POV-Ray : Newsgroups : povray.off-topic : Quick C++ question... Server Time
2 Nov 2026 02:46:35 EST (-0500)
  Quick C++ question... (Message 1 to 25 of 25)
Subject: Quick C++ question...
Date: 11 Nov 2009 15:33:16
Message: <4afb1f8c$1@news.povray.org>
This seems a bit of a stumper to me.
I'm trying to set up a simple class (for testing) that just initializes
directfb. So I have this header file:
class dfbScreen
    IDirectFB* dfb;
    IDirectFBScreen* screen;
    IDirectFBFont* font;
    public:
       void openscreen();
       void closescreen();
       dfbScreen(); ~dfbScreen();
Now, of course, the implementation of those need to know the actual
declarations of IDirectFB, IDirectFBFont, and so on. But everything in
DirectFB is done with pointers, so you never actually declare a IDirectFB
value as a value, only as a pointer.
So what do I need to put before "class dfbScreen" such that I can include
just that class header file (without #include <directfb.h>) such that it
compiles, given that directfb.h includes lines like
   typedef struct _IDirectFB IDirectFB;
   typedef struct _IDirectFBFont IDirectFBFont;
and so on?
If I put "class IDirectFB;" in front, it tells me that's a redeclaration
when I include <directfb.h>.  If I don't, it tells me IDirectFB isn't defined.
What I'm doing right now is declaring
struct _IDirectFB; struct _IDirectFBFont; ...
class dfbScreen {
   struct _IDirectFB* dfb;
   struct _IDirectFBFont* font;
But that seems wrong, given that I have to grope around in someone else's
headers to pull out private declarations to make it possible to compile a
header that doesn't depend on those declarations.
I tried googling, but I didn't really find any clear answer.
The other choice is to make it into a separate class and add another level
of indirection, but that too seems like a solution to what shouldn't be a
problem?
Subject: Re: Quick C++ question...
Date: 11 Nov 2009 15:46:29
Message: <4afb22a4@news.povray.org>
You stumbled across a limitation of C++: You cannot pre-declare typedeffed
types because typedef doesn't create a real type, and there's currently no
way of saying that "xyz is a typedeffed name, but don't mind what it actually
is an alias for" (like you can do for classes and structs).
  I'm afraid there are only ugly solutions to that problem. The least ugly
of them would be to simply #include that header.
  (A very ugly solution would be to use void pointers, and then reinterpret
cast them as needed. But if you are determined to not to have to #include
that header, then that's something that would work.)
Date: 11 Nov 2009 15:55:47
Message: <4afb24d2@news.povray.org>
  I thought of another uglyish kludge that might work and, while kludgey,
not necessarily as ugly as the void pointers:
// Header:
class dfbScreen
    class MyIDirectFB
    MyIDirectFB* dfb;
// Source file:
class dfbScreen::MyIDirectFB: public IDirectFB
 /* If IDirectFB supports copying, you can just implement a constructor
    here which takes an instance of type IDirectFB in order to initialize
    objects of type MyIDirectFB, like:
    MyIDirectFB(const IDirectFB& init): IDIrectFB(init) {}
    If IDirectFB does not support copying, then you'll have to replicate
    its constructors here. No way of automatizing that until the next C++
    standard gets implemented in compilers.
Date: 11 Nov 2009 18:21:53
Message: <4afb4711$1@news.povray.org>
Yeah. This is supposed to support numerous underlying technologies, so
including that header would fail when that class started using something
other than DFB. For now, putting the "struct _IDirectFB" into the private
part is probably better.
Before that, i'd just add an extra layer of indirection to my own private
type that was just the pile of pointers.
I'm not sure what this means, but I'm pretty sure it's not going to work
well. :-) DirectFB is all built on top of C, with fake OO stuff, so there's
no way to get one of these for real.
Anyway, thanks for your help. I've got a satisfactory kludge. I was just
hoping there was something less obviously kludgey I was missing.
Date: 11 Nov 2009 18:56:58
Message: <4afb4f4a$1@news.povray.org>
> class dfbScreen {
> else's headers to pull out private declarations to make it possible to
> compile a header that doesn't depend on those declarations.
Yes, that's why you normally /do/ include the headers... after all,
that's what they are for.
I'm not sure, but you might also be able to directly use
     struct IDirectFB;
instead of
     class IDirectFB;
> level of indirection, but that too seems like a solution to what
> shouldn't be a problem?
Unfortunately, C++ doesn't natively make a good job at separating
interface from implementation (the bane of allowing direct access to
data members, and "inlining" of classes as data members).
Speaking of interfaces, you might make dfbScreen abstract (serving as
what would usually be declared as an interface in Java), so that you can
keep the actual implementation of it in the background - private data
members included.
Date: 11 Nov 2009 19:00:19
Message: <4afb5013@news.povray.org>
  Why wouldn't it work? dfbScreen::MyIDirectFB *is* IDirectFB (this is OOP,
after all). Wherever an object of type IDirectFB is expected, you can pass
a pointer to an object of type dfbScreen::MyIDirectFB. And yes, even if you
are passing it to a C function.
  Just to make sure, I made a complete test to see that, indeed, it works:
  SomeCStruct.h
#ifdef __cplusplus
extern "C" {
#endif
struct SomeCStruct
    int i, j;
void someCFunction(struct SomeCStruct* object);
#ifdef __cplusplus
#endif
  SomeCStruct.c
#include "SomeCStruct.h"
#include <stdio.h>
    printf("i=%i, j=%i\n", object->i, object->j);
// MyClass.hh
class MyClass
    class SomeCStructWrapper;
    SomeCStructWrapper* obj;
    MyClass(const MyClass&);
    MyClass& operator=(const MyClass&);
 public:
    MyClass();
    ~MyClass();
    void foo();
// MyClass.cc
#include "MyClass.hh"
class MyClass::SomeCStructWrapper: public SomeCStruct
 public:
    SomeCStructWrapper(const SomeCStruct& init): SomeCStruct(init) {}
MyClass::MyClass()
    SomeCStruct instance = { 5, 10 };
    obj = new SomeCStructWrapper(instance);
MyClass::~MyClass()
    delete obj;
void MyClass::foo()
    someCFunction(obj);
// test.cc
int main()
    MyClass obj;
    obj.foo();
  Compiled with:
gcc -Wall -O3 -c SomeCStruct.c
g++ -Wall -O3 MyClass.cc test.cc SomeCStruct.o
  Works just fine.
Date: 11 Nov 2009 19:26:23
Message: <4afb562f@news.povray.org>
Here's another idea - a bit kludgey as well, but what the heck:
   struct MyIDirectFB;
   class dfbScreen
       MyIDirectFB* dfb;
and in your .cpp:
   struct MyIDirectFB
     IDirectFB data;
Requires a bit more effort in coding, but as I said: what the heck...
Or you might cheat a bit on the compiler, using something like:
   #ifndef _DIRECTFB_H__INCLUDED_
     // (or whatever symbol directfb uses in the header)
     struct IDirectFB;
   class dfbScreen
       IDirectFB* dfb;
and include <directfb> from your implementation instead of from your
header file.
There's more than one way to skin a cat...
Date: 11 Nov 2009 19:47:43
Message: <4afb5b2f@news.povray.org>
>    struct MyIDirectFB;
>    class dfbScreen
>        MyIDirectFB* dfb;
> and in your .cpp:
>    struct MyIDirectFB
>      IDirectFB data;
  Inheritance achieves the exact same thing, except that it makes MyIDirectFB
to be of type IDirectFB directly.
Date: 11 Nov 2009 20:42:19
Message: <4afb67fb$1@news.povray.org>
I'm not sure what I was thinking of. I'll have to look at this again (and
look up some syntax to see what "x::y : z" means :-) when I'm not at the end
of a day.
Date: 11 Nov 2009 20:47:14
Message: <4afb6922$1@news.povray.org>
>> class dfbScreen {
It seems wrong that I should have to expose the DirectFB declarations to
classes that don't care about the directfb declarations, simply because the
private parts of one of the classes they use has a pointer to something in
the directfb libs. That's what's the "seems wrong" part.
>     struct IDirectFB;
IDirectFB isn't a struct or a class. It's a typedef. Therein lies the problem.
Yeah. Plus having to declare everything *and* define it.
> members included.
What I did for the "real" library interface was to have a Player and a
Player_p object, and the Player.h forward-declared Player_p and the
Player.cpp included the actual definition. It's just an extra level of
indirection and another header file and such, which seemed unnecessary for a
unit-test helper function. (Only the fact that I expect to have to do unit
tests for multiple GUI bits drove me to make it separate from the unit tests
to start with, and then I got sidetracked down to figuring out how to do it
better. :-)
Date: 11 Nov 2009 20:51:54
Message: <4afb6a3a$1@news.povray.org>
Hmmm. I remember.
You get an IDirectFB by calling
   IDirectFB* myIDFB;
   good = DirectFBCreate(&myIDFB);
You get a "screen" by calling
   IDirectFBScreen* myIDFBScreen;
   good = myIDFB->GetScreen(myIDFB, this, that, &myIDFBScreen);
In other words, DirectFB is allocating and initlaizig the space, as well as
filling in pointers (like the GetScreen pointer) for each one, and then
putting the space it allocated into the pointer whose address you passed in.
I'm not sure how to cleanly turn that into a class without wrapping every
single function. None of those functions take a pointer to your own class,
so there's a bunch of casting on every creation at a minimum, and you have
to hope your class is laid out the same as the parent struct and all that.
Maybe it'll work, but it's 9 hours of working on this stuff today already, so...
Date: 11 Nov 2009 21:05:03
Message: <4afb6d4f$1@news.povray.org>
> every single function. None of those functions take a pointer to your
> own class, so there's a bunch of casting on every creation at a minimum,
> and you have to hope your class is laid out the same as the parent
Fun fact about structs in C++: They /are/ classes. Only major difference
(IIRC) being that their members default to "public:".
Classes only start to really diverge from classic C structs when you go
for stuff like virtual methods or multiple inheritance. In the former
case there'll be a few hidden data members that C++ will automatically
add, while in the latter case... heck, I have not the slightest clue :-)
Date: 11 Nov 2009 21:08:35
Message: <4afb6e23$1@news.povray.org>
No, you can pretty much mash that all together (not that I'd advocate
it, because /then/ you really need to give up ever inch of
implementation-hiding.)
Date: 11 Nov 2009 21:39:31
Message: <4afb7563@news.povray.org>
I guess if you really want to recompile your entire library inside every
source file that uses any of it, yah.
Besides, I'm not sure Qt works that way. It has to run a preprocessor on
stuff, and putting code in .h files is a good way to make that not work.
Date: 11 Nov 2009 21:46:15
Message: <4afb76f7$1@news.povray.org>
That much I knew already. But I don't know if C structs are C++ structs for
sure. :-)
Date: 11 Nov 2009 22:21:07
Message: <4afb7f23$1@news.povray.org>
Darren New schrieb:
>> difference (IIRC) being that their members default to "public:".
> for sure. :-)
Well, C structs are fully compatible to C++ structs, aren't they? You
can link a C++ program against any C library; and you can compile a C
library with a C++ compiler, and still link it to a C program. So...?
Date: 11 Nov 2009 23:05:51
Message: <4afb899f@news.povray.org>
Aren't they?  That's what I understood the intent to be, but I'm not sure I
ever looked it up definitively. :-) Good to know.
Date: 12 Nov 2009 12:49:16
Message: <4afc4a9c@news.povray.org>
  Firstly, C++ structs are enormously different from C structs in that C++
structs are, in fact, C++ classes. The *only* difference between a struct
and a class is default accessibility of members (iow. if access rights are
not specified, members will be by default private in a class but public in
a struct). This means that you can add a whole lot of things to a C++ struct
which you cannot to a C struct, such as constructors, a destructor, assignment
and other operators, member functions, and public/protected/private access
right specifiers.
  But secondly, if you *inherit* from a C-style struct (POD), this base
part will still be a basic struct even if you use things like virtual
methods or multiple inheritance in the derived class. In other words,
if something expects a pointer to an object of the struct type, you can
pass it a pointer to an object of the derived type and it will work just
fine. The inherited class using things like virtual functions and multiple
inheritance does not affect the base struct part.
Date: 12 Nov 2009 12:51:54
Message: <4afc4b39@news.povray.org>
  That might surprise many beginner and mid-level C++ programmers, but
there's nothing special going on there. You can pre-declare an inner
class and declare it later. The "x::y" part simply means "class y inside
class x". And the ": z" part means, of course, inheritance from z.
  In other words, this is perfectly valid (and quite handy):
class A
    class B;
class A::B
Date: 12 Nov 2009 14:14:43
Message: <4afc5ea3$1@news.povray.org>
Oh! OK. Heh. I don't think I've ever had the pleasure of needing or using
inner classes before, in any language, so it didn't leap out at me.
Oh! And A::B means class B inside class A, not class A inside class B. Wow,
that confused me for a bit.
I see that. Yes, that could work cleanly, if I wanted to redeclare every
function exported by DirectFB. Easier to kludge it in *this* case, but I'll
remember the trick for another time where I'm writing actual production
code. :-)
(Indeed, I'm doing the same thing with the "Player" vs "Player_private"
except I'm not making it an inner class. I'll have to think if that would
help anything.)
Date: 12 Nov 2009 14:16:15
Message: <4afc5eff$1@news.povray.org>
Cool. Not even C# manages that. (You can't put virtual methods on a value
class.) Another win for C++ MI.
Date: 12 Nov 2009 14:56:51
Message: <4afc6882@news.povray.org>
  Why not? It aids in limiting the visibility of types, and thus increases
modularity. If a class uses a helper class which is completely exclusive
to that class (and might even be a friend), then it makes sense that the
helper class is defined as a private inner class.
Date: 12 Nov 2009 14:58:57
Message: <4afc6901@news.povray.org>
  Forgot to mention practical examples.
  Ever wondered what, for example, std::list<int>::iterator is? Well,
surprisise surprise, it's an inner class inside std::list<int>. It's so
related to std::list that it makes a lot of sense to make it an inner class.
Date: 12 Nov 2009 16:53:39
Message: <4afc83e3$1@news.povray.org>
>   Why not?
I just haven't needed it. In languages where there's specific header files
(i.e., C and C++), I don't include the header file for the child class. In
languages where there's specific support for the concept (C#) I use the
internal visibility. I haven't done much in Java since they invented inner
classes, but those aren't really "invisible" so much as obsfucated anyway,
so there didn't seem to be a benefit there either.
I.e., everyone already has modular visibility controls, so putting it inside
a class rather than a namespace didn't seem worthwhile.
Yes it does. I didn't say it was bad. I just said I never found the need to
use one. The existent mechanisms were already sufficient.
Date: 12 Nov 2009 17:55:13
Message: <4afc9251$1@news.povray.org>
> to use one. The existent mechanisms were already sufficient.
Altho your point of a public class with an embedded iterator is a good one.
I even expect C# uses embedded classes to implement that in the libraries,
now that you mention it. Of course, the name isn't exposed outside the class
in any way, so it's hard to tell without reading actual source code.
Instead, there's a call called "getEnumerator" or something on the
collection that returns something that inherits the Enumerator interface or
some such. You don't directly instantiate an iterator, but rather ask the
class for one.
