POV-Ray : Newsgroups : povray.off-topic : 4D Server Time
18 Oct 2026 09:27:54 EDT (-0400)
  4D (Message 1 to 50 of 64)
Goto Latest 50 Messages Next 14 Messages >>>
Subject: 4D
Date: 20 Oct 2009 06:21:50
Message: <4add8f3e$1@news.povray.org>
I find it to be the most frustrating and fascinating thing ever. I did a
search for its objects:
http://search.viewpoint.com/pl/websearch?vb=2&tn=&type=ONE&k=4th+dimension+objects
I don't know if some day would be possible but would be great to visit a
4D world and meet 4D people :-D
I was thinking and maybe this is where you go when you die and ghosts
are just what we can see from a 4D person. 4D makes my head go thinking
pretty bizarre stuff, don't you?
Cheers.
Subject: Re: 4D
Date: 20 Oct 2009 06:41:03
Message: <4add93bf$1@news.povray.org>
I should point out that a rotation in 4D can leave your body in mirror
image. If you go to 4D-land, turn around the "wrong" way, and then come
back, your body will be inverted.
Why would you care? Well... certain biological molecules are chiral,
so... good luck assimilating your food. :-P
(If 4D rotation seems weird, consider a 2D figure rotated through 3D
space. For example, take the letter "d", draw it on a transparency, and
then flip the transparency over. You now have the letter "b" - it's
mirrored in 2D space, but in 3D space it's just a rotation!)
Let us not also forget that your body would have 0 thickness in 4D-land.
> 4D makes my head go thinking pretty bizarre stuff, don't you?
Perhaps.
The logic is fairly simple; the trouble starts when you try to
"visualise" what it means.
For example, when you extrude an object, the following happens:
- Each point becomes two matching points.
- Each line becomes two matching lines.
- Each pair of matching points as a new line added between them.
- Each pair of matching lines has a new surface added between them.
Thus, clearly, when extruding an object into a new dimension:
- P = 2P
- L = 2L + P
- S = 2 + L
By that reconing, extruding a square (4 points, 4 lines) into a cube
should yield
- 2*4 = 8 points
- 2*4 + 4 = 12 lines
- 2 + 4 = 6 surfaces
...which turns out to be correct.
Applying the exact same formulas, extruding a cube into a 4D hypercube
should yield
- 8*2 = 16 points
- 2*12 + 8 = 32 lines
- 2 + 6 = 8 hypersurfaces
- I have no idea how many "normal" surfaces
For extra fun, look at a 2D projection of a rotating 3D cube.
Unfortunately, this won't look like some 2D lines moving around, it will
*look like* a true 3D cube - because our brains are designed this way.
But now consider a 3D perspective projection of a rotating 4D
hypercube... You can see exactly the same effects. It's just more
mind-blowing. ;-)
Subject: Re: 4D
Date: 20 Oct 2009 07:54:45
Message: <4adda505$1@news.povray.org>
Invisible wrote:
>> a 4D world and meet 4D people :-D
Hahaha, yeah I've been reading... :-) didn't know about the
bio-molecules tho.
Isn't this thing alone just cool? This reminds me the transformation
between 3D rectangular and spherical coordinates, a circumference in the
former is a line in the latter, fascinating...
Imagine that, like a 2D being in a 3D world, great for a movie plot :-D
> Perhaps.
agree
exactly, like how does a 2D being thinks about a 3D object or being, how
do they "see" it, is just bizarre...
> - P = 2P
> - L = 2L + P
> - S = 2 + L
> should yield
> - 2*4 = 8 points
> ....which turns out to be correct.
yeah, I was thinking for about 3 hours how to get to a 4D hypercube
following the logic of building a 3D cube from a single line segment,
then a square and then a cube, the way a 90º rotations on the n-1
dimension adds a new(n+1) dimension, the irony is you already must know
what direction to rotate to in order to build the n+1-dimension object
in that dimension, I was also noticing the increasing number of P,L and
S, great brain exercise, also it reminded me of a possible explanation
for the Bermuda Triangle as a "door" to a Wormhole into hyperspace, man
this is the most pleasing way of meditation I have ever found :-); yoga?
way stay meditating in a 3D world when you can imagine the awesomeness
of a 4D world? :-D
> should yield
> - 8*2 = 16 points
> mind-blowing. ;-)
In deed :-)
http://en.wikipedia.org/wiki/Fourth_dimension
Subject: Re: 4D
Date: 20 Oct 2009 08:17:29
Message: <4addaa59$1@news.povray.org>
>> come back, your body will be inverted.
> bio-molecules tho.
Remember Thalidomide?
One Thelidomide molecule is actually "safe", but it's mirror image
causes... well, go Google it. (Unfortunately, it turns out that normal
human metabolism can convert one molecule to the other, so it's not so
"safe" after all...)
But there are lots and lots of biological molecules who's mirror images
are at best inactive and at worst toxic.
Have you read about non-Euclid geometry? You may find it interesting...
Assuming our hypothetical 4D world has 4D atoms and 4D gravity, I
imagine your 0-thickness body would slip between the microscopic gaps
between atoms...
> agree
>> the trouble starts when you try to "visualise" what it means.
And that's just about the best way for us 3D simpletons to imagine the
4D world; try to imagine how you'd describe a cube or a torus to a 2D
simpleton.
>> - P = 2P
>> - L = 2L + P
>> - S = 2 + L
>> should yield
>> - 2*4 = 8 points
> then a square and then a cube.
Start with 1 point.
Extrude. Now you have 2 points + 1 line.
Extrude. Now you have a square consisting of 4 points + 4 lines + 1 surface.
Extrude. Now you have a cube with 8 points + 12 lines + 6 surfaces + 1
volume.
Extrude. Now you have a hypercube with... uh... 16 points, 32 lines, 24
surfaces, 8 volumes and 1 hypervolume.
More fascinating, 4D space apparently has a regular hypergon with 400
sides...
>> will *look like* a true 3D cube - because our brains are designed this
>> way. But now consider a 3D perspective projection of a rotating 4D
>> mind-blowing. ;-)
> In deed :-)
Once you realise that a frustrum is a squished cube, and that you're
looking *through* the 8th side, it's quite easy to find al 8 sides of a
wireframe projection...
Subject: Re: 4D
Date: 20 Oct 2009 08:51:56
Message: <4addb26c@news.povray.org>
Already the plot of a book: Flatland. ;)
~Mike
Subject: Re: 4D
Date: 20 Oct 2009 09:43:37
Message: <4addbe89$1@news.povray.org>
No idea about this man.
oh, interesting, I'll dig into it later, thanks
wow, maybe is not such a good idea without an anti-mirror protection :-)
No, but I'll try to download a free book from wikipedia wikibooks,
> between atoms...
wow, a 4D ghost :-D imagining is just great, someone has to do a movie
out of this, is just too good to be just a Math tale. 4D gravity, that
will be a problem since the simple "shadow" of a hypercube looks
bizarre, imagine a true hypercube or more complex object or people, how
gravity, being normal to a 4D surface by definition, affects the 4D
matter, man! *blows mind*, if mathematicians help get this to the movies
will break the Academy Oscar record set by Lord Of The Rings... assuming
non-math-friendly-people don't go to sleep or exit the movie yelling for
a refund...
> simpleton.
yeah, wow, assuming they understand our language, this is getting more
and more a new Star Trek series: Voyager in the 4th Dimension.
> Start with 1 point.
> surface.
> volume.
> sides...
Thanks for this, I'd save this and the previous info for future
reference. I have always liked Math over any other science, I'd be a
mathematician if it were a Degree anywhere near my city; Math seldom
bores me, all the opposite, is lots of fun :-)
OK, I'll take your word for it :-) and I'll start looking on this
"frustratum" :-D to start with and then go through the 8 sides.
Thanks for all the info pal.
Cheers.
Subject: Re: 4D
Date: 20 Oct 2009 09:45:16
Message: <4addbeec$1@news.povray.org>
Oh! coincidence, wikipedia has it
(http://en.wikisource.org/wiki/Flatland), thanks anyway :-)
Subject: Re: 4D
Date: 20 Oct 2009 10:00:22
Message: <4addc276$1@news.povray.org>
You seem to know an awful amount of Math, you have a Degree on it or
something related to it?
Subject: Re: 4D
Date: 20 Oct 2009 10:06:30
Message: <4addc3e6@news.povray.org>
I have an Internet connection and too much free time. ;-)
Actually, I have an honors degree in Computer Science, which is closely
related to mathematics. (However, this is only what it says on the sheet
of paper; it was "really" a degree in Information Technology, which is
quite different...)
When I did my maths GCSE, I only got a C. But that was back when I
thought "maths" just meant doing endless runs of pen and paper
calculations...
Subject: Re: 4D
Date: 20 Oct 2009 10:07:20
Message: <4addc418$1@news.povray.org>
Just wondering, have you or anybody seen: Cube²: Hypercube, movie? I
have seen all 4 Cube movies, even the '70s one.
Cheers.
Subject: Re: 4D
Date: 20 Oct 2009 11:55:49
Message: <4adddd85$1@news.povray.org>
I have. I liked Cube better. I didn't know there were more.
Subject: Re: 4D
Date: 20 Oct 2009 14:54:15
Message: <4ade0757$1@news.povray.org>
I liked Cube²:Hypercube better because of the wonderful weirdness of
waking up inside a 3d Cube which was part of a 4D cube, all the
fascinating theories and convoluted plot and the non-sense ending was
just classy for me, I only wish I had know more Math and understand was
was the cylinder that psychiatrists brought back, but for me was the
best anyway :-)
Ironically Cube 0, was the fourth movie and explain how the first Cube
was build, is very interesting and creepy like the res of them. The
first one was: Man in a Cube, literally; was a UK idea originally at the
seems, there was a German version of Man in a Cube too, I don't
understand much German so I didn't saw it completely.
Subject: Re: 4D
Date: 20 Oct 2009 15:02:24
Message: <4ade0940$1@news.povray.org>
It's good to know that some people are taking the idea of a fourth
spatial dimension seriously. A lot of people argue that time is the
"true" 4th dimension, but that idea just doesn't sit well with me, even
though I don't have a lot of knowledge in this area.
Yeah. I think maybe with our 3D minds we could travel through the fourth
dimension, yet not be able to witness it directly as we do the 3rd. More
speculation, I know. It might have been inspired by something...
Sam
Subject: Re: 4D
Date: 20 Oct 2009 15:23:44
Message: <4ade0e40@news.povray.org>
> quite different...)
> calculations...
Oh I see, well even I like Math there is a point where get really
complex, so unless you devote your life to it you won't get an A from a
teacher I think or you are some kind of genius. I have been the victim
of those intellectually wain teachers that won't let you get more grade
than they think you deserve even when I have proven them wrong according
to a particular Math concept that they taught us to begin with, so I
wouldn't worry much about a grade, you know what you know and life will
grade you more fairly when the grade don't depend on biased humans.
Subject: Re: 4D
Date: 20 Oct 2009 15:36:08
Message: <4ade1128$1@news.povray.org>
I agree that it seems sort of like cheating to call time the fourth
dimension, but there are some extremely good reasons for doing so.
Foremost among these is that, due to special relativity, time and space
can't be cleanly pulled apart like they can under a more classical model
of physics.
In the "common sense" viewpoint we have a three-dimensional universe
which is changing over time, so that at each time the entire 3d universe
has some "state".  If you wanted to look at this is a four-dimensional
space, you'd just stack these 3d universe-states together along a single
other dimension representing time.  This gives you a 4d space, but under
this view it's perfectly possible to the time dimension as somehow
"fake".  The key point here, however, is that the common sense view is
possible because these 3d "slices" of things happening at the same time
are always parallel (and thus never intersect).
Under special relativity, unfortunately, this model is no longer the
most natural.  The reason is that there is no longer a well-defined
meaning to "things happening at the same time" as there was before.
Instead, this meaning is dependent on your velocity (or rather the
relative velocities of objects to you).
If we go back to the 4d model of the universe we'd built up for the
common sense viewpoint, the interpretation now is that the *angle* of
the 3d slice corresponding to everything "happening at the same time"
changes with your velocity.  Thus it's not possible to pull the space
apart into a bunch of well-defined 3d universe-states anymore, but
instead you need to keep time in there are a proper fourth dimension.
It is worth nothing, however, that the time dimension is *not* identical
to the space dimensions (one would hope not!) and distances are measured
differently in time than in space.  Nevertheless this doesn't prevent it
from being a proper dimension, it just means that the space has a
different geometry than you'd get from treating time just like another
spatial dimension.
Subject: Re: 4D
Date: 20 Oct 2009 15:40:42
Message: <4ade123a$1@news.povray.org>
> between atoms...
Since clearly the electromagnetic forces would remain three dimensional?
  I'm not sure it's possible to talk about what it would actually mean
to superimpose a three and four spatial-dimensional laws of physics in
this way in a coherent manner, and at the very least doing so would
require a significant amount of analysis to make sure you've correctly
coupled the two.
Subject: Re: 4D
Date: 20 Oct 2009 16:10:52
Message: <4ade194c$1@news.povray.org>
I have found that there are 2 theories (Wikipedia), spacial 4D and the
one assuming the 4th dimension is time, I think both concepts are not
compatible, are two different assumtions.
Or maybe you leave your 3D body and become a 4D spirit that then will
incarnate a 4D being and so on...
Subject: Re: 4D
Date: 20 Oct 2009 17:42:36
Message: <4ade2ecc$1@news.povray.org>
of
OK, maybe i'm remembering the wrong movie. The second Cube movie I saw wa
s
shown from the POV of the operators of the first Cube.
Maybe we're talking about entirely different series of movies. :-)
Subject: Re: 4D
Date: 20 Oct 2009 17:55:09
Message: <4ade31bd$1@news.povray.org>
But if so, how could you possible remember and/or integrate the
experience with a 3D mind? Maybe you could remember that *something*
happened, with a gained benefit of a new spiritual perspective...
Subject: Re: 4D
Date: 20 Oct 2009 17:56:51
Message: <4ade3223$1@news.povray.org>
> was shown from the POV of the operators of the first Cube.
No no, the second movie you saw is 'Cube Zero: the beginning' or
something like that, which is the fourth and latest of the series, to my
knowledge.
Subject: Re: 4D
Date: 20 Oct 2009 18:00:08
Message: <4ade32e8@news.povray.org>
Is a possibility, but again, who remembers being a 2D person before this
life? maybe is part of the "instinct" of each person, but who knows...
Subject: Re: 4D
Date: 20 Oct 2009 18:18:25
Message: <4ade3731@news.povray.org>
You seem to be alluding to a sort of an evolution of consciousness.
Which I won't refute, considering how this life seems to be evolving our
consciousnesses.
I can see how having a working knowledge of the second dimension could
help our understanding of this one, just as this would have an effect on
the next :-)
Subject: Re: 4D
Date: 20 Oct 2009 18:27:18
Message: <4ade3946$1@news.povray.org>
> consciousnesses.
is just one of many possibilities you can speculate, since nobody
actually knows for sure, what we were or what we will be before/after
this life, all you can do is just choose to believe in something...
> the next :-)
yeah, would be logical, fair and a nice guiding way :-)
Subject: Re: 4D
Date: 20 Oct 2009 18:34:21
Message: <4ade3aed$1@news.povray.org>
>> our consciousnesses.
Which I do.
That's not _all_ we can do ;) Dreams, for instance, can facilitate new
learning experiences. But that's not the end of the possibilities. Some
are more morally accepted than others, though.
>> on the next :-)
Which, based on my experiences of this life, I can only guess that we'll
have as much fun and as much good company as this one :)
Subject: Re: 4D
Date: 20 Oct 2009 19:54:01
Message: <4ade4d99@news.povray.org>
stbenge wrote:
> Which I do.
Me too.
I agree.
I really hope so :)
Subject: Re: 4D
Date: 20 Oct 2009 21:15:00
Message: <web.4ade5fd3cc16d839fe147f960@news.povray.org>
Yes, me too. Fascinating because I have a kind of feeling that it's sort of
real; frustrating, because I can't imagine it.
Over the past months I've read some stuff about it. But sometimes only part of
the books, because I often didn't succeed in understanding the examples (I have
a very bad understanding of all mathemetical related things), let alone
imagining it.
There are many interesting resources on the topic. I assume you already know the
Pov-Ray generated films:
http://www.dimensions-math.org/Dim_E.htm
I found them very intriguing, though too difficult to understand sometimes.
Apart from the classic novel Flatland there seem to have been written quite a
lot of books and essays on the topic between 1880 and about 1925, maybe because
the topic was inspiring to those day's broader interest in mysticism and
theosophy, e.g. Ouspensky's Tertium Organum and some essays by Rudolf Steiner.
I thought the books by "amateur-mathematician" Charles Howard Hinton most
interesting, because I got the impression that he really was capable of imagine
a little of the 4th dimension, at least in so far as it can be imagined.
Some of his books can be downloaded for free, e.g.:
http://www.archive.org/details/fourthdimension00hintarch
He developed a set of coloured cubes (that could be bought along with his books
at that time) which were supposed to facilitate the imagination of the hypercube
in his book "The fourth dimension":
http://www.greylodge.org/occultreview/glor_011/hintoncubes.pdf
I haven't tried yet to make these models, because I was too lazy and thought
maybe it wouldn't help and I would possibly be more frustrated than before. When
reading through part of "The fourth dimension" I noticed however, that there
would be no chance to understand it properly without models. I also thought of
recreating them in POV too, but it seems to be an awful lot of work.
However Hinton's approach to visualizing the 4th dimension is supposed to have
had a strong influence on Alicia Boole Stott, too, who herself had no formal
education in mathematics either but managed to get a honorary doctorate in 1914
because of her work on four dimensional polytopes. She made lots of beautiful
cardboard models and one gets the impression that she too was capable of
"imagining" at least some sort of 4th dimension.
Simone
> Cheers.
Subject: Re: 4D
Date: 20 Oct 2009 21:31:16
Message: <4ade6464$1@news.povray.org>
Interesting... yes I downloaded the movie but haven't seen it yet, yes I
have trouble also imagining 4D object, I think reading the 4D Cartesian
coordinate system and basic elements like a "line" and a "plane" could
help imagining more complex forms, thanks for the tips, I'll check them
out later.
Cheers.
Subject: Re: 4D
Date: 21 Oct 2009 04:54:40
Message: <4adecc50$1@news.povray.org>
An extra spatial dimension gives you 4D Euclidian space.
Time as an extra dimension gives you a 4D non-Euclidian space, which
turns out to be useful in Einstien's various reletivity theories.
These are two seperate, unrelated geometries.
4D Euclidian space is interesting because it's a straight extension of
3D Euclidian geometry.
And then, as I mentioned, there are other non-Euclidian geometries. For
example, elliptic geometry. In 2D elliptic geometry, a "straight line"
is in fact a line drawn on the surface of a sphere. Since the surface of
a sphere is curved, all these "straight lines" curve around it and
eventually close into circles. (E.g., the Earth's equator is such a
circle.) Thus, in elliptic geometry, *all* lines intersect each other,
and there is no such thing as "parallel" lines.
Somewhat weirder is hyperbolic geometry, where multiple "straight lines"
through a single point do not intersect each other [except at that
point]. You really need to play with this:
http://cs.unm.edu/~joel/NonEuclid/NonEuclid.html
I lost hours in it...
Subject: Re: 4D
Date: 21 Oct 2009 09:16:18
Message: <4adf09a2$1@news.povray.org>
Just one stupid question: What is there to be taken serious about - I
mean, if not considering time to be the 4th dimension (which it actually
is)?
The main point is that /if/ such a 4th ("space-like") dimension /does/
exist, then our 3 dimensions /already are/ embedded in that 4D world -
the 4th dimension will not just suddenly appear out of thin air to
entertain us.
There is no room for "serious" speculation about "what would it be like
if there /was/ a 4th dimension" - either a 4th (space-like) dimension
/does/ exist, in which case the natural laws in this 4D world /must/
result in the effects we observe in "our" 3D "slice" - or such a 4th
dimension does /not/ exist, in which case there's no room for
speculation left.
In any case we cannot in any way "leave 3D and enter 4D" - all we can do
is act within our 3D world, and (possibly) find that the resulting
effects can only (or best) be explained by assuming that our 3D world is
just a "slice" embedded in a 4D world.
Scientists are, by the way, seriously discussing models according to
which the universe does indeed have more than three space-like
dimensions (quite a lot actually), but they appear to agree that in this
case those extra dimensions must be quite small (think of the surface of
a thin wire, with the length corresponding to our known three space-like
dimensions, and the circumfence corresponding to the extra dimensions).
Subject: Re: 4D
Date: 21 Oct 2009 09:23:03
Message: <4adf0b37$1@news.povray.org>
Well, AFAIK there's actually no fundamental reason to apply different
"measuring tapes" to time and space: The constant vacuum speed of light
can serve as a ruler for both, with the distance of a light second
equating a second.
It just happens that it's still more practical to use meters for
space-like dimensions and seconds for time-like dimensions.
Subject: Re: 4D
Date: 21 Oct 2009 09:26:43
Message: <4adf0c13$1@news.povray.org>
You can't be (and never could have been in any prior life) a "2D
person": Evidently, there /are/ 3 dimensions (or more), so each "2D"
being must also be embedded in 3D space, and therefore /be/ a 3D being.
Similarly with 4 (space-like) dimensions: Either we /are/ 4D beings, or
there is no such thing as a 4th dimension.
Subject: Re: 4D
Date: 21 Oct 2009 09:27:37
Message: <4adf0c49$1@news.povray.org>
>> identical to the space dimensions (one would hope not!) and distances
>> are measured differently in time than in space.
> equating a second.
When you start measuring "events" which happen at different points in
space and different points in time, it becomes worth using a "spacetime"
measurement which simultaneously encodes both.
(Not that I know much about such things...)
Subject: Re: 4D
Date: 21 Oct 2009 09:30:02
Message: <4adf0cda$1@news.povray.org>
It seems to me people are confusing mathematical formalisms with reality.
4D Euclidian geometry is an interesting mathematical system. 4D
time-dimension geometry is an interesting mathematical system. 2D Euclid
is an interesting mathematical system. (Euclid was reputedly so
fascinated by it that he was speared to death by some random Roman.)
Whether these systems have any baring on the Real World which we inhabit
is an entirely orthogonal question. ;-)
Subject: Re: 4D
Date: 21 Oct 2009 09:43:12
Message: <4adf0ff0$1@news.povray.org>
>>>> will incarnate a 4D being and so on...
>> this life? maybe is part of the "instinct" of each person, but who
>> knows...
You're missing the point: by 2D person we mean you live in a 2D world as
we live in a 3D world, without being able to experience any other
dimension. Of course 2D, 3D, 4D, etc are included in a nD universe but
we're not gonna call everything a nD being or object, we have to call
the object dimensional feature by how many dimensions that being/object
is able to experience not by how many dimension that being/object is
included in.
read above.
Subject: Re: 4D
Date: 21 Oct 2009 09:44:57
Message: <4adf1059$1@news.povray.org>
ANd nobody knows if we were or not 2D beings.
Subject: Re: 4D
Date: 21 Oct 2009 11:06:04
Message: <4adf235c$1@news.povray.org>
I should read more about this, sounds interesting.
I'll check it out.
I've been trying to figure out how to calculate hyperbolic geometry, so
I may create new "circle limit" Poincare disk tesselations. I figure it
must be possible to create such a thing with POV-Ray functions, but so
far all my attempts have been total failures :(
Subject: Re: 4D
Date: 21 Oct 2009 11:15:28
Message: <4adf2590$1@news.povray.org>
3D Euclidian space = the place where we (apparently) live.
4D Euclidian space = the place where objects such as the hypercube live.
4D non-Euclidian space = any space with 4 dimensions that *isn't* 4D
Euclidian space. This includes a system where time is the 4th dimension,
but also many other kinds of space as well.
>> lines" through a single point do not intersect each other [except at
>> that point]. You really need to play with this:
> I'll check it out.
I believe you can use ordinary 2D coordinates for hyperbolic space, you
just need to remap them when plotting them in normal 2D space.
(Unfortunately, I can't find any formulas for doing this.)
Note that there is more than one way to project hyperbolic space into
Euclidian space; you probably want the Poincaré disk model if you're
trying to copy Escher's Circle Limit.
Subject: Re: 4D
Date: 21 Oct 2009 11:40:26
Message: <4adf2b6a$1@news.povray.org>
It's not measured *quite* the same way... The distance between two events is
sqrt(x*x+y*y+z*z-t*t) Note the - sign.
Subject: Re: 4D
Date: 21 Oct 2009 11:41:13
Message: <4adf2b99$1@news.povray.org>
> events is sqrt(x*x+y*y+z*z-t*t) Note the - sign.
Hence "non-Euclidian space".
Subject: Re: 4D
Date: 21 Oct 2009 12:03:25
Message: <4adf30cd$1@news.povray.org>
> equating a second.
I think that this becomes problematic for measuring between points which
aren't connectible by a lightlike geodesic, but maybe there's some
clever way around that (although I don't see how).
In any case, I was referring to the fact that under special relativity
spacetime has a metric that differs from that of a 4D Euclidian space
along the dimension corresponding to time.  For instance, the length of
a vector can be negative, which is impossible under a Euclidean metric.
Subject: Re: 4D
Date: 21 Oct 2009 12:03:50
Message: <4adf30e6$1@news.povray.org>
Yes. I wasn't sure if that counted as a euclidian space or not. :-)
Subject: Re: 4D
Date: 21 Oct 2009 12:08:21
Message: <4adf31f5@news.povray.org>
It doesn't, but it does share the property that the metric tensor is
constant over the entire space.
Subject: Re: 4D
Date: 21 Oct 2009 12:57:41
Message: <4adf3d85$1@news.povray.org>
It /is/ measured in the same way - it's just that the Pythagorean
theorem doesn't hold in our peculiar (3+1)D universe...
Subject: Re: 4D
Date: 21 Oct 2009 13:01:06
Message: <4adf3e52$1@news.povray.org>
Well, if two points cannot be reached from one another - is there /any/
way to assign a distance to these points at all?
So I think this is a non-issue.
Subject: Re: 4D
Date: 21 Oct 2009 13:16:35
Message: <4adf41f3$1@news.povray.org>
>> which aren't connectible by a lightlike geodesic, but maybe there's
>> some clever way around that (although I don't see how).
In this context a lightlike geodesic refers to a path in spacetime which
  light would follow, and I meant to imply that defining the distance
between points which could only be connected by going *slower* than
light would also be hard to define uniformly.
Subject: Re: 4D
Date: 21 Oct 2009 13:27:00
Message: <4adf4464$1@news.povray.org>
I fail to see how stating that the Pythagorean theorem doesn't hold
isn't just another way of saying that distances are measured differently
in our spacetime?
Is you point that in space time there *is* a well-defined notion of
distance which unifies both the spatial and temporal aspects, and thus
we don't really need to use one set of units for space and another set
for time?  Your comment about light-seconds would make more sense in
this context.  If this is the case perhaps I've been misunderstanding
your point form the beginning, since I'd surely agree with this.
Subject: Re: 4D
Date: 21 Oct 2009 13:36:51
Message: <4adf46b3$1@news.povray.org>
>> /any/ way to assign a distance to these points at all?
In light of one of your other comments I think I now understand what
point you're making: we can treat space-time distances in a common set
of units by treating distances as times via the speed of light.  In
which case I'd agree, and it fact the necessity for this clearly falls
out of being able to have a single number represent the distance at all.
I still don't see how it's relevant for my initial comment that the
space and time coordinates are treated differently though, since they
are most definitely factor into the distance function in different ways.
  Stated another way, swapping the time axis with a space axis is *not*
in the symmetries of Minkowski spacetime, but swapping any of the space
axes *is*, and this there's something "different" about the time axis.
Otherwise why bother saying (3+1)D instead of just 4D?
Subject: Re: 4D
Date: 21 Oct 2009 14:00:42
Message: <4adf4c4a@news.povray.org>
http://blog.orphi.me.uk/
Download 'brain.jpg' (47 KB)
Preview of image 'brain.jpg'
Subject: Re: 4D
Date: 21 Oct 2009 15:24:15
Message: <4adf5fdf$1@news.povray.org>
>  my head asplode
It was just a fancy way of saying that there's a sense in which the
spacetime isn't "curved"; which I probably should have just said in the
first place since the way I phrased it should really be made more
precise to be accurate anyway.
Subject: Re: 4D
Date: 21 Oct 2009 16:23:25
Message: <4ADF6DBC.8060007@hotmail.com>
Book reference: 'Doorways in the sand' Roger Zelazny
