm curious... the cross product is only defined for 3D vectors,
but you said you used a lot of cross products?
Date: 11 Dec 2009 07:14:19
Message: <4b22379b$1@news.povray.org>
Treat your 2D working area as a plane in 3D space (with Z coordinate zero if
you like), then you can do cross products, and checking whether the result
points "in to" the plane or "out of" the plane can be pretty useful (eg to
find out which side of a line a point is on).
Date: 11 Dec 2009 07:40:19
Message: <4b223db3@news.povray.org>
>> vectors, but you said you used a lot of cross products?
> zero if you like), then you can do cross products, and checking whether
> the result points "in to" the plane or "out of" the plane can be pretty
> useful (eg to find out which side of a line a point is on).
Oh, right.
...or you could just take the dot product instead, which requires only 2
multiplies and one addition as opposed to four multiplies and two
subtractions...
Date: 11 Dec 2009 08:23:10
Message: <4b2247be$1@news.povray.org>
> subtractions...
How is that useful?
Date: 11 Dec 2009 08:24:15
Message: <4b2247ff@news.povray.org>
>> 2 multiplies and one addition as opposed to four multiplies and two
>> subtractions...
> How is that useful?
Because you can use it to determine which side of the line a point is on?
Date: 11 Dec 2009 08:29:36
Message: <4b224940$1@news.povray.org>
How?
Example: Line through (0,0) and (0,1), and points either side of the line at
(1,0) and (-1,0)
Date: 11 Dec 2009 08:47:00
Message: <4b224d54$1@news.povray.org>
> How?
> line at (1,0) and (-1,0)
Suppose you have a line from point A to point B. Compute the vector AB,
make it unital, and rotate through 90°; call the result V. Now compute
the dot product V . A and call it k.
Which side of the line is point X on? Well, take the dot product V . X,
and subtract k. The result is negative on one side, positive on the
other, and zero if X is on the line itself (or at least, parallel to it).
...so basically, it's a ray/plane intersection test, except the "plane"
is a 2D slide - a line.
A = (0,0)
B = (0,1)
AB = (0,1) - (0,0) = (0,1) [already unital]
V = (0,1) * {(0,-1), (1,0)} = (-1,0)
k = (0,0) . (-1,0) = 0
X = (1,0)
X . V - k = (1,0) . (-1,0) - 0 = -1
Y = (-1,0)
Y . V - k = (-1,0) . (-1,0) - 0 = +1
QED.
Date: 11 Dec 2009 10:35:25
Message: <4b2266bd$1@news.povray.org>
> make it unital, and rotate through 90°; call the result V. Now compute the
> and subtract k. The result is negative on one side, positive on the other,
> ...so basically, it's a ray/plane intersection test, except the "plane" is
Sorry, but that seems much more complicated and using up more instructions
compared to the cross product:
> A = (0,0)
> B = (0,1)
No need to make AB unital for the cross product method (saves a square root
and divide).
No need to calculate V or k for the cross product method (saves some
multiplies and adds).
> X = (1,0)
X cross AB = (1,0) x (0,1) = (1)(1) - (0)(0) = 1
(saves one subtraction compared to your method)
> Y = (-1,0)
Y cross AB = (-1,0) x (0,1) = (-1)(1) - (0)(0) = -1
Date: 11 Dec 2009 10:44:12
Message: <4b2268cc@news.povray.org>
> root and divide).
Actually, thinking about it, you wouldn't need to for the dot product
either. I should have seen that...
>> X = (1,0)
Oh, I see. You're only computing the Z ordinate of the cross product?
Well, I guess that could be quicker, yes...
Date: 11 Dec 2009 10:49:26
Message: <4b226a06$1@news.povray.org>
Well the other 2 ordinates are always zero, so there seems little point :-)
Date: 11 Dec 2009 10:53:37
Message: <4b226b01$1@news.povray.org>
...that's true, of course. I had it in my head that you would only
compute the X and Y ordinates (which would take *more* effort than a
simple dot product). But, of course, that would be pointless.
I should go sit in the corner now. :'{
Date: 11 Dec 2009 12:25:51
Message: <4b22809f$1@news.povray.org>
>> ((distSq<  (radius1Sq+radius2Sq))
>> or (4*radius1Sq*radius2Sq>  (distSq - (radius1Sq+radius2Sq))^2))
>   - Slime
Well, it comes naturally from
distSq - (radius1Sq + radius2Sq ) <  2 * radius1 * radius2
(distSq - (radius1Sq + radius2Sq ))^2 <  4 * radius1Sq * radius2Sq,
but the downside is that you have an overflow risk here to check
Date: 11 Dec 2009 13:23:06
Message: <4b228e0a@news.povray.org>
  I was curious to see how much of a difference sqrt() really makes compared
to avoiding it, so I made this C++ file:
#include <cmath>
#include <algorithm>
bool circlesCollide1(double cx1, double cy1, double rs1,
                     double cx2, double cy2, double rs2)
    const double vx = cx2 - cx1, vy = cy2 - cy1;
    return std::sqrt(vx*vx + vy*vy) < std::sqrt(rs1) + std::sqrt(rs2);
bool circlesCollide2(double cx1, double cy1, double rs1,
    const double dist2 = vx*vx + vy*vy;
    const double tmp = dist2 - (rs1 + rs2);
    return dist2 < rs1 + rs2 || 4.0*rs1*rs1 > tmp*tmp;
and then a main program to test the speed:
#include <iostream>
#include <ctime>
                     double cx2, double cy2, double rx2);
int main()
    double cx1 = -10.0, cy1 = -5.0, rs1_1 = 2.0*2.0, rs1_2 = 16.0*16.0;
    double cx2 = 5.0, cy2 = 10.0, rs2_1 = 2.5*2.5, rs2_2 = 18.0*18.0;
    const int iterations = 200000000;
    std::clock_t iClock = std::clock();
    for(int i = 0; i < iterations; ++i)
        circlesCollide1(cx1, cy1, rs1_1, cx2, cy2, rs2_1);
        circlesCollide1(cx1, cy1, rs1_2, cx2, cy2, rs2_2);
    std::clock_t eClock = std::clock();
    std::cout << "circlesCollide1: " << iterations << " iterations took "
              << double(eClock-iClock) / CLOCKS_PER_SEC << " seconds."
              << std::endl;
        circlesCollide2(cx1, cy1, rs1_1, cx2, cy2, rs2_1);
        circlesCollide2(cx1, cy1, rs1_2, cx2, cy2, rs2_2);
    std::cout << "circlesCollide2: " << iterations << " iterations took "
              << std::endl;
  I compiled with "-O3 -march=native" and got this result:
circlesCollide1: 200000000 iterations took 16.23 seconds.
circlesCollide2: 200000000 iterations took 5.42 seconds.
  (I didn't test that the functions give the correct result, though.)
Date: 11 Dec 2009 18:00:58
Message: <4b22cf2a$1@news.povray.org>
hmm, it looks that this sqrt-free test
will equally work in 3D for sphere-sphere intersection test.
Date: 11 Dec 2009 19:15:59
Message: <4b22e0bf$1@news.povray.org>
If you do this in 2D, minus the unnecessary normalization, the math is
equivalent to doing the 3D cross product while ignoring the components you
know to be 0.
inline vec_t Vec2Cross( const vec2_t v1, const vec2_t v2 )
 return v1[0] * v2[1] - v1[1] * v2[0];
If the result is positive, v2 points to the "left" of v1, otherwise it
points to the "right".
 - Slime
Date: 14 Dec 2009 04:17:00
Message: <4b26028c$1@news.povray.org>
I would imagine this sort of thing varies by processor, but yeah... I'm
often curious to know how "expensive" various math operations are in
relation to each other. (Of course, real programs are also affected by
cache issues and which combinations of math ops you perform together and
branch prediction issues and so forth... But typically you can't do much
about that.)
Date: 22 Dec 2009 14:00:25
Message: <4b311749$1@news.povray.org>
> a glitch in my test program or what... It shouldn't be insurmountable
> though.
One would have to be very hell-bent indeed to employ, in lieu of sqrt(),
functions that are probably just as computationally expensive, like ln()
and exp().  Unless you have a quick way of getting n and 2^(n/2) without
ln() and exp(), you'll need them.
Now if you know the internal representation of your floats (or doubles),
you can slap together a union like
union MajorKludge {
	double dvalue;
	char carray[sizeof double];
and get both n and 2^(n/2) using some very simple bitwise logical
operations (as well as code whose portability will be highly suspect).
John
Date: 22 Dec 2009 14:16:51
Message: <4b311b23$1@news.povray.org>
>> that's a glitch in my test program or what... It shouldn't be
>> insurmountable though.
Indeed, the *only* reason you would ever use a construction like this is
because it's very fast and efficient to get at these numbers using the
binary representation of a float.
http://blog.orphi.me.uk/
