POV-Ray : Newsgroups : povray.off-topic : Tool of choice for lighteweight Linux GUI tools Server Time
17 Jan 2026 16:13:27 EST (-0500)
  Tool of choice for lighteweight Linux GUI tools (Message 1 to 10 of 14)
Subject: Tool of choice for lighteweight Linux GUI tools
Date: 19 Nov 2009 00:19:01
Message: <4b04d545@news.povray.org>
In the recent months, I have set up some shell-script-based framework to
run benchmarks (and verify output) on experimental POV-Ray versions.
So far, so good.
I'm not too happy with the current solution though: It's good as far as
command-line tools go, but I'd like to take it further towards an
interactive GUI thing.
Any recommendations for the tool of choice?
I'm looking for a language - or toolkit - that is easy to learn for me,
and easy to throw together some user interface as well as
shell-script-ish program logic.
The user interface should have some rather elaborate support for tables:
Popup context menus and per-cell background color will me minimum, bells
& whistles like merged cells, elaborate cell formatting options, varying
grid line widths or even images in table cells would be nice to have. A
GUI element to display images is an absolute must.
Other than that, it must be easy to run external commands and process
their output, ideally with a means to "time" the external command (both
CPU and wall-clock time). Support for Sqlite3 databases would be nice.
I guess that Tcl/Tk and Perl might fit the bill; how about Python or
Ruby? And which of all these would you recommend to someone presently
actively using C/C++, some Unix shell scripting, a bit of JavaScript,
and of course POV-Ray SDL?
Subject: Re: Tool of choice for lighteweight Linux GUI tools
Date: 19 Nov 2009 00:39:45
Message: <4b04da21$1@news.povray.org>
clipka wrote:
> I guess that Tcl/Tk
That may be a touch more than Tcl/Tk can *easily* do, but it has been used
for a variety of high-end professional programs, so I'm sure it's not too
rough to get out what you're looking for. Certainly Tcl is one of the
easiest languages to find OS-level interfaces for doing things like grabbing
the elapsed time of child processes.
And of course I'd be happy to help if you run into troubles with Tcl. The
others I don't know well enough to help you myself.
     Is God willing to prevent naglams, but not able? Then he is not omnipotent.
     Is he able, but not willing, to prevent naglams? Then he is malevolent.
Date: 19 Nov 2009 01:24:45
Message: <4b04e4ad$1@news.povray.org>
Darren New schrieb:
> clipka wrote:
>> I guess that Tcl/Tk
> used for a variety of high-end professional programs, so I'm sure it's
> not too rough to get out what you're looking for. Certainly Tcl is one
> of the easiest languages to find OS-level interfaces for doing things
> like grabbing the elapsed time of child processes.
> The others I don't know well enough to help you myself.
First question: How can I get Tk to use the window manager's look &
feel? A simple test script resulted in something motif-like, even though
according to Wikipedia Tcl/Tk 8 and above should use the "native" look &
feel, which in this particular case is KDE4.
Or am I missing something fundamental here?
Date: 19 Nov 2009 01:52:43
Message: <4b04eb3b@news.povray.org>
There's two possibilities. One is to frob around all the settings. You can
probably google around for a set of configuration options for widgets
that'll do it, altho that's the sledgehammer way.
More recently, there's "ttk", which is a re-do of Tk.  I'm afraid I haven't
used it much, but it's apparently supposed to make that sort of thing much
easier.
But, yes, Tk programs often look like motif. It uses native widgets where
available - it just by default has the colors and texts and such set to
something that makes it look like motif.
Here are some starting points, if this helps.
http://wiki.tcl.tk/9485
http://wiki.tcl.tk/11075
http://wiki.tcl.tk/14796
http://www.tkdocs.com/
It isn't trivial, but it's not too hard to match a particular style pretty
well. Admittedly, getting it to not look too motif-like is one common
complaint. :-)
     Is God willing to prevent naglams, but unable? Then he is not omnipotent.
Date: 19 Nov 2009 08:03:28
Message: <4b054220$1@news.povray.org>
>> though according to Wikipedia Tcl/Tk 8 and above should use the
>> "native" look & feel, which in this particular case is KDE4.
> haven't used it much, but it's apparently supposed to make that sort of
> thing much easier.
Looks like the way to go: It's apparently a re-do of the traditional Tk
widgets, with a framework to implement custom styles, which may or may
not be implemented using "native" GUI widgets. Unfortunately, while
there seems to exist a Qt style (TileQt), I can't get that one to
compile for some obscure reason.
Well, I'm trying for qtcl now.
Date: 20 Nov 2009 08:34:00
Message: <4b069ac8$1@news.povray.org>
Ah well - apparently Tcl with Tk 8.5 is the way for me to go: Readily
available for my Linux (openSUSE) machine, including some
can-do-all-you'll-ever-need table widget (Tktable), support for widget
themes (via the Ttk package), and sqlite3 (via the sqlite3 package); to
my pleasant surprise, the same functionality is available "ready to
rock" for Windows as well (via ActiveTcl); and the language is ugly as
hell - so all in all it's pretty much the right stuff for me...
Date: 20 Nov 2009 08:36:15
Message: <4b069b4f$1@news.povray.org>
You are a sick, sick person, you know that? ;-)
Date: 20 Nov 2009 09:29:21
Message: <4b06a7c1$1@news.povray.org>
Invisible schrieb:
> clipka wrote:
>> and the language is ugly as hell - so all in all it's pretty much the
Absolutely! :-)
Date: 20 Nov 2009 10:11:13
Message: <4b06b191@news.povray.org>
> Absolutely! :-)
Oh, OK then. Just so long as you know... :-)
Date: 20 Nov 2009 13:14:52
Message: <4b06dc9c$1@news.povray.org>
Note that you can get the free version of everything from ActiveTcl if you
like.  The language isn't *too* ugly. It's just not all complex syntax infix
stuff.   Read the twelve (now 13?) rules of syntax, and believe them. The
way to understand the syntax is to realize the program never looks at the
same character twice while parsing - i.e., it never ever backs up during
parsing.
There's a lot of other good packages, too, and it's pretty trivial to write
extensions that would let you (for example) run a program and collect the
child runtimes, if [exec] doesn't already do that.
