POV-Ray : Newsgroups : povray.off-topic : Trivial trigonometry Server Time
12 Apr 2026 18:58:17 EDT (-0400)
  Trivial trigonometry (Message 1 to 10 of 178)
Subject: Trivial trigonometry
Date: 24 Nov 2009 10:13:37
Message: <4b0bf821$1@news.povray.org>
A little math help here? Wolfram Alpha is being bloody awkward at me...
side is 1 mile long, and the other side is 24 cm long. What are the
other two angles??
Subject: Re: Trivial trigonometry
Date: 24 Nov 2009 10:27:39
Message: <4b0bfb6b@news.povray.org>
> other two angles??
	That depends on whether one of those sides is the hypotenuse.
"Graphic Artist seeks Boss with vision impairment."
Date: 24 Nov 2009 10:28:56
Message: <4b0bfbb8@news.povray.org>
> side is 1 mile long, and the other side is 24 cm long. What are the other
> two angles??
Google "(24 cm / 1 mile) in degrees".
If you want more accuracy then it's going to depend on whether the 1 mile
side is the one opposite the 90 degrees or not.
Google:
"asin(24 cm / 1 mile) in degrees"
or
"atan(24 cm / 1 mile) in degrees"
Date: 24 Nov 2009 10:45:44
Message: <4b0bffa8$1@news.povray.org>
Ah, good old Google calculator. It may not know how to compute the
Riemann zeta function, but it at least manages to do common math
operations. :-D
Apparently it's 0.00854446724 degrees, which is about 30 seconds. That's
some pretty fricken tiny angle!
Date: 24 Nov 2009 10:46:12
Message: <op.u3worblq7bxctx@bigfrog.bredbandsbolaget.se>
> other two angles??
http://en.wikipedia.org/wiki/Right_triangle#Trigonometric_ratios_in_right_triangles
FE
Date: 24 Nov 2009 10:56:16
Message: <4b0c0220$1@news.povray.org>
According to Wikipedia:
"20/20 is the visual acuity needed to discriminate two points separated
So I guess 30 seconds (0.5 minutes) could plausibly be within the range
of normal human vision then.
I just noticed the other night that as I passed under a sign telling me
the motorway exit was in 1 mile, I could already see the green traffic
lights beyond the exit. And those lights can't be much more than 24cm
across...
Date: 24 Nov 2009 11:00:54
Message: <4b0c0336@news.povray.org>
> > other two angles??
  This is basic trigonometry which is taught in high schools in most places.
Date: 24 Nov 2009 11:01:17
Message: <4b0c034d$1@news.povray.org>
> "20/20 is the visual acuity needed to discriminate two points separated by
> So I guess 30 seconds (0.5 minutes) could plausibly be within the range of
> across...
Hmm, I can see an object perfectly fine with an angle of 10^-9 degrees.
Being able to see something and discriminate between two points is
different.
Date: 24 Nov 2009 11:05:42
Message: <4b0c0456@news.povray.org>
I did say "trivial", didn't I? ;-)
My education didn't include this information. Also, I have no idea how
many centimeters there are in one mile.
Date: 24 Nov 2009 11:07:46
Message: <4b0c04d2@news.povray.org>
> across...
  Lights can be seen much easier than other details.
