POV-Ray : Newsgroups : povray.off-topic : Question about imperial units Server Time
21 Mar 2026 15:18:19 EDT (-0400)
  Question about imperial units (Message 1 to 10 of 49)
Subject: Question about imperial units
Date: 6 Nov 2009 20:46:02
Message: <4af4d15a@news.povray.org>
In the metric system it's very common to use the superscript power
notation for squared and cubed units of length, such as "m^2"
(m superscript 2, damn the limitations of ascii...) for square meters
and "m^3" for cubic meters.
  How about imperial units. Can you write "square feet" as "ft^2" or
something like that?
Subject: Re: Question about imperial units
Date: 6 Nov 2009 20:58:45
Message: <4af4d455@news.povray.org>
Yes.
Tim Cook
http://empyrean.freesitespace.net
Date: 6 Nov 2009 22:28:43
Message: <4af4e96b$1@news.povray.org>
imperial units are not SI units and therefore wrong anyway, so you can
do with them whatever you like :-P
(*ducks & runs*)
(BTW, those "limitations of ASCII" work pretty neat in T'bird :-))
Date: 7 Nov 2009 01:34:07
Message: <4af514df@news.povray.org>
> notation for squared and cubed units of length, such as "m^2" (m
> superscript 2, damn the limitations of ascii...) for square meters and
Sure, you can.  I find "Square feet" typically is written "sq. ft."
though (or some variation like that)
Jim
Date: 7 Nov 2009 02:35:40
Message: <4af5234c$1@news.povray.org>
4af4d15a@news.povray.org...
>                                                          - Warp
Of course you can
and you can try converting hPa to psi by head with a hangover by a misty
morning in a gas station of Kyle of Lochalsh.
Duh!
Marc
Date: 7 Nov 2009 07:13:16
Message: <4af5645c$1@news.povray.org>
While we are at this, where does cid come from? Cubic Inch...Dimensions?
-Aero
Date: 7 Nov 2009 09:47:45
Message: <4af58891$1@news.povray.org>
'pedia is your friend:
http://en.wikipedia.org/wiki/CID
For the impatient: It's "... Displacement".
Date: 7 Nov 2009 11:07:01
Message: <4af59b25$1@news.povray.org>
news:4af4d15a@news.povray.org...
I don't ever recall seeing it written that way, but yes, it's common for
metric units.  I often see "sq. ft.", "sqft", and "cu. ft."  But I don't
ever remember seeing ft^2 (superscript).
I actually wonder if that would confuse.
e.g.
"The area is about 100 feet square"
"100 square feet?"
"No, that would be 10,000 square feet."
I just wonder if writing it as "100 ft^2" could possibly be (mis)interpreted
that way.
Date: 7 Nov 2009 12:13:45
Message: <4af5aac9@news.povray.org>
Another question:
  Is there a reason that 1 gallon is exactly 231 cubic inches? Was a gallon
first defined in terms of cubic inches? (And why such an arbitrary number
as 231?)
  Why no such round number with cubic feet? 1 gallon = 0.133680556 cubic feet.
Date: 7 Nov 2009 13:25:52
Message: <4af5bbb0$1@news.povray.org>
Warp schrieb:
>   Another question:
> as 231?)
231 cubic inch, actually.
"The wine gallon, which some sources relate to the volume occupied by
eight medieval merchant pounds of wine, was at one time defined as the
volume of a cylinder six inches deep and seven inches in diameter, i.e.
6 * (3+1/2)2 * pi ~= 230.90706 cu in.  It had been redefined during the
reign of Queen Anne, in 1706, as 231 in^3 exactly (3 * 7 * 11 in), which
is the result of the earlier definition with pi approximated to 22/7."
The wine gallon is the one adopted by the U.S. as "the" gallon. Note
that Brits and Canadians went for the "imperial gallon" instead.
(WIYF)
