POV-Ray : Newsgroups : povray.off-topic : Trolltech doesn't know how amortized time works Server Time
17 Jan 2026 17:55:43 EST (-0500)
  Trolltech doesn't know how amortized time works (Message 1 to 10 of 17)
Subject: Trolltech doesn't know how amortized time works
Date: 2 Nov 2009 13:52:51
Message: <4aef2a83$1@news.povray.org>
http://doc.trolltech.com/4.2/containers.html#algorithmic-complexity
Their "growth strategies" give you an amortized time of O(n), not O(1) as
documented. :-)
Subject: Re: Trolltech doesn't know how amortized time works
Date: 2 Nov 2009 14:47:30
Message: <4aef3752@news.povray.org>
  Everybody always says that "inserting in the middle of a linked list is
a constant-time operation". My response to that is: "Ok, if that is so, then
give me a function which takes a linked list and an element as parameters,
and make the function insert the element in the exact middle of the list in
constant time. I'll wait."
  The claim is rather imprecise. You can't just magically insert an element
in the middle of a list in constant time. You have to get there somehow first.
Only if you happen to have, from some previous operation, an iterator pointing
to the place where you want to insert, *then* it will be a constant-time
operation.
  A more precise wording would be: "Inserting an element in a linked list at
the location pointed by any given iterator is a constant-time operation."
Then the complexity of the thing is left to getting said iterator.
Date: 2 Nov 2009 15:23:53
Message: <4aef3fd9$1@news.povray.org>
> operation.
The claim /is/ precise: Whenever you want to insert an element into
/any/ data structure, you /always/ need to first figure out /where/ to
insert, so the cost of an insertion operation is /always/ specified
presuming that the insertion is to happen at a /predetermined/ location.
Of course if someone only considers the cost of insertion, neglecting
any other costs his algorithm may incur, he's doin' it wrong...
Date: 2 Nov 2009 15:28:14
Message: <4aef40de@news.povray.org>
  "Inserting" and "inserting in the middle" are two slightly different
things. The latter is making a more concrete claim.
  As said, if you really can "insert in the middle" of a linked list in
constant time, give me such a function.
  If the claim is "insert at the location pointed by an iterator", then
the claim is true.
Date: 2 Nov 2009 16:52:31
Message: <4aef549f$1@news.povray.org>
It's not "in the middle" in the sense of "at the centroid", but in the
sense of "not at the beginning nor at the end, but at an arbitrary
position somewhere in between".
Date: 2 Nov 2009 18:01:36
Message: <4aef64d0@news.povray.org>
Trolltech gets the numbers wrong even if you insert always at the end.
Amortized O(1) append is only O(1) if you double the size of the array each
time you insert something. It's not O(1) if you add a fixed size to the
array each time (assuming you're copying elements from the old array to the
new array each time, of course).
Date: 2 Nov 2009 18:21:47
Message: <4aef698b$1@news.povray.org>
> to the new array each time, of course).
They do seem to actually address exactly this assumption with respect to
their resizing scheme:
"This makes sense because modern operating systems don't copy the entire
data when reallocating a buffer; the physical memory pages are simply
reordered, and only the data on the first and last pages actually needs
to be copied"
In fact, they explicitly address this difference with respect to QVector:
"Since the cost of reallocating is higher in that case, QVector<T>
reduces the number of reallocations by always doubling the memory when
running out of space."
Date: 2 Nov 2009 20:37:53
Message: <4aef8971$1@news.povray.org>
> to be copied"
Well, yes, there is that. Hmmm... OK, it seems they do know what that's
about. I guess if you don't copy the pages in the middle of the string,
there's no need to double the size each time to get O(1) amortized growth.
Date: 2 Nov 2009 22:29:38
Message: <4aefa3a2$1@news.povray.org>
>> entire data when reallocating a buffer; the physical memory pages are
>> simply reordered, and only the data on the first and last pages
>> actually needs to be copied"
In general my experience with using Qt has been extremely positive, so I
  would have been surprised had they made a mistake of that magnitude.
Still, I certainly didn't anticipate that the algorithm they use would
actually be O(1), so it was quite cool to see that it was.
Date: 2 Nov 2009 22:50:06
Message: <4aefa86e@news.povray.org>
Well, lots of people think that (for example) growing a hash table by adding
a few thousand buckets each time it fills up amortizes out to O(1), but it
doesn't.
Honestly, I'm rather impressed they documented it at all. Maybe I'm just
cynical, tho.
And yes, I'm finding Qt to be sort of "this is the bit that C++ forgot to
define."  Sort of like how jQuery is "this is what javascript should have
been in the first place."
Altho I must admit, I occasionally smack my head against the wall repeatedly
trying to find how to make something work. You *know* it's a simple
question, but it's just not in the docs.
