POV-Ray : Newsgroups : povray.off-topic : More power Server Time
18 Oct 2026 07:28:48 EDT (-0400)
  More power (Message 1 to 18 of 18)
Subject: More power
Date: 20 Nov 2009 06:06:16
Message: <4b067828$1@news.povray.org>
As far as I am able to determine, AMD's latest Phenom II processor goes
up to 4 cores, and Intel's Core i7 is 4 cores as well (with plans for 6
soon, but no products yet).
It seems that AMD has a 6-core Opteron, and Intel has a 6-core Xeon.
(Don't you just love the way it's really hard to track down this
information if you haven't been paying attention for a while? Sure, lots
of places allow you to get the latest in-depth product detail, but if
you just haven't looked for a while and you're trying to get back up to
speed, forget it.)
I wonder - what would it cost to buy a twin 6-core Opteron or Xeon box?
Subject: Re: More power
Date: 20 Nov 2009 09:12:55
Message: <4b06a3e7$1@news.povray.org>
> speed, forget it.)
A lot of money... as in "start with a 4 figures number for each CPU,
whereas current lambda-user market just runs in the 3 figures (higher)
range, with short incursion under 2000 for a full system."
CPU: 4 figures
Memory... guess what, you might need ECC correction, not common (so,
expensive)
Motherboard: Tyan makes a few, expect 500€ / $750 (ok, maybe 400/600 ?)
PSU: you need some real powerbox... at 140W/cpu... about 100/200
Easier part: disk, CD/DVD/BR & case, you might go with standard
components (but check the MB size for the case, as well as enough room
for cpu-cooler). Keyboard & mouse are not so expensive.
What graphic card would you plug in ? probably yet another 200 to 500.
What display would you use ? (a 13" LCD ? or a set of 26" ?)
Last (but not least): the OS, might be a bit expensive too. (lesser
version might not recognize all memory & cores).
Finding the CPU & MB is the hardest part.
A: Because it messes up the order in which people normally read text.<br/>
Q: Why is it such a bad thing?<br/>
A: Top-posting.<br/>
Q: What is the most annoying thing on usenet and in e-mail?
Date: 20 Nov 2009 09:44:04
Message: <4b06ab34@news.povray.org>
> CPU: 4 figures
> expensive)
Alternatively he could just learn C++ instead of Haskell :-)
Date: 20 Nov 2009 10:09:24
Message: <4b06b124$1@news.povray.org>
Yes, because that'll make POV-Ray run *so* much faster. :-P
Actually, I guess the correct response would be: Alternatively, you
could help the guys hacking on the GPU backend for Data Parallel Haskell
and leave all those silly C++ programmers in the dust. 0;-)
Date: 20 Nov 2009 10:16:16
Message: <4b06b2c0$1@news.povray.org>
Indeed. Both the Opteron and Xeon are server-class processors. It
wouldn't surprise me if the only way to get a twin 6-core box is to go
to somebody like HP and buy an actual server. This, presumably, is
freakishly expensive.
Still, it would be interesting to see just *how* expensive it is. I
remember looking at an HP ProLiant server a few months back - a big
rack-mount thing with hot-swap RAID, redundant PSUs and fast CPUs. And
while it *was* very expensive, it wasn't as expensive as you might
imagine...
Date: 20 Nov 2009 10:21:26
Message: <4b06b3f6$1@news.povray.org>
"Invisible" <voi### [at] devnull> wrote in message
news:4b067828$1@news.povray.org...
> of places allow you to get the latest in-depth product detail, but if you
> just haven't looked for a while and you're trying to get back up to speed,
> forget it.)
A good source for info of this sort is MaximumPC magazine, or their
corresponding web site (http://www.maximumpc.com/). They keep up on the
bleeding edge, have up to date articles and product comparisons, and their
target audience has always been build-it-yourselfers who want computers that
need tp be chained to the wall lest they fly away at the speed of sound.
Jack
Date: 20 Nov 2009 14:38:42
Message: <4b06f042$1@news.povray.org>
Sorry, but I just have to hit here: Linux.
-Aero
Date: 22 Nov 2009 15:04:04
Message: <4b099934$1@news.povray.org>
If you have to ask, you can't afford it.
John
Date: 22 Nov 2009 15:35:01
Message: <web.4b099fd6c9e18a496672c09b0@news.povray.org>
I'd think an X-box is definitely cheaper. ;)
Date: 22 Nov 2009 23:04:06
Message: <4b0a09b6$1@news.povray.org>
I'd think even an X-box /cluster/ is cheaper ;-)
Date: 23 Nov 2009 04:32:18
Message: <4b0a56a2$1@news.povray.org>
And a C64 is probably cheaper still. You're point?
Date: 23 Nov 2009 23:32:05
Message: <4b0b61c5$1@news.povray.org>
You can't compare the computing power of an Xbox360 (triple-core PowerPC
3.2GHz, theoretical peak of 115 GFLOPS; and one hell of a GPU that I won't
bother to describe) with the computing power of a C64.
Date: 24 Nov 2009 04:28:39
Message: <4b0ba747@news.povray.org>
Interesting. I wasn't aware PowerPC was still extant.
Regardless, the Xbos360 is a games machine. It's not like you can just
fire up a copy of POV-Ray on it.
Date: 24 Nov 2009 07:29:34
Message: <4b0bd1ae$1@news.povray.org>
Dunno about the XBox, but you can put a Linux on the PS3 very easily (Sony
give you a "boot other OS" menu option).  Compiling POV on the PS3 shouldn't
be beyond the reach of a Linux-literate person.
Date: 24 Nov 2009 09:02:13
Message: <4b0be765@news.povray.org>
> shouldn't be beyond the reach of a Linux-literate person.
The PS3 has a menu item labeled "install another OS". The Xbox360 has all
sorts of protections to ensure you can't run software that hasn't been
digitally signed by Microsoft.
It's quite a contrast.
Date: 24 Nov 2009 10:40:16
Message: <4b0bfe60@news.povray.org>
Really? I was considering getting an xbox because with the XNA game studio
it seems you can compile programs for the xbox.  Can you not run these on
your xbox then?
Date: 24 Nov 2009 11:45:05
Message: <4b0c0d91$1@news.povray.org>
> studio it seems you can compile programs for the xbox.  Can you not run
> these on your xbox then?
Sure, you can, and it works great.  But you can't compile random code
for the XBox... it needs to be C#, and use  the XNA framework.
If you want to be able to compile random C++ code then I believe you
need a dev kit.
...Chambers
Date: 25 Nov 2009 02:57:07
Message: <4b0ce353$1@news.povray.org>
> Sure, you can, and it works great.  But you can't compile random code for
> If you want to be able to compile random C++ code then I believe you need
> a dev kit.
Ah OK I see, I didn't realise the (free) compiler for the xbox only accepted
C# with the XNA framework - would take quite a lot of work to port POV to C#
I suppose :-)
