POV-Ray : Newsgroups : povray.off-topic : Random griping about Debian "Lenny", Gnome gdb and XDMCP... Server Time
17 Jan 2026 17:55:40 EST (-0500)
  Random griping about Debian "Lenny", Gnome gdb and XDMCP... (Message 1 to 10 of 29)
Subject: Random griping about Debian "Lenny", Gnome gdb and XDMCP...
Date: 30 Oct 2009 12:29:46
Message: <4aeb147a$1@news.povray.org>
Okay, so I decided it was time to upgrade my Linux machine from Debian
"Etch" (4.0.5) to "Lenny" (5.0.3)...
Gripe #1: How to download the packages?
I don't have the Linux machine configured to connect to the internet
(and don't intend to), so I'd have to download ISO DVD images using my
Windows machine. Debian strongly suggests using jigdo (there is no
serious alternative to download images, unless one would be happy to use
BitTorrent, which I don't intend to install either).
Unfortunately, the pre-compiled jigdo for Windows won't run on XP x64;
the MSYS environment it is based on just refuses to cooperate, all I get
is an error message from sh.exe.
I guess I tried everything by now: Changing the compatibility settings
for the MSYS tools; tweaking various MSYS tweakables; praying, shouting,
swearing and cursing; re-compiling the whole MSYS environment (on my
Linux machine, using the MinGW cross-compiler, which of course I had to
install first...)
In the end I gave up, and powered up the old 32-bit Windows XP machine
once more, which had proven to run jigdo just fine back when I
downloaded the "Etch" images.
(Next problem was to burn the ISO images to DVDs; the 32-bit box only
had a CD writer - but the only DVD writing software I owned turned out
to not run on XP x64 either. Tough luck. Well, a freeware DVD writer
software was quickly found on the 'net and installed, and served the
purpose fine, so not a big deal there.)
It seems that updating was easier than some official Debian How-To
claimed: Instead of hassling with gazillions of steps on an SSH text
terminal ("do /not/ try this via an X-Window connection!"), all I did
was click some menu entries and buttons in the Synaptic Package Manager
running under Gnome, and make a few decisions whether to have some
configuration files overwritten by new versions or keep the old ones.
And reboot once, because I couldn't bother trying to figure out the
correct commands to restart a few services (most notably gdm) manually.
I said it /seems/ that updating was easier than claimed, because... um,
well... honestly I don't /know/ whether I really updated my system. It
uses a new kernel now, and all the packages have been updated from the
"Etch" versions to the "Lenny" ones. And - hey, guess what - I do have
an official Debian distribution of boost 1.35 now! Maybe there's hope to
even get 1.36 some day... :-P
If that constitutes an updated system, then yes, I apparently did update
it...
Everything seems to be fine - except...
Gripe #2: WTF?!
After updating, two essential network services appeared broken: Samba
(which I used to transfer files between the Linux and the Windows
machine), and X-Window access (which I used to actually interact with
the Linux machine... who needs a display or a keyboard on a Linux box?!).
Other network services still worked fine though (SSH, but also HTTP, for
instance), and as a matter of fact the Samba issue was easily solved by
restarting the service (well, the whole machine in this case, but I
guess having restarted only the service would have done the job just as
well :-)).
The problems with X-Window persisted though. I browsed through all the
configuration files I could think of, over and over again, without
finding any hint. I googled the 'net up and down. Symptoms remained,
invariably: Xming (which I use on the Windows side) would briefly show
the typical X-window background, then close. Even without the
"-terminate" option. And no log file would tell me why. Starting Xming
in non-XDMCP mode would work fine, but what I really wanted was XDMCP.
No way; the only hint I found was a bug report from an Ubuntu user. With
a link into nowhere.
So what did I do?
Well, here I am, sitting at an X-Window terminal connection to a
Gnome/XDM hybrid, relieved that I managed to get *some* XDMCP connection
running (without any additional hassle as it seems), but being convinced
that the font used by XDM is a tad too small, or would need ClearType,
or whatever...
Linux sucks.
Sometimes.
Subject: Re: Random griping about Debian "Lenny", Gnome gdb and XDMCP...
Date: 30 Oct 2009 13:27:21
Message: <4aeb21f9$1@news.povray.org>
imgburn is best. :-) There are a couple of proprietary formats it doesn't
handle, but nothing used by free software.
Date: 30 Oct 2009 15:36:00
Message: <4aeb4020$1@news.povray.org>
> doesn't handle, but nothing used by free software.
CDBurnerXP went my way, and by doing the job without hassle it has
earned itself the right to stay for a while ;-)
Date: 30 Oct 2009 16:29:04
Message: <4aeb4c90$1@news.povray.org>
You're kind of paranoid, huh? ;)  You never really used bittorrent?
BTW, I don't see the logic behind an offline Linux in favor of an online
Windows if security is of concern... :)
Yeah, Synaptic is such a joy.
> Gripe #2: WTF?!
> So what did I do?
> Linux sucks.
there you go!  Linux don't like you either. ;)
Date: 30 Oct 2009 17:25:46
Message: <4aeb59da@news.povray.org>
No Sir; up until this day and hour, I have managed to stay /far/ away
from it. So far that I have not much of an idea what it /really/
actually is.
Because I haven't got the slightest clue about administering Linux, so I
decided to not bother about regular updates, firewalls and what-have-you
on that box. All I wanted it for was running POV-Ray on a dedicated
machine, without having to pay for another Windows license, and with a
comfortable scripting environment.
Linux may have more /potential/ when it comes to achieving a
comparatively secure environment, but I really don't believe in systems
delivering lifetime security out of the box.
For instance, I guess my Linux system would be a big gaping security
hole if I connected it to the internet directly. I haven't knowingly
installed any firewall, but I did install Samba, activated XDMCP, and
set up a lighttpd-based HTTP server which may soon host a few CGI
scripts - all set up for ease of use in my own local network instead of
worrying about security. Because when usability issues arise, I'm not
proficient enough with the operating system to work around them /and/
avoid compromising security.
Windows, however, is the operating system I have been running for about
a decade by now, and working with it both in my profession and in
private life, and I imagine I have enough administrative experience to
have at least /some/ idea of the security implications of what I'm
doing. And besides, it's the machine that runs the OS and software I'm
familiar with and need for my daily work and/or hobby, which regularly
includes internet research, so that machine /must/ be hooked up to the
internet, while the Linux box doesn't need to.
>> Linux sucks.
Apparently, yes :-)
Then again, I imagine I quite like Linux and Linux quite likes me - and
that it just gets its fits now and then because I don't spend enough
time with it... just like I get my occasional fits for exactly the same
reason :-)
Date: 30 Oct 2009 17:31:50
Message: <4aeb5b46$1@news.povray.org>
> actually is.
It's a way of obtaining files. Has the advantage that it's inherantly
resumable, and hypothetically allows the best possible download rates by
adaptively selecting where to download from. Has the notable
disadvantage that it requires open ports exposed to the Internet in
order to work properly, which can be problematic to configure.
>> online Windows if security is of concern... :)
> Because I haven't got the slightest clue about administering Linux.
That's a pretty logical reason, actually...
http://blog.orphi.me.uk/
Date: 30 Oct 2009 18:46:56
Message: <4aeb6ce0$1@news.povray.org>
> actually is.
It's a sophisticated form of FTP, basically. There's nothing inherently
dangerous about it.
> on that box.
Really, OpenSuSE is about as easy to admin as Windows is, for simple stuff,
if you wanted to. (Altho 11 kind of made the UI for a lot of things a lot
more confusing than it was for 10. Not that such isn't true of Windows
either. :-)
FWIW, the admin tool that comes with SuSE (YaST) makes saying "firewall
everything incoming from outside the local net" very easy.
Of all the versions of Linux I've used, OpenSuSE has been most friendly in
terms of admin.  (Even better than Ubuntu in my experience.)
Date: 31 Oct 2009 02:27:50
Message: <4aebd8e6$1@news.povray.org>
> actually is.
	When it comes to downloading large files or ISO's, you're shooting
yourself in the foot. Bittorrent is the way to go.
	And you're using Debian, of all distros?
	<dodges tomato>
	Maybe it's a bad idea, but I just use the firewall in my router.
Ghosts are merely unsubstantiated roomers.
Date: 31 Oct 2009 06:46:28
Message: <4aec1584$1@news.povray.org>
> in terms of admin.  (Even better than Ubuntu in my experience.)
I read somewhere that "ubuntu" is an ancient African word meaning "I
can't get Debian to work"...
Date: 31 Oct 2009 08:07:25
Message: <4aec287d$1@news.povray.org>
LOL!
