POV-Ray : Newsgroups : povray.off-topic : Water glass Server Time
12 Apr 2026 18:59:30 EDT (-0400)
  Water glass (Message 1 to 10 of 17)
Subject: Water glass
Date: 1 Dec 2009 08:17:07
Message: <4b151753$1@news.povray.org>
http://en.wikipedia.org/wiki/Sodium_silicate
That's the longest list of "uses" I've seen for quite some time. This
stuff is, apparently, Really Useful.
Subject: Re: Water glass
Date: 1 Dec 2009 10:01:40
Message: <4B152FD2.7030507@hotmail.com>
Funnily the only use I knew is not in the list. Making ceramics
waterproof if you don't fire it high enough to be non-porous. E.g. if
you fire it Raku style.
Date: 1 Dec 2009 10:16:30
Message: <4b15334e@news.povray.org>
I'm guessing that's similar to the concrete and masonry treatment they
talk about. If it makes concrete less porous, chances are it'll work for
other things as well...
(I wonder if it works for wood?)
Date: 1 Dec 2009 11:02:20
Message: <4B153E09.9050209@hotmail.com>
Yes, it even makes pots that have cracks waterproof again.
AFAIK wood is generally not porous.
Date: 1 Dec 2009 11:04:32
Message: <4b153e90$1@news.povray.org>
>> for other things as well...
...or fills gaps in gaskets...
Yes it is. Wood's entire structure is composed of long tubes designed to
channel water (from the roots to the leaves). This makes wood quite
water-absorbant.
Date: 1 Dec 2009 16:22:12
Message: <4b158904$1@news.povray.org>
> water-absorbant.
Which is why boats are built with wood exposed along the grain.
I've used water glass to keep eggs when refrigeration isn't
available, after about a month they start tasting odd though.
Date: 1 Dec 2009 16:33:33
Message: <4b158bad$1@news.povray.org>
On Tue, 01 Dec 2009 13:22:20 -0800, Tim Attwood wrote:
> I've used water glass to keep eggs when refrigeration isn't available,
The convenient thing is that when they start to go bad, you know very
quickly.  Good eggs don't float; bad ones do.
Jim
Date: 1 Dec 2009 17:11:43
Message: <4b15949f$1@news.povray.org>
My cookery teacher told me this. Is it actually true?
http://blog.orphi.me.uk/
Date: 1 Dec 2009 17:28:31
Message: <4B15988B.2060006@hotmail.com>
Hmm, are you deliberately confusing water glass with a glass of water?
Date: 1 Dec 2009 17:58:01
Message: <4b159f79@news.povray.org>
Yes.  Have tried it and it works just fine.
Any reason why you'd think it doesn't work? ;-)
Jim
