POV-Ray : Newsgroups : povray.off-topic : Water glass Server Time
2 Nov 2026 01:59:15 EST (-0500)
  Water glass (Message 1 to 17 of 17)
Subject: Water glass
Date: 1 Dec 2009 08:17:07
Message: <4b151753$1@news.povray.org>
http://en.wikipedia.org/wiki/Sodium_silicate
That's the longest list of "uses" I've seen for quite some time. This
stuff is, apparently, Really Useful.
Subject: Re: Water glass
Date: 1 Dec 2009 10:01:40
Message: <4B152FD2.7030507@hotmail.com>
Funnily the only use I knew is not in the list. Making ceramics
waterproof if you don't fire it high enough to be non-porous. E.g. if
you fire it Raku style.
Date: 1 Dec 2009 10:16:30
Message: <4b15334e@news.povray.org>
I'm guessing that's similar to the concrete and masonry treatment they
talk about. If it makes concrete less porous, chances are it'll work for
other things as well...
(I wonder if it works for wood?)
Date: 1 Dec 2009 11:02:20
Message: <4B153E09.9050209@hotmail.com>
Yes, it even makes pots that have cracks waterproof again.
AFAIK wood is generally not porous.
Date: 1 Dec 2009 11:04:32
Message: <4b153e90$1@news.povray.org>
>> for other things as well...
...or fills gaps in gaskets...
Yes it is. Wood's entire structure is composed of long tubes designed to
channel water (from the roots to the leaves). This makes wood quite
water-absorbant.
Date: 1 Dec 2009 16:22:12
Message: <4b158904$1@news.povray.org>
> water-absorbant.
Which is why boats are built with wood exposed along the grain.
I've used water glass to keep eggs when refrigeration isn't
available, after about a month they start tasting odd though.
Date: 1 Dec 2009 16:33:33
Message: <4b158bad$1@news.povray.org>
On Tue, 01 Dec 2009 13:22:20 -0800, Tim Attwood wrote:
> I've used water glass to keep eggs when refrigeration isn't available,
The convenient thing is that when they start to go bad, you know very
quickly.  Good eggs don't float; bad ones do.
Jim
Date: 1 Dec 2009 17:11:43
Message: <4b15949f$1@news.povray.org>
My cookery teacher told me this. Is it actually true?
http://blog.orphi.me.uk/
Date: 1 Dec 2009 17:28:31
Message: <4B15988B.2060006@hotmail.com>
Hmm, are you deliberately confusing water glass with a glass of water?
Date: 1 Dec 2009 17:58:01
Message: <4b159f79@news.povray.org>
Yes.  Have tried it and it works just fine.
Any reason why you'd think it doesn't work? ;-)
Jim
Date: 1 Dec 2009 17:58:18
Message: <4b159f8a$1@news.povray.org>
Not deliberately, but I do see that I may have done so. ;-)
Jim
Date: 2 Dec 2009 04:04:31
Message: <4b162d9f@news.povray.org>
It just seems suspiciously convinient, that's all. ;-)
Date: 2 Dec 2009 04:21:43
Message: <4b1631a7$1@news.povray.org>
Le 02/12/2009 10:04, Invisible nous fit lire :
It's all physic: eggs have an air volume inside, at one end.
As the egg get older, the volume of the real-egg matter diminish a bit,
leaving more room for air. Like a submarine, emptying the ballast
(filling them with air) has a clear result: making float.
The interesting fact about the hen's egg is that a fresh egg's density
is a bit above the water, and old one's is below. It does not work for
ostrich's egg.
On the other hand, it is also easy to separate boiled egg from normal
one (before breaking them): if you rotate them on a plane, boiled egg
keep rotating, normal one  slows down more quickly.
Date: 2 Dec 2009 04:52:44
Message: <4b1638ec$1@news.povray.org>
The variation of internal volumes in the egg would not change the
density... In order to change the density, at least one of two things
must happen:
- matter going in or out
- overall volume changing
It seems to me that the shell of the eggs would prevent both, but then
there might be some permeability or some room for shrinking/expanding.
Vincent
Date: 2 Dec 2009 04:58:25
Message: <4b163a41$1@news.povray.org>
> must happen:
The shell is air-permiable. It has to be; the embrio would suffocate
otherwise.
(It may or may not be water-permiable as well, I'm not sure...)
Date: 2 Dec 2009 05:23:35
Message: <4b164027$1@news.povray.org>
> otherwise.
Maybe some of the internal liquid/solid parts of the egg are decomposed into
gasses which then escape through the shell?
Date: 2 Dec 2009 15:38:31
Message: <4b16d047$1@news.povray.org>
Sometimes the convenient things are convenient for a reason. ;-)
Jim
