POV-Ray : Newsgroups : povray.off-topic : Intelligence test Server Time
18 Oct 2026 07:28:46 EDT (-0400)
  Intelligence test (Message 1 to 13 of 13)
Subject: Intelligence test
Date: 19 Nov 2009 06:23:04
Message: <4b052a98$1@news.povray.org>
I'm using the following library:
http://cairographics.org/
Now, can *anybody* figure out what the default coordinate space is?!
Seriously, I can't find this information anywhere in the documentation.
Is (0,0) at the bottom-left corner? The top-left corner? Somewhere else?
What??
It seems this is so trivial they forgot to actually write it down. >_<
Subject: Re: Intelligence test
Date: 19 Nov 2009 07:12:09
Message: <op.u3m5ijl47bxctx@e6600>
> What??
The user space coordinate system depends on the device space coordinate
system. By default, the mapping between them is an identity transformation.
I think most device spaces have (0,0) in the upper left corner, but I am
not sure if that is a requirement or a coincidence.
No, I did not figure this out by reading the Cairo documentation, which
seems to consist mostly of Doxygen-style pseudo-docs.
FE
Date: 19 Nov 2009 07:36:13
Message: <4b053bbd$1@news.povray.org>
Yes. This much is stated explicitly.
For raster image formats (JPEG, PNG, GIF, TIFF...) this is true.
However, for both PostScript and PDF [the formats I'm actually
interested in], the default origin point is actually the bottom-left
corner, not the top-left.
In addition to this, both of these formats allow the coordinate space to
be arbitrarily transformed. (Cairo provides the same functionallity
itself as well, but PS and PDF have it natively.) So I'm not sure if
Cairo is using the native defaults, or transforming them to match the
other backends, or...?
Yeah, it is a little... sparse?
Date: 19 Nov 2009 07:45:26
Message: <op.u3m61zca7bxctx@e6600>
Then how about you just try it, and find out?
FE
Date: 19 Nov 2009 08:05:47
Message: <4b0542ab$1@news.povray.org>
> What??
Experience indicates that everything that virtually all graphics output
frameworks have (0,0) at the top-left corner - and the samples confirm
that it is the case here as well.
Date: 19 Nov 2009 08:13:05
Message: <4b054461$1@news.povray.org>
Why not just... try it out?
Date: 19 Nov 2009 11:52:10
Message: <4b0577ba$1@news.povray.org>
That's OK. The graphics lib I'm workign with takes R, G, B, and A. And
sometimes A=0xFF means opaque and sometimes it means transparent. And you
get to guess for any given function whether A comes first in the list or last.
   Is God willing to prevent naglams, but unable?
     Then he is not omnipotent.
   Is he able, but not willing, to prevent naglams?
     Then he is malevolent.
Date: 19 Nov 2009 11:57:56
Message: <4b057914$1@news.povray.org>
> you get to guess for any given function whether A comes first in the
> list or last.
Wow, that's pretty sweet, man.
That's almost as good as the threadDelay function, that doesn't tell you
whether the argument is seconds or miliseconds or picoseconds or...
Date: 19 Nov 2009 12:08:47
Message: <4b057b9f$1@news.povray.org>
Probably biliseconds.
Date: 19 Nov 2009 15:54:32
Message: <4b05b088$1@news.povray.org>
>> to be arbitrarily transformed. (Cairo provides the same functionallity
In the PostScript case, since Ghostscript insists on displaying every PS
file under the assumption of A4 paper, it's hard to decide where Cairo
thinks the edge of the paper is. PDF works correctly, however, and this
indicates that Cairo is indeed translating and reflecting the coordinate
system such that the origin is the top-left corner.
They could have saved me a whole heap of trouble if this were written
down somewhere. (Note that it doesn't even say what the coordinate
system is for image surfaces either...)
http://blog.orphi.me.uk/
Date: 19 Nov 2009 15:55:55
Message: <4b05b0db@news.povray.org>
> down somewhere.
Report it, then. Or even send them a patch, if the documentation source
files are available.
Date: 19 Nov 2009 20:33:29
Message: <4b05f1e9$1@news.povray.org>
Darren New schrieb:
>> you whether the argument is seconds or miliseconds or picoseconds or...
Billyseconds?
Date: 20 Nov 2009 03:20:22
Message: <4b065146$1@news.povray.org>
> Billyseconds?
no, bilisecond, from the USA/MS nomenclature :
 bil : 1000 mil   (million, billion...)
and the isecond unit (inverted second)
milisecond is 1/1000 second,
so bilisecond is 1000 times that, 1/1000000 s.
(From the thread about MS api)
I now expect a precision of femtosecond in timestamps...
