POV-Ray : Newsgroups : povray.off-topic : Largest POV image? Server Time
18 Oct 2026 09:27:51 EDT (-0400)
  Largest POV image? (Message 1 to 50 of 56)
Goto Latest 50 Messages Next 6 Messages >>>
Subject: Largest POV image?
Date: 22 Oct 2009 05:10:02
Message: <4ae0216a@news.povray.org>
Hi, there!
I wonder how large a povray rendered image can be?
While 1280x1024 fits on an A4-page nicely at 150 dpi, what about renders at
higher resolutions? What are the limits?
What is the largest image you have rendered and how long did it take?
Subject: Re: Largest POV image?
Date: 22 Oct 2009 06:25:49
Message: <4ae0332d@news.povray.org>
I've rendered stuff for Zazzle at silly resolutions. (It takes a *long*
time with a 32-bit CPU.)
Let me go check... Yeah, that was 8,000 x 6,000 pixels.
Date: 22 Oct 2009 06:51:10
Message: <4ae0391e$1@news.povray.org>
Sky's the limit!
Ah well, main memory actually is.
I did a 20,000x10,000 pixels render recently. On my 6-GB 64-bit XP
machine POV-Ray went unstable, but my 6-GB 64-bit Linux machine did the job.
Note that the output buffer needs 4 bytes per pixel and color channel
(invariably buffering the data in 32-bit floating point format before
converting to whatever the output file format holds), for a total of 12
or 16 bytes per pixel (can't tell off the top of my head whether space
for an alpha channel is always reserved or not), so the aforementioned
resolution needs some 2 GB of output buffer alone.
Rendering times are too strongly influenced by the scene to make any
absolute statement here that would help you.
The 20,000x10,000 render, for instance, did take no more than 7 minutes;
but it was only a montage step to merge two other renders - something
that would take just a few seconds at "sane" resolutions.
As a rule-of-thumb, expect a render with twice the resolution (i.e. four
times the pixels) to simply take about four times as long; or, more
generally, multiplying the resolution by N will multiply your rendering
times by N^2. Maybe a bit lower I'd guess, as some caching mechanisms
may become more effective (provided you keep the overall level of detail
unchanged), but probably not much. Radiosity may actually bog down the
render more at higher resolution if you set always_sample to on (which
is generally a bad idea but happens to be the default).
(BTW, why did you post this in povray.off-topic?)
Date: 22 Oct 2009 10:03:22
Message: <4ae0662a@news.povray.org>
> Sky's the limit!
  Note that many image formats have a limit of 65536x65536 pixels. (I don't
know if PNG has such a limit.)
  As for POV-Ray itself, I bet the limit is 2147483648x2147483648 pixels
(or maybe even 4294967296x4294967296 pixels).
Date: 22 Oct 2009 10:12:57
Message: <4ae06869$1@news.povray.org>
According to the official PNG specification [which I just happen to have
on my work PC], the size of the image is specified by the IHDR chunk.
The maximum value for the width and height in pixels is explicitly
specified to be  2^31 - 1 (even though the fields are 4-byte unsigned
integers). It is plausible that some programs might incorrectly support
2^32 - 1 though.
Any theories on how many GB of RAM would be required to render that?
(Assuming you turn off the display preview - apparently some people
don't know you can do this...)
Date: 22 Oct 2009 10:17:21
Message: <4ae06971@news.povray.org>
In theory, POV-Ray needs to store (width*2) pixels. libpng may need to store
a bunch more rows at once while compressing.
Date: 22 Oct 2009 10:33:07
Message: <4ae06d23$1@news.povray.org>
libpng only needs the current and previous row to run the pixel filter.
I have no idea what the DEFLATE compressor needs. (Other than a complete
redesign...) All assuming you're not going to generate interlaced PNG,
that is.
I note that to store (2^31 - 1) x (2^31 - 1) pixels, where each pixel
requires exactly 4 bytes, requires about 18 exabytes of storage. (!!)
http://www.wolframalpha.com/input/?i=(2^31+-+1)^2+*+4+bytes
Note: 1 exabyte = 1,000 petabytes = 1,000,000 terabytes (or thereabouts).
Nobody has anything approaching that amount of disk space, never mind RAM.
Also, if POV-Ray achieves a million pixels per second (highly unlikely),
that gives us...
http://www.wolframalpha.com/input/?i=(2^31+-+1)^2+%2F+1000000+*+1+second
...almost 150 millennia. So it seems pretty moot to me. :-P
Date: 22 Oct 2009 11:06:03
Message: <4ae074db@news.povray.org>
> that is.
Well, with antialiasing off, it should be possible (in theory) to produce an
interlaced PNG with O(1) memory too. You'd have to modify POV-Ray to
compute the pixels in the same order they're stored in the PNG file.
Date: 22 Oct 2009 11:11:35
Message: <4ae07627$1@news.povray.org>
On contemporary x64 machines, the limit will be much smaller - some 4e6
x 4e6 pixels; more than that, and you'll crash through the 256 TeraByte
address limit (contrary to legend, contemporary x64 processors only
support 48-bit addresses, despite the architecture being designed for
future extensibility to full-fledged 64-bit addresses).
Windows will not allow more than some 7e5 x 7e5 pixels (8 TB), while
Linux will not go beyond some 3e6 x 3e6 pixels (128 TB) due to
per-process address space limits.
Date: 22 Oct 2009 11:13:16
Message: <4ae0768c$1@news.povray.org>
Hum... yes, for POV-Ray 3.6 this is true. I was thinking of POV-Ray 3.7
only.
Date: 22 Oct 2009 11:14:44
Message: <4ae076e4$1@news.povray.org>
A bit, yes. :-)
Date: 22 Oct 2009 11:21:12
Message: <4ae07867@news.povray.org>
  Is that so even if you don't use antialiasing?
  Compression algorithms almost invariably use a buffer for the data, and
this buffer is often surprisingly small (like some tens of kilobytes).
(This means that most compression algorithms will *not* find and compress
repetitions which are gigabytes apart from each other. This is for the
simple reason that the compression routine has to use only a limited amount
of memory and be relatively fast.)
  Some modern algorithms might use larger buffers (like some megabytes),
but they nevertheless don't achieve enormously better compression ratios
(for some reason there seems to be some kind of cutoff point after which
enlarging the compression buffer does not improve the compression of average
data significantly, but slows down the compression more than it's worth).
  The problem with compressing exabytes of data is not the compression
algorithm itself, but the file format into which the compressed data is
stored. (Theoretically if the data is compressed as a stream then there
shouldn't be any theoretical limit to how much data you can compress.
However, if the file format has headers and other data expressing the
amount of compressed data, you may run into limitations.)
  Depends on what those pixels contain, and how smart your compression
algorithm is. If the image is completely filled with black pixels, using
a smart compression algorithm could compress it down to some tens of
bytes. (Actual compression algorithms, however, often fail to do this
because of the limited compression buffer. Some of the most naive
algorithms achieve surprisingly poor compression ratios when the input
is full of the same byte value. Other smarter algorithms are more capable
of taking advantage of this.)
  Of course if your image actually contains something meaningful, the
best you can hope to compress (losslessly) is something like to 1/10th
of the original size.
  I don't think many file systems even support files which are exabytes
large.
Date: 22 Oct 2009 11:24:51
Message: <4ae07943@news.povray.org>
  But those are not limitations of POV-Ray, they are limitations of the
hardware and/or operating system.
  If POV-Ray were to be compiled on a system without those limitations,
it could probably achieve images of those sizes (in theory, of course,
because in practice it would take millenia to render such an image, as
noted elsewhere).
Date: 22 Oct 2009 11:27:54
Message: <4ae079fa@news.povray.org>
> noted elsewhere).
  Actually, thinking about it, you confused me.
  POV-Ray doesn't need to keep the entire image in memory in order to render
it (after all, POV-Ray was developed on systems with limited amount of memory,
yet was able to render images larger than any conceivable RAM size back then).
  Thus it's perfectly possible for POV-Ray to render a 2^31 x 2^31 pixels
large image even on a system which limits memory addresses to be smaller
than that.
  (Of course you won't be able to *save* that image anywhere because you
would encounter limitations in the file system. But that doesn't stop
POV-Ray from *rendering* the image.)
Date: 22 Oct 2009 11:31:38
Message: <4ae07ada$1@news.povray.org>
>> that is.
If you generate a PNG image without any fancy filtering, then you don't
need any extra memory except for the DEFLATE compressor. But usually PNG
files use filtering to increase compression. (I don't know, but I'd
*hope* libpng provides a way to control this...) If filtering, you may
need the previous row of pixels [only].
Date: 22 Oct 2009 11:34:32
Message: <4ae07b88@news.povray.org>
  I think PNG has options to filter with the previous row, the previous
column, or both. I assume that if you choose to filter with the previous
column only, you don't need to store the previous row of pixels in memory
at all. (I don't know if libpng optimizes in this way, but at least in
theory I think it could be possible to implement png compression like that.)
Date: 22 Oct 2009 11:35:31
Message: <4ae07bc3$1@news.povray.org>
DEFLATE is ancient. I doubt it needs a lot of space. Most particularly,
the space required by DEFALTE is *unrelated* to the dimensions of the
PNG image. The PNG spec says the pixel data is optionally "filtered",
and then fed to DEFLATE as raw data, which DEFLATE then compresses in
the usual way.
> stored.
> algorithm is.
I was thinking more of the amount of RAM required if you were to store
the entire thing uncompressed. I would expect any half-decent
compression algorithm to improve on this significantly.
> large.
I agree.
(Maybe Google BigFile or whatever the hell it's called?)
Date: 22 Oct 2009 11:37:12
Message: <4ae07c28$1@news.povray.org>
> than that.
No - geological time stops you from rendering it. ;-)
Date: 22 Oct 2009 11:39:00
Message: <4ae07c94$1@news.povray.org>
> column, or both.
Yes.
Each row can be filtered in one of these ways (or not filtered at all).
The choice is independent per row.
> at all.
Yes.
Indeed - I have no idea if libpng has an option to control this...
Date: 22 Oct 2009 12:14:09
Message: <4ae084d1$1@news.povray.org>
> large.
There are a number that support 2^64 clusters, I think. People are beginning
to realize that if you actually need more than 2^64 clusters, you're not
going to want to copy that all over to a new file system when you run out of
space. :-)
Both NTFS and VFS in theory support up to 8 exabytes on a partition.
Date: 22 Oct 2009 12:34:37
Message: <4ae0899d@news.povray.org>
  Actually wikipedia claims that NTFS supports partitions and files of
16 exabytes. That's a bit better than ReiserFS which supports "only"
8 terabytes.
Date: 22 Oct 2009 12:40:14
Message: <4ae08aee@news.povray.org>
> that.)
You need to store the previous row in POV-Ray anyway, to know if you need to
antialias the current pixel :)
Date: 22 Oct 2009 12:52:56
Message: <4ae08de8$1@news.povray.org>
Thank you all for your posts. Quite an insight.
Because it was just an idle thought. I saw some pov-rendered posters. I then
pondered upon resolution and pixel-sizes for an A0-poster and wondered how
far you can realistically go. And how long it would take.
I realize of course that render-time is dependent on the scene to be
rendered. I just hoped to get to know if render-time behaves proportionally
to the numer of pixels to be rendered or if render time increases
exponentially with the number of pixels at really high resolutions.
Do you have any experience?
Furthermore I did not wish to bother anybody with this who might be occupied
with productive work. Whoever is browsing through povray.off-topic is
probably somewhat bored and wishes to pass time (probably until the current
render finishes) ;-)
Date: 22 Oct 2009 13:07:37
Message: <4ae09159@news.povray.org>
  Not in 3.7, which renders one small square at a time.
Date: 22 Oct 2009 13:55:31
Message: <4ae09c93$1@news.povray.org>
Invisible escreveu:
That`s truly insane!  Some fractal, I guess?
how about render time?  Days, weeks or months? :)
a game sig: http://tinyurl.com/d3rxz9
Date: 22 Oct 2009 15:36:06
Message: <4ae0b426$1@news.povray.org>
I was under the impression that with AA enabled, *all* pixels are
supersampled. (But with adaptive supersampling, it shoots 4 rays before
deciding whether to supersample further...)
http://blog.orphi.me.uk/
Date: 22 Oct 2009 15:37:29
Message: <4ae0b479$1@news.povray.org>
> 8 terabytes.
Does this amount of storage actually exist somewhere? (E.g., what kind
of space does somebody like Google or Amazon have?)
Date: 22 Oct 2009 15:42:19
Message: <4ae0b59b$1@news.povray.org>
>> 8 terabytes.
Well, I have 2 terabytes at home and AFAIK that's not uncommon these
days. Thinking from there, I think Google or Amazon really does have at
least exabytes.
XFS also seems to support 8 exabytes, so I won't have a problem when
upscaling the array some day :p.
-Aero
Date: 22 Oct 2009 15:44:13
Message: <4ae0b60d$1@news.povray.org>
> least exabytes.
Yes, 1 or 2 TB HDs are on sale if you have the cash.
Note that before you get to exabytes you must first pass through
petabytes - we're talking about *two* scale units, not just one.
Given that a single drive can hold 1 TB, it's not infeasible that
somebody could amass 1,000 of those in a data-center somewhere. That
would give you 1 PB. But 1 EB? Is that really possible yet?
Date: 22 Oct 2009 15:49:33
Message: <4ae0b74d@news.povray.org>
  Nope. What do you think the factor after the +a option means?
Date: 22 Oct 2009 15:51:50
Message: <4ae0b7d6@news.povray.org>
  But that would not be 1 petabyte as one partition. It would be 1 petabyte
of disk storage in total, among many smaller drives/partitions.
Date: 22 Oct 2009 16:13:05
Message: <4ae0bcd1$1@news.povray.org>
The threshold for deciding whether or not to subdivide further...
Date: 22 Oct 2009 16:13:52
Message: <4ae0bd00$1@news.povray.org>
...unless you can find a RAID controller that supports 1,000 array
elements. o_O
Date: 22 Oct 2009 16:20:45
Message: <4ae0be9d@news.povray.org>
  No, it's the threshold for starting antialiasing in the first place.
The comparison is against neighbour pixels.
Date: 22 Oct 2009 16:29:00
Message: <4ae0c08c@news.povray.org>
even then, 2e9 x 2e9 wouldn't quite be reached (unless you'd have a >64
bit system), some 1e9 x 1e9 would be the limit then.
(Again, speaking of POV-Ray 3.7. I don't think anyone would want to
render such a big image without multiprocessor support ;-))
Date: 22 Oct 2009 16:31:59
Message: <4ae0c13f$1@news.povray.org>
OK, I didn't know that...
So yes, POV-Ray will need to buffer some of the neighboring pixels. :-}
Date: 22 Oct 2009 16:32:36
Message: <4ae0c164$1@news.povray.org>
I'm too much involved in 3.7 development to have 3.6 anywhere on the
radar ;-)
At present, the architecture of POV-Ray 3.7 does not allow for writing
image output before rendering has actually finished, so the whole smash
must be buffered.
You'd probably have to disable preview as well :-)
Date: 22 Oct 2009 16:35:30
Message: <4ae0c212$1@news.povray.org>
So far, I haven't seen any significant exceptions to the rule-of-thumb
that render time is proportional to the number of pixels.
Date: 22 Oct 2009 16:37:30
Message: <4ae0c28a$1@news.povray.org>
...not forgetting that there are scenes where the parse-time dwarfs the
render-time. ;-)
(And then there's things like radiosity pre-trace, photon mapping, etc.)
Date: 22 Oct 2009 16:57:42
Message: <4ae0c746$1@news.povray.org>
I'd guess maybe about a million drives with maybe 250G each, tops? I'd read
somewhere they had a half-million computers, and they all use commodity 160G
drives, so something like that. What does that turn out to? 250 peta bytes?
Date: 22 Oct 2009 16:58:45
Message: <4ae0c785$1@news.povray.org>
One partition spread amongst many disks. :-)  Actually, I think Windows
calls it a "volume", while a partition is part of a disk, a volume holds a
file system.
Date: 22 Oct 2009 16:59:49
Message: <4ae0c7c5$1@news.povray.org>
> render-time. ;-)
But probably not on an 8000x3000 resolution picture. :-)
Date: 22 Oct 2009 17:04:36
Message: <4ae0c8e4$1@news.povray.org>
> read somewhere they had a half-million computers, and they all use
> commodity 160G drives, so something like that. What does that turn out
> to? 250 peta bytes?
There was an article recently about someone at Google talking about
needing to manage 10 million machines....
Jim
Date: 22 Oct 2009 17:28:06
Message: <4ae0ce66@news.povray.org>
  I'm sure once could artificially construct a scene which renders fast
at one resolution but extremely slow if you make the resolution even
slightly larger (by having some extremely-slow-to-render detail be so
small that no ray hits it at the lower resolution).
Date: 22 Oct 2009 20:25:59
Message: <4ae0f817$1@news.povray.org>
Your numbers are probably closer to mine, assuming it wasn't a "we plan
systems in ways that we can manage 10 million, even tho at the moment we
have only 1." :-)  My numbers are old and estimated from outside the company.
Date: 22 Oct 2009 21:06:26
Message: <4ae10192@news.povray.org>
On average, that will not change a thing. So you'd have to make the
detail not only particularly small, but also place it strategically.
But a scene coded so that the detail level is driven by the image_height
and image_width variables would do - which would even make sense in some
cases, especially for fractal geometry.
Date: 22 Oct 2009 22:06:52
Message: <4ae10fbc$1@news.povray.org>
> company.
I think it might've actually been something along those lines, actually -
I'll have to see if I can find the reference again.
Jim
Date: 23 Oct 2009 03:24:48
Message: <4ae15a40@news.povray.org>
Doesn't the detail level change automatically with image_width /
image_height?
A texture should produce a higher level of detail automatically.
Or do you mean something like #NoOfTreesToPlant= image_width*image_height /
AnyReasonableNumber?
Can image_width be accessed in povray?
Date: 23 Oct 2009 04:40:16
Message: <4ae16bf0$1@news.povray.org>
>> *long* time with a 32-bit CPU.)
Nah, just some marbles.
In fact:
http://www.zazzle.com/marbles_print-228982257548484115
Also:
http://www.zazzle.com/mist_print-228771069264566889
I think it took about a day. It's a pretty simple scene...
Date: 23 Oct 2009 06:27:34
Message: <4ae18516$1@news.povray.org>
> image_height?
Procedural textures, as used by POV-Ray, inherently provide unlimited
detail anyway, regardless of resolution.
Yes, something along those lines.
Yes, of course. It is commonly used to make sure the camera parameters
match the output image aspect ratio, as in:
     up    y
but it can be used for any other purpose you deem fit.
