POV-Ray : Newsgroups : povray.off-topic : Has anyone seen me? Server Time
12 Apr 2026 21:09:03 EDT (-0400)
  Has anyone seen me? (Message 1 to 10 of 18)
Subject: Has anyone seen me?
Date: 17 Nov 2009 02:55:20
Message: <4b0256e8$1@news.povray.org>
In the process of writing one of my scenes I arrived through tedious
trial and error at a particular constant with a value of 0.28867519
(plus an unknown number of additional decimals after the last place).
No matter to how many decimal places I manually determine the value, I'd
rather know for sure *where* the number came from and *what* it
represents. Is it a mathematical constant like 'e'? Is it the result of
some trigonometric expression?
My question is, in your travels in the land of mathematics, have you
seen this number before? Is it familiar to you? Have you arrived at this
value yourself in past operations, and how?
I would post the entire scene (probably the only *real* solution), but
it is fairly complex and I haven't received a lot of responses in my
previous threads.
Anyway, thanks for any assistence.
Mike
Subject: Re: Has anyone seen me?
Date: 17 Nov 2009 03:48:04
Message: <4b026344$1@news.povray.org>
It's likely to be the combination of two or more numbers that we may be
familiar with, but unrecognizable on its own. For instance, I might
recognize 'e', and I might recognize sqrt(3), but I wouldn't recognize e /
sqrt(3).
...assuming, of course, that no one else recognizes the number. =)
 - Slime
 [ http://www.slimeland.com/ ]
Date: 17 Nov 2009 04:58:11
Message: <4b0273b3$1@news.povray.org>
Hey, that's a possible use of Wolfram alpha :-)
http://www.wolframalpha.com/input/?i=0.28867519
Seems fairly close to sqrt(3)/6, then. Not exactly but close enough.
Vincent
> previous threads.
> Mike
Date: 17 Nov 2009 05:01:31
Message: <4b02747b$1@news.povray.org>
The expression for your number could be arbitrarily complex. I found at
least half a dozen simple expressions which give an answer *vaguely*
similar to the one above, but none of them are especially close to it.
To give you an example: The Fibonacci numbers. Each Fibonacci number is
the sum of the previous two numbers in the sequence. (The first two
numbers are 1 and 1.) If you divide a Fibonacci number by the one before
it, the sequence of numbers gradually approaches the number
   1.618033988749894848204586834...
This number, it turns out, is equal to (1 + Sqrt(5))/2. (WTF?)
And if you think that's weird, try adding up 1/x^2 from x=1 to infinity.
The result just happens to be exactly pi^2 / 6.
The number you seek is probably a polynomial, polynomial root, or
trigonometric ratio thereof. There's a hell of a lot of potential
candidates to choose from. It's probably fundamentally impossible to
tell which one just by looking at the number itself. (Which, by the way,
you seem to have an aweful lot of digits for already...)
Date: 17 Nov 2009 05:18:24
Message: <4b027870$1@news.povray.org>
Heh. And to think I specifically didn't try that because I figured it
wouldn't tell me anything interesting...
So apparently your number is one nineth of the twenty vertex constant. :-P
Also 1/(2 * Sqrt(3)), cos(73°), log(4/3) and several others...
...but it's probably the root of some polynomial or something weird.
Without knowing what on earth this number is supposed to be for, it's
hard to say.
Date: 17 Nov 2009 07:35:55
Message: <4b0298ab$1@news.povray.org>
Wow! Good sleuthing! It seems Wolfram Alpha has quite a few esoteric uses.
Mike
Date: 17 Nov 2009 07:40:51
Message: <4b0299d3$1@news.povray.org>
As far as I know, *all* of Wolfram Alpha's uses are "quite esoteric". ;-)
Date: 17 Nov 2009 07:41:55
Message: <4b029a13$1@news.povray.org>
I'm looking for trigonometric functions in particular since I am
performing lots of vector operations.
tand(60)/6 is a good fit. I wonder if there are others.
Mike
Date: 17 Nov 2009 07:45:02
Message: <4b029ace@news.povray.org>
> Mike
sind(60)/3
Mike
Date: 17 Nov 2009 07:47:41
Message: <4b029b6d$1@news.povray.org>
On 11/17/2009 7:45 AM, SharkD wrote:
> sind(60)/3
> Mike
cosd(30)/3
Mike
