POV-Ray : Newsgroups : povray.off-topic : HWN Server Time
30 Jul 2026 22:37:47 EDT (-0400)
  HWN (Message 1 to 8 of 8)
Subject: HWN
Date: 5 Dec 2009 14:00:38
Message: <4b1aadd6$1@news.povray.org>
Heh, I just found a few nice quotes from the Haskell weekly news:
"Any sufficiently misguided opinion is indistinguishable from deep insight."
"One does not simply >>= into Mordor."
"I was TA for a C++ programming course aimed at 1st year physics once.
Some girl asked for help. 'I wrote pseudo-code but I cannot translate it
to C++'. Her pseudo-code was valid Haskell. I cried."
"I swear that most of higher-dimensional category theory must have been
arrived at by some guys sitting around in a room with a blackboard and
saying "What if a drew a diagram like *THIS*!?" and drawing some insane
scribble up on the blackboard, and then everyone tries to figure out how
to turn it into meaningful mathematics."
"If you read a haskell book or an FP book, by chapter 5 it's already
doing data structures. It's chapter 10 in imperative books."
"I'm on a rollomorphism."
http://blog.orphi.me.uk/
Subject: Re: HWN
Date: 5 Dec 2009 14:28:02
Message: <4b1ab442$1@news.povray.org>
	Stolen for my taglines file - thanks!
	I'm sure SICP gets there quicker. The whole book is only 5 chapters.
BREAKFAST.COM Halted... Cereal Port Not Responding.
Subject: Re: HWN
Date: 5 Dec 2009 15:00:47
Message: <4b1abbef@news.povray.org>
  I would be really surprised if that was a real story.
  It depends on the book, really.
  If I were to write a book on C++, I would start with object-oriented
programming concepts and the first C++ keyword which would appear in the
entire book would be "class".
  (I really think that books which start with "main()" or a "hello world"
program are starting from the wrong end of the spectrum.)
Subject: Re: HWN
Date: 5 Dec 2009 15:25:15
Message: <4b1ac1ab@news.povray.org>
Yeah, I would imagine it's more like "it was _almost_ valid Haskell".
Unless this girl happened to be an actual Haskell programmer in the
first place, of course... Otherwise it's unlikely it would be exactly
runnable. But I guess it might be close if you're used to the
mathematician's way to explaining things.
Well, this is true. Of course it's a blanket generalisation.
I guess having Hello World means you've got something you can actually
compile and run, and thereby check that your C++ compiler is set up
right and you know how to work it... But yes, for learning the language,
it's probably not the best place to start. But if you want a *runnable*
C++ program, you need to know about main() and so forth.
(Haskell has the advantage here that you can run code snippets in an
interpretter before you've learned how to make a "runnable program".
Haskell books usually have Hello World near the back. Then again, maybe
somebody somewhere has a C++ interpretter, or at least some C++
boilerplate for running small example fragments?)
Subject: Re: HWN
Date: 5 Dec 2009 15:29:55
Message: <4b1ac2c3@news.povray.org>
> Then again, maybe
  Making a full-fledged C++ interpreter would be an enormous job. (OTOH an
interpreter would probably make some things easier, such as implementing
export templates.)
  I think there exist full-fledged C interpreters, though.
  You write the C++ program using a C++ IDE and run it.
Subject: Re: HWN
Date: 5 Dec 2009 15:50:16
Message: <4b1ac788$1@news.povray.org>
Am Sat, 05 Dec 2009 15:29:55 -0500 schrieb Warp:
>> Then again, maybe
>   an
> export templates.)
Don't know, how complete it is (they write themself, that it is not
complete), but CINT of the ROOT framework at CERN comes to mind:
http://root.cern.ch/drupal/content/cint
Subject: Re: HWN
Date: 5 Dec 2009 18:01:57
Message: <4b1ae665$1@news.povray.org>
Yep. I used them back when 512K of RAM was a lot of memory and linking took
your lunchtime.
It was very handy to relink the interpreter with the libraries you had
working and then work on the next level of your abstraction on top of that.
(E.g., link the interpreter with your curses-like library while writing form
handling, relink with form handling while writing the calculations you were
configuring via the forms, etc.)
Nowadays we do things more powerful than C as interpreters and just throw
shovels full of CPU cycles at them. :-)
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Subject: Re: HWN
Date: 14 Dec 2009 13:46:59
Message: <4b268823$1@news.povray.org>
"analogies are endofunctors in the category of bad explanations"
