POV-Ray : Newsgroups : povray.off-topic : 4D Server Time
12 Apr 2026 23:03:26 EDT (-0400)
  4D (Message 1 to 10 of 64)
Subject: 4D
Date: 20 Oct 2009 06:21:50
Message: <4add8f3e$1@news.povray.org>
I find it to be the most frustrating and fascinating thing ever. I did a
search for its objects:
http://search.viewpoint.com/pl/websearch?vb=2&tn=&type=ONE&k=4th+dimension+objects
I don't know if some day would be possible but would be great to visit a
4D world and meet 4D people :-D
I was thinking and maybe this is where you go when you die and ghosts
are just what we can see from a 4D person. 4D makes my head go thinking
pretty bizarre stuff, don't you?
Cheers.
Subject: Re: 4D
Date: 20 Oct 2009 06:41:03
Message: <4add93bf$1@news.povray.org>
I should point out that a rotation in 4D can leave your body in mirror
image. If you go to 4D-land, turn around the "wrong" way, and then come
back, your body will be inverted.
Why would you care? Well... certain biological molecules are chiral,
so... good luck assimilating your food. :-P
(If 4D rotation seems weird, consider a 2D figure rotated through 3D
space. For example, take the letter "d", draw it on a transparency, and
then flip the transparency over. You now have the letter "b" - it's
mirrored in 2D space, but in 3D space it's just a rotation!)
Let us not also forget that your body would have 0 thickness in 4D-land.
> 4D makes my head go thinking pretty bizarre stuff, don't you?
Perhaps.
The logic is fairly simple; the trouble starts when you try to
"visualise" what it means.
For example, when you extrude an object, the following happens:
- Each point becomes two matching points.
- Each line becomes two matching lines.
- Each pair of matching points as a new line added between them.
- Each pair of matching lines has a new surface added between them.
Thus, clearly, when extruding an object into a new dimension:
- P = 2P
- L = 2L + P
- S = 2 + L
By that reconing, extruding a square (4 points, 4 lines) into a cube
should yield
- 2*4 = 8 points
- 2*4 + 4 = 12 lines
- 2 + 4 = 6 surfaces
...which turns out to be correct.
Applying the exact same formulas, extruding a cube into a 4D hypercube
should yield
- 8*2 = 16 points
- 2*12 + 8 = 32 lines
- 2 + 6 = 8 hypersurfaces
- I have no idea how many "normal" surfaces
For extra fun, look at a 2D projection of a rotating 3D cube.
Unfortunately, this won't look like some 2D lines moving around, it will
*look like* a true 3D cube - because our brains are designed this way.
But now consider a 3D perspective projection of a rotating 4D
hypercube... You can see exactly the same effects. It's just more
mind-blowing. ;-)
Subject: Re: 4D
Date: 20 Oct 2009 07:54:45
Message: <4adda505$1@news.povray.org>
Invisible wrote:
>> a 4D world and meet 4D people :-D
Hahaha, yeah I've been reading... :-) didn't know about the
bio-molecules tho.
Isn't this thing alone just cool? This reminds me the transformation
between 3D rectangular and spherical coordinates, a circumference in the
former is a line in the latter, fascinating...
Imagine that, like a 2D being in a 3D world, great for a movie plot :-D
> Perhaps.
agree
exactly, like how does a 2D being thinks about a 3D object or being, how
do they "see" it, is just bizarre...
> - P = 2P
> - L = 2L + P
> - S = 2 + L
> should yield
> - 2*4 = 8 points
> ....which turns out to be correct.
yeah, I was thinking for about 3 hours how to get to a 4D hypercube
following the logic of building a 3D cube from a single line segment,
dimension adds a new(n+1) dimension, the irony is you already must know
what direction to rotate to in order to build the n+1-dimension object
in that dimension, I was also noticing the increasing number of P,L and
S, great brain exercise, also it reminded me of a possible explanation
for the Bermuda Triangle as a "door" to a Wormhole into hyperspace, man
this is the most pleasing way of meditation I have ever found :-); yoga?
way stay meditating in a 3D world when you can imagine the awesomeness
of a 4D world? :-D
> should yield
> - 8*2 = 16 points
> mind-blowing. ;-)
In deed :-)
http://en.wikipedia.org/wiki/Fourth_dimension
Subject: Re: 4D
Date: 20 Oct 2009 08:17:29
Message: <4addaa59$1@news.povray.org>
>> come back, your body will be inverted.
> bio-molecules tho.
Remember Thalidomide?
One Thelidomide molecule is actually "safe", but it's mirror image
causes... well, go Google it. (Unfortunately, it turns out that normal
human metabolism can convert one molecule to the other, so it's not so
"safe" after all...)
But there are lots and lots of biological molecules who's mirror images
are at best inactive and at worst toxic.
Have you read about non-Euclid geometry? You may find it interesting...
Assuming our hypothetical 4D world has 4D atoms and 4D gravity, I
imagine your 0-thickness body would slip between the microscopic gaps
between atoms...
> agree
>> the trouble starts when you try to "visualise" what it means.
And that's just about the best way for us 3D simpletons to imagine the
4D world; try to imagine how you'd describe a cube or a torus to a 2D
simpleton.
>> - P = 2P
>> - L = 2L + P
>> - S = 2 + L
>> should yield
>> - 2*4 = 8 points
> then a square and then a cube.
Start with 1 point.
Extrude. Now you have 2 points + 1 line.
Extrude. Now you have a square consisting of 4 points + 4 lines + 1 surface.
Extrude. Now you have a cube with 8 points + 12 lines + 6 surfaces + 1
volume.
Extrude. Now you have a hypercube with... uh... 16 points, 32 lines, 24
surfaces, 8 volumes and 1 hypervolume.
More fascinating, 4D space apparently has a regular hypergon with 400
sides...
>> will *look like* a true 3D cube - because our brains are designed this
>> way. But now consider a 3D perspective projection of a rotating 4D
>> mind-blowing. ;-)
> In deed :-)
Once you realise that a frustrum is a squished cube, and that you're
looking *through* the 8th side, it's quite easy to find al 8 sides of a
wireframe projection...
Subject: Re: 4D
Date: 20 Oct 2009 08:51:56
Message: <4addb26c@news.povray.org>
Already the plot of a book: Flatland. ;)
~Mike
Subject: Re: 4D
Date: 20 Oct 2009 09:43:37
Message: <4addbe89$1@news.povray.org>
No idea about this man.
oh, interesting, I'll dig into it later, thanks
wow, maybe is not such a good idea without an anti-mirror protection :-)
No, but I'll try to download a free book from wikipedia wikibooks,
> between atoms...
wow, a 4D ghost :-D imagining is just great, someone has to do a movie
out of this, is just too good to be just a Math tale. 4D gravity, that
will be a problem since the simple "shadow" of a hypercube looks
bizarre, imagine a true hypercube or more complex object or people, how
gravity, being normal to a 4D surface by definition, affects the 4D
matter, man! *blows mind*, if mathematicians help get this to the movies
will break the Academy Oscar record set by Lord Of The Rings... assuming
non-math-friendly-people don't go to sleep or exit the movie yelling for
a refund...
> simpleton.
yeah, wow, assuming they understand our language, this is getting more
and more a new Star Trek series: Voyager in the 4th Dimension.
> Start with 1 point.
> surface.
> volume.
> sides...
Thanks for this, I'd save this and the previous info for future
reference. I have always liked Math over any other science, I'd be a
mathematician if it were a Degree anywhere near my city; Math seldom
bores me, all the opposite, is lots of fun :-)
OK, I'll take your word for it :-) and I'll start looking on this
"frustratum" :-D to start with and then go through the 8 sides.
Thanks for all the info pal.
Cheers.
Subject: Re: 4D
Date: 20 Oct 2009 09:45:16
Message: <4addbeec$1@news.povray.org>
Oh! coincidence, wikipedia has it
(http://en.wikisource.org/wiki/Flatland), thanks anyway :-)
Subject: Re: 4D
Date: 20 Oct 2009 10:00:22
Message: <4addc276$1@news.povray.org>
You seem to know an awful amount of Math, you have a Degree on it or
something related to it?
Subject: Re: 4D
Date: 20 Oct 2009 10:06:30
Message: <4addc3e6@news.povray.org>
I have an Internet connection and too much free time. ;-)
Actually, I have an honors degree in Computer Science, which is closely
related to mathematics. (However, this is only what it says on the sheet
of paper; it was "really" a degree in Information Technology, which is
quite different...)
When I did my maths GCSE, I only got a C. But that was back when I
thought "maths" just meant doing endless runs of pen and paper
calculations...
Subject: Re: 4D
Date: 20 Oct 2009 10:07:20
Message: <4addc418$1@news.povray.org>
have seen all 4 Cube movies, even the '70s one.
Cheers.
