POV-Ray : Newsgroups : povray.off-topic : Locking references Server Time
2 Nov 2026 03:35:08 EST (-0500)
  Locking references (Message 1 to 33 of 33)
Subject: Locking references
Date: 9 Nov 2009 05:43:30
Message: <4af7f252@news.povray.org>
I have heard it suggested that if every thread in a program takes
whatever locks it needs to take in sorted order, it is guaranteed that
deadlock can never occur.
Is this correct? And does anybody have a reference I can site?
Subject: Re: Locking references
Date: 9 Nov 2009 08:10:38
Message: <4af814ce$1@news.povray.org>
I'd think this is immediately obvious.
One issue is that a thread does not always know what locks it needs
before the fact.  And if you hold a lock and want to get another with a
lower key then you have to release the lock you hold then go back and
get them in the right order.
As to references, Wikipedia 'Deadlock' article is a decent starting
point.  Many more erudite references are given there.
Date: 9 Nov 2009 08:26:29
Message: <4af81885$1@news.povray.org>
Not to me. ;-)
> before the fact.
Yes, this is the killer. Often it's not possible to know what locks you
want until you read some data (which you have to lock first). And if you
release the locks, somebody else could come and change the data...
OK, I'll take a look.
Date: 9 Nov 2009 08:46:56
Message: <4af81d4f@news.povray.org>
Invisible wrote:
>> before the fact.
Isn't that the point? I've never worked with a low-level locking setup, but
I implemented a high-level one in the CMS I'm currently working on. If
somebody accesses a specific item, it is locked with a timeout. If he
doesn't commit changes within 15 minutes (or whatever is set), he "loses"
the lock, and somebody else can edit.
I.e. releasing a lock = it's ok for somebody else to change the data. You
have the lock = everybody else is blocked from changing the data?
Stefan Viljoen
Date: 9 Nov 2009 08:52:22
Message: <4af81e96$1@news.povray.org>
>>> before the fact.
My point is, you can't just go "I've got lock 7 and lock 13, and now I
need lock 2, so I'll just release lock 7 and lock 13, then take lock 2
and take back lock 7 and lock 13". In between releasing the locks and
taking them back, something could change. You need a better plan than that.
Date: 9 Nov 2009 09:19:30
Message: <4af824f1@news.povray.org>
> that.
Isn't this what a mutex (like it is implemented in the Linux kernel) is for?
Wik it a bit, I think it might be a partial answer to your original
question... :)
Stefan Viljoen
Date: 9 Nov 2009 09:36:13
Message: <4af828dd@news.povray.org>
Is this just theoretical interest or is there an actual problem that you
are trying to solve ?
In non-trivial cases like databases and operating systems the
possibility of deadlocks cannot be eliminated entirely.  The designers
seek to reduce the chances by good design but they also have to
implement 'deadlock detection' and 'deadlock resolution'.
Date: 9 Nov 2009 09:46:06
Message: <4af82b2e$1@news.povray.org>
I just saw this:
http://en.wikipedia.org/wiki/Gridlock
I can't help thinking that this should be an XKCD strip. I can just
imagine Black Hat Guy doing something to the timing of the traffic
signals to induce a mathematically indefinite deadly embrace. (And throw
in a pun or two in the process... Get it?... Process?)
Date: 9 Nov 2009 09:46:41
Message: <4af82b51$1@news.povray.org>
I've just implemented a solution; I'm trying to write it up. ;-)
Date: 9 Nov 2009 09:49:17
Message: <4af82bed@news.povray.org>
http://en.wikipedia.org/wiki/Deadlock_provision
...so, it's like the deadlock resolution algorithm where you randomly
terminate one process, except that you're terminating somebody's
*employment* instead?
Wow, that's pretty harsh. :-D
Date: 9 Nov 2009 11:58:23
Message: <4af84a2f$1@news.povray.org>
>> that.
With a mutex /being/ a lock, it doesn't get you out of the dilemma:
(1) Locks can create deadlocks.
(2) Deadlocks can be prevented by numbering the locks, and emposing the
constraint that a program cannot acquire a "lower" lock than the
"highest" one it currently owns, prevents deadlocks for sure.
(3) With this locking scheme, a program that has acquired lock X, done
some computations on the data read while holding the lock, possibly even
written other data, and is now coming to the conclusion that it needs to
acquire lock X-N, can do nothing but rollback to the state before it
acquired lock X, acquire lock X-N, and then acquire lock X again and
re-do all the computations, because the data the previous run was based
on might have been changed in the meantime.
So if performance is an issue, and it is not known beforehand what locks
may be required to complete the operation, this locking concept is
usually not an option.
Date: 9 Nov 2009 12:07:11
Message: <4af84c3f$1@news.povray.org>
Not really their *employment*, but rather their partial ownership of a
business - at a monetary compensation.
And most variants don't seem too random to me.
Date: 9 Nov 2009 12:17:33
Message: <4af84ead$1@news.povray.org>
No. He's talking about taking and holding multiple mutexes.
There are officially five ways to prevent deadlocks. Let's see if I can
remember them from memory:
1) Lock things in order, as you say.
2) Don't hold a lock while waiting for another lock.
    I.e., immediately roll back if you can't immediately aquire a lock.
3) Aquire all locks you'll need before you start processing.
    E.g., "run this job where there's a video tape reader, a CD burner,
    and a DSP available."
4) Only lock one thing, obviously.
5) Hmmmm... It's taking me too long to remember. :-)
But yeah, there's a formal mathematical proof that you can avoid deadlock in
exactly five ways.
Date: 9 Nov 2009 12:28:10
Message: <4af8512a$1@news.povray.org>
I don't think you have a choice, if you want ACID-style guarantees that your
changes are committed and valid. :-)  Everything else breaks down to doing
locks and retrying for a deadlock.
Date: 9 Nov 2009 12:41:10
Message: <4af85436$1@news.povray.org>
Darren New schrieb:
>> locks may be required to complete the operation, this locking concept
>> is usually not an option.
> your changes are committed and valid. :-)  Everything else breaks down
> to doing locks and retrying for a deadlock.
If noticing during an operation that you'll need an additional "lower"
lock is a frequent situation you'll encounter, then risking deadlock may
be the more performant option. Especially if all you really need are a
few individual pages from a database, for instance, so that the risk of
deadlock may actually be quite low. You'd be in for a retry anyway,
whether you need to rollback to ackquire additional locks or to break up
a deadlock.
Of course, if you absolutely positively know which locks you'll need,
ordered locking seems to be the way to go.
If you're not sure, then of course you can acquire just any lock you
/may/ possibly need, but that'll degrade performance as well.
Date: 9 Nov 2009 12:45:55
Message: <4af85553$1@news.povray.org>
> deadlock in exactly five ways.
I guess timing out on acquiring a lock would constitute a variant of 2)
in theory, right?
Also note that 3) only works to prevent deadlocks if acquiring multiple
locks at once is an atomic operation.
Date: 9 Nov 2009 14:35:07
Message: <4af86eeb@news.povray.org>
  Perhaps if you explained what it means to "take whatever locks it needs
to take in sorted order", then I might be able to write some answer.
I just can't understand what that means.
Date: 9 Nov 2009 15:26:50
Message: <4af87b0a$1@news.povray.org>
If you assign a unique ID to every lock in the system, and arrange for
every thread to take whatever locks it needs to take in ascending order,
deadlock is guaranteed not to occur.
Or so I believe, anyway...
http://blog.orphi.me.uk/
Date: 9 Nov 2009 15:40:25
Message: <4af87e39@news.povray.org>
See, Darren knew.
(You see what I did there?)
Although... how is #4 different from #2?
Anyway, do you have a citable reference for this stuff? (I'm guessing
Dijkstra, Knuth, or somebody must have written about this...)
Date: 9 Nov 2009 16:31:48
Message: <4af88a44@news.povray.org>
  I still don't understand how the "ascending order" has anything to do
with locks.
  Assume process 1 reserves resource 1, and then wants to also reserve
resource 2. However, resource 2 has already been reserved by process 2,
which means that process 1 has to wait for it to be freed. Meanwhile
process 2 tries to also reserve resource 1, but it's already reserved
by process 1, so process 2 has to wait. They are in a deadlock, waiting
for each other.
  What does any "ascending order" of locks have anything to do with this?
  (Btw, if you are curious, the above is the classical "dining philosophers
problem" with two processes and two resources. There could be more processes
and resources, forming a ring, with the same deadlock possibility.)
Date: 9 Nov 2009 16:44:59
Message: <4af88d5b$1@news.povray.org>
> with locks.
> for each other.
Because, if every process always reversed resources in ascending order,
then both processes above will attempt to reverse resource 1 and then
resource 2, in that order. In the above example, deadlock occurs exactly
because the first process tries to get resource 1 and then resource 2,
but the other process tries to get resource 2 and then resource 1
(descending order).
Date: 9 Nov 2009 16:45:24
Message: <4af88d74$1@news.povray.org>
Ooo... Wikipedia claims you're supposed to also release resources in
descending order. I didn't know that. o_O
Date: 9 Nov 2009 17:02:15
Message: <4af89167$1@news.povray.org>
I misunderstood your reference to "this locking concept".
Date: 9 Nov 2009 17:03:47
Message: <4af891c3$1@news.povray.org>
> in theory, right?
Yes. In that case, you're not "holding" the locks, as you'll release them to
prevent a deadlock.
Yes, that's the idea. It's pretty simple to set up an atomic-lock mechanism
if you have a complete list of all possible locks up front.
Date: 9 Nov 2009 17:05:37
Message: <4af89231$1@news.povray.org>
#4 is only having a lock on one item at a time. #2 means you can have
multiple locks, you just can't *wait* on a lock if you already have another
lock.
They all sound pretty similar, and boil down to "don't cause conflicts
without resolving it."  You can avoid causing it (by only locking one thing,
or locking in order) or you can resolve it (by freeing locks when you get a
deadlock).
Uh, probably somewhere, but not off the top of my head, no.
Date: 9 Nov 2009 18:05:26
Message: <4af8a035@news.povray.org>
  Reversed?
> (descending order).
  You assume that the processes can reserve the resources in any order
they want. It may be so that process 1 *has to* reserve resource 1 before
it can reserve resource 2, and the other way around for process 2.
  Anyways, you were talking about ordering IDs of *locks*, not ordering
resources. I still can't understand what you are talking about.
Date: 9 Nov 2009 19:16:28
Message: <4af8b0dc@news.povray.org>
Right. In which case, this mechanism doesn't work. :-) Otherwise, everyone
would always use this mechanism and not worry about deadlocks.
He's trying to say this:
Establish a globally unique total ordering on all possible things you can
lock. (Whether you're locking a mutex or a resource or whatever is
irrelevant.) Let us call the thing you can lock a resource, and you prevent
someone from using that resource while you hold the lock.
If you always request locks on resources in the same order as the globally
unique total ordering described above, you will never deadlock. You can skip
over resources, but you can't hold a lock on a higher-numbered resource
while requesting a lock on a lower-numbered resource.
It's not always possible to create this global ordering, mind, but if you
have something hierarchical (like B-Tree pages), it can be possible and
efficient. So if you always lock everything you need from left-to-right at
each level of a tree before locking something at the next level, you are
guaranteed not to ever get a deadlock. If you want in an XML document to
lock all the <div> elements with class="lockme", for example, you can do
that without hitting a deadlock, as long as everyone follows the same rules.
I'm pretty sure you can release in any order, so IIRC you could even iterate
thru the whole tree in pre-order traversal, locking each node, peeking,
unlocking without modifying if you don't want to change it, then moving on
to the next node.
Date: 9 Nov 2009 20:26:46
Message: <4af8c156@news.povray.org>
  So the original claim was not about numbering locks (whatever that might
mean), but numbering shared resources so that one process can only reserve
more than one resource at a time in the order dictated by those numbers?
  I suppose that would work, at least assuming that a process never releasing
a resource is not included in the definition of "deadlock".
Date: 9 Nov 2009 20:58:56
Message: <4af8c8e0$1@news.povray.org>
If you have a process that never releases a resource, then you're
somewhat screwed anyway...
Date: 9 Nov 2009 23:13:11
Message: <4af8e857$1@news.povray.org>
Right. I think probably the term "lock" there meant an individual mutex, or
whatever structure you're using to keep track of who has which resource.
I.e., "lock" meant a resource, not a reservation.
As long as the process holding the lock on the resource is not prevented
from making progress, it's technically not a deadlock. That's why there are
usually "fairness" criteria in such systems as well, where "fairness" means
that no process that's ready to run gets delayed indefinitely.
Date: 9 Nov 2009 23:14:06
Message: <4af8e88e$1@news.povray.org>
clipka wrote:
>> releasing
Not really. It could be livelock, with all else outside of the resource
locking/reservation/management subsystem being correct.
Date: 10 Nov 2009 13:30:07
Message: <4af9b12f$1@news.povray.org>
>>> releasing
Yes. In this case it's the livelock that screws you. But screwed you are.
However you resolve such a situation, you want /some/ mechanism to make
sure that processes don't run endless in the first place, not to mention
doing so with resources locked (unless of course it's a daemon process
and the only one to use the resource anyway). And if the only mechanism
in place is a human brain & fingers typing "kill -9 <PID>", you'll still
want it at any rate.
Date: 10 Nov 2009 14:18:19
Message: <4af9bc7b$1@news.povray.org>
clipka wrote:
>>>> releasing
>> resource locking/reservation/management subsystem being correct.
Sure. I was just pointing out that "livelock" (or any other indefinite
holding of a lock while not blocked) is not included in the definition of
"deadlock". :-)
