POV-Ray : Newsgroups : povray.off-topic : That's novel .... Server Time
18 Oct 2026 09:27:04 EDT (-0400)
  That's novel .... (Message 1 to 14 of 14)
Subject: That's novel ....
Date: 27 Oct 2009 12:17:47
Message: <4ae71d2b@news.povray.org>
For no reason that I can discover, Thunderbird decided to erase all my
p.o-t cache. It's not the first time that it's behaved in a random
fashion so I'm now using Pan.
Still getting my head round the differences and retraining my fingers but
I'm beginning to like it.
Secondly, re: a comment about showing email addresses some time back, how
about doing what I've done here?
John
wbu### [at] tznvypbz (rotted)
GPG Key Fingerprint: 0D9BCF4CF1B71CA2F5F7
                     BFBBCBC34EDEAEFCE453
Cogito sum, ergo sum, cogito.
Subject: Re: That's novel ....
Date: 27 Oct 2009 13:02:48
Message: <4ae727b8@news.povray.org>
Oops, got the header wrong and showed my RL name. Corrected now
John
Date: 27 Oct 2009 13:42:20
Message: <4ae730fc$1@news.povray.org>
> John
One problem with Pan is that you can't cancel that post. Pan sucks.
  -Shay
Date: 27 Oct 2009 13:57:09
Message: <4ae73475$1@news.povray.org>
> John
I'm fairly satisfied with Thunderbird. The few issues I can think of
are, 1) the advanced thread commands such as Kill and Watch do not
appear in menus AFAIK, and 2) you can't configure the display of watched
and unread threads separately. The latest beta version also takes longer
to load.
Mike
Date: 27 Oct 2009 14:01:40
Message: <4ae73584$1@news.povray.org>
>> John
At the bottom of the message menu. It's not in the roght-click menu.
I'm not sure what that means, but you can sort by either column.
My primary regrets are that it doesn't seem to let me kill a sub-tree of a
thread, and it doesn't show the subject-list properly, as in it does not
always default to scrolling to the header of the post you're reading when
you change posts, nor does it consistently highlight the subject line of the
post you're reading.
Date: 27 Oct 2009 14:03:49
Message: <4ae73605@news.povray.org>
>   -Shay
There is a cancel option under Post, but I couldn't be bothered to use it
since I'm not overly worried about my name appearing a few times. My
phone numbers and my address are different matters.
John
Date: 27 Oct 2009 14:22:05
Message: <4ae73a4d$1@news.povray.org>
Still don't see it. I'm using version 3.0b4.
>> and 2) you can't configure the display of watched and unread threads
>> separately.
Go to the menu View > Threads. There are some options allowing you to
select which threads to display by whether they are watched or unread.
However, you cannot say select ALL watched threads AND ALL unread threads.
Mike
Date: 27 Oct 2009 14:27:51
Message: <4ae73ba7$1@news.povray.org>
Sure you can, I use pan to cancel posts all the time.
Jim
Date: 27 Oct 2009 16:45:03
Message: <4ae75bcf@news.povray.org>
> Jim
Looks like I missed it or was using an older version.
  -Shay
Date: 27 Oct 2009 16:45:54
Message: <4ae75c02@news.povray.org>
It's in 2.0.
I see.
Date: 27 Oct 2009 17:51:47
Message: <4ae76b73$1@news.povray.org>
You must've missed it, I used to use 0.14.x and it was in there as well
as in the 0.13x series that's current.
Jim
Date: 27 Oct 2009 19:38:53
Message: <4ae7848d@news.povray.org>
	Showing up fine on 3.0b2. Same place Darren described it.
Every little BYTE helps.
Date: 27 Oct 2009 19:40:12
Message: <4ae784dc$1@news.povray.org>
> a thread,
	If you're feeling adventurous, switch to the 3.0 Beta. It's in 3.0b2
(and probably beyond).
	I've been using it on these newsgroups since June, and so far have no
complaints.
Date: 27 Oct 2009 20:28:09
Message: <4ae79019$1@news.povray.org>
That probably would have been a good reason to switch back when newsgroups
were still around and usable. :-)
