POV-Ray : Newsgroups : povray.off-topic : An explanation of what next_permutation does Server Time
18 Oct 2026 06:24:17 EDT (-0400)
  An explanation of what next_permutation does (Message 1 to 32 of 32)
Subject: An explanation of what next_permutation does
Date: 3 Dec 2009 02:21:54
Message: <4b176712$1@news.povray.org>
next_permutation being a subroutine in the C++ standard library that gives
you the lexographically next permutation of an array.
http://wordaligned.org/articles/next-permutation?utm_source=feedburner&utm_medium=feed&utm_campaign=Feed%3A+wordaligned+(Word+Aligned)
Interesting. :-)
   Human nature dictates that toothpaste tubes spend
   much longer being almost empty than almost full.
Subject: Re: An explanation of what next_permutation does
Date: 3 Dec 2009 09:08:38
Message: <4b17c666$1@news.povray.org>
Darren New wrote:
> Interesting. :-)
"while (!(*i < *--j)) {}"
Um, yeah, "interesting" would be the term I'd use. WTF? o_O
Personally, I'd do it this way:
nextP :: Ord x => [x] -> Maybe [x]
nextP []  = Nothing
nextP [x] = Nothing
nextP xs  =
   case split (reverse xs) of
     ([] , _  ) -> Nothing
     (ss', ps') ->
       let
         p0         = head ps'
         (ss0, ss1) = span (p0 >=) ss'
         s0         = head ss1
         ps         = reverse (s0 : tail ps')
         ss         = ss0 ++ [p0] ++ tail ss1
       in Just (ps ++ ss)
split :: Ord x => [x] -> ([x], [x])
split [] = ([], [])
split (x:xs) = work x xs
   where
     work x0 [] = ([x0], [])
     work x0 (x:xs)
       | x >= x0   = let (ys,zs) = work x xs in (x0:ys, zs)
       | otherwise = ([x0], x:xs)
Date: 3 Dec 2009 12:34:20
Message: <4b17f69c$1@news.povray.org>
C has always advocated piling up a bunch of side effects inside
conditionals.   Even to the point where Google's go has completely useless
syntax for doing so.
In go, you can write
   if x := y + 1; x > 5 { ... }
Which is always exactly precisely the same as
   x := y + 1;
   if x > 5 { ... }
Since you *always* need braces, and the result of evaluating the assignment
isn't ever used as the conditional, it's just a way of embedding
side-effects into a part of a statement that should be side-effect free,
apparently because the people designing go are so used to C's actually
*useful* side effects that they missed the result.
The above line could also be
   do { j -= 1; } while (*j <= *i);
(or maybe while *i < *j. I don't care to work it out for sure)
So, yeah, it's opaque C++ code there.
The algorithm is interesting, not the implementation.
Date: 3 Dec 2009 14:04:44
Message: <4b180bcc@news.povray.org>
> conditionals.
  OTOH, once you learn to read it, it's not that bad.
  It's a bit like using "++i" instead of "i = i + 1". The latter might be
clearer at first, but once you understand what "++i" means, not really.
Date: 3 Dec 2009 15:00:13
Message: <4b1818cd$1@news.povray.org>
>> conditionals.
Not in moderation. If something in the condition can't easily be expressed
outside the condition, it's helpful. For example,
   while (EOF != (c = getchar())) { ... }
You can't really put the assignment outside the condition without
duplicating that code, and it's kind of an accident of the design of the
libraries that means you can't find out the result from getchar without
invoking undesirable side-effect.[1] But convolving the comparison and the
decrement in this case was unnecessary, I think. Doing the decrement in the
body would say "keep decrementing until the condition is satisfied", which
doesn't really come across in the way it's written.
You definitely have to look at that expression to figure out what it's
doing. Of course, they could have reversed the letters and made it a little
clearer, too.
[1] You don't have this problem with iterators, for example, as you can just
as for "*j" as often as you want without changing "j".  Eiffel and Ada solve
it by requiring/suggesting that anything that has side effects doesn't
return a value. So in Eiffel, there's a (void) procedure to read the next
character into a buffer inside the object, and a function to get whatever
character was most recently read, so you don't need to do the assignment
inside the condition to save the character it returned, the way you need to
in non-OO C.
Date: 4 Dec 2009 10:53:15
Message: <4b19306b@news.povray.org>
Yeh, it's really clear what this line does to a non-Haskeller :-)
Date: 4 Dec 2009 10:57:47
Message: <4b19317b$1@news.povray.org>
I'll tell you what it does: It makes the function crash. o_O
It *should* in fact be
    (_  , [] ) -> Nothing
It seems I got my arguments the wrong way around. :-/
As for what it *means*, it means that if the prefix is empty ("[]"),
there is no next permutation ("Nothing"). The "_" simply means that it
doesn't matter what the suffix part is.
Date: 4 Dec 2009 11:19:16
Message: <4b193684@news.povray.org>
  After this you should really stop picking on C variants (or at the very
least, not immediately compare them to Haskell). ;)
Date: 4 Dec 2009 11:28:02
Message: <4b193892$1@news.povray.org>
Why? Because I wrote some code with a small typo?
Date: 4 Dec 2009 11:51:32
Message: <4b193e14$1@news.povray.org>
It's pretty standard notation for functional languages. Erlang uses the same
notation. If you get a two-element tuple with the first element being an
empty list, the result is an arbitrary atomic value (not unlike an "enum")
called "Nothing".
It's no less clear than function calls or array indexes if you've ever used
that operation before in a programming language. It's about as complex as a
case statement.
Date: 4 Dec 2009 11:56:22
Message: <4b193f36$1@news.povray.org>
Darren New wrote:
> It's about as complex as a case statement.
In particular, it *is* [part of] a case expression. ;-)
Date: 4 Dec 2009 12:12:32
Message: <4b194300$1@news.povray.org>
Yes, *I* know that. :-)
Date: 4 Dec 2009 12:40:25
Message: <4b194989@news.povray.org>
  Because it's exactly as (or even more) obfuscated as your hated C, and
it seems to be equally easy to make something "crash" by mistake.
  Also you should understand that the Haskell line might not be obfuscated
to *you* because you know how to read it, but it's quite obfuscated to
others who don't understand it. The same works for C as well. Thus you
really don't prove anything by saying "that piece of C(++) is really
obfuscated, I don't understand it, here's how I would write it in Haskell"
and proceed to present a program which is at least as obfuscated.
Date: 5 Dec 2009 08:57:23
Message: <4b1a66c3@news.povray.org>
If you make a typo in a Haskell program, the program stops and says
"error: you tried to access the first element of an empty list". If you
make a typo in a C program, the program stops and says "error:
segmantation fault".
The former is easier to debug [although, admittedly, it gives you
absolutely no indication of *where* the program crashed], while the
latter is no fun at all. Also, the former is an *exception*. You can
catch exceptions and handle them if you want. As far as I'm aware, you
cannot catch segfaults.
Performing multiple steps all at once in a small blob of symbols? Sounds
fairly non-trivial to me. By contrast, the Haskell version doesn't use
any remotely advanced features of Haskell, just a few case expressions
with some basic pattern matching. No monads, no typeclasses, no
existential types, nothing. Just plain ordinary pattern matching.
For me, the question is not how obscure it looks, but how difficult it
is to explain it.
FWIW, I think this particular algorithm itself is pretty tricky, no
matter which language you use for it.
http://blog.orphi.me.uk/
Date: 5 Dec 2009 12:12:16
Message: <4b1a9470@news.povray.org>
  And?
  Actually you can catch exceptions in most systems, and you can resolve
the exact location of the crash using a debugger.
  Haskell is fairly (in)famous for its one-liners which do tons of things.
  Because you wrote it so. The C++ version could also have been written to
be as verbose and straightforward as possible. It's not like you *have* to
write dense code.
> is to explain it.
  Many Haskell one-liners would probably take entire books to explain.
Date: 5 Dec 2009 12:34:53
Message: <4b1a99bd$1@news.povray.org>
*If* you're lucky.  What's worse is when it *doesn't*. :-)
> As far as I'm aware, you cannot catch segfaults.
You can, but not in a portable way, a language-defined way, or in a way
that's useful for debugging or continuing on.  You cannot, for example,
catch a segfault and use it to extend the size of the array you just ran off
the end of.
Date: 5 Dec 2009 12:36:35
Message: <4b1a9a23$1@news.povray.org>
I think APL (and now J) is the canonical example for that.
Well, the particular bit you complained about is no more complex than
    case 23: return 0;
in C. It's just that Haskell has literals that aren't in C, so "case 23"
looks funky.
Date: 5 Dec 2009 13:45:01
Message: <4b1aaa2d@news.povray.org>
Worse Than Failure.
> You can, but not in a portable way.
I had a feeling the OS might provide a way to do this. (Presumably
that's how the shell tells you your program segfaulted.) And that would
make it OS-dependent...
Date: 5 Dec 2009 13:57:33
Message: <4b1aad1d$1@news.povray.org>
>   And?
And if your program stops with an exception, you can catch and handle
it. If it segaults, AFAIK you can't do anything about it.
C and C++ have debuggers which are actually useable. I'll give you that one.
> write dense code.
No, BUT EVERYBODY DOES.
Nobody told this C++ programmer "hey, please write this in the most
complicated way possible". He just did, out of habit.
Personally, I don't have a problem with being able to incriment or
decriment a variable just by saying "x++" or whatever. It's a nice
shortcut. But when you reach the point of performing an assignment and
incriment at the same time... well, *I* certainly wouldn't write code
like that. I'd be forever having to double-check whether the incriment
happens before or after the assignment, and so on.
>> is to explain it.
Haskell allows you to do clever and rather opaque things such as compute
a list of all the prime numbers in the universe in a one-liner, or
Pascal's triangle, or the Fibonacci numbers, or whatever. And, yes, it
takes some explaining to unravel.
*This* program, however, involves no such cleverness. Merely a few case
expressions. Aside from the unfamiliar syntax, there's really little
about it that's complex. No fancy tricks, no clever math, just a few
conditional tests and a couple of function calls.
Date: 5 Dec 2009 13:58:09
Message: <4b1aad41@news.povray.org>
  You seriously claiming that if you make a typo in Haskell, it always
magically knows that and gives you an error message?
Date: 5 Dec 2009 14:09:17
Message: <4b1aafdd$1@news.povray.org>
What's magic?
If you type something wrong, it might be a syntax error. (Any
half-decent compiler will catch these.) If you type the wrong name by
mistake, it's probably a type error. If you assume that a certain list
will always contain 3 items (for example) and actually it doesn't,
you'll get an exception when you try to access a non-existent element.
It's not *guaranteed* that all mistakes will be caught. If you
accidentally write "x + x" instead of "x + y", no error (just the wrong
result). Same as any other language.
Let's look at this the other way around: There is no typo you can
possibly make which will result in a segfault. (Unless you're doing
something *very* special, like calling an external C routine or
something.) About the worst that can happen is that your program eats
craploads of RAM or goes into an infinite loop. (Or, if you're using
explicit concurrency with locks, you might deadlock or something.)
Date: 5 Dec 2009 17:55:21
Message: <4b1ae4d9$1@news.povray.org>
> one.
Because they need it, because when something goes wrong you have to step
outside the language into a different address space to be able to figure out
why. ;-)
Date: 5 Dec 2009 17:57:25
Message: <4b1ae555$1@news.povray.org>
Me? No.
I'm saying you're lucky if when you make a mistake in C you get a segfault.
If you're unlucky, you clobber some random unrelated variable that *is*
allocated and things progress as normal except with totally undefined results.
If you make a mistake in Haskell such that the results are undefined, it
stops in a way that's probably pretty easy to debug compared to a segfault in C.
Date: 6 Dec 2009 08:29:43
Message: <4b1bb1c7@news.povray.org>
> > one.
> why. ;-)
  Can you name one language which would not benefit from a debugger (which
you can use, among other things, to insert breakpoints, execute the program
step-by-step and examine the values of all objects at current scope)?
Date: 6 Dec 2009 08:37:20
Message: <4b1bb390$1@news.povray.org>
I know *I* would like it better if Haskell had a quality debugger.
They say if a Haskell program compiles, it usually works correctly. This
is true, but note that the phrase is "usually".
(There *is* a debug feature in recent versions of GHC, but it doesn't
seem to work terribly well. And crawling through a complicated piece of
program using a CLI interface isn't much fun anyway...)
Date: 6 Dec 2009 12:22:03
Message: <4b1be83b$1@news.povray.org>
No language per se, but environments. :-)
I just try to avoid languages where the primary debugging tools are outside
the language. (Altho APL is cool, I can't imagine doing a production program
in a language that needs something like OBSERVE[1], for example.)
I was pretty impressed at how VS lets you put breakpoints in code-behind
pages so you can single-step a piece of code as it processes a web request,
which is really a PITA in most of the other web-oriented languages like PHP.
So yeah, of course debuggers are *useful*. Do I want an external program to
be the *only* way to track down bugs? Nah.  C is useful too. That doesn't
mean I want C to be the only language I can use.
[1] Since Google is making it hard to find, the "observe" command sets a
flag that makes each APL statement print the line it's running, puts a
carret under the current operator it's evaluating, prints out both
arguments, and then the result, essentially single-stepping the evaluation
of a single expression with copious output.
Date: 7 Dec 2009 02:59:07
Message: <4b1cb5cb@news.povray.org>
> same notation. If you get a two-element tuple with the first element being
> an empty list, the result is an arbitrary atomic value (not unlike an
> "enum") called "Nothing".
Sure, I didn't doubt there was a pretty easy explanation behind it, it's
just [], _ and the whole statement syntax had no meaning to me before it was
explained.  I would imagine once Andrew knew what -- and * does in C (I
think < and ! are common enough not to need to explain?) he would know what
the statement he highlighted meant too.  I don't see much difference.
Date: 7 Dec 2009 04:30:38
Message: <4b1ccb3e$1@news.povray.org>
> was explained.  I would imagine once Andrew knew what -- and * does in C
> (I think < and ! are common enough not to need to explain?) he would
> know what the statement he highlighted meant too.  I don't see much
> difference.
I *already* know that * is pointer dereference and -- is decriment. But
now I have to sit here and wonder "is that pre-decriment or
post-decriment? And in why is it 'not (x < y)" rather than 'x >= y'?"
And similar questions. (Why "for (;;)" rather than "while true"? Is
there some difference?)
(Also... I just noticed how many one-letter variable names there are. So
much for that being a bad thing.)
Date: 7 Dec 2009 04:43:18
Message: <4b1cce36$1@news.povray.org>
> post-decriment?
Like I have to sit and wonder why it's (suffix,prefix) and not
(prefix,suffix) in your example?
Aren't they the same? (btw the only reason I can see that you would use the
first one is if the types being used don't have the >= operator defined).
IIRC quite a lot of functions and libraries only assume that one of those
operators is implemented, so that's probably why you'll see stuff like that.
> And similar questions. (Why "for (;;)" rather than "while true"? Is there
> some difference?)
Not that I'm aware of.
Date: 7 Dec 2009 04:50:09
Message: <4b1ccfd1@news.povray.org>
>> But now I have to sit here and wonder "is that pre-decriment or
>> post-decriment?
No specific reason. I probably did it that way around because "split"
takes the list in reverse order. (Working from the back towards the
front is inefficient for a single-linked list, so I reversed the list so
it can be processed from front to back instead.) Technically you could
return the sublists either way around if you wanted. I just did it this
way because if you take (x, y) and do x ++ y, you get the original
(backwards) list. If you'd returned the components the other way around,
you'd have to do y ++ x instead.
You'd certainly think so.
> the first one is if the types being used don't have the >= operator
> defined). IIRC quite a lot of functions and libraries only assume that
> one of those operators is implemented, so that's probably why you'll see
> stuff like that.
Hmm, I see.
Of course, we're working with *digits* here, for which both operators
are definitely defined. However, it seems this part of the code is from
a library, so presumably it's supposed to work with anything.
(In Haskell, it is impossible to define one ordering relation without
also defining the others. Well, no, not impossible, but you'd have to
purposely go out of your way to do it. So in Haskell it's not something
a library needs to worry about it. But now I recall that in C++, these
are all seperate, notionally unrelated operators.)
It's like when a Haskell programmer writes a new function that's
equivilent to an existing one. You have to sit there and wonder why they
did that. Was it personal taste, or is there actually some subtle
difference you've missed?
Date: 7 Dec 2009 12:48:48
Message: <4b1d4000@news.povray.org>
  It is customary in the C++ standard library to demand as little as
possible from the types being handled. Anything requiring comparison of
element usually demands only operator< from the elements (if the algorithm
can be feasibly be implemented using that operator only).
  If you are making a generic algorithm or data container which compares
elements, it's also usually a good idea to demand as little as possible
from it, and stick to operator< exclusively, if possible.
Date: 7 Dec 2009 13:30:35
Message: <4b1d49cb$1@news.povray.org>
And other than readability, compilers these days are smart enough to
generate the same optimal[1] code for it regardless.
[1] Funny how "optimized" no longer means what it used to, isn't it?
