POV-Ray : Newsgroups : povray.off-topic : Inside Win32 Server Time
13 Apr 2026 00:57:16 EDT (-0400)
  Inside Win32 (Message 1 to 10 of 27)
Subject: Inside Win32
Date: 13 Oct 2009 05:08:22
Message: <4ad44386$1@news.povray.org>
There now follows a huge braindump of my research into the inner
mysteries of how Win32 actually works. The information is correct as
best as I can tell, although it's rather incomplete in places...
MS-DOS had two formats for runnable programs. There were *.COM files,
and *.EXE files.
As far as I can tell, a *.COM file is just a file containing raw machine
code. You load the entire file into memory, starting at a predefined
base address [I forget what that is], and jump to byte 0. And that's all
there is to it.
The MS-DOS *.EXE format is more complicated. For starters, it begins
with a magic number ("MZ" ASCII, apparently some programmer's initials).
I don't know anything further about it.
VAX VMS uses a format known as Common Object File Format, or COFF.
Windows NT is based on VMS, and hence uses a format called Portable
Executable, or PE, which is heavily based on COFF.
Anybody old enough to remember may recall that it used to be possible to
switch between MS-DOS and Windows at will. (Windows was originally a
trivial graphical shell that runs under MS-DOS. Only later did it become
a true OS.) Back in those days, you could quite possibly try to run
Notepad.exe or something from MS-DOS. Doing so would cause a short error
message saying "this program requires Windows to run" or similar.
Apparently every PE file is also a valid MS-DOS *.EXE file, and it
contains a tiny stub program which simply prints out that error message
and then exits. After that stub program comes the real PE headers.
As well as runnable programs, Windows has Dynamic Link Libraries, of
DLLs. These apparently use the exact same PE format; there's a single
bit in the header which is different for a program and a library. Apart
from that, they're both identical. (Also DLLs aren't always *.DLL;
there's also *.OCX, *.CPL, etc.)
I never realised this, but apparently PE files can contain machine code
for many, many different CPU types. (IA32, AMD64, IA64, DEC Alpha, MIPS,
PowerPC, ARM...)
I've come across vague references to code and data sections in programs,
but it turns out that a PE file can actually have an arbitrary number of
sections in it. Each section is loaded into a different memory page, and
can have a different combination of protection settings (read / write /
execute / etc).
Apparently the layout of the data on disk is very similar to the layout
in memory. When a DLL or EXE is loaded into memory, it becomes known as
a "module". And you can actually page-align the data in the file to make
it load into memory faster - at the expense of making the file bigger.
This is why EXE files often have huge chunks of zeros inside them, it seems.
Anyway, it seems that apart from executable machine code, a PE file can
contain several other kinds of section. (Indeed, it seems to be possible
to write PE files that contain no runnable code at all!)
- Resource sections contains "resouces". This seems to include icons,
cursors, bitmaps, menu and GUI descriptions, text strings and so forth.
Several of these resouces can have multiple versions, and APIs exist to
fetch the appropriate version automatically. (E.g., you can have
versions of a text string in multiple languages, and fetch the one for
the current system language. Or multiple sizes of the same icon and
fetch the requested size. And so on.) Having a GUI description appears
to allow you to construct a complex GUI with just one API call, instead
of programatically building the entire GUI manually.
- Debug symbols. (I.e., names corresponding to various addresses. Useful
if you want to crawl through the code with a low-level debugger.) I'm
not sure precisely how this part works - but it's not very relevant to
me anyway.
- You can have "data" sections which are either read-only or read-write.
Apparently this kind of thing is used for global variables.
I note in passing that since the PE header is at the front of the file
and a Zip header is at the back of a file, it's possible to make a file
which is simultaneously a valid Zip file and a valid PE file. That's
apparently how self-extracting Zip files work. You can also have other
random data off the end of the PE file, past the last section (and this
won't automatically be loaded into memory).
More interesting, a PE file can import and export symbols. A DLL will
usually export the symbols for externally-callable functions, and EXE
files typically import various symbols.
It seems there are in fact two ways to call the functions in a DLL. One
way is to call LoadLibrary() to load your DLL, and GetProcAddress() to
look up the address of a given function (either by name or by index number).
The *other* way, which I didn't know about, is to import the symbols
from that DLL. This basically means putting some info into the PE
headers saying which functions in which DLLs you're interested in. When
the program is loaded, this table gets copied into memory, the requested
DLLs are loaded, and the slots in the table are filled in with the
addresses of the requested functions. The generated machine code can
then access these functions by indexing the table.
And then there's the fact that a DLL, being an ordinary PE file, can
*also* import from other DLLs, which can import other DLLs, and so
forth. Apparently it's possible to "bind" a DLL - that is, to precompute
and fill out the function table, based on the versions of the referenced
DLLs installed and their preferred base addresses. And this apparently
speeds up DLL loading. (But if the information is not current, it is
automatically ignored.)
And then there's the whole song and dance about what happens if a DLL
can't be loaded at its preferred base address. (Which would seem a
freakishly unlikely occurrance, but still...)
OK, so I have a program that will edit resouces, and a program which
shows exported symbols. But reading the above descriptions, it becomes
clear that these are just two optional sections in a PE file. Apparently
compiled .NET programs contain a whole bunch of special sections that
only appear in .NET programs, and contain compiled CIL code. I haven't
read anything about COM, but it seems likely that all the COM-related
data goes in yet another section which I don't yet have a way to inspect
- which is why some DLLs appear to be "empty". They don't have the
symbol export section, but they have other useful sections in them.
It also becomes apparent that there's more than one way for the compiler
and the linker to do their job. (Apparently finished programs are PE
files, but "object files" are COFF files - go figure!) I'm told the
section *names* are actually irrelevant [except that the linker uses
them to decide which sections to merge together], and the OS only cares
about the section options. It's all quite complex in there...
Well, my head hurts, I've learned a whole crap-load of stuff, and I'm
still nowhere nearer to my goal of being able to use COM. :-}
Subject: Re: Inside Win32
Date: 13 Oct 2009 11:56:50
Message: <op.u1qw80n07bxctx@e6600>
Because none of that stuff is relevant to using COM. It is kind of like
learning to drive a car by studying the chemical properties of petroleum
products.
FE
Date: 13 Oct 2009 13:48:55
Message: <4ad4bd87$1@news.povray.org>
It will take quite a while to learn to use and understand COM,
especially from C++.
~Mike
Date: 13 Oct 2009 14:37:39
Message: <4ad4c8f3$1@news.povray.org>
How about from a high-level cross-platform language which doesn't even
support COM? :-}
http://blog.orphi.me.uk/
Date: 13 Oct 2009 16:41:23
Message: <4ad4e5f3$1@news.povray.org>
> support COM? :-}
Good Luck!
~Mike
Date: 13 Oct 2009 16:42:43
Message: <4ad4e643$1@news.povray.org>
> Good Luck!
Why thank you. I believe I'll be needing it... :-/
Date: 13 Oct 2009 16:45:10
Message: <4ad4e6d6$1@news.povray.org>
On 10/13/2009 3:42 PM, Orchid XP v8 wrote:
>> Good Luck!
Indeed! You will need it.
~Mike
Date: 14 Oct 2009 04:24:39
Message: <4ad58ac7$1@news.povray.org>
>>> Good Luck!
All we need now is for Warp to pop up and tell me that if only I used a
*real* programming environment like VisualStudio C++, I would only need
to click on a button and everything would instantly work right...
Date: 14 Oct 2009 04:39:06
Message: <4ad58e2a$1@news.povray.org>
> products.
Maybe. But it's pretty interesting, all the same... ;-)
Date: 14 Oct 2009 04:52:38
Message: <4ad59156@news.povray.org>
> *real* programming environment like VisualStudio C++, I would only need to
Or Scott to pop up and tell you to just use a .net language and be done with
COM altogether.
What do you think of this?
http://www.ffconsultancy.com/dotnet/fsharp/rule30/code/1/rule30.fs
